My Attempt at making Andriod, MAC, PC users 1st steps in to Hyperspin Android easier
This is an adjusted version of the Media and Databases that are included with Hyperspin Full Install 1.3.3
Tweaked and cutdown for use directly with Android devices (It will not directly work with a PC although you can merge it with a PC setup to aid the building of an Android setup)
Whats Included
  1. Indenticle Media files as 1.3.3 with some removals
  2. Pre configured Settings files
  3. Brief Android Emulator setup notes
  4. MAME Adjusted xml for 0.139 ROM set (Default one included also Outdated)
  5. Additional Settings files for 123 systems/collections (Provided by Badhemi)
Systems Included & Emulators suggested
Atari 5200 (Retroarch MAME (Arcade) Core)
Atari Lynx (Retroarch Handy Core)
MAME (MAME4droid Reloaded (Red) 0.139v romset
NEC TurboGrafx-16 (Retroarch Mednafen PCE Fast Core)
Nintendo 64 (Retroarch Mupen64Plus Core or Glupen Core)
Nintendo Entertainment System (Retroarch Nestopia Core)
Nintendo Game Boy Advance (Retroarch VBA Next Core
Panasonic 3DO (Retroarch 4DO Core)
Sega 32X (Retroarch Picodrive Core)
Sega CD (Retroarch Picodrive Core)
Sega Dreamcast (Reicast 73e2691 2016_05_22 Build)
Sega Game Gear (Retroarch Genesis Plus GX Core)
Sega Genesis (Retroarch Picodrive Core)
Sega Master System (Retroarch Picodrive Core)
SNK Neo Geo (Retroarch FB Alpha Core)
SNK Neo Geo Pocket Color (Retroarch Madnafen NGP Core)
Sony PlayStation (Retroarch PCSX Rearmed Core)
Super Nintendo Entertainment System (Retroarch BSNES Mercury Performance Core)
See this Thread for details
(Tutorial) Hyperspin Android Overview & Installation
Install Notes
To install this Hyperspin Android base pack
Step 1 - Combine the download parts
Extract the "Hyperspin 1.3.3 Android PT1" (Hyperspin.zip) file
Place the "Hyperspin 1.3.3 Android PT2" (Media.zip) file within the extracted Hyperspin folder
Extract the "Hyperspin 1.3.3 Android PT2" (Media.zip) file and it will combine the two parts
Alternativly extract both files and the cut and paste them together
(Optional Addition)
  1. Extract the Settings_Android.zip and pick out the settings files you require as you build your setup.
  2. Place them in your Settings folder or Settings_Android folder depending on your setup
  3. Rename specific systems if needed
  4. ADD YOUR ROMPATH
Step 2 - READ the Setup Notes.txt
Step 3 - Organise your roms
Organise your roms so they are located in the suggested folder structure OR place them in a location of your
own choice.
MAKE sure you adjust the "SYSTEMNAME".ini files to reflect your own rompath
****Remeber rom names will need to exactly match your Hyperspin databases (.xml) and be in a format that your
chosen emulator can open****
Step 4 - Move the pack to your Android Device
Once you have the complete Hyperspin folder place this at the root of your storage device connected to your android device
(USB HDD, Internal storage, SDCard or Network drive)
Step 5 - Download and configure your emulators
Step 6 - Install Hyperspin Application
Download and install the Hyperspin application from the Goggle Playstore
What's New in Version 1.1
  • Added cleaned default version of user Badhemi's Settings files.
  • See setup notes above
  • Like 5
  • Upvote 5
