Welcome Guest!
Join us now to get access to all our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, and so, so much more. It's also quick and totally free, so what are you waiting for?
  • Announcements
    • thatman84
      Uploading Content   12/15/2017
      Please Read Before Uploading.... Thank You to everyone that shares their creations in the Upload Here section. There is some outstanding contributions to check out. Some simple things to help people find your content and admins to manage uploads. Post a topic in HyperStudio forum before uploading Upload to the correct Sub Section Use tags Please add details to your Title Good Title: -   World of Warcraft (PC Games) (16:9)
      Bad Title: -   World of Warcraft Aspect Ratio = (16:9), (16:9ST), (4:3)
      System = (Hyperlist Names)
      Details = Main Menu, System Default, +Wheel, Animated BG, Universal Theme.......
        Peace Out Thatman84
HyperSpin version 1.4.15 (2015 Edition)
Added can now use default theme for main menu. Whats different about having a default theme as some may now is that they don't get reloaded when going from one item to next that don't have themes. This allows for a cleaner experience vs reloading individual copies of default themes.
Added if a theme doesn't have a background in the zip file then it was only attempting to load a png background, from the backgrounds folder of the item name. Now it can load swf and also default.png and default.swf.
Added Shortcut key F6 to toggle fullscreen and windowed. For windowed to work resolution must be set to resolution lower than fullscreen.
Added Ledblinky 9 for main menu and Ledblinky 8 for switching menus (not sure if this one is even needed)
Fixed - HyperSpin not shutting down sometimes.
Fixed issue when launching certain software/emulators and HS taking focus.
Fixed background music not working. Put music in Media\System\Sound\Background Music\Name.mp3
Fixed mp4 looping causing stuttering or black video
Fixed returning from emu causing moving 1 wheel item when spinner is enabled
Added Horizontal Wide wheel style for widescreen themes that can fit more wheel items
Fixed spinner and trackball only working in 1 direction
Changed more fixes to joy controls.
Changed made some changes to joystick behavior, POV was interferring with analog and vice versa
Fixed joystick not being able to stop intro video
Fixed returning to HS from certain emulators causes HS to be squished.
Fixed main menu always returning to last_system used when starting even though last_game is off.
Fixed no speakers bug, no speakers or headphones plugged in would crash HS
Fixed HL relative path issue(i think)
Fixed strobe animation not working. I had to slow it down, due to the speed up of the new HS, i had to slow it down by a factor of 4 to get it to even work. So if it doesn't match up with HyperTheme, you know why.
Fixed themes freezing when exiting theme.
Fixed joystick support (i think)
Fixed skip up and skip down number not working
Fixed letter wheel using wrong direction per wheel style
Fix pin style was backwards, moves left to right now
Added ability to use mp4 as intro video
Fixed % in filename issue when playing videos.
Changed the behavior of pin and horizontal wheels due to a lot of complaints. Left and Right move the wheel and Up and Down select the letter wheel. The directions are fixed and should behave as expected now.
Added smoothing to letter images.
Changed path to HScript, delete your old HScript.ahk and autohotkey.dll, Unzip now the script is in \Scripts\HScript\HScript.ahk, this allows the autohotkey.dll not to interfere with the one other programs use in the main root, sorry to those that got their old autohotkey.dll overwritten.
Release to private beta
Changed - See above
Fixed - HyperLaunch error, hopefully.
Added - Allow relative path to launcher i.e ( .\Folder\HyperLaunch.exe") where the dot represents the HyperSpin directory. Doesn't do relative double dots though for going up a folder.
Added - Disable item in main menu i.e ( <game name="MAME" enabled = "0"/>, just add enabled ="0" to any system and it will disable it. if there is no enabled attribute or you have it set to 1 then the game will show.
Added - Disable item in sub menu , same as above.
Added - Smoothing to special artwork png's
Added - HyperLaunch not forced as launcher. You can now set the full path to the launcher in the ini. Has to be fullpath\launcher.exe in the ini file. If your hyperlaunch isn't working then you must add hyperlaunch.exe to your hyperlaunch path in the ini.
Added - Can run a script everytime you land on a wheel item to allow scripters to add interactive features to HS. The script is located in a new scripts folder called "Scripts".
