Welcome Guest!
Join us now to get access to all our features. Once registered and logged in, you will be able to create topics, post replies to existing threads, give reputation to your fellow members, get your own private messenger, and so, so much more. It's also quick and totally free, so what are you waiting for?
Ext2k
Tutorial How to config Ledwiz-PacDrive
I dont know for sure (Ext2k will have to answer that), but I dont think it would. I know that the software supports the PacDrive, but this one seems to only support LEDs (so no solenoids and only supports 20mA (vs 500mA on the PacDrive/LED-Wiz).
Very cool product though, I had not seen it before. Must be new...
Share this post
Link to post
Chriz99,
Can you please post your TAF? I am having terrible problems getting it to work...
I only have the Left Red activated for S18:
taf,L88,W27,ON,ON,ON,S48,S46,S2,L41,0,0,0,ON Yellow,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,S18,0,0,0
and it flashes blue!! What the hell!!
Share this post
Link to post
Chriz99,
here is my taf
taf,L88,W27,ON,ON,ON,S48,S46,S2,L41,S14/S13,S15,S16,0,ON,ON,S27/S25,S11,S12/S4,S12/S10,S9,S10/S17/S18/S22/S2,S10/S18/S2,S10/S18/S2,S2,0,S17/S12/S21/S2,S12/S17/S21/S2,S17/S21/S2,S13/S9/S18/S19/S20/S2,S13/S19/S20/S2,S11/S19/S20/S2,0
Share this post
Link to post
Chris,
I get this error:
Line: 0
Subscript out of range: 'OutsPD'
On a whim, which file are you running for TAF?
Edit:
I tried a different TAF. It works perfectly. THe one I was trying to run, however, is better quality... Re-downloaded the table and it now works great...
Edited by shilmover
Share this post
Link to post
yeah, thanks a lot barry :party:
here are TOTAN, TOM (awesome flasher), CC AND RUDY
tom,L88,W15,ON,ON,ON,S48,S46,S7,L87,S9/S35,S10/S1/S5,S2/S5/S33/S35/S17/S18,ON,ON,ON,S17/S18,S2/S15,S12/S16/S34/S14,S13,S4/S6/S8/S11/S21,S7/S26,S7/S26,S7/S28/S26,S7/S26,W77,S20/S24/S27/S26/S7,S27/S26/S7,S20/S24/S28/S7,S20/S26/S27/S7,S26/S27/S7,S20/S25/S7,W77
fh,L88,W62/W47,ON,ON,ON,S48,S46,S7,0,S12/S14,S13/S15,W46/W51/W65/W45,0,ON,ON,S21,S48/S3/S9,S10/S2/S5/S6,S1/S4/S8/S16/S25/S26/S27/S28,S11/S10/S1/S4/S8/S16,S7/S20/S19/S23,S7/S20,S11/S7,S7/S18,0,S23/S10/S24/S7,S10/S24/S7,S10/S24/S7,S9/S7,S7,S17/S7,0
cc,L88,W18,ON,ON,ON,S48,S46,S7,0,S10/S14,S11/S1/S9/S15,S14/S15/S36,ON,ON,0,S37/S38,S2/S6/S12,S5/S22,S16/S33,S3/S4/S13/S8/S36,S18/S26/S7,S13/S18/S26/S7,S18/S26/S7,S18/S26/S7,0,S20/S24/S25/S27/S7,S24/S7,S7,S19/S24/S28/S7,S12/S28/S7,S7,0
totan,L88,W18,ON,ON,ON,S48,S46/S9,S7,ON,S10,S11,S1/S2/S6/S35,ON,0,0,S8,S12/S15/S34,S13/S5/S36,S3/S4/S21,S14,S23/S7,S7,S18/S22/S25/S7,S7,0,S2/S27/S17/S20/S24/S26/S7,S17/S26/S2/S7,S2/S7,S1/S16/S19/S28/S27/S17/S7,S1/S16/S28/S17/S7,S1/S7,0
have fun!
Share this post
Link to post
My pleasure. Its kind of fun (yet frustrating at the same time... :) )
You will have to re-map the settings from these configs to how you map yours. Luckily (by design), I configured mine the same as Chriz99's so that they are interchangable (for now).
Share this post
Link to post
Here is Gilligan's Island:
gi,L88,W78,ON,ON,ON,S48,S46,S7,0,S6/S8,S5/S10,0,ON,0,0,0,S1/S2/S11/S23/S24,S15/S16,S4/S14,S13,S18,S18,S18,0,0,S21,S21,S21,S17/S19/S20,S19/S20,S19/S20,0
And Who Dunnit (converted from Ext2k's):
wd,L88,W15,ON,ON,ON,S48,S46,S7,0,S9,S1/S2/S8/S10,0,ON,0,0,0,S11,S6/S16/S13,S4/S12,0,S14/S12/S17,S14/S17,S17,S17,0,S14/S20/S21/S13,S14,0,S14/S19/S11/S17,S14/S17,S17,0
And Lord of the Rings (also from converted from Ext2k's):
lotr,L80,W16,ON,ON,ON,S48,S46,S7,0,S17/S3,S18/S2/S21,0,ON,0,0,0,S9,S5/S7/S10,S11/S4/S7/S8,0,S25/S31/S32/S26,S26,S26,S26,0,S14/S25/S30,S14/S30,S30,S23/S25/S27,S23,0,0
Edited by shilmover
Share this post
Link to post
Just built a macro that will convert Ext2k's config to my setup. Took about 15 minutes or so. Need to do some more testing, but it seems to work well.
Once I get Chriz99's new config, I will write that macro (and create one that will convert it back).
This will not work for everyone, but it should save some time and give eveyone pointers on what to do.
Share this post
Link to post
Anyone have the Xenon configuration? If not I will to do It :D seems that the manual have a wrong solenoids :(
Chris I have the StarWars DE working perfect now I just add the solenoidscallback on the Script table and now woks amazing :D
Regards!
Share this post
Link to post
Judge Dredd:
jd,L88,W41,ON,ON,ON,S48,S46,S7,L87,S2/S15/S9,S8/S16/S13,0,ON,ON,ON,0,0,S3,S5/S10,S11,S21/S22/S26,S21/S22,S21/S22,S21/S22,0,0,0,S21/S22,S21/S22/S26,0,0,0
Indy 500:
i500,L88,L86,ON,ON,ON,S48,S46,S7,L87,S11/S36,S12/S1/S13,0,ON,0,0,0,S5,S9,S10/S3/S4,S2/S8,S23,0,0,0,0,S24/S25/S26/S28,S26,S16/S26,S14/S27,0,S15,0
Guns 'N Roses:
gnr,L64,W16,ON,ON,ON,S48,S46,S8,L63,S20/S12/S14,S1/S2/S3/S21/S9,0,ON,0,0,0,S22/S7/S4,S19,S18/S6,S17,0,0,0,0,0,S25/S26,S26,S26,S27,S25/S27,S27,0
Edited by shilmover
Share this post
Link to post
Hi all, I am LOVING this LED Whiz but have a question. How do I alter the HPLedControl.ini to get different results while in the Hyperpin menu? (Not running a table) Currently while in the hyperpin menu, it flashes output 1 (start) so it is working, but I want to change it to do different things. I see that by changing the number next to start i can make it flash a different output but i also want it to light 2 other lights, my INSTRUCTIONS and FLYER BUTTONS. No matter what i do or input, it simply flashes the single output only while in hyperpin. How can i alter this or what is the syntax for that particular INI file since it seems to be different. There is no syntax noted anywhere that i can find for that INI, and whatever i do in the HPLedControl.ini file doesn't seem to do anything, other than flash the single output.
Thanks for any help.
Pat
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
