Search In
  • More options...
Find results that contain...
Find results in...
    Sorry for the recent downtime. Still much to do but we have the site updated, secure and back online.  Expect more changes.
This stream auto-updates
  1. Past hour
  2. Today
  3. Yesterday
  4. Last week
  5. Earlier
  6. I have this issue as well. It doesn't work on two of my computers - works fine on the third. I mirrored all .net and Visual c++ installations but still no luck. No idea what this could be. I'm not sure why whomever made this program can't just say what is required to run it after all of these years. Definite PITA.
  7. Hello friends I hope everyone is well in these times, difficult yes but not impossible I have no idea what to do, someone has a request for a game that they need
  8. Olá. Muito obrigado camarada. Salvou minha semana (férias). 🙏🙏🙏 Vamos para a diversão então. 💪 Thankssss
  9. helllion
    helllion
  10. Version 0.238
    75 downloads
    **This removes the nag screen that informs you if a rom doesn't work correctly, or if at all, if you use this no nag, then please do NOT go to the mame support site with issues with games, please only use if you understand that there will be no help from anyone at mamedev as you are using a modified version of mame. mame.exe - Normal Mame with Nags removed. For Version 0.238 (Note mame no longer carries the 64 in its exe name changed by Devs in 0.229) It's advisable to download the full 0.238 official pack and install it, then just overwrite the exe with the replacement, this covers any changes the mame devs may have made to the support files. After you have done this, make sure you copy the folders artwork, ctrlr, cheat, hlsl, ini, folders and the ini files from the root of your original mame folder, and move/copy them to the new install. make sure in the mame.ini file you have the following set. Skip_gameinfo 1
  11. Module for .212 and forward found here: http://www.rlauncher.com/showthread.php?6201-MAME-v0-212-don-t-launch-with-RocketLauncher&p=44551&viewfull=1#post44551
  12. Olá, Peço desculpa por vir aqui expor a presente questão, que para alguns de vos deve ser fácil de solucionar, contudo, estou exausto de tentativas.... Já tentei muitas coisas, não sou expert no assunto, não chego lá... daí peço e agradeço a ajuda que me possam dar. Baixei o MAME 0.232 e uns milhares de jogos desta versão, porém tenho um problema de há largos dias que não consigo resolver: colocar o MAME a funcionar no HyperSpin. 🤮 É assim mesmo que já me sinto...) Segundo entendo, quando verifico no RocketLauncher o teste de qualquer jogo, o mesmo emite um aviso de erro de MODULO... Alguém me sabe explicar porque isso acontece ou qual a solução? O modulo MAME.ahk não funciona. 🥵 Existe um modulo MAME (...bbb...).ahk que dá um erro de função....etc 🤯 Tou cansado mesmo e por isso agradeço alguma alma caridosa que me ajude: 🙏 1 - Onde encontro um modulo proprio que funcione? (Acho que resolvia todos os meus problemas, espero) 2 - Existe algum modulo conhecido para o FBNeo? Desde já fico eternamente agradecido pela ajuda... Deus vos pague...! Muito obrigado Cumprimentos
  13. ok so ive read this post looking for a solution to using subfolders and there isnt really an answer, ive read several other pages on the subject with no help so could someone help me figure this out, i dont really want to compress my entire psx & ps2 library Thanks Dakota
  14. QueenRaven
    QueenRaven
  15. Damn, I'm so jealous that you can play. I'll tell you a story now. In general, we had a great computer, we connected it to the TV, opened Steam and played. Everything was fine until somehow our computer was flooded by our child. I was in shock. After that, I generally thought about what I should install an Ajax security system, well, that is, water and smoke sensors, and even better movement. And do not let my son near the computer at all. These are extremes, but nevertheless...What would you do in my place?
  16. I'm glad everything is still working. I wasn't notified of the messages for some reason l. Yes, this version is still working and configurations are done within the HyperSpin folder as you have already figured out. MAME works well, but I found out that I rather stick with older roomsets + cores. Hopefully the next version of NVIDIA Shield will be backwards compatible with its existing architecture / software. I've heard that NVIDIA is going to shut down Tegra even though Nintendo Switch helped move a lot of NVIDIA hardware. It's too bad as Tegra was / is still the best SoC on Android TV hardware.
  17. Hi - have searched but cant find anything. Is it possible to add scan lines to the front end menu of HS? Any help would be much appreciated!
  18. denis031
    denis031
  19. After more than a year of work we are finally releasing our Nintendo Wii video snap set. Version 1.0 includes 1,129 videos in HD, HQ & SQ formats. We have been adding these videos to EmuMovies Sync as we got them done over the last year so some of our supporting members may have some of these already. Huge thanks to the team that helped capture the footage for this set including @avaris @drewby @mccorkled @Riffman81 & @xALPHAxOMEGAx (File List) Nintendo Wii (Videos Snaps)(EM 1.0).txt High Definition (FTP & Sync) Resolution 1440x1080 1920x1080 Frame Rate 60 / 50 Audio Rate 192 kbit/s File Count 1,115 Total Size 30.1 GB High Quality (FTP & Sync) Resolution 640x480 854x480 Frame Rate 60 / 50 Audio Rate 192 kbit/s File Count 1,129 Total Size 14 GB Standard Quality (Site, FTP & Sync) Resolution 320x240 426x240 Frame Rate 30 / 25 Audio Rate 128 kbit/s File Count 1,129 Total Size 5.79 GB EmuMovies Website (SQ Only) Directly through your front-end or our app using EmuMovies Sync (HD, HQ & SQ) EmuMovies File Server (FTP) (HD, HQ & SQ) View all our updates on the EmuMovies Files Feed (We only post a handful in the news feed) Follow EmuMovies on Facebook Join EmuMovies on Discord View the full article
  20. Hi, your hyperspin folder need to be in the root of your hdd, if it is inside a folder it won't worked.
  21. Hello, i´ve installed the 200gb hyperspin pack for my nvidia shield, but some games, nintendo, supernintendo wont bot through hyperspin, the screen goes black for a while then throws me back to the select games menu. The same roms work fine if i start retroarch and run the game through there. Whats wrong?
    excelent, i need a supreme warrior game wheel, please
  22. Hypersync will only work for platinum members.
  23. any update on this hypersync error as i still have the problem
  24. Another MAME System updated. Today we release a new Sega ST-V set in HD, HQ & SD formats. This update includes 61 new Video Snaps from EmuMovies. These videos are in a stand alone package and also available in the general MAME Video Snap set. What's New: EmuMovies Website (SQ Only) Directly through your front-end or our app using EmuMovies Sync (HD, HQ & SQ) EmuMovies File Server (FTP) (HD, HQ & SQ) View all our updates on the EmuMovies Files Feed (We only post a handful in the news feed) Follow EmuMovies on Facebook Join EmuMovies on Discord View the full article
  1. Load more activity
