Spawk 252 Posted June 22, 2020 Sounds like RL is just using default values. Go to “edit global module settings” for mame in RLUI and tell it to use the ini files from mame itself.Sent from my iPhone using Tapatalk 1 Share this post Link to post Share on other sites
gigapig 2,468 Posted June 22, 2020 Fire up a game via Rocketlaucher if that is launching mame. Set all your controls under general after hitting tab. You can also set trackballs and spinners etc as well. Once done close the game and find the default.cfg file found in the cfg folder. Copy the file and paste it into the ctrlr folder. Open folder and rename the default file to something familiar to you like 'taz101 controls'. Now head to you mame ini folder and open the mame ini or vertical or horizont or maybe all 3 if you have them. You probably just have mame.ini though. Once the ini is open look for 'core input options. Find ctrlr and put in quotes the name of your ctrlr file e.g. ctrlr "taz101 controls" Save it. That should be it but please refer to the other guide as well because this is off the top of my head. Share this post Link to post Share on other sites
taz101 2 Posted June 23, 2020 18 hours ago, gigapig said: Fire up a game via Rocketlaucher if that is launching mame. Set all your controls under general after hitting tab. You can also set trackballs and spinners etc as well. Once done close the game and find the default.cfg file found in the cfg folder. Copy the file and paste it into the ctrlr folder. Open folder and rename the default file to something familiar to you like 'taz101 controls'. Now head to you mame ini folder and open the mame ini or vertical or horizont or maybe all 3 if you have them. You probably just have mame.ini though. Once the ini is open look for 'core input options. Find ctrlr and put in quotes the name of your ctrlr file e.g. ctrlr "taz101 controls" Save it. That should be it but please refer to the other guide as well because this is off the top of my head. So firstly there is only one mame.ini right? I found it but inside there’s no ‘core input options’ or ctrlr? also when I’m in a game, button 2 exits back to HS wheel indicating it is using the ‘back’ that I assigned to ‘Esc’ key Share this post Link to post Share on other sites
Spawk 252 Posted June 23, 2020 What version and flavor of mame are you running? Some flavors store it in different folders. Mame64 has it's mam.ini in the root folder and Arcade64 has it's mame.ini in the ini folder. You should only have 1 though unless you tried to install 2 flavors to the same location. This is what that section looks like: 1 hour ago, taz101 said: also when I’m in a game, button 2 exits back to HS wheel indicating it is using the ‘back’ that I assigned to ‘Esc’ key 1. don't create the default config through RL, this is what we are trying to setup. create it in mame itself. 2. make sure JTK is not running while you do this. "Esc" key??? Finally, make sure you go into "edit global module settings" here: This is all the stuff RL needs to know. You can hover your mouse over all the "i" symbols for a description of each setting. Share this post Link to post Share on other sites
taz101 2 Posted June 24, 2020 Ok guys..I am close to my wits end with this bloody thing now. Remeber I said before how it weirdly changed/deleted stuff? Well..its done it AGAIN I literally just turn it on this morning to make the changes you suggested and boom, JTK profile is RL is GONE..open HS and try to run a game it errors saying cant find MAME ahk file. I go into RL and the path is BLANK..then another path is blank. HOW can it bloody make changes like this without me asking it????? Share this post Link to post Share on other sites
Spawk 252 Posted June 24, 2020 Oh man, this is not something I personally will be able to help with. I have just never seen or heard anything like it. Honestly it sounds like the beginning of HDD failure, or possibly a virus, or virus/malware programs? Maybe Win10 is the culprit??? Did an update happen? Share this post Link to post Share on other sites
taz101 2 Posted June 24, 2020 4 minutes ago, Spawk said: Oh man, this is not something I personally will be able to help with. I have just never seen or heard anything like it. Honestly it sounds like the beginning of HDD failure, or possibly a virus, or virus/malware programs? Maybe Win10 is the culprit??? Did an update happen? Yes its crazy but appreciate all your help. In spending too much time on this tbh and dont think it will ever just be all done where I can fire it up and play, something will always be off I know this isnt relevant here but was thinking maybe of switching to Retropie as all I want is MAME. Do you know if that just 'works' kinda thing with less config to go wrong? Share this post Link to post Share on other sites
taz101 2 Posted June 24, 2020 3 hours ago, Spawk said: Oh man, this is not something I personally will be able to help with. I have just never seen or heard anything like it. Honestly it sounds like the beginning of HDD failure, or possibly a virus, or virus/malware programs? Maybe Win10 is the culprit??? Did an update happen? Or I might just start over delete and reinstall completly disabling the WIFI so no way of any update but id always have the worry of stuff changing I think Share this post Link to post Share on other sites
Spawk 252 Posted June 25, 2020 I really don't think you are having any config issues per say, this stuff just doesn't disappear because of a setting somewhere. Something more serious is happening on your PC IMO. You should have zero worries about anything disappearing. You can probably confirm this with the possibly hundreds of thousands of people who have an HS setup. It is a bitch to setup as a new user and it has a steep learning curve, but when you do get it, it works. When you say the JTK profile is gone, do you mean the file is no longer in the windows folder? or is the file there and just the setting in RL deleted? Same with the mame.ahk? Maybe a screenshot of the actual error? Maybe a new RL log might help??? If you try to "run as admin" (not usually needed or recommended), then make sure to run all the programs you use in your setup as admin. Don't be afraid to start over either. I have done so several times over the years and not only do I understand the way things work better each time, the final product gets better every time I do. The Pi's popularity sure seems to suggest that it would in fact be "easier" to setup. Definitely an option especially if you are only concerned with 80's and early 90's arcade. Not really my cup of tea though. I want the extra power to include a few systems. And I like to use some of the more advanced shaders that make my TV/LCD look like a CRT. Share this post Link to post Share on other sites
taz101 2 Posted June 30, 2020 Update: So out of desperation I reinstalled Windows 10 after formatting to ensure no virus was the issue. When I got to run hyperspin.exe off my external HDD nothing happens? JTK, RL etc all fire up fine with the settings still there, MAME runs independently just nothing from HS or HyperHQ that also just eggtimes then nothing. Both still running from same directory location Share this post Link to post Share on other sites
gigapig 2,468 Posted June 30, 2020 2 hours ago, taz101 said: Update: So out of desperation I reinstalled Windows 10 after formatting to ensure no virus was the issue. When I got to run hyperspin.exe off my external HDD nothing happens? JTK, RL etc all fire up fine with the settings still there, MAME runs independently just nothing from HS or HyperHQ that also just eggtimes then nothing. Both still running from same directory location Could it be your new install of Windows 10 has the new 2004 update? If so you need this. Share this post Link to post Share on other sites
taz101 2 Posted June 30, 2020 1 hour ago, gigapig said: Could it be your new install of Windows 10 has the new 2004 update? If so you need this. Thanks - I tried your fix but under Windows.old theres nothing windows related just Desktop and other stuff. I did find the Windows update also here Copied HS and HQ.exe's but same thing nothing happening. Share this post Link to post Share on other sites
gigapig 2,468 Posted June 30, 2020 That link is from 2018 so nothing to do with this recent Windows update. First confirm you have the recent Windows update, so look at your Windows version which maybe be 2004. If it is copy the dll file in the download I linked to and put it in the root of your Hyperspin folder. Share this post Link to post Share on other sites
taz101 2 Posted June 30, 2020 1 hour ago, gigapig said: That link is from 2018 so nothing to do with this recent Windows update. First confirm you have the recent Windows update, so look at your Windows version which maybe be 2004. If it is copy the dll file in the download I linked to and put it in the root of your Hyperspin folder. Checked and it is 2004 build I have. Copied the .DLL but same issue. I can see HS.exe opens in Task Manager and it usage shows as 'Very High' not sure if thats normal but still won't launch Share this post Link to post Share on other sites
taz101 2 Posted June 30, 2020 8 minutes ago, taz101 said: Checked and it is 2004 build I have. Copied the .DLL but same issue. I can see HS.exe opens in Task Manager and it usage shows as 'Very High' not sure if thats normal but still won't launch Did it again and it worked, no idea why it didnt was same 39kb file but thanks 1 Share this post Link to post Share on other sites
taz101 2 Posted July 1, 2020 Incredibly I’m back to where I was with everything working except bloody JTK closing when you exit a game argh Share this post Link to post Share on other sites
taz101 2 Posted July 1, 2020 I know you guys have probably had enough of me but lets get this over the finish line lol? Share this post Link to post Share on other sites
taz101 2 Posted July 14, 2020 Giga, Spawk i'd gladly pay one of you for your time to remote connect to my cabinet PC and bottom out my remaining few issues. They are probably easy fixes I just want to finally enjoy the thing rather than every day spending ages trying to work out whats wrong. Share this post Link to post Share on other sites
Spawk 252 Posted July 16, 2020 On 6/30/2020 at 9:45 PM, taz101 said: Incredibly I’m back to where I was with everything working except bloody JTK closing when you exit a game argh Like I said earlier, RL will close/re-open JTK every single time it switches profiles. At this point you should know that the HS profile (inside RL) is the one that is suppose to load. If you have created one and it still doesn't load, then possibly you haven't selected HS as the default profile again like was covered in this thread? Everything you need to know should already be here in this thread. Maybe a RL "Troubleshooting" log might help if it is in fact a setting wrong somewhere. If for some reason you are still experiencing "things disappearing"... I can't help! Remote connecting won't help as I will have no clue what I would be looking for. As you can tell, I am not a big fan of "remote connecting". For arguments sake, if I had connected after your first post and fixed everything all up, you would still have zero understanding of what's actually going on. By talking you through it, you now (at least theoretically) have a better knowledge of how everything works. You can do it! 1 Share this post Link to post Share on other sites
taz101 2 Posted July 16, 2020 15 hours ago, Spawk said: Like I said earlier, RL will close/re-open JTK every single time it switches profiles. At this point you should know that the HS profile (inside RL) is the one that is suppose to load. If you have created one and it still doesn't load, then possibly you haven't selected HS as the default profile again like was covered in this thread? Everything you need to know should already be here in this thread. Maybe a RL "Troubleshooting" log might help if it is in fact a setting wrong somewhere. If for some reason you are still experiencing "things disappearing"... I can't help! Remote connecting won't help as I will have no clue what I would be looking for. As you can tell, I am not a big fan of "remote connecting". For arguments sake, if I had connected after your first post and fixed everything all up, you would still have zero understanding of what's actually going on. By talking you through it, you now (at least theoretically) have a better knowledge of how everything works. You can do it! I shall re-double my efforts! Share this post Link to post Share on other sites
taz101 2 Posted July 20, 2020 JTK problem SOLVED. Was of course me being a dougnut. I had two HS profiles in JTK for some reason one being a custom one. I deleted that and it worked fine. Only issue left is MAME games refusing to run full screen/stretched. Have set it everywhere I can see in RL and also in the Mame.ini under 'keep aspect ratio' set to 0 Also is there a way of cherry picking only the roms I want HS to show on the wheel? Share this post Link to post Share on other sites
Spawk 252 Posted July 20, 2020 Way to go Taz! I am really not sure about the stretching stuff. I mean the horizontal games may or may not stretch out ok but what about the vertical games? That's an awful lot of stretch! A much better approach is to use bezels with some nice artwork on the sides. You have a couple of options when it comes to filtering down the list in HS. The 4 options in HQ are found here: The "Parents Only" is a quick way to get down to just 1 of each game. The Parent rom is not always the preferred one (Puckman is parent of Pacman for example). With the other 3 choices you can just delete the one file to remove it from wheel. So with roms only you would delete the game itself. With wheels only it will only show games with a wheel graphic, so you would delete the wheel to remove. If you use a "Roms Only" filter like shown above, also make sure to set the Rom Path and Extension (Do not set the executable here!). If you want even more control over what gets used/displayed, you can download a freeware program called "Notepad plus plus" (Notepad++). Tell RL where the program is: Then you can easily edit the DB's (xml) Share this post Link to post Share on other sites
taz101 2 Posted July 25, 2020 On 7/20/2020 at 7:04 PM, Spawk said: Way to go Taz! I am really not sure about the stretching stuff. I mean the horizontal games may or may not stretch out ok but what about the vertical games? That's an awful lot of stretch! A much better approach is to use bezels with some nice artwork on the sides. You have a couple of options when it comes to filtering down the list in HS. The 4 options in HQ are found here: The "Parents Only" is a quick way to get down to just 1 of each game. The Parent rom is not always the preferred one (Puckman is parent of Pacman for example). With the other 3 choices you can just delete the one file to remove it from wheel. So with roms only you would delete the game itself. With wheels only it will only show games with a wheel graphic, so you would delete the wheel to remove. If you use a "Roms Only" filter like shown above, also make sure to set the Rom Path and Extension (Do not set the executable here!). If you want even more control over what gets used/displayed, you can download a freeware program called "Notepad plus plus" (Notepad++). Tell RL where the program is: Then you can easily edit the DB's (xml) Thanks Spawk will take a look at the best approach. I also fixed the stretch issue (I know purist view is use bezels but I just want to have the full arcade thing as I remember it) so all this bl**dy time I RL was looking at the WRONG mame.ini file! So annoying but i've pointed it to the root one in Arcade and it now uses the 'Keep Aspect Ratio' 0 that I set Thanks so much for your and Gigapigs help I finally got there Share this post Link to post Share on other sites
