HyperSync, HyperList and FTP are now back online ×
taz101
Certain games wont open
Hey Guys
So weirdly most of my MAME games run fine except a handful. They go to the 'loading complete' stage then it switches back to HS.
They do run directly through MAME itself but very slowly and with weird echo sound.
My RL log is below - the only obvious error I can see is highlighted?
20:07:02:886 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.2.0.1 (www.rlauncher.com)
20:07:03:223 | RL |      INFO  | +328   | Main - System Specs:
                    RocketLauncher Dir: D:\Arcade\RocketLauncher
                    RocketLauncher is: 32-bit
                    OS: Microsoft Windows 10 Pro
                    SKU: Professional
                    Total Memory: 8150.00 MB
                    Free Memory: 5417.40 MB
                    Used Memory: 2732.594 MB
                    SystemType: 64-bit
                    Physical Processors: 1
                    Logical Processors: 4
                    GPU 1 Name: NVIDIA Quadro 2000D
                    GPU 1 RAM: 1024.00 MB
                    GPU 1 Driver Version: 10.18.13.5330
                    Sound 1 Device: Realtek High Definition Audio
                    Sound 1 Status: Enabled
                    Sound 2 Device: NVIDIA High Definition Audio
                    Sound 2 Status: Enabled
                    Sound 3 Device: NVIDIA High Definition Audio
                    Sound 3 Status: Enabled
                    Sound 4 Device: NVIDIA High Definition Audio
                    Sound 4 Status: Enabled
                    Sound 5 Device: NVIDIA High Definition Audio
                    Sound 5 Status: Enabled
                    OS Language: English_United_Kingdom
                    System Locale: en-GB
                    Formats Locale: en-GB
                    Windows UI Language: en-GB
                    Text Encoding: Windows-1252
                    OS Admin Status: No
                    RL Compatibility Flags:
                    Latest .Net Version: v4.0.30319
                    Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1080 work) [32bit] [60hz] [Landscape]  (Primary)
                    Current AHK Desktop Width: 1920
                    Current AHK Desktop Height: 1080
                    Monitor #1 DPI: 100
                    ErrorMode: 0
                    AutoHotkey Path:
                    AHK Version: 1.1.13.00
                    Unicode: No
20:07:03:223 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\RocketLauncher.exe exists
20:07:03:224 | RL |      INFO  | +0     | Main - Using HyperSpin normal mode for version 1.5.1.0 found at: D:\Arcade\HyperSpin.exe
20:07:03:225 | RL |      INFO  | +0     | Main - Raw CLI received: "MAME alien3"
20:07:03:225 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
20:07:03:225 | RL |      INFO  | +0     | Process.Process - "Exist" "HyperSpin.exe"
20:07:03:231 | RL |      INFO  | +16    | Main - Detected HyperSpin.exe is currently running
20:07:03:232 | RL |      INFO  | +0     | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080
20:07:03:232 | RL |      INFO  | +0     | Main - RocketLauncher received "MAME" and "alien3"
20:07:03:328 | RL |      INFO  | +94    | Main - Found a "Games Options.ini" file, loading it into memory.
20:07:03:346 | RL |      INFO  | +15    | Main - alien3 is switching to emulator MAME (0.166) (Gun Games) via: D:\Arcade\RocketLauncher\Settings\MAME\Games.ini
20:07:03:346 | RL |      INFO  | +0     | Main - Checking for a [MAME (0.166) (Gun Games)] section in D:\Arcade\RocketLauncher\Settings\MAME\Emulators.ini
20:07:03:346 | RL |      INFO  | +0     | Main - Checking for a [MAME (0.166) (Gun Games)] section in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
20:07:03:347 | RL |      INFO  | +0     | Main - Found [MAME (0.166) (Gun Games)] in D:\Arcade\RocketLauncher\Settings\Global Emulators.ini
20:07:03:348 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Modules\MAME\MAME.ahk exists
20:07:03:358 | RL |      INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
20:07:03:358 | RL |      INFO  | +0     | Main - alien3 will use module: D:\Arcade\RocketLauncher\Modules\MAME\MAME.ahk
20:07:03:385 | RL |      INFO  | +15    | Main - Using SkipChecks method "Rom Only".
20:07:03:389 | RL |      INFO  | +16    | CheckFile - Checking if D:\Arcade\Emulators\MAME (0.166) (Gun Games)\mame64.exe exists
20:07:03:390 | RL |      INFO  | +0     | Main - INI Keys read
20:07:03:390 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.exe exists
20:07:03:391 | RL |      INFO  | +0     | CheckFile - Checking if D:\Arcade\RocketLauncher\Module Extensions\7z.dll exists
20:07:03:399 | RL |      INFO  | +0     | Main - "alien3" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
20:07:03:399 | RL |   WARNING  | +N/A   | Main - SkipChecks is enabled and set to: Rom Only
20:07:03:399 | RL |      INFO  | +0     | CheckPaths - Started
20:07:03:399 | RL |      INFO  | +0     | CheckPaths - Looking for rom: D:\Arcade\Games\MAME\alien3.zip
20:07:03:399 | RL |      INFO  | +0     | CheckPaths - Found rom: D:\Arcade\Games\MAME\alien3.zip
20:07:03:400 | RL |      INFO  | +0     | CheckPaths - Ended
20:07:03:400 | RL |      INFO  | +0     | BuildScript - User Variables:
Share this post
Link to post
It's called emulation.
You will not get 100% of games working.
Also try another version of MAME emulator for specific games that do not load.
Share this post
Link to post
@Spawk @gigapig Me again :/ these games worked fine before I reinstalled my OS. Also rolled back graphics card driver but didnt help
Share this post
Link to post
I would suggest making sure they run fine in mame itself before even thinking about worrying about RL/HS.
Might help to know specifically which roms are giving you problems... although this kind of "some work, some don't" usually suggests that you are mix and matching romsets and mame versions.
Share this post
Link to post
It's:
Alien 3
Jurrasic Park
Lethal Enforcers
Operation Wolf
Point Blanc
Teenage Mutant Ninja Turtles
Terminator 2 Judgement Day
Time Crisis
WWF Wrestlefest
A lot of those are light gun games (although i'm just using the sticks). Indeed I believe all the light gun games above use a different MAME version that has 'light gun' on the title or something but I havent changed any roms/mame versions so nothing has 'changed' persay there since they worked before
Share this post
Link to post
They dont run right in MAME so issue isnt RL related as you rightly said. I'm with you on mismatch of Rom sets/mame etc but nothing has changed on my build from those aspects, these were all working before? Only change persay was a Windows update
Share this post
Link to post
Which mame version is it?
So after a windows update some games stopped working in mame directly?
Share this post
Link to post
0.217
Would seem coincidence yes. So most games run fine except a bunch listed above that open but run REALLY slow with choppy/doubled echo'd sound basically unplayable.
I can download a newer version of MAME but then my roms wont work needing new AHK file etc would rather just find out why these arent working ideally im sure its a simple silly thing ive done maybe in an ini file or RL?
Share this post
Link to post
To update I have resolved this. My Video setting needed to be changed from Opengl to dddraw which looks slightly blockier than opengl and it refuses to add scanlines but is much smoother. d3d displays black screen but audio correct.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
