Brandin
Hypersync cannot verify membership
Thank you so much guys for all your hard work and for keeping this stuff going. I know it's no picnic :)
  • Upvote 1
Share this post
Link to post
On 10/13/2018 at 9:56 PM, thatman84 said:
HyperSync is back live again thanks to the blank stares of @fr0stbyt3
Get that man a beer!  Currently syncing as I type.  Big thanks to everyone involved in getting HyperSync up and running again.
Share this post
Link to post
No worries, hopefully it dont break soon and so frosty gets more time on better things ;)
If your syncing can you test a couple of files please? Reported corrupt here
I currently dont have a working PC :(
Share this post
Link to post
NOT working here... I downloaded a fresh copy (3.5.0.32) and am still getting the same error as other Win10 users (as of 10/16):
System.Runtime.InteropServices.COMException (0x80040154): Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
   at System.Windows.Forms.UnsafeNativeMethods.CoCreateInstance(Guid& clsid, Object punkOuter, Int32 context, Guid& iid)
   at System.Windows.Forms.AxHost.CreateWithLicense(String license, Guid clsid)
   at System.Windows.Forms.AxHost.CreateInstanceCore(Guid clsid)
   at System.Windows.Forms.AxHost.CreateInstance()
   at System.Windows.Forms.AxHost.GetOcxCreate()
   at System.Windows.Forms.AxHost.TransitionUpTo(Int32 state)
   at System.Windows.Forms.AxHost.CreateHandle()
   at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
   at System.Windows.Forms.AxHost.EndInit()
   at HyperSync.Forms.Secondary.Subscribe.InitializeComponent()
   at HyperSync.Forms.Secondary.Subscribe..ctor()
   at HyperSync.Forms.Primary.MainWindow..ctor()
   at HyperSync.Program.Main()
Share this post
Link to post
3 minutes ago, DanDoyle said:
Looks like the hypersync login is hosed again, is someone taking a look?  Thanks!
Yep, it's being worked on.
Share this post
Link to post
17 hours ago, DubaiShark said:
Hi
I'm still Cant login to Hyper Sync
13 hours ago, DanDoyle said:
Hey guys sorry to keep bugging you with this, but it seems to be down again
It looks like we had another outage after updates. We're watching it to see if it happens again. Thanks for reporting it!
Share this post
Link to post
I had this same error.  I uninstalled windows media player since I didn't ever use it, but HyperSync seems to require it.  This error went away after reinstalling windows media player.
Share this post
Link to post
weird, let me see if I can remove that requirement.
Share this post
Link to post
Same here. HyperSync connection issue as it cannot test my HyperSpin membership. Opened a request - I supposed it's an issue on the server itself.
Share this post
Link to post
10 hours ago, JGio33 said:
Can not log into hypersync here either
You need to be a platinum member.
Share this post
Link to post
Ok, I did see that mentioned somewhere earlier.  I thought I had a lifetime platinum membership but I'm not seeing that now.   I use to be able to log in and have in the past.  If I had to guess maybe I have another account.  Or something happened to this one.
Share this post
Link to post
You will need to send me a support ticket with all the email address you may have used and I will see if I can find it.
I think the site software should have flagged multiple accounts from your IP.
Share this post
Link to post
in all honesty if hypersync cant be used unless platinum why have it in the base install? why not keep it in platinum media instead so platinum members can access it and non platinum and newbies dont try using it before having to sit and search the fourms for the reason why they cant use it
Share this post
Link to post
I cannot login to Hyperspin account through HyperSync. I have updated to lastest version and recently changed my password on my hyperspin membership. The emumvies login works fine but I get a message saying could not verify Hyperspin membership, check your dredentials and try again. Is there a way I can resolve this?
Share this post
Link to post
Did you install the version into an empty folder?
Share this post
Link to post
Hi all. newbie here.
I signed up to platinum and tried Hyper Sync last year (October) and again tonight but still getting the Could not verify hyperspin membership error.  My password was really long so I changed to to shorter version but still no luck.
As a newbie it's confusing. I downloaded the the Hyper Sync app but it says it's end of life and to use hyerbase (via this link http://www.hyperspin-fe.com/topic/15306-hyperbase-live-public-beta/ ) so I tried that and it has 404 for the download with the topic closed.
What do you folks recommend?
Edit - problem solved. I only had platinum on EMUMOVIES, not Hyperspin-Fe. Once I signed up to platinum it logged in.
Thank you
Share this post
Link to post
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
  • Similar Content
    • By Hyperspinner5000
      Hi all! I have been using hypersync without fault to update most of my themes and vids etc for quite some time. I noticed that when ever anyone shows off the Taito Type X system or the Type X2 system on Hyperspin their videos are always there. I cant seem to download any at all. I have also had a look on the ftp to see if i could find anything but no luck there either.
      Where is everyone getting their Taito videos from including the main menu preview?
    • By koscica
      Hi I have and Hyperspin install on mounted network drive. HyperSync was working fine until I installed Windows 10 April 2108 update. I tried it on two PCs. It stops working after windows update. Any ideas?
      HyperSpin shows no internet connection available which is not the case
    • By punkysuen
      I have just purchased the HyperSpin platinum account and the EmuMovie account.
      I can log in both in the HyperSync. However, when I click "individual system settings" icon, it fails and shows the message below:
      "Sling 2: there was an error connecting to HyperBase, please try again later"
      What should I do now?
    • By relic
      Hi guys this is where ill be listing a full database chart of what content is available  for hyper sync and which content is not there but could be added in. I know its been ages since ive been in this scene but i promise to do a full list of every single system available in the list of hyper sync and go through every single bit of content and list what is in their and whats not it will be a huge project but im gonna get it done thanks regards relic.
    • By Dakin23
      HyperSync WILL NOT recognize my HyperSpin login...WHY?  It logs into my "Emumovies" account just fine.  PLEASE HELP!
      THANK YOU!
