Special Artwork 1.0.0
   (0 reviews)
Português:
Atendendo a pedidos, disponibilizo as Special Artworks que utilizo no meu Hyperspin (que peguei por aqui mesmo no site do Hyperspin ha tempos atrás)
Estes arquivos devem ficar dentro da pasta
media\"seu sistema" ou main menu\imagens\Special
Colar estas informaçoes no arquivo ini dentro da pasta settings
(settings.ini ou "seu sistema".ini)
English:
In response to requests, I make available the Special Artworks that I use in my Hyperspin (which I picked up right here on Hyperspin's website some time ago)
These files should be inside the folder
media \ "your system" or main menu \ images \ Special
Paste this information into the ini file inside the settings folder
(settings.ini or "your system" .ini)
[special Art A]
default=false
active=true
x = 512
y = 384
in = .4
out = .4
length = 3
delay = .1
type =normal
start =none
[special Art B]
default=false
active=true
x = 512
y = 750
in = .4
out = .4
length = 3
delay = .1
type =normal
start =none
[special Art C]
active=true
x=974
y=12
in=0
out=0
length=3
delay=0
type=fade
start=none
credits to its due author
  • Super Like 3
