Unable to exit HyperSpin with this keyboard mapping/setup.
Dazz 139 Posted January 19 Changed Severity to 2 - High Priority Changed Development Feedback to Additional findings - This setup does NOT work unless there is a Menu key mapped. I would rather not have a "Menu" key, but would rather keep hitting "Back" until the Menu/Exit screen
fr0stbyt3 1,125 Posted January 19 As the menu will eventually expand, this would be less than ideal. Also, its important to note not all users will be using escape - since controllers and other devices will be supported. Continuing to hit ESC (whatever back key you have set) should prompt with a menu when you are at the root wheel.
fr0stbyt3 1,125 Posted January 19 Changed Severity to 4 - Low Priority Changed Current Status to Investigation
Dazz 139 Posted January 20 14 hours ago, fr0stbyt3 said: As the menu will eventually expand, this would be less than ideal. Also, its important to note not all users will be using escape - since controllers and other devices will be supported. Continuing to hit ESC (whatever back key you have set) should prompt with a menu when you are at the root wheel. In this case, I'd suggest making multi-button combinations mappable to bring up the menu. I don't want/need a dedicated MENU button anywhere. Set an option that disables the MENU, or base it on profiles. So I can have a kids profile, that disables anything to do with admin, for when the kids are playing. When you have 10 kids, that can't/don't read anything, pounding on a control panel and will just click on anything... having any additional menus pop-up is a really bad idea. 1
fr0stbyt3 1,125 Posted February 1 Changed Current Status to Fixed Changed Development Feedback to we should create a feature request for a no menu mode
