PROBLEM - FIXING MEDIA
I added a bunch of wheels.... And was able to use the full screen Theme override for things like Atari 2600, 5200 etc...
Then for Atari Jaguar... I couldnt get the override theme to work... however after some testing.... I eventually did figure this out.... I had to go into HyperHQ.. delete the system. Go into the main menu media.. renmaed the theme. Closed HyperHQ... Reopened it again. And readded the system.
I then reloaded Hyperspin and Voila... I was able to use the Full screen menu override for Atari Jaguar
I then tried to do the same exact thing with MUGEN... Which doesnt actually have a theme but is a noted system on the HyperHQ installation process.
Well doing this and trying to use an Override... doesnt work at all. Even if I did the above. The wheel also refuses to show any media at all.
Other problems.... Some of the wheels have a main menu theme... but the wheel media refuses to show.
Its very hard to make heads or tails of anything.... And even using process of elimation is proving difficult because it seems that certain wheels, which seem to have a theme... act differently then other wheels that were seemingly added but the backend code was never completed. This is the only explanation I can think of..
Im going to find another one with a theme and do the same thing.....
Also the forums are very active... Zero threads of people testing this stuff.
Very Frustrated - Any insight is welcome... Things need to be fixed
