  • PROBLEM - FIXING MEDIA
    I added a bunch of wheels.... And was able to use the full screen Theme override for things like Atari 2600, 5200 etc...
    Then for Atari Jaguar... I couldnt get the override theme to work... however after some testing.... I eventually did figure this out.... I had to go into HyperHQ.. delete the system. Go into the main menu media.. renmaed the theme. Closed HyperHQ... Reopened it again. And readded the system.
    I then reloaded Hyperspin and Voila... I was able to use the Full screen menu override for Atari Jaguar
    I then tried to do the same exact thing with MUGEN... Which doesnt actually have a theme but is a noted system on the HyperHQ installation process.
    Well doing this and trying to use an Override... doesnt work at all. Even if I did the above. The wheel also refuses to show any media at all.
    Other problems.... Some of the wheels have a main menu theme... but the wheel media refuses to show.
    Its very hard to make heads or tails of anything.... And even using process of elimation is proving difficult because it seems that certain wheels, which seem to have a theme... act differently then other wheels that were seemingly added but the backend code was never completed. This is the only explanation I can think of..
    Im going to find another one with a theme and do the same thing.....
    Also the forums are very active... Zero threads of people testing this stuff.
    Recommended Comments
    rik81
    So I just went through all the systems....
    Any wheel that had a main menu theme that worked.... The media also seemed to work in wheel. Anything that the media didnt work... ArcadePC for instance.. which is PC games. And I have a video theme for... Overrides dont take... None of the media will sync either.
    fr0stbyt3
    There are systems that are missing data at this time, and that's likely what you're running into. I think I know what the bug is based on your description and I will take a look shortly.
    rik81
    Newest update just tested
    I just added American laser games again... The Main wheel showed up.. the theme video showed up... Still no media inside the wheel for anything. Mugen doesnt have any wheel media/video at all.... Both on the main menu and inside the wheel.
    This seems like its backend stuff.. related to the cache and the plugins.. as its only happening to certain wheels.. other wheels seem to be ok... Glad that youve seen this thread.
    Also... Hyperspin goes completely grey for me now after the latest update, after about 30 seconds of scrolling... I got a wide screen... Seems just like the white screen error in HS1. But this time its grey. Im thinking its running out of video ram?!
    fr0stbyt3
    I suppose its possible. What are the specs of the machine your're testing on. I haven't had the white screen error yet myself.
    So it sounds like the issue you're running into is due to the database missing for the system so matchmaking stops. We'll be working on these missing databases in the coming weeks. However, This is a bug since overrides should not be dependent on this.
    I'm on it, thank you!
    • Confused 1
    rik81
    I got a 3080... 64 gigs of ram.. its a good machine.
    Yeah i dont know about the database... I mean its happening to systems in your approved list of adds... and also happening to custom adds... to systems that dont show up when you type them in the systems search bar.
    Anyways if your on it... Ill be around to test things.
    Thanks!
    fr0stbyt3
    That's gonna be better than the vast majority of machines that run HS. Once I get done with this bug, we'll circle back and find that one.
    • Haha 1
    rik81
    This is the screen I get after about 8 seconds of loading up Hyperspin... Just a big grey blank screen.
    This only happened after the last update. Just for reference... Its hyperspin version 2.0.36.. Maybe hyperspin didnt update with the new version? What version should it be? I know it gets incremental updates.
    rik81
    Just an update on things... applied the new update..
    At first I still got the screen where things went completely grey and I had to manually close things.
    I reset the cache... Tried to reinstall plugins etc.
    Now its just frozen on the hyperspin loading screen...
    I really hope I dont have to start fresh yet again. 😞
    rik81
    Im going to try a brand new install and add mugen again... see if the media populates.
    rik81
    Still not working.... Nothing from the Override folder works.
    Im going to assume the custom system add doesnt work either...
    I guess ill try again in 2 weeks. 😪
    rik81
    Quick update!
    The software is getting better.... After doing a fresh install. I made a backup of the files on C was able to import them over. And I tried loading hyperspin, and It did load!
    So im happy about that!
    Please work on the systems not populating media and custom systems! Its pretty important and fundamental to the use of the program.
    rik81
    Another update.... I tried to import my media back over.... and its frozen at the "Loading system and rom assets" Screen again.
    Ill wait a few mins and see it loads... but if it doesnt... Im going to start removing media... reloading.. see if I can isoloate the problem.
    rik81
    Another update...
    So ive been messing with this for a few hours....
    Bad PNG files... completely crash hyperspin. I had some bad files in the Marquee folders... And I guess when hyperspin tries to read them.... The loading screen gets stuck.
    Also... the Grey error seems to be gone too... amybe it was from the bad files? Im not entirely sure.
    rik81
    Teknoparrot
    PC Games
    Openbor
    Atomiswave
    Hikaru
    Model 1
    Model 2
    Model 3
    Naomi
    St-v
    Triforce
    Taito Type X
    Touhou
    Xbox original
    Xbox 360
    Dice
    PS3
    Pinball
    PSP Mini
    Pocketstation
    PSP
    Sega VMU
    Game and watch
    3DS
    Wonderswan Colour
    Sinclair
    Sharp X68000
    Sega SC3000
    These dont display the main themes that were downloaded from HyperTheme...
    Theres more... but I keep getting the Grey screen again....
    I appreciate that your trying to work on a ton of different new features... but the cache system although better... still has a ton of problems. In its current form... The launching and various things work great... but the media... is still very much a mess since most of the main wheel media, doesnt populate like it should.
    Also the search needs to be improved... Doesnt find the right matches.
    I dont know... i messed with this for a few hours today.... Pretty drained to be honest... Hopefully the next update addresses the media... in its current form. Its broken.
