Sega Model 2 Emulator dual AimTrak lightguns
shiryu55
I need some help in order to operate the two guns aimtrack segamodel 2 .
is there a program trubleshooter 2, but not as integration into the Hyperspin .
There are 2 different Troubleshooter programs that I know of to get 2 guns working: Troubleshooter and Troubleshooter 2. I've been using the original one for Model 2. You could use Troubleshooter 2 for Model 2 but I couldn't get it to work. Anyway heres the link for the one that works for me:
http://thetroubleshooter.home.mindspring.com/index.htm
After you install it, it runs in the background when you turn on your computer. Its a bizarre file to unzip. I remember having to create a bat file in Notepad to get the program to install. Anyway good luck and let me know if you have any questions
then they work with the original trubleshooter two guns in the sega model 2 . ??
You could put a couple of screenshots of how you have configured the trubleshooter sega model 2 with two gun.
Thank you very much for answering and greetings from Spain.
Oh yea you're right! I got it wrong. haha I'm sorry. I used Troubleshooter 2 for sega model 2 and the original Troubleshooter for PC games. I wanted to get the House of the Dead series working with 2 guns. I use the Sega Model 2 version of HOTD1 with Troubleshooter 2 because the PC version had no sound. Then I use the PC versions of HOTD2 and HOTD3 with the original Troubleshooter. I use the WII Dolphin version of HOTD Overkill but it only allows one gun at the time :(
When you open up TS2, toward the bottom it says "Model 2 Specific Settings". Click on "Model 2 Setup Helper" and make sure the path to where you installed the Model 2 emulator is correct. I use Aimtrak guns so I have Step 2 set to Mouse. Then you should be able to click on Install Files for Model 2.
Thank you very much for responding, proves it tonight.
Also I have two pistols guncon2 original Namco using the driver 082B wingun
and two pistols ps2 compatible with the driver of smog.
These last have them working with an old CRT TV .
I have to fix some flaws with these two pistols , shooting and refilling offscreen and two pistols appear in mame at once.
