matt2015 Posted August 8, 2015 Posted August 8, 2015 when I launcher hyperspin and goto a system says xml not found but its in my database
earthprime Posted August 8, 2015 Posted August 8, 2015 1) Double-check the name of your XML file in Hyperspin / Databases. 2) Ensure the corresponding INI file in Hyperspin / Settings is named exactly the same. 3) Open the INI file. Ensure the system name in the PARAMETERS field is named exactly the same. 4) If it still doesn't work, it helps to remove the system from Hyperlaunch or Rocketlauncher and add it again. The system name must match through all back-end files.
