cybernoid Posted August 13, 2015 Posted August 13, 2015 Hello from Switzerland, I have searched in the forum but did not find a solution for my problem. Is there a possibility that the wheel art is on top of the default theme? As you can see, the wheel art is hidden behind the X6800 "video.png". TIA Cybernoid
rdyott Posted August 16, 2015 Posted August 16, 2015 Someone correct me if I'm wrong. But no. The background is the bottom layer. The pointer is next higher. Then the wheel. So only background layer. And pointer are below the wheel art. Everything else will cover over. And those look like artwork layers to me
Dunk3000 Posted August 16, 2015 Posted August 16, 2015 In hypertheme there is an option on the video to have it above or below wheel - so that can be changed. But there isn't one for artwork. Now, maybe setting the image in the original post as the video overlay (instead of an artwork layer) and setting video to be below wheel would work for op? Not tried that, but worth a shot? Sent from my SM-G925F using Tapatalk
cybernoid Posted August 18, 2015 Author Posted August 18, 2015 Hi Dunk3000, Your tip works so far, the wheel image is over the vide artwork. But when i switch to another game, the video artwork disappears - so i have to redo my theme :-(! Thank you both for your help.
Dunk3000 Posted August 18, 2015 Posted August 18, 2015 Oh damn. The only alternative I can think of is having the video image 'appear" as I guess you have it stationary atm. If you set the time low it will vanish when you scroll wheel then appear underneath wheel when you stop. Might not be the look you want, but might be closer than re designing ur entire layout. Sent from my SM-G925F using Tapatalk
