Set exit key for kega fusion
seantron1
This is the last item I have on my list to cleanup my configuration. I was originally using hyperhq and hyperlaunch. I followed the transition tutorial and have everything setup with rocketlauncher and hypersync.
I just need to figure out how to edit the exit button for fusion.
Any help would be appreciated, thanks! (I did try to search for this first)
I couldn't figure out how to change fusions exit button either. I have since switched to retroarch for genesis which is more flexible. Did you set your exit emulator key in rocketlauncherUI?
Did you go into fusions options and check if you could?
Yeah, I didn't see an option for changing it anywhere in the menus :(
Everything I've read around this talks about people switching to retroarch, ha. I'll check it out, thanks.
you should check out Simply Austin on youtube and look at his setup guide for sega. He has the Emulator, pre setup and ready to go for ya.
If you decide to stick with Fusion tho. Im pretty sure you don't need to change the default key to exit the emulator as long as you set a specific "exit emulator key" in your RocketlauncherUI.
