Can launch game in rocketlauncherUI, get an error when trying to launch from HS
bnuts77
Following error
"Error at line 626. Line text: HideEmuStart(ms=2) Error: Duplicate function definition. The program will exit"
I looked that code up and error 2 has to do with incomplete games. But they launch fine in RL​
Edit : forgot to include logs
RL
[code]
19:51:35:341 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.2 (www.rlauncher.com)
19:51:35:341 | RL |  WARNING  | +0     | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done.
19:51:35:397 | RL |     INFO  | +62    | Main - System Specs:
					RocketLauncher Dir: F:\New folder\Hyperspin
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 10 Home
					SKU: Windows 8
					Total Memory: 8136.00 MB
					Free Memory: 4114.28 MB
					Used Memory: 4021.719 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 4
					GPU 1 Name: NVIDIA GeForce GTX 970
					GPU 1 RAM: -1.00 MB
					GPU 1 Driver Version: 10.18.13.5362
					Sound 1 Device: NVIDIA High Definition Audio
					Sound 1 Status: Enabled
					Sound 2 Device: Rocketfish 5.1
					Sound 2 Status: Enabled
					Sound 3 Device: Realtek High Definition Audio
					Sound 3 Status: Enabled
					Sound 4 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
					Sound 4 Status: Enabled
					OS Admin Status: Yes
					Monitor #1 (\\.\DISPLAY1): 2560x1440 (2560x1400 work) [Landscape] (Primary)
					Current AHK Desktop Width: 2560
					Current AHK Desktop Height: 1440
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
19:51:35:397 | RL |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\RocketLauncher.exe exists
19:51:35:398 | RL |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\Plugins\HyperSpin.plugin exists
19:51:35:398 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
19:51:35:398 | RL |     INFO  | +0     | Main - RocketLauncher received "MAME" and "005"
19:51:35:402 | RL |     INFO  | +0     | Main - Did not find a "F:\New folder\Hyperspin\Settings\MAME\Game Options.ini" file, skipping any game-specific options.
19:51:35:402 | RL |     INFO  | +0     | Main - 005 is using the default emulator: Mame
19:51:35:402 | RL |     INFO  | +0     | Main - Checking for a [Mame] section in F:\New folder\Hyperspin\Settings\MAME\Emulators.ini
19:51:35:402 | RL |     INFO  | +0     | Main - Found [Mame] in F:\New folder\Hyperspin\Settings\MAME\Emulators.ini
19:51:35:402 | RL |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\Modules\Mame\Mame.ahk exists
19:51:35:405 | RL |     INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
19:51:35:405 | RL |     INFO  | +0     | Main - 005 will use module: F:\New folder\Hyperspin\Modules\Mame\Mame.ahk
19:51:35:412 | RL |     INFO  | +0     | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
19:51:35:414 | RL |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\Emulators\MameUI64\Mameui64.exe exists
19:51:35:415 | RL |     INFO  | +0     | Main - INI Keys read
19:51:35:415 | RL |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\Module Extensions\7z.exe exists
19:51:35:415 | RL |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\Module Extensions\7z.dll exists
19:51:35:418 | RL |     INFO  | +0     | Main - "005" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
19:51:35:418 | RL |     INFO  | +0     | CheckPaths - Started
19:51:35:418 | RL |     INFO  | +0     | CheckPaths - Found rom: F:\New folder\Roms\MAME\005.zip
19:51:35:418 | RL |     INFO  | +0     | CheckPaths - Ended
19:51:35:418 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = F:\New folder\Hyperspin\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.2
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = F:\New folder\Hyperspin\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = F:\New folder\Hyperspin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = F:
					exitEmulatorKey = ~Esc
					exitEmulatorKeyWait = 0
					forceHoldKey = ~Esc
					restoreFE = false
					exitScriptKey = ~PGUP & ~PGDN
					toggleCursorKey = ~e & ~t
					emuFullPath = F:\New folder\Hyperspin\Emulators\MameUI64\Mameui64.exe
					emuPath = F:\New folder\Hyperspin\Emulators\MameUI64
					emuName = Mame
					emuExt = exe
					romPath = F:\New folder\Roms\MAME
					romPathFromIni = F:\New folder\Roms\MAME
					romExtension = .zip
					romExtensionOrig = .zip
					romExtensions = zip
					executable = Mameui64.exe
					systemDbName = MAME
					systemName = MAME
					dbPath =
					dbName = 005
					dbExt =
					romName = 005
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = F:\New folder\Hyperspin\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = F:\New folder\Hyperspin\RocketLauncher.log
					logLevel = 3
					logShowDebugConsole = false
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = true
					rlDebugConsoleStdout =
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 2560
					originalHeight = 1440
					vdEnabled = false
					vdFullPath =
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = F:\New folder\Hyperspin\Profiles\LEDBlinky
					ledblinkyRLProfile = F:\New folder\Hyperspin\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					launchPasswordHash = zQJHGuIBD6bt2rEoPola0Rbrl81Ci3lgdm1mxbcm+QfXe+SDPHV0ig==
					hideCursor = false
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1715|952
					fadeLyr4Y = 720|1596
					fadeLyr4W = 200
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = F:\New folder\Hyperspin\Media\Fade
					RLDataPath = F:\New folder\Hyperspin\Data
					RLMediaPath = F:\New folder\Hyperspin\Media
					RLErrSoundPath = F:\New folder\Hyperspin\Media\Sounds\Error
					modulesPath = F:\New folder\Hyperspin\Modules
					moduleFullName = F:\New folder\Hyperspin\Modules\Mame\Mame.ahk
					moduleName = Mame
					modulePath = F:\New folder\Hyperspin\Modules\Mame
					moduleExtension = ahk
					moduleExtensionsPath = F:\New folder\Hyperspin\Module Extensions
					libPath = F:\New folder\Hyperspin\Lib
					7zEnabled = false
					7zPath = F:\New folder\Hyperspin\Module Extensions\7z.exe
					7zDllPath = F:\New folder\Hyperspin\Module Extensions\7z.dll
					7zExtractPath = F:\New folder\Hyperspin\Extract
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = false
					pauseKey = ~NumpadAdd
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = F:\New folder\Hyperspin\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = F:\New folder\Utilities\Xpadder\xpadder.exe
					joyToKeyFullPath = F:\New folder\Utilities\JoyToKey\JoyToKey.exe
					keymapperProfilePath = F:\New folder\Hyperspin\Profiles\xpadder
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal =
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = F:\New folder\Hyperspin\Profiles\xpadder\HyperSpin
					defaultProfile = F:\New folder\Hyperspin\Profiles\xpadder\_Default
					systemProfile = F:\New folder\Hyperspin\Profiles\xpadder\MAME
					xPadderSystemProfile = F:\New folder\Hyperspin\Profiles\xpadder\MAME\_Default
					emuProfile = F:\New folder\Hyperspin\Profiles\xpadder\MAME\Mame
					romProfile = F:\New folder\Hyperspin\Profiles\xpadder\MAME\005
					RocketLauncherProfile = F:\New folder\Hyperspin\Profiles\xpadder\RocketLauncher
					blankProfile = F:\New folder\Hyperspin\Profiles\xpadder\_Default\blank
					ahkFEProfile = F:\New folder\Hyperspin\Profiles\AHK\HyperSpin
					ahkDefaultProfile = F:\New folder\Hyperspin\Profiles\AHK\_Default
					ahkSystemProfile = F:\New folder\Hyperspin\Profiles\AHK\MAME
					ahkEmuProfile = F:\New folder\Hyperspin\Profiles\AHK\MAME\Mame
					ahkRomProfile = F:\New folder\Hyperspin\Profiles\AHK\MAME\005
					ahkRocketLauncherProfile = F:\New folder\Hyperspin\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = F:\New folder\Hyperspin\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = F:\New folder\Hyperspin\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = F:\New folder\Hyperspin\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = F:\New folder\Hyperspin\Lib\User Fade Animations.ini
19:51:35:420 | RL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
19:51:35:420 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
19:51:35:421 | RL |     INFO  | +15    | BuildScript - Loaded User Functions Init.ahk script
19:51:35:421 | RL |     INFO  | +0     | BuildScript - Validating module
19:51:35:422 | RL |     INFO  | +0     | BuildScript - Validation complete
19:51:35:422 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = MAME
					MEmuV =  v0.161
					MURL = http://www.mame.net/
					MAuthor = djvj
					MVersion = 2.1.14
					MCRC = 7B006C89
					iCRC = CA5CEF4B
					MID = 635038268903403479
					MSystem = "AAE","Atari Classics","Cave","Capcom","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Data East Classics","Konami Classics","LaserDisc","MAME","Midway Classics","Namco Classics","Namco System 22","Nintendo Arcade Systems","Nintendo Classics","Sega Classics","Sega Model 1","Sega ST-V","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","Taito Classics"
					; Notes:
					; No need to edit mame.ini and set your rom folder, module sends the rompath for you.
					; Command Line Options - http://easyemu.mameworld.info/mameguide/mameguide-options.html
					; High Scores DO NOT SAVE when cheats are enabled!
					; HLSL Documentation: http://mamedev.org/source/docs/hlsl.txt.html
					; If you use MAME for AAE, create a vector.ini in mame's ini subfolder and paste these HLSL settings in there: http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=309968&page=&view=&sb=5&o=&vc=1
					; Bezels:
					; Module settings control whether RocketLauncher or MAME bezels are shown
					; In the bezel normal mode only RocketLauncher Bezels will be show and the MAME use_bezels option will be forced disbaled
					; In the bezel layout mode, RocketLauncher Bezels will be drawn only when you do not have a layout file on your MAME folders for the current game
					; ServoStik:
					; The module will automatically control any connected ServoStiks found on the system.
					; It does this by reading the xml info from MAME. If that XML info has directional info at 4 or less, 4-way mode will be enabled. All others get 8-way mode.
					; Ini Files:
					; Module will set most settings through command line which will override any settings you might have on your MAME ini files. Everything else will be read from
					; those. MAME supports a hierarchical ini file structure and will load settings from several ini files following a specific order:
					;- mame.ini
					;- <mymame>.ini (i.e. if MAME was renamed mame060.exe, MAME parses mame060.ini here)
					;- debug.ini (if the debugger is enabled)
					;- <parent>.ini (for clones only, may be called recursively)
					;- <gamename>.ini
					;- vertical.ini (for games with vertical monitor orientation)
					;- horizont.ini (for games with horizontal monitor orientation)
					;- vector.ini (for vector games only)
					;- <driver>.ini (based on the source filename of the driver)
					; The settings in the later ini's override those in the earlier ini's.
					; It's highly recommended that you set skipchecks to 'Rom Only" for MAME otherwise RocketLauncher won't be able to launch several games due
					; to the way MAME roms are packaged. This will be even more noticeable for those using merged sets.
					StartModule()
					BezelGUI()
					FadeInStart()
					legacyMode := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "LegacyMode","false",,1)
					hlsl := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "HLSL","false",,1)
					glsl := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "GLSL","false",,1)
					bezelMode := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "BezelMode","layout",,1)	; "layout" or "normal"
					Videomode := IniReadCheck(settingsFile, "Settings", "Videomode","d3d",,1)
					pauseMethod := IniReadCheck(settingsFile, "Settings", "PauseMethod",1,,1)	; set the pause method that works better on your machine (preferred methods 1 and 2) 1 = Win7 and Win8 OK - Problems with Win XP, 2 = preferred method for WinXP - Problems in Win7, 3 and 4 = same as 1 and 2, 5 = only use If you have a direct input version of mame, 6 = suspend mame process method, it could crash mame in some computers
					verticalRotationMode := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "VerticalRotationMode","none",,1)
					cheatMode := IniReadCheck(settingsFile, "Settings", "CheatMode","false",,1)
					cheatModeKey := IniReadCheck(settingsFile, "Settings", "CheatModeKey",A_Space,,1)	; user defined key to be held down before launching a mame rom.
					sysParams := IniReadCheck(settingsFile, systemName, "Params", A_Space,,1)
					romParams := IniReadCheck(settingsFile, romName, "Params", A_Space,,1)
					mameRomName := IniReadCheck(settingsFile, romName, "MameRomName", A_Space,,1)
					Artwork_Crop := IniReadCheck(settingsFile, systemName . "|" . romName, "Artwork_Crop", "true",,1)
					Use_Bezels := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Bezels", "false",,1)
					Use_Overlays := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Overlays", "true",,1)
					Use_Backdrops := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Backdrops", "true",,1)
					Use_Cpanels := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Cpanels", "false",,1)
					Use_Marquees := IniReadCheck(settingsFile, systemName . "|" . romName, "Use_Marquees", "false",,1)
					autosave := IniReadCheck(settingsFile, systemName . "|" . romName, "Autosave", "false",,1)
					volume := IniReadCheck(settingsFile, "Settings|" . systemName . "|" . romName, "Volume",,,1)
					inipath := IniReadCheck(settingsFile, systemName, "IniPath", "",,1)
					artworkCrop := If (Artwork_Crop = "true") ? " -artwork_crop" : " -noartwork_crop"
					useBezels := If (Use_Bezels = "true") ? " -use_bezels" : " -nouse_bezels"
					useOverlays := If (Use_Overlays = "true") ? " -use_overlays" : " -nouse_overlays"
					useBackdrops := If (Use_Backdrops = "true") ? " -use_backdrops" : " -nouse_backdrops"
					UseCpanels := If (Use_Cpanels = "true") ? " -use_cpanels" : " -nouse_cpanels"
					UseMarquees := If (Use_Marquees = "true") ? " -use_marquees" : " -nouse_marquees"
					; Get MAME version from executable, this is needed since some CLI switches are not available in older MAME versions
					exeAtrib := FileGetVersionInfo_AW( EmuPath . "\" . executable, "FileVersion|ProductVersion", "|"  )
					Loop, Parse, exeAtrib, |%A_Tab%, %A_Space%
					 A_Index & 1 ? ( _ := A_LoopField ) : ( %_% := A_LoopField )
					If (ProductVersion)
						StringRight, MAMEVersion, ProductVersion, StrLen(ProductVersion) - 2
					Log("Detected MAME Product Version from '" . EmuPath . "\" . executable . "' is " . MAMEVersion)
					If inipath
						inipath := AbsoluteFromRelative(EmuPath, inipath)
					If (verticalRotationMode = "none")
						verticalRotationMode := ""
					hideEmuObj := Object(dialogOpen . " ahk_class ConsoleWindowClass",0,"ahk_class MAME",1)	;Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					; Process mame's ListXML for certain features
					If (bezelEnabled = "true" || servoStikEnabled != "false" || verticalRotationMode) {
						ListXMLObject := Object()
						ListXMLObject := ListXMLInfo(romName)
						If (bezelEnabled = "true") {
							If (bezelMode = "layout"){
								BezelStart("layout",ListXMLObject["Parent"].Value,ListXMLObject["Angle"].Value,romName)
							} Else { ;bezel mode = normal
								useBezels := " -nouse_bezels"   ; force disabling MAME built-in bezels
								BezelStart(,,ListXMLObject["Angle"].Value)
						If (servoStikEnabled != "false") {
							ServoStik(If ListXMLObject["Ways"].Value <= 4 ? 4 : 8)	; If "ways" in the xml is set to 4 or less, the servo will go into 4-way mode, else 8-way mode will be enabled
						If (verticalRotationMode && ListXMLObject["Angle"].Value) {
							If (verticalRotationMode = "original")
								verticalRotationMode := " -norotate"
							Else If (verticalRotationMode = "right")
								verticalRotationMode := " -ror"
							Else If (verticalRotationMode = "left")
								verticalRotationMode := " -rol"
							Else
						Else
					; -romload part of 147u2 that shows what roms were checked when missing roms
					winstate := If (Fullscreen = "true") ? "Hide UseErrorLevel" : "UseErrorLevel"
					fullscreen := If (Fullscreen = "true") ? " -nowindow" : " -window"
					If (Videomode = "opengl")
						hlsl := " -nohlsl_enable"
						If (MAMEVersion > 159)
							glsl := If glsl = "true" ? " -gl_glsl" : (If glsl = "ini" ? "" : " -nogl_glsl")
						Else
							glsl := ""
					Else
						hlsl := If hlsl = "true" ? " -hlsl_enable" : (If hlsl = "ini" ? "" : " -nohlsl_enable")
							glsl := If Videomode = "ini" ? "" : " -nogl_glsl"
						Else
							glsl := ""
						If (Videomode = "ini")
							Videomode := ""
					videomode := If (Videomode != "" ) ? " -video " . videomode : ""
					sysParams := If sysParams != ""  ? A_Space . sysParams : ""
					romParams := If romParams != ""  ? A_Space . romParams : ""
					autosave := If autosave = "true"  ? " -autosave" : ""
					volume := If volume != ""  ? " -volume " . volume : ""
					inipath := If inipath != "" ? " -inipath """ . inipath . """" : ""
					StringReplace,mameRomPaths,romPathFromIni,|,`"`;`",1	; replace all instances of | to ; in the Rom_Path from Emulators.ini so mame knows where to find your roms
					mameRomPaths := " -rompath """ .  (If mameRomName ? romPath : mameRomPaths) . """"	; if using an alt rom, only supply mame with the path to that rom so it doesn't try to use the original rom
					If InStr(romParams,"-rompath")
						ScriptError("""-rompath"" is defined as a parameter for " . romName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
					If InStr(sysParams,"-rompath")
						ScriptError("""-rompath"" is defined as a parameter for " . systemName . ". The MAME module fills this automatically so please remove this from Params in the module's settings.")
					If mameRomName {
						FileMove, %romPath%\%romName%%romExtension%, %romPath%\%mameRomName%%romExtension%	; rename rom to match what mame needs
						originalRomName := romName	; store romName from database so we know what to rename it back to later
						romName := mameRomName
						If ErrorLevel
							ScriptError("There was a problem renaming " . romName . "  to " . mameRomName . " in " . romPath . ". Please check you have write permission to this folder/file and you don't already have a file named """ . mameRomName . """ in your rom folder.",8)
						Else	; if rename was successful, set var so we know to move it back later
							fileRenamed = 1
					If cheatMode = true
					{	If (!FileExist(emuPath . "\cheat.zip") && !FileExist(emuPath . "\cheat.7z"))
							ScriptError("You have cheats enabled for " . MEmu . " but could not locate a ""cheat.zip"" or ""cheat.7z"" in " . emuPath)
						If cheatModeKey	; if user wants to use a key to enable CheatMode
							cheatEnabled := If XHotkeyAllKeysPressed(cheatModeKey) ? " -cheat" : ""	; only enables cheatMode when key is held down on launch
						Else	; no cheat mode key defined
							cheatEnabled := " -cheat"
					HideEmuStart()
					If legacyMode = true
						errLvl := Run(executable . A_Space . romName . fullscreen . cheatEnabled . volume . mameRomPaths . sysParams . romParams, emuPath, winstate)
					Else
						errLvl := Run(executable . A_Space . romName . fullscreen . hlsl . glsl . cheatEnabled . volume . inipath . verticalRotationMode . videomode . artworkCrop . useBezels . useOverlays . useBackdrops . UseCpanels . UseMarquees . mameRomPaths . sysParams . romParams . autosave, emuPath, winstate)
					If errLvl {
						If (errLvl = 1)
							Error = Failed Validity
						Else If(errLvl = 2)
							Error = Missing Files
						Else If(errLvl = 3)
							Error = Fatal Error
						Else If(errLvl = 4)
							Error = Device Error
						Else If(errLvl = 5)
							Error = Game Does Not Exist
						Else If(errLvl = 6)
							Error = Invalid Config
						Else If errLvl in 7,8,9
							Error = Identification Error
						Else
							Error = MAME Error
						Log("MAME Error - " . Error,3)
					WinWait("ahk_class MAME")
					WinWaitActive("ahk_class MAME")
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					BezelExit()
					If fileRenamed {	; rename file back to alternate name for next launch
						FileMove, %romPath%\%romName%%romExtension%, %romPath%\%originalRomName%%romExtension%
						If ErrorLevel	; if rename was successful, set var so we know to move it back later
							ScriptError("There was a problem renaming " . romName . " back to " . originalRomName)
					FadeOutExit()
					ExitModule()
					ListXMLInfo(rom){ ; returns MAME/MESS info about parent rom, orientation angle, resolution
						Global emuFullPath, emuPath
						listXMLVarLog :=
						RunWait, % comspec . " /c " . """" . emuFullPath . """" . " -listxml " . rom . " > tempBezel.txt", %emuPath%, Hide
						Fileread, ListxmlContents, %emuPath%\tempBezel.txt
						RegExMatch(ListxmlContents, "s)<game.*name=" . """" . rom . """" . ".*" . "cloneof=" . """" . "[^""""]*", parent)
						RegExMatch(parent,"cloneof=" . """" . ".*", parent)
						RegExMatch(parent,"""" . ".*", parent)
						StringTrimLeft, parent, parent, 1
						RegExMatch(ListxmlContents, "s)<display.*rotate=" . """" . "[0-9]+" . """", angle)
						RegExMatch(angle,"[0-9]+", angle, "-6")
						RegExMatch(ListxmlContents, "s)<display.*width=" . """" . "[0-9]+" . """", width)
						RegExMatch(width,"[0-9]+", width, "-6")
						RegExMatch(ListxmlContents, "s)<display.*height=" . """" . "[0-9]+" . """", Height)
						RegExMatch(Height,"[0-9]+", Height, "-6")
						RegExMatch(ListxmlContents, "s)<control.*ways=" . """" . "[0-9]+" . """", Ways)
						RegExMatch(Ways,"[0-9]+", Ways, "-6")
						logVars := "Parent|Angle|Height|Width|Ways"
						Loop, Parse, logVars, |
							currentobj:={}
							currentobj.Label := A_Loopfield
							currentobj.Value := %A_Loopfield%
							ListXMLObject.Insert(currentobj["Label"], currentobj)
							listXMLLog .= "`r`n`t`t`t`t`t" . currentobj["Label"] . " = " . currentobj["Value"]
						Log("Module - MAME ListXML values: " . listXMLLog,5)
						If (ListXMLObject["Height"].Value > ListXMLObject["Width"].Value) {
							ListXMLObject["Angle"].Value := true
							Log("Module - This game's height is greater than its width, forcing vertical mode",5)
						FileDelete, %emuPath%\tempBezel.txt
						Return ListXMLObject
					HaltEmu:
						If pauseMethod = 1
						{	disableSuspendEmu = true
							disableRestoreEmu = true
							PostMessage,0x211, 1, , , ahk_class MAME
						} Else If pauseMethod = 2
						} Else If pauseMethod = 3
							PostMessage,% 0x0400+6, 1, , , ahk_class MAME
						} Else If pauseMethod = 4
						} Else If pauseMethod = 5
							Send, {P down}
							Sleep, 1000
							Send, {P up}
					Return
					RestoreEmu:
						If pauseMethod = 1
						{	PostMessage,0x212, 1, , , ahk_class MAME
							WinActivate, ahk_class MAME
						{	PostMessage,% 0x0400+6, 0, , , ahk_class MAME
							Send, {P down}
							Sleep, 1000
							Send, {P up}
						} Else If pauseMethod = 6
					Return
					CloseProcess:
						FadeOutStart()
						WinClose("ahk_class MAME")
					Return
19:51:35:430 | RL |     INFO  | +0     | BuildScript - Loaded Multi-Player scripts
19:51:35:431 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
19:51:35:431 | RL |     INFO  | +0     | BuildScript - Loaded User Functions.ahk script
19:51:35:431 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
19:51:35:432 | RL |     INFO  | +0     | Main - Module is built
19:51:35:432 | RL |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\AutoHotkey.dll exists
19:51:35:433 | RL |     INFO  | +0     | Main - Running module
19:51:35:532 | MD |     INFO  | +N/A   | Module initialized
19:51:35:533 | MD |     INFO  | +0     | StartModule - Started
19:51:35:533 | MD |     INFO  | +0     | StartModule - MEmu: MAME
					MEmuV: v0.161
					MURL: http://www.mame.net/
					MAuthor: djvj
					MVersion: 2.1.14
					MCRC: 7B006C89
					iCRC: CA5CEF4B
					MID:
					MSystem: "AAE","Atari Classics","Cave","Capcom","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Data East Classics","Konami Classics","LaserDisc","MAME","Midway Classics","Namco Classics","Namco System 22","Nintendo Arcade Systems","Nintendo Classics","Sega Classics","Sega Model 1","Sega ST-V","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","Taito Classics"
19:51:35:533 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "MAME"
19:51:35:534 | MD |     INFO  | +0     | PluginInit - Started
19:51:35:534 | MD |     INFO  | +0     | CheckFile - Checking if F:\New folder\Hyperspin\Databases\MAME\MAME.xml exists
19:51:35:602 | MD |     INFO  | +62    | PluginInit - Ended
19:51:35:603 | MD |     INFO  | +0     | StartModule - Ended
19:51:35:603 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
19:51:35:603 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
19:51:35:603 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
19:51:35:603 | MD |     INFO  | +0     | Module Setting - [Settings] - LegacyMode: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [MAME] - LegacyMode: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [005] - LegacyMode: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [Settings] - HLSL: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [MAME] - HLSL: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [005] - HLSL: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [Settings] - GLSL: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [MAME] - GLSL: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [005] - GLSL: false
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [Settings] - BezelMode: normal
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [MAME] - BezelMode: normal
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [005] - BezelMode: normal
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [Settings] - Videomode: d3d
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [Settings] - PauseMethod: 4
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [Settings] - VerticalRotationMode: none
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [MAME] - VerticalRotationMode: none
19:51:35:604 | MD |     INFO  | +0     | Module Setting - [005] - VerticalRotationMode: none
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [Settings] - CheatMode: true
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [Settings] - CheatModeKey: Z&X
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [MAME] - Params:
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [005] - Params:
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [005] - MameRomName:
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [MAME] - Artwork_Crop: true
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [005] - Artwork_Crop: true
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Bezels: false
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [005] - Use_Bezels: false
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Overlays: true
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [005] - Use_Overlays: true
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Backdrops: true
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [005] - Use_Backdrops: true
19:51:35:605 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Cpanels: false
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [005] - Use_Cpanels: false
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [MAME] - Use_Marquees: false
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [005] - Use_Marquees: false
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [MAME] - Autosave: false
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [005] - Autosave: false
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [Settings] - Volume:
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [MAME] - Volume:
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [005] - Volume:
19:51:35:606 | MD |     INFO  | +0     | Module Setting - [MAME] - IniPath:
19:51:35:606 | MD |     INFO  | +0     | Detected MAME Product Version from 'F:\New folder\Hyperspin\Emulators\MameUI64\Mameui64.exe' is 149
19:51:35:606 | MD |     INFO  | +0     | Run - Running: F:\New folder\Hyperspin\Emulators\MameUI64\Mameui64.exe 005 -nowindow -nohlsl_enable -video d3d -artwork_crop -nouse_bezels -use_overlays -use_backdrops -nouse_cpanels -nouse_marquees -rompath "F:\New folder\Roms\MAME"
19:51:35:641 | MD |     INFO  | +47    | WinWait - Waiting for "ahk_class MAME"
19:51:36:624 | MD |     INFO  | +985   | WinWaitActive - Waiting for "ahk_class MAME"
19:51:36:741 | MD |     INFO  | +109   | Process - WaitClose Mameui64.exe
19:51:48:917 | MD |     INFO  | +12172 | WinClose - Closing: ahk_class MAME
19:51:49:315 | MD |     INFO  | +406   | StopGlobalUserFeatures - Starting
19:51:49:315 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
19:51:49:315 | MD |     INFO  | +0     | ExitModule - Started
19:51:49:315 | MD |     INFO  | +0     | Starting Updating Statistics:
19:51:49:412 | MD |     INFO  | +94    | Game section statistics updated.
19:51:49:415 | MD |     INFO  | +0     | ExitModule - Ended
19:51:49:415 | MD |     INFO  | +0     | End of Module Logs
19:51:49:474 | RL |     INFO  | +14047 | Main - Module ended, exiting RocketLauncher normally
19:51:49:474 | RL |     INFO  | +0     | ExitScript - Started
19:51:49:483 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
19:51:49:489 | RL |     INFO  | +16    | ExitScript - Ended
[/code]
HS
07:45:04 PM |  HyperSpin Started
07:45:04 PM |  Going windowed mode
07:45:04 PM |  Checking for updates
07:45:04 PM |  Update Check Complete
07:45:04 PM |  Startup program: HyperSpin Startup Script.exe
07:45:04 PM |  Startup params not set
07:45:04 PM |  Working directory: F:\New folder\Hyperspin\Utilities\Startup Script\
07:45:05 PM |  Window State: NORMAL
07:45:05 PM |  Launching HyperSpin Startup Script.exe
07:45:05 PM |  Command Line is HyperSpin Startup Script.exe
07:45:05 PM |  Playing intro video
07:45:07 PM |  Error intializing joysticks
07:45:07 PM |  Menu Mode is multi
07:45:08 PM |  Loading Main Menu.xml
07:45:08 PM |  Main Menu.xml successfully loaded
07:45:08 PM |  Main Menu wheel loaded successfully
07:45:38 PM |  Loading MAME.xml
07:45:39 PM |  Main Menu.xml successfully loaded
07:45:40 PM |  MAME wheel loaded successfully
07:45:47 PM |  Launching Game
07:45:47 PM |  Using HyperLaunch
07:45:47 PM |  Getting HyperLaunch path
07:45:47 PM |  HyperLaunch located at F:\New folder\Hyperspin\HyperLaunch.exe
07:45:47 PM |  Running HyperLaunch.exe
07:45:47 PM |  HyperLaunch Command Line is: F:\New folder\Hyperspin\HyperLaunch.exe "MAME" "1941j"
07:47:50 PM |  Launching Game
07:47:50 PM |  Using HyperLaunch
07:47:50 PM |  Getting HyperLaunch path
07:47:50 PM |  HyperLaunch located at F:\New folder\Hyperspin\HyperLaunch.exe
07:47:50 PM |  Running HyperLaunch.exe
07:47:51 PM |  HyperLaunch Command Line is: F:\New folder\Hyperspin\HyperLaunch.exe "MAME" "1941j"
07:47:52 PM |  Launching Game
