RetroArch NES and SNES crashes when started from HyperSpin
kaczawara
Hi for all of you, I hope there's a way to fix my problem.
I started to do some tests of HS on 64 bit win 7 and all is working ok, problems started when I changed to win XP Prof 32bit.
What ever I do, on any RetroArch version it keeps crashing after HS/RL starts it, when i start it manualy it works.
During one test I didn't copy the *.cfg files from RetroArch config catalogue, it said those are missing. After adding them the crushing started (maybe this will help to determin what's happening).
I'm adding some logs from troubleshooting:
[code]
00:29:58:218 | RL |     INFO  | +N/A   | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com)
00:29:58:546 | RL |     INFO  | +328   | Main - System Specs:
					RocketLauncher Dir: C:\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows XP Professional
					SKU:
					Total Memory: 1983.48 MB
					Free Memory: 1574.82 MB
					Used Memory: 408.664 MB
					SystemType: 32-bit
					Physical Processors: See Logical in XP
					Logical Processors: 1
					GPU 1 Name: SiS Mirage Graphics
					GPU 1 RAM: 64.00 MB
					GPU 1 Driver Version: 6.14.10.3680
					Sound 1 Device: Realtek AC'97 Audio
					Sound 1 Status: Enabled
					OS Language: Polish
					OS Admin Status: Yes
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1024x768 (1024x738 work) [Landscape] (Primary)
					Current AHK Desktop Width: 1024
					Current AHK Desktop Height: 768
					AutoHotkey Path:
					AHK Version: 1.1.09.04
					Unicode: No
00:29:58:546 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\RocketLauncher.exe exists
00:29:58:546 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.0.1.3
					LegalCopyright          	?2015 RocketLauncher
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2061824 bytes
					Created:			9/13/2015 - 10:42:51
					Modified:			9/13/2015 - 11:53:17
00:29:58:546 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\BinHexRW.ahk exists
00:29:58:562 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:562 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4961 bytes
					Created:			9/13/2015 - 10:43:03
					Modified:			8/17/2015 - 11:04:56
00:29:58:562 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\BlockInput.exe exists
00:29:58:578 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Modified:			8/17/2015 - 11:04:58
00:29:58:578 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\CLR_L.ahk exists
00:29:58:578 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:29:58:578 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5474 bytes
					Created:			9/13/2015 - 11:53:07
					Modified:			9/13/2015 - 11:53:08
00:29:58:578 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\Control_AniGif.ahk exists
					File Size:			5716 bytes
00:29:58:593 | RL |     INFO  | +16    | CheckFile - Checking if C:\RocketLauncher\Module Extensions\gdip.ahk exists
00:29:58:593 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:29:58:593 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
00:29:58:609 | RL |     INFO  | +15    | CheckFile - Checking if C:\RocketLauncher\Module Extensions\gdip_alt.ahk exists
00:29:58:609 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:609 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5895 bytes
					Created:			9/13/2015 - 10:43:04
00:29:58:625 | RL |   DEBUG1  | +16    | gdip_alt.ahk Version: 1.0.2
00:29:58:625 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\gsdll32.dll exists
00:29:58:625 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			13090816 bytes
					Modified:			8/17/2015 - 11:05:02
00:29:58:640 | RL |     INFO  | +16    | CheckFile - Checking if C:\RocketLauncher\Module Extensions\itextsharp.dll exists
00:29:58:640 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			9/13/2015 - 10:43:05
00:29:58:656 | RL |     INFO  | +15    | CheckFile - Checking if C:\RocketLauncher\Module Extensions\Java.ahk exists
00:29:58:656 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:671 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			7841 bytes
00:29:58:671 | RL |   DEBUG1  | +0     | Java.ahk Version: 1.0.0
00:29:58:671 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\JSON.ahk exists
00:29:58:671 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:29:58:687 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			9203 bytes
00:29:58:687 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\Origin.ahk exists
00:29:58:687 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:687 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
00:29:58:703 | RL |   DEBUG1  | +15    | Origin.ahk Version: 1.0.2
00:29:58:703 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\RegRW64.ahk exists
00:29:58:703 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:29:58:718 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			6915 bytes
00:29:58:718 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\RIni.ahk exists
00:29:58:734 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
00:29:58:734 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			67561 bytes
00:29:58:734 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
00:29:58:750 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.4841.31212
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.4841.31212
					CompanyName             	Markovtsev Vadim
					File Size:			165888 bytes
00:29:58:765 | RL |     INFO  | +16    | CheckFile - Checking if C:\RocketLauncher\Module Extensions\Steam.ahk exists
00:29:58:765 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:765 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			5347 bytes
					Modified:			8/17/2015 - 11:05:04
00:29:58:781 | RL |   DEBUG1  | +15    | Steam.ahk Version: 1.0.2
00:29:58:781 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\VA.ahk exists
00:29:58:781 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
00:29:58:781 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
00:29:58:796 | RL |     INFO  | +16    | CheckFile - Checking if C:\RocketLauncher\Module Extensions\VA_Extension.ahk exists
00:29:58:796 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:796 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
00:29:58:812 | RL |   DEBUG1  | +16    | VA_Extension.ahk Version: 1.0.1
00:29:58:812 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\7z.ahk exists
00:29:58:812 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:812 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			29013 bytes
					Created:			9/13/2015 - 10:43:16
					Modified:			9/13/2015 - 11:52:23
00:29:58:828 | RL |   DEBUG1  | +15    | 7z.ahk Version: 1.0.1
00:29:58:828 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Bezel.ahk exists
00:29:58:843 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:843 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			102587 bytes
					Modified:			8/17/2015 - 11:04:32
00:29:58:843 | RL |   DEBUG1  | +0     | Bezel.ahk Version: 1.1.2
00:29:58:843 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Fade.ahk exists
00:29:58:843 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			37849 bytes
					Modified:			9/13/2015 - 11:52:25
00:29:58:859 | RL |   DEBUG1  | +15    | Fade.ahk Version: 1.1.1
00:29:58:859 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Fade Init.ahk exists
00:29:58:859 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:875 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			999 bytes
00:29:58:875 | RL |   DEBUG1  | +0     | Fade Init.ahk Version: 1.0.1
00:29:58:875 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Fade Animations.ahk exists
00:29:58:890 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:890 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			79882 bytes
					Modified:			9/13/2015 - 11:52:27
00:29:58:890 | RL |   DEBUG1  | +0     | Fade Animations.ahk Version: 1.1.8
00:29:58:890 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Pause.ahk exists
00:29:58:921 | RL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:921 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			392698 bytes
					Modified:			9/13/2015 - 11:53:18
00:29:58:921 | RL |   DEBUG1  | +0     | Pause.ahk Version: 1.1.4
00:29:58:921 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Pause Init.ahk exists
00:29:58:921 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
					File Size:			553 bytes
					Modified:			9/13/2015 - 11:52:22
00:29:58:937 | RL |   DEBUG1  | +16    | Pause Init.ahk Version: 1.0.3
00:29:58:937 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Keymapper.ahk exists
00:29:58:937 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:937 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			33453 bytes
					Modified:			8/17/2015 - 11:04:34
00:29:58:953 | RL |   DEBUG1  | +15    | Keymapper.ahk Version: 1.1.2
00:29:58:953 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Keymapper Init.ahk exists
00:29:58:953 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:953 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3461 bytes
00:29:58:968 | RL |   DEBUG1  | +16    | Keymapper Init.ahk Version: 1.0.4
00:29:58:968 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\MultiGame.ahk exists
00:29:58:984 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:58:984 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			40753 bytes
					Modified:			9/13/2015 - 11:52:56
00:29:58:984 | RL |   DEBUG1  | +0     | MultiGame.ahk Version: 1.0.8
00:29:58:984 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\MultiGame Init.ahk exists
00:29:58:000 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			161 bytes
00:29:59:000 | RL |   DEBUG1  | +0     | MultiGame Init.ahk Version: 1.0.0
00:29:59:000 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\MultiPlayer.ahk exists
00:29:59:015 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:015 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			58770 bytes
00:29:59:015 | RL |   DEBUG1  | +0     | MultiPlayer.ahk Version: 1.0.6
00:29:59:015 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Password.ahk exists
00:29:59:031 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:031 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			10025 bytes
					Modified:			9/13/2015 - 11:52:19
00:29:59:031 | RL |   DEBUG1  | +0     | Password.ahk Version: 1.0.2
00:29:59:031 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
00:29:59:046 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:046 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			73772 bytes
00:29:59:046 | RL |   DEBUG1  | +0     | Rom Mapping Launch Menu.ahk Version: 1.0.5
00:29:59:062 | RL |     INFO  | +16    | CheckFile - Checking if C:\RocketLauncher\Lib\Shared.ahk exists
00:29:59:062 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:062 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			116503 bytes
					Modified:			9/13/2015 - 11:53:01
00:29:59:078 | RL |   DEBUG1  | +15    | Shared.ahk Version: 1.3.2
00:29:59:078 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Statistics.ahk exists
00:29:59:078 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:078 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26143 bytes
00:29:59:093 | RL |   DEBUG1  | +16    | Statistics.ahk Version: 1.0.3
00:29:59:093 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Statistics Init.ahk exists
00:29:59:093 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:109 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			33 bytes
00:29:59:109 | RL |   DEBUG1  | +0     | Statistics Init.ahk Version: 1.0.1
00:29:59:109 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\Virtual Drive.ahk exists
00:29:59:109 | RL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:125 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			17070 bytes
					Modified:			9/13/2015 - 11:53:07
00:29:59:125 | RL |   DEBUG1  | +0     | Virtual Drive.ahk Version: 1.0.1
00:29:59:125 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\XHotkey.ahk exists
00:29:59:140 | RL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:140 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			26540 bytes
					Modified:			9/13/2015 - 11:53:03
00:29:59:140 | RL |   DEBUG1  | +0     | XHotkey.ahk Version: 1.0.4
00:29:59:140 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Lib\XHotkey Init.ahk exists
00:29:59:156 | RL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Library.
00:29:59:156 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			1063 bytes
					Modified:			9/13/2015 - 11:52:09
00:29:59:156 | RL |   DEBUG1  | +0     | XHotkey Init.ahk Version: 1.0.2
00:29:59:156 | RL |   DEBUG1  | +0     | Main - Raw CLI received: "-s Nintendo Entertainment System -r 3-D WorldRunner (USA) -f C:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1"
00:29:59:171 | RL |   DEBUG1  | +16    | Main - Received this dbName with no path via CLI: "3-D WorldRunner (USA)"
00:29:59:171 | RL |   DEBUG1  | +0     | Main - dbName: 3-D WorldRunner (USA)
00:29:59:171 | RL |     INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
00:29:59:171 | RL |     INFO  | +0     | Main - RocketLauncher received "Nintendo Entertainment System" and "3-D WorldRunner (USA)"
00:29:59:203 | RL |     INFO  | +31    | Main - Did not find a "C:\RocketLauncher\Settings\Nintendo Entertainment System\Game Options.ini" file, skipping any game-specific options.
00:29:59:203 | RL |     INFO  | +0     | Main - 3-D WorldRunner (USA) is using the default emulator: RetroArch
00:29:59:203 | RL |     INFO  | +0     | Main - Checking for a [RetroArch] section in C:\RocketLauncher\Settings\Nintendo Entertainment System\Emulators.ini
00:29:59:203 | RL |     INFO  | +0     | Main - Checking for a [RetroArch] section in C:\RocketLauncher\Settings\Global Emulators.ini
00:29:59:203 | RL |     INFO  | +0     | Main - Found [RetroArch] in C:\RocketLauncher\Settings\Global Emulators.ini
00:29:59:218 | RL |     INFO  | +16    | CheckFile - Checking if C:\RocketLauncher\Modules\RetroArch\RetroArch.ahk exists
00:29:59:218 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			45379 bytes
					Created:			9/13/2015 - 10:42:57
					Modified:			9/13/2015 - 11:52:32
00:29:59:218 | RL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
00:29:59:218 | RL |     INFO  | +0     | Main - 3-D WorldRunner (USA) will use module: C:\RocketLauncher\Modules\RetroArch\RetroArch.ahk
00:29:59:265 | RL |     INFO  | +47    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
00:29:59:265 | RL |     INFO  | +0     | CheckFile - Checking if C:\Emulators\RetroArch\retroarch.exe exists
00:29:59:281 | RL |   DEBUG1  | +15    | CheckFile - Attributes:
					File Size:			1509390 bytes
					Created:			9/20/2015 - 12:02:59
					Modified:			7/5/2015 - 2:47:58
00:29:59:281 | RL |     INFO  | +0     | Main - INI Keys read
00:29:59:281 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.exe exists
00:29:59:281 | RL |   DEBUG1  | +0     | CheckFile - Attributes:
					FileVersion             	9.20
					InternalName            	7z
					ProductVersion          	9.20
					File Size:			163840 bytes
00:29:59:281 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\Module Extensions\7z.dll exists
					FileVersion             	9.20
					InternalName            	7za
					ProductVersion          	9.20
					File Size:			914432 bytes
					Created:			9/13/2015 - 10:43:00
00:29:59:281 | RL |     INFO  | +0     | Main - "3-D WorldRunner (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side
00:29:59:296 | RL |     INFO  | +16    | CheckPaths - Started
00:29:59:296 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).7z
00:29:59:296 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).7z
00:29:59:296 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:296 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).zip
00:29:59:296 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).zip
00:29:59:312 | RL |   DEBUG1  | +16    | CheckPaths - Rom not found
00:29:59:312 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).sfc
00:29:59:312 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).sfc
00:29:59:312 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:312 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).gba
00:29:59:328 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).gba
00:29:59:328 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:328 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).gb
00:29:59:328 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).gb
00:29:59:343 | RL |   DEBUG1  | +16    | CheckPaths - Rom not found
00:29:59:343 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).a78
00:29:59:343 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).a78
00:29:59:343 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:343 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).sv
00:29:59:343 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).sv
00:29:59:359 | RL |   DEBUG1  | +15    | CheckPaths - Rom not found
00:29:59:359 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).gbc
00:29:59:359 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).gbc
00:29:59:359 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:359 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).rpk
00:29:59:375 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).rpk
00:29:59:375 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:375 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).gme
00:29:59:375 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).gme
00:29:59:375 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).sc
00:29:59:390 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).sc
00:29:59:390 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:390 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).cdt
00:29:59:390 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).cdt
00:29:59:390 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).ws
00:29:59:406 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).ws
00:29:59:406 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:406 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).wsc
00:29:59:406 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).wsc
00:29:59:406 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).ngp
00:29:59:421 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).ngp
00:29:59:421 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:421 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).ngc
00:29:59:421 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).ngc
00:29:59:437 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).vms
00:29:59:437 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).vms
00:29:59:437 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:437 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).ipf
00:29:59:437 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).ipf
00:29:59:453 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).n64
00:29:59:453 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).n64
00:29:59:453 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:453 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).z64
00:29:59:453 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).z64
00:29:59:468 | RL |   DEBUG1  | +16    | CheckPaths - Rom not found
00:29:59:468 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).sg
00:29:59:468 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).sg
00:29:59:468 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:468 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).fds
00:29:59:468 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).fds
00:29:59:484 | RL |   DEBUG1  | +15    | CheckPaths - Rom not found
00:29:59:484 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).caq
00:29:59:484 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).caq
00:29:59:484 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:484 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).vb
00:29:59:484 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).vb
00:29:59:500 | RL |   DEBUG1  | +16    | CheckPaths - Rom not found
00:29:59:500 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).vec
00:29:59:500 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).vec
00:29:59:500 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:500 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).wav
00:29:59:500 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).wav
00:29:59:515 | RL |   DEBUG1  | +16    | CheckPaths - Rom not found
00:29:59:515 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).cas
00:29:59:515 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).cas
00:29:59:515 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:515 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).min
00:29:59:531 | RL |   DEBUG1  | +15    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).min
00:29:59:531 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:531 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).int
00:29:59:531 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).int
00:29:59:531 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).rom
00:29:59:546 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).rom
00:29:59:546 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:546 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).tap
00:29:59:546 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).tap
00:29:59:546 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).tzx
00:29:59:562 | RL |   DEBUG1  | +16    | CheckPaths - Looking for rom by name in subfolder: C:\Roms\NES\3-D WorldRunner (USA)\3-D WorldRunner (USA).tzx
00:29:59:562 | RL |   DEBUG1  | +0     | CheckPaths - Rom not found
00:29:59:562 | RL |   DEBUG1  | +0     | CheckPaths - Looking for rom: C:\Roms\NES\3-D WorldRunner (USA).nes
00:29:59:562 | RL |     INFO  | +0     | CheckPaths - Found rom: C:\Roms\NES\3-D WorldRunner (USA).nes
00:29:59:562 | RL |   DEBUG1  | +0     | CheckPaths - Current romName: 3-D WorldRunner (USA)
00:29:59:562 | RL |   DEBUG1  | +0     | CheckPaths - Current romPath: C:\Roms\NES
00:29:59:578 | RL |   DEBUG1  | +15    | CheckPaths - Current romExtension: .nes
00:29:59:578 | RL |     INFO  | +0     | CheckPaths - Ended
00:29:59:578 | RL |     INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					DetectHiddenWindows, ON
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 10
					pluginPath = C:\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.0.1.3
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = C:\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = C:\HyperSpin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = C:
					exitEmulatorKey = ~Esc
					restoreFE = false
					exitScriptKey = ~q & ~s
					toggleCursorKey = ~e & ~t
					emuFullPath = C:\Emulators\RetroArch\retroarch.exe
					emuPath = C:\Emulators\RetroArch
					emuName = RetroArch
					emuExt = exe
					romPath = C:\Roms\NES
					romPathFromIni = C:\Roms\NES
					romExtension = .nes
					romExtensionOrig = .nes
					romExtensions = 7z|zip|sfc|gba|gb|a78|sv|gbc|rpk|gme|sc|cdt|ws|wsc|ngp|ngc|vms|ipf|n64|z64|sg|fds|caq|vb|vec|wav|cas|min|int|rom|tap|tzx|nes|col|nds|cpr|gg|pce|st2|sms|smc|lnx|md|32x|n64|a52|j64|cso|cue|iso|ccd|chd|bin
					executable = retroarch.exe
					systemDbName = Nintendo Entertainment System
					systemName = Nintendo Entertainment System
					dbPath =
					dbName = 3-D WorldRunner (USA)
					dbExt =
					romName = 3-D WorldRunner (USA)
					romMapPath =
					romMappingEnabled = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = false
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = C:\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					logFile = C:\RocketLauncher\RocketLauncher.log
					logLevel = 10
					logShowDebugConsole = true
					logIncludeModule = true
					logShowCommandWindow = false
					logCommandWindow = false
					rlDebugConsoleStdout = 7
					sysLang = Polish
					sysType = 32-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1024
					originalHeight = 768
					vdEnabled = false
					vdFullPath =
					vdUseSCSI = true
					vdDriveLetter =
					vdAddDrive = true
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkyFullPath =
					ledblinkyProfilePath = C:\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = C:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					emuIdleShutdown = 0
					hideCursor = false
					hideEmu = false
					hideFE = false
					fadeIn = false
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeBarNon7zProgressTime = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoManufacturer = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = C:\RocketLauncher\Media\Fade
					RLDataPath = C:\RocketLauncher\Data
					RLMediaPath = C:\RocketLauncher\Media
					RLErrSoundPath = C:\RocketLauncher\Media\Sounds\Error
					modulesPath = C:\RocketLauncher\Modules
					moduleFullName = C:\RocketLauncher\Modules\RetroArch\RetroArch.ahk
					moduleName = RetroArch
					modulePath = C:\RocketLauncher\Modules\RetroArch
					moduleExtension = ahk
					moduleExtensionsPath = C:\RocketLauncher\Module Extensions
					libPath = C:\RocketLauncher\Lib
					7zEnabled = false
					7zPath = C:\RocketLauncher\Module Extensions\7z.exe
					7zDllPath = C:\RocketLauncher\Module Extensions\7z.dll
					7zExtractPath = C:\Users\Jakub Piekielniak\AppData\Local\Temp\HS
					7zExtractPathOrig =
					7zAttachSystemName = false
					7zDelTemp = true
					7zSounds = true
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgOnLaunch = false
					pauseEnabled = false
					pauseKey = ~NumpadAdd
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = C:\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = C:\Utilities\Xpadder\xpadder.exe
					joyToKeyFullPath = C:\Utilities\JoyToKey\JoyToKey.exe
					keymapperProfilePath = C:\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfileName = RocketLauncherUI
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal =
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = C:\RocketLauncher\Profiles\xpadder\RocketLauncherUI
					defaultProfile = C:\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = C:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System
					xPadderSystemProfile = C:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\_Default
					emuProfile = C:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\RetroArch
					romProfile = C:\RocketLauncher\Profiles\xpadder\Nintendo Entertainment System\3-D WorldRunner (USA)
					RocketLauncherProfile = C:\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = C:\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncherUI
					ahkDefaultProfile = C:\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = C:\RocketLauncher\Profiles\AHK\Nintendo Entertainment System
					ahkEmuProfile = C:\RocketLauncher\Profiles\AHK\Nintendo Entertainment System\RetroArch
					ahkRomProfile = C:\RocketLauncher\Profiles\AHK\Nintendo Entertainment System\3-D WorldRunner (USA)
					ahkRocketLauncherProfile = C:\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = C:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					mon1O =
					pacDrivedllFile = C:\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = C:\RocketLauncher\Lib\User Fade Animations.ini
00:29:59:921 | RL |     INFO  | +344   | BuildScript - Loaded XHotkey Init.ahk scripts
00:29:59:937 | RL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
00:29:59:937 | RL |  WARNING  | +16    | BuildScript - "C:\RocketLauncher\Lib\User Functions Init.ahk" not found
00:29:59:937 | RL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
00:29:59:937 | RL |     INFO  | +0     | BuildScript - Validating module
00:29:59:953 | RL |     INFO  | +15    | BuildScript - Validation complete
00:29:59:953 | RL |     INFO  | +0     | BuildScript - Module:
					MEmu = RetroArch
					MEmuV =  v05-11-2015 Nightly
					MURL = http://themaister.net/retroarch.html
					MAuthor = djvj,zerojay
					MVersion = 2.3.2
					MCRC = C04B6C16
					iCRC = 42C3B552
					MID = 635038268922229162
					MSystem = "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System 2","Capcom Play System 3","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
					; Notes:
					; If the emu doesn't load and you get no error, usually this means the LibRetro DLL is not working!
					; Devs stated they will never add support for mounted images (like via DT)
					; Fullscreen is controlled via the module setting in RocketLauncherUI
					; This module uses the CLI version of RetroArch (retroarch.exe), not the GUI (retroarch-phoenix.exe).
					; The emu may make a mouse cursor appear momentarily during launch, MouseMove and hide_cursor seem to have no effect
					; Enable 7z support for archived roms
					; Available CLI options: https://github.com/PyroFilmsFX/iOS/blob/master/docs/retroarch.1
					; LibRetro DLLs:
					; LibRetro DLLs come with the emu, but here is another source for them: http://forum.themaister.net/
					; Whatever cores you decide to use, make sure they are extracted anywhere in your Emu_Path\cores folder. The module will find and load the default core unless you choose a custom one for each system.
					; You can find supported cores that Retroarch supports simply by downloading them from the "retroarch-phoenix.exe" or by visiting here: https://github.com/libretro/libretro.github.com/wiki/Supported-cores
					; Some good discussion on cores and filters: http://forum.themaister.net/viewtopic.php?id=270
					; SRM files:
					; srm are stored in a "srm" dir in the emu folder. Each system ran through retroarch gets its own folder inside srm
					; Save states:
					; Save states are stored in a "save" dir in the emu folder. Each system ran through retroarch gets its own folder inside save
					; Config files:
					; By default, the module looks for config files in a folder called config in the RetroArch folder. Example: C:\emus\RetroArch\config. You can change this folder to anything you like by changing the module's ConfigFolder setting in RocketLauncherUI.
					; RetroArch's global config file is called "retroarch.cfg". RetroArch will use a system cfg file named to match your System Name (example: Nintendo Entertainment System.cfg).
					; RetroArch will also load core config files named after the core name. Example: nestopia_libretro.cfg
					; This allows different settings globally, for each system, and for each core. If you want all systems to use the same retroarch.cfg, do not have any system or core cfg files, only have the retroarch.cfg.
					; If a core config exists, it takes precedence over the global config. And if a system config exists, it takes precedence over the core config.
					; MultiGame:
					; MultiGame support is currently only available for the Mednafen PSX core. Retroarch uses the same method as Mednafen to load multi-disc games. This method involves m3u playlists which are commonly used for music. The m3u files needed to load multi-disc games are generated for you by the module when you launch a multi-disc game and are saved to your corresponding rom directory. Due to m3u limitations, your multi-disc roms/images cannot be archived -- they must be unzipped. All single disc games can remain archived and you can still enable 7z under system settings. If you do not wish to use MultiGame support you can archive your roms/images and m3u generation will be skipped on launch.
					; The m3u files generated by the module contain a list of paths to all roms/images in the multi-disc set. Retroarch automatically loads the first path in the m3u so the first path will always be the disc you are loading. For example, Final Fantasy VII has 3 discs and if you load Disc 2 first, the order of the paths in the m3u will be disc 2, disc 3, disc 1. If you load Disc 3 first, the order will be disc 3, disc 1, disc 2. The module anticipates this and will load the correct disk, selected from the Pause/MultiDisk menus. However if you choose to manually use Retroarch's UI or disk swap keys to change discs, you will need to keep this in mind.
					; In order for RocketLauncher's MultiGame UI to swap discs, you must define Eject_Toggle_Key, Next_Disk_Key, and Previous_Disk_Key under global settings for the emulator in RocketLauncher. Because AHK and Retroarch use different naming conventions for some keyboard keys, it is best to use a letter, a number, or F1-F12.
					; MESS:
					; MESS BIOS roms should be placed in the system\mess folder
					; System Specific Notes:
					; Microsoft MSX/MSX2: Launch an MSX game and in the core options, set the console to be an MSX2 and it will play both just fine.
					; Nintendo Famicom Disk System - Requires disksys.rom be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Sega CD - Requires "bios_CD_E.bin", "bios_CD_J.bin", "bios_CD_U.bin" all be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Super Nintendo Entertainment System - requires split all 10 dsp# & st### roms all be placed in the folder you define as system_directory in the RetroArch's cfg. Many games, like Super Mario Kart require these.
					; NEC TurboGrafx-CD - Requires "syscard3.pce" be placed in the folder you define as system_directory in the RetroArch's cfg.
					; Nintendo Super Game Boy - Set the Module setting in RocketLauncherUI SuperGameBoy to true to enable a system or only a rom to use SGB mode. This is not needed if your systemName is set to the official name of "Nintendo Super Game Boy". Requires "sgb.boot.rom" and "Super Game Boy (World).sfc" to be placed in the folder you define as system_directory in the RetroArch's cfg. This is needed if you want to use Super game boy mode and color palettes. Also requires using the latest bsnes core. Not all games support SGB mode.
					; MAME: The nag screen patch has been removed from the MAME core as of some point in March. We will be investigating our options for this. For MAME-based systems, make sure to set 7z use to false as MAME needs zip files.
					; Sony PSP/PlayStation Minis: To avoid the dialog box complaining about ppge_atlas.zim, download it from https://github.com/libretro/libretro-ppsspp/blob/master/assets/ppge_atlas.zim and place it in your Retroarch/system/PPSSPP/ directory.
					StartModule()
					BezelGUI()
					FadeInStart()
					; Here we define all supported systems for this module. This object controls how the module reacts to different systems. RetroArch can play a lot of systems, but needs to know what system you want to run, so this module has to adapt.
					; 1 - Official System Name in RocketLauncher
					; 2 - Short name used only for easy referencing within module
					; 3 - Default core
					; 4 - The system ID MESS core recognizes
					Log("Module - Started building the " . MEmu . " object",4)
					mTypeVar=
						( LTrim
						AAE|LibRetro_AAE|mame_libretro
						Acorn BBC Micro|LibRetro_BBCB|mess_libretro|bbcb
						Amstrad CPC|LibRetro_CPC|mess_libretro|cpc464
						Amstrad GX4000|LibRetro_GX4K|mess_libretro|gx4000
						APF Imagination Machine|LibRetro_APF|mess_libretro|apfimag
						Apple IIGS|LibRetro_AIIGS|mess_libretro|apple2gs
						Applied Technology MicroBee|LibRetro_MBEE|mess_libretro|mbeeic
						Atari 2600|LibRetro_2600|stella_libretro|a2600
						Atari 5200|LibRetro_5200|mess_libretro|a5200
						Atari 7800|LibRetro_7800|prosystem_libretro|a7800
						Atari 8-bit|LibRetro_ATARI8|mess_libretro|a800
						Atari Classics|LibRetro_ACLS|mame_libretro
						Atari Jaguar|LibRetro_JAG|virtualjaguar_libretro|jaguar
						Atari Lynx|LibRetro_LYNX|handy_libretro|lynx
						Atari ST|LibRetro_ST|hatari_libretro
						Atari XEGS|LibRetro_XEGS|mess_libretro|xegs
						Bally Astrocade|LibRetro_BAST|mess_libretro|astrocde
						Bandai Gundam RX-78|LibRetro_BGRX|mess_libretro|rx78
						Bandai Super Vision 8000|LibRetro_SV8K|mess_libretro|sv8000
						Bandai Wonderswan|LibRetro_WSAN|mednafen_wswan_libretro|wswan
						Bandai Wonderswan Color|LibRetro_WSANC|mednafen_wswan_libretro|wscolor
						Canon X07|LibRetro_CX07|mess_libretro|x07
						Capcom Classics|LibRetro_CAPC|mame_libretro
						Capcom Play System|LibRetro_CPS1|fba_cores_cps1_libretro
						Capcom Play System 2|LibRetro_CPS2|fba_cores_cps2_libretro
						Capcom Play System 3|LibRetro_CPS3|mame_libretro
						Casio PV-1000|LibRetro_CAS1K|mess_libretro|pv1000
						Casio PV-2000|LibRetro_CAS2K|mess_libretro|pv2000
						Cave|LibRetro_CAVE|mame_libretro
						Coleco ADAM|LibRetro_ADAM|mess_libretro|adam
						ColecoVision|LibRetro_COLEC|mess_libretro|coleco
						Commodore Amiga|LibRetro_PUAE|puae_libretro
						Commodore Max Machine|LibRetro_CMAX|mess_libretro|vic10
						Creatronic Mega Duck|LibRetro_DUCK|mess_libretro|megaduck
						Data East Classics|LibRetro_DATA|mame_libretro
						Dragon Data Dragon|LibRetro_DRAG64|mess_libretro|dragon64
						Elektronika BK|LibRetro_EBK|mess_libretro|bk0010
						Elektronska Industrija Pecom 64|LibRetro_P64|mess_libretro|pecom64
						Emerson Arcadia 2001|LibRetro_A2001|mess_libretro|arcadia
						Entex Adventure Vision|LibRetro_AVISION|mess_libretro|advision
						Epoch Game Pocket Computer|LibRetro_GPCKET|mess_libretro|gamepock
						Epoch Super Cassette Vision|LibRetro_SCV|mess_libretro|scv
						Exidy Sorcerer|LibRetro_SORCR|mess_libretro|sorcerer
						Fairchild Channel F|LibRetro_CHANF|mess_libretro|channelf
						Final Burn Alpha|LibRetro_FBA|fb_alpha_libretro
						Funtech Super Acan|LibRetro_SACAN|mess_libretro|supracan
						GamePark 32|LibRetro_GP32|mess_libretro|gp32
						GCE Vectrex|LibRetro_VECTX|mess_libretro|vectrex
						Hartung Game Master|LibRetro_GMASTR|mess_libretro|gmaster
						Interton VC 4000|LibRetro_VC4K|mess_libretro|vc4000
						Irem Classics|LibRetro_IREM|mame_libretro
						JungleTac Sport Vii|LibRetro_SPORTV|mess_libretro|vii
						Konami Classics|LibRetro_KONC|mame_libretro
						Magnavox Odyssey 2|LibRetro_ODYS2|mess_libretro|odyssey2
						MAME|LibRetro_MAME|mame_libretro
						Matra & Hachette Alice|LibRetro_ALICE|mess_libretro|alice32
						Mattel Aquarius|LibRetro_AQUA|mess_libretro|aquarius
						Mattel Intellivision|LibRetro_INTV|mess_libretro|intv
						MGT Sam Coupe|LibRetro_SAMCP|mess_libretro|
						Microsoft MS-DOS|LibRetro_MSDOS|dosbox_libretro
						Microsoft MSX|LibRetro_MSX|bluemsx_libretro
						Microsoft MSX2|LibRetro_MSX2|bluemsx_libretro
						Microsoft Windows 3.x|LibRetro_WIN3X|dosbox_libretro
						Midway Classics|LibRetro_MIDC|mame_libretro
						Namco Classics|LibRetro_NAMC|mame_libretro
						Namco System 22|LibRetro_NAM2|mame_libretro
						NEC PC Engine|LibRetro_PCE|mednafen_pce_fast_libretro|pce
						NEC PC Engine-CD|LibRetro_PCECD|mednafen_pce_fast_libretro|pce
						NEC PC-FX|LibRetro_PCFX|mednafen_pcfx_libretro
						NEC SuperGrafx|LibRetro_SGFX|mednafen_supergrafx_libretro|sgx
						NEC TurboGrafx-16|LibRetro_TG16|mednafen_pce_fast_libretro|tg16
						NEC TurboGrafx-CD|LibRetro_TGCD|mednafen_pce_fast_libretro|tg16
						Nintendo 64|LibRetro_N64|mupen64plus_libretro|n64
						Nintendo 64DD|LibRetro_N64|mupen64plus_libretro
						Nintendo Arcade Systems|LibRetro_NINARC|mame_libretro
						Nintendo Classics|LibRetro_NINC|mame_libretro
						Nintendo DS|LibRetro_DS|desmume_libretro
						Nintendo Entertainment System|LibRetro_NES|nestopia_libretro|nes
						Nintendo Famicom|LibRetro_NFAM|nestopia_libretro
						Nintendo Famicom Disk System|LibRetro_NFDS|nestopia_libretro|famicom
						Nintendo Game Boy|LibRetro_GB|gambatte_libretro|gameboy
						Nintendo Game Boy Advance|LibRetro_GBA|vba_next_libretro|gba
						Nintendo Game Boy Color|LibRetro_GBC|gambatte_libretro|gbcolor
						Nintendo Game Boy Japan|LibRetro_GBJ|gambatte_libretro|gameboy
						Nintendo Game & Watch|LibRetro_GW|gw_libretro
						Nintendo Pokemon Mini|LibRetro_POKE|mess_libretro|pokemini
						Nintendo Satellaview|LibRetro_NSFS|snes9x_libretro
						Nintendo SuFami Turbo|LibRetro_NSFST|snes9x_libretro
						Nintendo Super Famicom|LibRetro_NSF|bsnes_balanced_libretro
						Nintendo Super Game Boy|LibRetro_SGB|bsnes_balanced_libretro
						Nintendo Virtual Boy|LibRetro_NVB|mednafen_vb_libretro|vboy
						Othello Multivision|LibRetro_OTHO|genesis_plus_gx_libretro
						Panasonic 3DO|LibRetro_3DO|4do_libretro
						Philips CD-i|LibRetro_CDI|mess_libretro|cdimono1
						Philips Videopac|LibRetro_PVID|mess_libretro|videopac
						RCA Studio II|LibRetro_STUD2|mess_libretro|studio2
						SCUMMVM|LibRetro_SCUMM|scummvm_libretro
						Sega 32X|LibRetro_32X|picodrive_libretro|32x
						Sega CD|LibRetro_SCD|genesis_plus_gx_libretro|segacd
						Sega Classics|LibRetro_SEGC|mame_libretro
						Sega Game Gear|LibRetro_GG|genesis_plus_gx_libretro|gamegear
						Sega Genesis|LibRetro_GEN|genesis_plus_gx_libretro|genesis
						Sega Mark III|Libretro_SM3|genesis_plus_gx_libretro
						Sega Master System|LibRetro_SMS|genesis_plus_gx_libretro|sms
						Sega Mega Drive|LibRetro_GEN|genesis_plus_gx_libretro|megadriv
						Sega Mega Drive 32X|LibRetro_MD32X|picodrive_libretro
						Sega Pico|LibRetro_PICO|picodrive_libretro
						Sega Saturn|LibRetro_SAT|yabause_libretro
						Sega Saturn Japan|LibRetro_SAT|yabause_libretro
						Sega SC-3000|LibRetro_SC3K|mess_libretro|sc3000
						Sega SG-1000|LibRetro_SG1K|genesis_plus_gx_libretro
						Sega ST-V|LibRetro_STV|mame_libretro
						Sega VMU|LibRetro_SVMU|mess_libretro|svmu
						Sharp X1|LibRetro_SX1|mess_libretro|x1
						Sinclair ZX Spectrum|LibRetro_SPECZX|mess_libretro|spectrum
						SNK Classics|LibRetro_SNKC|mame_libretro
						SNK Neo Geo|LibRetro_NEO|fb_alpha_libretro
						SNK Neo Geo AES|LibRetro_NEOAES|mame_libretro|aes
						SNK Neo Geo CD|LibRetro_NEOCD|mess_libretro|neocdz
						SNK Neo Geo MVS|LibRetro_NEOMVS|mame_libretro
						SNK Neo Geo Pocket|LibRetro_NGP|mednafen_ngp_libretro|ngp
						SNK Neo Geo Pocket Color|LibRetro_NGPC|mednafen_ngp_libretro|ngpc
						Sony PlayStation|LibRetro_PSX|mednafen_psx_libretro|psx
						Sony PlayStation Minis|LibRetro_PSXMIN|ppsspp_libretro
						Sony PocketStation|LibRetro_POCKS|mess_libretro|pockstat
						Sony PSP|LibRetro_PSP|ppsspp_libretro
						Sord M5|LibRetro_SORD|mess_libretro|m5
						Spectravideo|LibRetro_SV328|mess_libretro|svi328n
						Super Nintendo Entertainment System|LibRetro_SNES|bsnes_balanced_libretro|snes
						Taito Classics|LibRetro_TAIC|mame_libretro
						Tandy TRS-80 Color Computer|LibRetro_TRS80|mess_libretro|coco3
						Technos|LibRetro_TECHN|mame_libretro
						Texas Instruments TI 99-4A|LibRetro_TI99|mess_libretro|ti99_4a
						Thomson MO5|LibRetro_MO5|mess_libretro|mo5
						Thomson TO7|LibRetro_TO7|mess_libretro|to7
						Tiger Game.com|LibRetro_TCOM|mess_libretro|gamecom
						Tiki-100|LibRetro_TIKI|mess_libretro|kontiki
						Tomy Tutor|LibRetro_TOMY|mess_libretro|tutor
						VTech CreatiVision|LibRetro_VTECH|mess_libretro|crvision
						Watara Supervision|LibRetro_SUPRV|mess_libretro|svision
						Williams Classics|LibRetro_WILLS|mame_libretro
					mType := Object()
					Loop, Parse, mTypeVar, `n, `r
						obj := {}
						Loop, Parse, A_LoopField, |
							If A_Index = 1
								obj.System := A_LoopField
							Else If A_Index = 2
								obj.ID := A_LoopField
							Else If A_Index = 3
								obj.Core := A_LoopField
							Else	; 4
								obj.MessID := A_LoopField
						mType.Insert(obj["System"], obj)
					Log("Module - Finished building the " . MEmu . " object",4)
					; For easier use throughout the module
					retroSystem := mType[systemName].System
					retroID := mType[systemName].ID
					retroCore := mType[systemName].Core
					retroMessID := mType[systemName].MessID
					If !retroSystem
						ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for this " . MEmu . " module: " . moduleName)
					If !retroCore
						ScriptError("Your Core ID is: " . retroID . "`nCould not find a default core to use. Please update the module with a default core.")
					core := IniReadCheck(settingsFile, systemName, "LibRetro_Core",retroCore,,1)
					configFolder := IniReadCheck(settingsFile, "Settings", "ConfigFolder",emuPath . "\config",,1)
					messRomPath := IniReadCheck(settingsFile, "Settings", "MESS_BIOS_Roms_Folder",,,1)
					hideConsole := IniReadCheck(settingsFile, "Settings", "HideConsole","true",,1)
					ejectToggleKey := IniReadCheck(settingsFile, "Settings", "Eject_Toggle_Key",,,1)
					nextDiskKey := IniReadCheck(settingsFile, "Settings", "Next_Disk_Key",,,1)
					prevDiskKey := IniReadCheck(settingsFile, "Settings", "Previous_Disk_Key",,,1)
					superGB := IniReadCheck(settingsFile, systemName . "|" . romName, "SuperGameBoy","false",,1)
					enableNetworkPlay := IniReadCheck(settingsFile, "Network|" . romName, "Enable_Network_Play","false",,1)
					overlay := IniReadCheck(settingsFile, systemName . "|" . romName, "Overlay",,,1)
					videoShader := IniReadCheck(settingsFile, systemName . "|" . romName, "VideoShader",,,1)
					aspectRatioIndex := IniReadCheck(settingsFile, systemName . "|" . romName, "AspectRatioIndex",,,1)
					customViewportWidth := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportWidth",,,1)
					customViewportHeight := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportHeight",,,1)
					customViewportX := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportX",,,1)
					customViewportY := IniReadCheck(settingsFile, systemName . "|" . romName, "CustomViewportY",,,1)
					stretchToFillBezel := IniReadCheck(settingsFile, systemName . "|" . romName, "StretchToFillBezel","false",,1)
					rotation := IniReadCheck(settingsFile, systemName . "|" . romName, "Rotation",0,,1)
					cropOverscan := IniReadCheck(settingsFile, systemName . "|" . romName, "CropOverscan",,,1)
					threadedVideo := IniReadCheck(settingsFile, systemName . "|" . romName, "ThreadedVideo",,,1)
					vSync := IniReadCheck(settingsFile, systemName . "|" . romName, "VSync",,,1)
					integerScale := IniReadCheck(settingsFile, systemName . "|" . romName, "IntegerScale",,,1)
					configurationPerCore := IniReadCheck(settingsFile, systemName . "|" . romName, "ConfigurationPerCore","false",,1)
					configFolder := GetFullName(configFolder)
					messRomPath := GetFullName(messRomPath)
					overlay := GetFullName(overlay)
					videoShader := GetFullName(videoShader)
					rotateBezel := false
					If (retroID = "LibRetro_SGB" || superGB = "true")	; if system or rom is set to use Super Game Boy
					{	superGB = true	; setting this just in case it's false and the system is Nintendo Super Game Boy
						sgbRomPath := CheckFile(emuPath . "\system\Super Game Boy (World).sfc","Could not find the rom required for Super Game Boy support. Make sure the rom ""Super Game Boy (World).sfc"" is located in: " . emuPath . "\system")
						CheckFile(emuPath . "\system\sgb.boot.rom","Could not find the bios required for Super Game Boy support. Make sure the bios ""sgb.boot.rom"" is located in: " . emuPath . "\system")
						retroID := "LibRetro_SGB"	; switching to Super Game Boy mode
						retroSystem := "Nintendo Super Game Boy"
					; Find the dll for this system
					libDll := CheckFile(emuPath . "\cores\" . core . ".dll", "Your " . retroID . " dll is set to " . core . " but could not locate this file:`n" . emuPath . "\cores\" . core . ".dll")
					; Find the cfg file to use
					If !FileExist(configFolder)
						ScriptError("You need to make sure ""ConfigFolder"" is pointing to your RetroArch config folder. By default it is looking here: """ . configFolder . """")
					globalRetroCfg := emuPath . "\retroarch.cfg"
					systemRetroCfg := configFolder . "\" . retroSystem . ".cfg"
					coreRetroCfg := configFolder . "\" . core . ".dll.cfg"
					Log("Module - Global cfg should be: " . globalRetroCfg,4)
					Log("Module - System cfg should be: " . systemRetroCfg,4)
					Log("Module - Core cfg should be: " . coreRetroCfg,4)
					foundCfg :=
					If FileExist(systemRetroCfg) {	; check for system cfg first
						retroCFGFile := systemRetroCfg
						foundCfg := 1
						Log("Module - Found a System cfg!",4)
					} Else If FileExist(coreRetroCfg) {	; 2nd option is a core config
						retroCFGFile := coreRetroCfg
						foundCfg := 1
						Log("Module - Found a Core cfg!",4)
					} Else If FileExist(globalRetroCfg) {	; 3rd is global cfg
						retroCFGFile := globalRetroCfg
						foundCfg := 1
						Log("Module - Found a Global cfg!",4)
					If !foundCfg
						Log("Module - Could not find a cfg file to update settings. RetroArch will make one for you.",2)
					Else {
						Log("Module - " . MEmu . " is using " . retroCFGFile . " as its config file.")
						retroCFG := LoadProperties(retroCFGFile)
					If rotation In 1,3 ; use vertical bezel if RA rotation is set to 90 or 270 degrees
						rotateBezel := true
					If RegExMatch(retroID, "LibRetro_NFDS|LibRetro_SCD|LibRetro_TGCD|LibRetro_PCECD|LibRetro_PCFX") {		; these systems require the retroarch settings to be read
						retroSysDir := ReadProperty(retroCFG,"system_directory")	; read value
						retroSysDir := ConvertRetroCFGKey(retroSysDir)	; remove dbl quotes
						StringLeft, retroSysDirLeft, retroSysDir, 2
						If (retroSysDirLeft = ":\") {	; if retroarch is set to use a default folder
							StringTrimLeft, retroSysDir, retroSysDir, 1
							Log("Module - RetroArch is using a relative system path: """ . retroSysDir . """")
							retroSysDir := emuPath . retroSysDir
						If !retroSysDir
							ScriptError("RetroArch requires you to set your system_directory and place bios rom(s) in there for """ . retroSystem . """ to function. Please do this first by running ""retroarch-phoenix.exe"" manually.")
						StringRight, checkForSlash, retroSysDir, 1
						If (checkForSlash = "\")	; check if a backslash is the last character. If it is, remove it, as this is non-standard method to define folders
							StringTrimRight, retroSysDir, retroSysDir, 1
					If (RegExMatch(retroID, "LibRetro_N64|LibRetro_NES|LibRetro_LYNX|LibRetro_PSX") || RegExMatch(retroID, "LibRetro_NES") && (InStr(core, "nestopia_libretro"))) {	; these systems will use an ini to store game specific settings
						sysSettingsFile := CheckSysFile(modulePath . "\" . systemName . ".ini")	; create the ini if it does not exist
						coreOptionsCFGFile := CheckFile((configurationPerCore ? configFolder . "\retroarch-core-options.cfg" : emuPath . "\retroarch-core-options.cfg"), "Could not find retroarch-core-options.cfg in retroarch directory: """ . (configurationPerCore ? configFolder : emuPath) . """")
						coreOptionsCFG := LoadProperties(coreOptionsCFGFile)
						If InStr(retroID, "LibRetro_N64") {	; Nintendo 64
							mupenGfx := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Gfx_Plugin", "auto",,1)
							mupenRsp := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_RSP_Plugin", "auto",,1)
							mupenCpu := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_CPU_Core", "dynamic_recompiler",,1)
							mupenPak1 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_1", "memory",,1)
							mupenPak2 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_2", "memory",,1)
							mupenPak3 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_3", "memory",,1)
							mupenPak4 := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Pak_4", "memory",,1)
							mupenGfxAccur := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Gfx_Accuracy", "high",,1)
							mupenExpMem := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Disable_Exp_Memory", "no",,1)
							mupenTexturFilt := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Texture_Filtering", "nearest",,1)
							mupenViRefresh := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_VI_Refresh", "2200",,1)
							mupenFramerate := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Framerate", "fullspeed",,1)
							mupenResolution := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Resolution", "640x480",,1)
							mupenPolyOffstFctr := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Polygon_Offset_Factor", "-3.0",,1)
							mupenPolyOffstUnts := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Polygon_Offset_Units", "-3.0",,1)
							mupenViOverlay := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_VI_Overlay", "disabled",,1)
							mupenAnalogDzone := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Mupen_Analog_Deadzone", "15",,1)
							WriteProperty(coreOptionsCFG, "mupen64-gfxplugin", mupenGfx, 1)
							WriteProperty(coreOptionsCFG, "mupen64-rspplugin", mupenRsp, 1)
							WriteProperty(coreOptionsCFG, "mupen64-cpucore", mupenCpu, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak1", mupenPak1, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak2", mupenPak2, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak3", mupenPak3, 1)
							WriteProperty(coreOptionsCFG, "mupen64-pak4", mupenPak4, 1)
							WriteProperty(coreOptionsCFG, "mupen64-gfxplugin-accuracy", mupenGfxAccur, 1)
							WriteProperty(coreOptionsCFG, "mupen64-disableexpmem", mupenExpMem, 1)
							WriteProperty(coreOptionsCFG, "mupen64-filtering", mupenTexturFilt, 1)
							WriteProperty(coreOptionsCFG, "mupen64-virefresh", mupenViRefresh, 1)
							WriteProperty(coreOptionsCFG, "mupen64-framerate", mupenFramerate, 1)
							WriteProperty(coreOptionsCFG, "mupen64-screensize", mupenResolution, 1)
							WriteProperty(coreOptionsCFG, "mupen64-polyoffset-factor", mupenPolyOffstFctr, 1)
							WriteProperty(coreOptionsCFG, "mupen64-polyoffset-units", mupenPolyOffstUnts, 1)
							WriteProperty(coreOptionsCFG, "mupen64-angrylion-vioverlay", mupenViOverlay, 1)
							WriteProperty(coreOptionsCFG, "mupen64-astick-deadzone", mupenAnalogDzone, 1)
						} Else If InStr(retroID, "LibRetro_NES") {		; these systems will use an ini to store game specific settings
							If InStr(core, "nestopia_libretro") {	; Nestopia
								nestopiaBlargg := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Blargg_NTSC_Filter", "disabled",,1)
								nestopiaPalette := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Palette", "canonical",,1)
								nestopiaNoSprteLimit := IniReadCheck(sysSettingsFile, "Nestopia" . "|" . romName, "Nestopia_Remove_Sprites_Limit", "disabled",,1)
								WriteProperty(coreOptionsCFG, "nestopia_blargg_ntsc_filter", nestopiaBlargg, 1)
								WriteProperty(coreOptionsCFG, "nestopia_palette", nestopiaPalette, 1)
								WriteProperty(coreOptionsCFG, "nestopia_nospritelimit", nestopiaNoSprteLimit, 1)
						} Else If InStr(retroID, "LibRetro_LYNX") {	; Atari Lynx
							If InStr(core, "handy_libretro") {   ; Handy
								handyRotate := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "Handy_Rotation", "None",,1)
								If InStr(handyRotate, "240") or InStr(handyRotate, "90")
									rotateBezel := true
								WriteProperty(coreOptionsCFG, "handy_rot", handyRotate, 1)
						} Else If InStr(retroID, "LibRetro_PSX") {	; Sony PlayStation
							psxCdImageCache := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_CD_Image_Cache", """enabled""",,1)
							psxMemcardHandling := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_Memcard_Handling", """libretro""",,1)
							psxDualshockAnalogToggle := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "PSX_Dualshock_Analog_Toggle", """enabled""",,1)
							WriteProperty(coreOptionsCFG, "beetle_psx_cdimagecache", psxCdImageCache, 1)
							WriteProperty(coreOptionsCFG, "beetle_psx_use_mednafen_memcard0_method", psxMemcardHandling, 1)
							WriteProperty(coreOptionsCFG, "beetle_psx_analog_toggle", psxDualshockAnalogToggle, 1)
						SaveProperties(coreOptionsCFGFile, coreOptionsCFG)
					hideEmuObj := Object("ahk_class ConsoleWindowClass",0,"RetroArch ahk_class RetroArch",1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					mgM3UPath:= romPath . "\" . romTable[1,4] . ".m3u"
					mgRomExtensions := "cue|iso|ccd"
					mgValidExtension := false
					Loop, parse, mgRomExtensions, |
						If (romExtension = "." . A_LoopField)
							mgValidExtension := true
					If (InStr(retroID, "LibRetro_PSX") && romTable.MaxIndex() && mgValidExtension) { ; See if MultiGame table is populated
						m3uRomIndex := Object()
						mgType := romTable[1,6] . " "
						mgMaxIndex := romTable.MaxIndex()
						mgRomIndex := 0
						If FileExist(mgM3UPath)
							FileDelete, %mgM3UPath%
						Loop %mgMaxIndex% {
							If (romTable[A_Index, 3] = romName) {
								tempType := romTable[A_Index, 5]
								StringTrimLeft, mgRomIndex, tempType, StrLen(mgType)
								Log ("Found rom index in rom set in romTable: " . mgRomIndex)
								break
						If (mgRomIndex > 0) {
							tempRomIndex := mgRomIndex
							Loop %mgMaxIndex% {
								mgTypeIndex := mgType . tempRomIndex
								m3uRomIndex.Insert(tempRomIndex)
								Loop %mgMaxIndex% {
									If (romTable[A_Index, 5] = mgTypeIndex) {
										tempRomPath := romTable[A_Index, 1]
										FileAppend, %tempRomPath%`n, %mgM3UPath%
										Log("Appending rom path to m3u: " . tempRomPath)
										break
								If (tempRomIndex < mgMaxIndex)
									tempRomIndex++
								Else
									tempRomIndex := 1
					; MESS core options
					messParam1 :=
					messParam2 :=
					messParam3 :=
					If InStr(core, "mess") {	; if a mess core is used
						Log("Module - Retroarch MESS mode enabled")
						If !retroMessID
							ScriptError("Your systemName is: " . systemName . "`nIt is not one of the known supported systems for the MESS LibRetro core")
						Else
							Log("Module - MESS mode using a known ident: " . retroMessID)
						If !messRomPath
							ScriptError("Please set the RetroArch module setting ""MESS_BIOS_Roms_Folder"" to the folder that contains your MESS BIOS roms to use MESS with RetroArch.")
						messParam1 :=
						messParam2 := " -rompath \" . """" . messRomPath . "\" . """"
						; Build a key/value object containing the different messParam3 choices
						messP3 := Object("alice32","cass1","gp32","memc","cpc464","cass","spectrum","cass","dragon64","cass","cdimono1","cdrom","bk0010","cass","neocd","cdrom","neocdz","cdrom","svi328n","cass","pecom64","cass","svmu","quik","gamecom","cart1","mbeeic","quik1")
						messParam3 := messP3[retroMessID]	; search object for the retroMessID pair
						messParam3 := " -" . (If messParam3 ? messParam3 : "cart") . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
						If retroMessID = mbeeic ; Applied Technology MicroBee
						{	microbeeModel := IniReadCheck(messSysINI, romName, "MicroBee_Model","mbeeic",,1)
									If microbeeModel not in mbee,mbeeic,mbeepc,mbeepc85,mbee56
										ScriptError("This is not a known MicroBee model value: " . microbeeModel)
									Else If (microbeeModel != "mbeeic")
										retroMessID := microbeeModel
									If romExtension in .mwb,.com,.bee
										mediaDeviceType := "quik1"
									Else If romExtension in .wav,.tap
										mediaDeviceType := "cass"
									Else If romExtension in .rom
										mediaDeviceType := "cart"
									Else If romExtension in .dsk
										mediaDeviceType := "flop1"
									Else	; .bin format
										mediaDeviceType := "quik2"
									messParam3 := " -" . mediaDeviceType . " \" . """" . romPath . "\" . romName . romExtension . "\" . """"
						fullRomPath := messParam1 . messParam2 . messParam3
					} Else If (superGB = "true") {
						Log("Module - Retroarch Super Game Boy mode enabled")
						fullRomPath := " """ . sgbRomPath . """ --subsystem sgb """ . romPath . "\" . romName . romExtension . """"
					} Else {
						Log("Module - Retroarch standard mode enabled")
						fullRomPath := " """ . romPath . "\" . romName . romExtension . """"
					If retroID = LibRetro_NFDS	; Nintendo Famicom Disk System
					{	IfNotExist, %retroSysDir%\disksys.rom
							ScriptError("RetroArch requires ""disksys.rom"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If retroID = LibRetro_SCD	; Sega CD
					{	If romExtension Not In .bin,.cue,.iso
							ScriptError("RetroArch only supports Sega CD games in bin|cue|iso format. It does not support:`n" . romExtension)
						IfNotExist, %retroSysDir%\bios_CD_E.bin
							ScriptError("RetroArch requires ""bios_CD_E.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
						IfNotExist, %retroSysDir%\bios_CD_U.bin
							ScriptError("RetroArch requires ""bios_CD_U.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
						IfNotExist, %retroSysDir%\bios_CD_J.bin
							ScriptError("RetroArch requires ""bios_CD_J.bin"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If retroID in LibRetro_PCECD,LibRetro_TGCD	; NEC PC Engine-CD and NEC TurboGrafx-CD
					{	If romExtension Not In .ccd,.cue
							ScriptError("RetroArch only supports " . retroSystem . " games in ccd or cue format. It does not support:`n" . romExtension)
						IfNotExist, %retroSysDir%\syscard3.pce
							ScriptError("RetroArch requires ""syscard3.pce"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					} Else If retroID = LibRetro_PCFX
						IfNotExist, %retroSysDir%\pcfx.bios
							ScriptError("RetroArch requires ""pcfx.bios"" for " . retroSystem . " but could not find it in your system_directory: """ . retroSysDir . """")
					networkSession :=
					If (enableNetworkPlay = "true") {
						Log("Module - Network Multi-Player is an available option for " . dbName,4)
						netplayNickname := IniReadCheck(settingsFile, "Network", "NetPlay_Nickname","Player",,1)
						getWANIP := IniReadCheck(settingsFile, "Network", "Get_WAN_IP","false",,1)
						If (getWANIP = "true")
							myPublicIP := GetPublicIP()
						Log("Module - CAREFUL WHEN POSTING THIS LOG PUBLICLY AS IT CONTAINS YOUR IP ON THE NEXT LINE",2)
						defaultServerIP := IniReadCheck(settingsFile, "Network", "Default_Server_IP", myPublicIP,,1)
						defaultServerPort := IniReadCheck(settingsFile, "Network", "Default_Server_Port",,,1)
						lastIP := IniReadCheck(settingsFile, "Network", "Last_IP", defaultServerIP,,1)	; does not need to be on the ISD
						lastPort := IniReadCheck(settingsFile, "Network", "Last_Port", defaultServerPort,,1)	; does not need to be on the ISD
						mpMenuStatus := MultiPlayerMenu(lastIP,lastPort,networkType,,0)
						If (mpMenuStatus = -1) {	; if user exited menu early
							Log("Module - Cancelled MultiPlayer Menu. Exiting module.",2)
							ExitModule()
						If networkSession {
							Log("Module - Using a Network for " . dbName,4)
							IniWrite, %networkPort%, %settingsFile%, Network, Last_Port
							; msgbox lastIP: %lastIP%`nlastPort: %lastPort%`nnetworkIP: %networkIP%`nnetworkPort: %networkPort%
							If (networkType = "client") {
								IniWrite, %networkIP%, %settingsFile%, Network, Last_IP	; Save last used IP and Port for quicker launching next time
								netCommand := " -C " . networkIP . " --port " . networkPort . " --nick """ . netplayNickname . """"	; -C = connect as client
							} Else {	; server
								netCommand := " -H --port " . networkPort . " --nick """ . netplayNickname . """"	; -H = host as server
							Log("Module - Starting a network session using the IP """ . networkIP . """ and PORT """ . networkPort . """",4)
						} Else
							Log("Module - User chose Single Player mode for this session",4)
					BezelStart(,,(If rotateBezel ? 1:""))
					If foundCfg {
						If (stretchToFillBezel = "true" and bezelEnabled = "true" and bezelPath)
							customViewportWidth := bezelScreenWidth
							customViewportHeight := bezelScreenHeight
							customViewportX := 0
							customViewportY := 0
							aspectRatioIndex := 22
							Log("Stretching viewport to fit bezel")
						retroCFG := LoadProperties(retroCFGFile)	; load the config into memory
						raCfgHasChanges :=
						WriteRetroProperty("input_overlay", overlay)
						WriteRetroProperty("video_shader", videoShader)
						WriteRetroProperty("aspect_ratio_index", aspectRatioIndex)
						WriteRetroProperty("custom_viewport_width", customViewportWidth)
						WriteRetroProperty("custom_viewport_height", customViewportHeight)
						WriteRetroProperty("custom_viewport_x", customViewportX)
						WriteRetroProperty("custom_viewport_y", customViewportY)
						WriteRetroProperty("video_rotation", rotation)
						WriteRetroProperty("video_crop_overscan", cropOverscan)
						WriteRetroProperty("video_threaded", threadedVideo)
						WriteRetroProperty("video_vsync", vSync)
						WriteRetroProperty("video_scale_integer", integerScale)
						WriteRetroProperty("input_disk_eject_toggle", ejectToggleKey)
						WriteRetroProperty("input_disk_next", nextDiskKey)
						WriteRetroProperty("input_disk_prev", prevDiskKey)
							Loop, 8	; Loop 8 times for 8 controllers
							{	p%A_Index%ControllerType := IniReadCheck(sysSettingsFile, systemName . "|" . romName, "P" . A_Index . "_Controller_Type", 517,,1)
								WriteRetroProperty("input_libretro_device_p" . A_Index, p%A_Index%ControllerType)
						If raCfgHasChanges {
							Log("Module - Saving changed settings to: """ . retroCFGFile . """")
							SaveProperties(retroCFGFile, retroCFG)
					fullscreen := If fullscreen = "true" ? " -f" : ""
					srmPath := emuPath . "\srm\" . retroSystem	; path for this system's srm files
					saveStatePath := emuPath . "\save\" . retroSystem	; path for this system's save state files
					retroCFGFile := If foundCfg ? " -c """ . retroCFGFile . """" : ""
					IfNotExist, %srmPath%
						FileCreateDir, %srmPath% ; creating srm dir if it doesn't exist
					IfNotExist, %saveStatePath%
						FileCreateDir, %saveStatePath% ; creating save dir if it doesn't exist
					HideEmuStart()	; This fully ensures windows are completely hidden even faster than winwait
						Run(executable . " """ . (retroMessID ? retroMessID : "") . fullRomPath . """ " . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide")
					} Else If (retroID = "LibRetro_SGB" || If superGB = "true") { ; For some reason, the order of our command line matters in this particular case.
						Run(executable . " " . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . fullRomPath . netCommand, emuPath, "Hide")
					} Else If FileExist(mgM3UPath) {
						Run(executable . " " . """" . mgM3UPath . """" . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide")
					} Else {
						Run(executable . " " . fullRomPath . fullscreen . retroCFGFile . " -L """ . libDll . """ -s """ . srmPath . "\" . romName . ".srm"" -S """ . saveStatePath . "\" . romName . ".state""" . netCommand, emuPath, "Hide")
					mpMenuStatus :=
					If networkSession {
						canceledServerWait := false
						multiplayerMenuExit := false
						SetTimer, NetworkConnectedCheck, 500
						If (networkType = "server") {
							Log("Module - Waiting for a client to connect to your server")
							mpMenuStatus := MultiPlayerMenu(,,,,,,,,"You are the server. Please wait for your client to connect.")
						} Else {	; client
							Log("Module - Trying to contact the server to establish a connection.")
							mpMenuStatus := MultiPlayerMenu(,,,,,,,,"Attempting to connect to the server...")
						If (mpMenuStatus = -1) {	; if user exited menu early before a client connected
							Log("Module - Cancelled waiting for the " . If (networkType = "server") ? "client to connect" : "server to respond" . ". Exiting module.",2)
							If Process("Exist", executable)
								Process("Close", executable)	; must close process as the exe is waiting for a client to connect and no window was drawn yet
							ExitModule()
						} Else {	; blank response from MultiPlayerMenu, exited properly
							Log("Module - " . If (networkType = "server") ? "Client has connected" : "Connected to the server")
							WinWait("RetroArch ahk_class RetroArch")
							WinWaitActive("RetroArch ahk_class RetroArch")
						SetTimer, NetworkConnectedCheck, Off
					} Else {	; single player
					If hideConsole = true
						WinSet, Transparent, On, ahk_class ConsoleWindowClass	; makes the console window transparent so you don't see it on exit
					BezelDraw()
					HideEmuEnd()
					FadeInExit()
					7zCleanUp()
					BezelExit()
					FadeOutExit()
					ExitModule()
					; Writes new properties into the retroCFG if defined by user
					WriteRetroProperty(key,value="") {
						If (value != "") {
							Global retroCFG,raCfgHasChanges
							WriteProperty(retroCFG, key, value,1,1)
							raCfgHasChanges := 1
					; Used to convert between RetroArch keys and usable data
					ConvertRetroCFGKey(txt,direction="read"){
						Global emuPath
						If direction = read
						{	StringTrimLeft,newtxt,txt,1	; removes the " from the left of the txt
							StringTrimRight,newtxt,newtxt,1	; removes the " from the right of the txt
							relativeCheck := SubStr(newtxt, 1, 1)
							If InStr(relativeCheck,":") {	; if the path contains a ":" then it is a relative path
								Log("ConvertRetroCFGKey - " . newtxt . " is a relative path",4)
								StringTrimLeft,newtxt,newtxt,1	; removes the : from the left of the txt
								newtxt := AbsoluteFromRelative(emuPath, "." . newtxt)	; convert relative to absolute
							If InStr(newtxt,"/")
								StringReplace,newtxt,newtxt,/,\,1	; replaces all forward slashes with backslashes
						} Else If direction = write
						{	newtxt = "%txt%"	; wraps the txt with ""
							If InStr(newtxt,"\")
								StringReplace,newtxt,newtxt,\,/,1	; replaces all backslashes with forward slashes
						} Else
							ScriptError("Not a valid use of ConvertRetroCFGKey. Only ""read"" or ""write"" are supported.")
						Log("ConvertRetroCFGKey - Converted " . txt . " to " . newtxt,4)
						Return newtxt
					; This will simply create a new blank ini if one does not exist
					CheckSysFile(file){
						IfNotExist, %file%
							FileAppend,, %file%
						Return file
					MultiGame:
						SetKeyDelay(100)
						WinActivate, ahk_class RetroArch
						Send, {%ejectToggleKey% down}{%ejectToggleKey% up}	; eject disc in Retroarch
						If (!mgLastRomIndex) {
							mgLastRomIndex := mgRomIndex
						selectedRomIndex := 0
						StringTrimLeft, selectedRomIndex, selectedRomNum, StrLen(mgType)
						Loop %mgMaxIndex% {
							If (m3uRomIndex[A_index] = mgLastRomIndex) {
								tempLastRomIndex := A_index
								Log("Temp last index: " . tempLastRomIndex)
							If (m3uRomIndex[A_index] = selectedRomIndex) {
								tempSelectedRomIndex := A_index
								Log("temp selected index: " . tempSelectedRomIndex)
						mgNewIndex := tempLastRomIndex - tempSelectedRomIndex
						If (mgNewIndex < 0) {
							mgNewIndex := mgNewIndex * -1
							Loop %mgNewIndex% {
								Log("Sending the next disk key: " . nextDiskKey)
								Send, {%nextDiskKey% down}{%nextDiskKey% up}
						} Else If (mgNewIndex > 0) {
							Loop %mgNewIndex% {
								Log("Sending the previous disk key: " . mgNewIndex)
								Send, {%prevDiskKey% down}{%prevDiskKey% up}
						Send, {%ejectToggleKey% down}{%ejectToggleKey% up}	; close disc in Retroarch
						mgLastRomIndex := selectedRomIndex
					Return
					NetworkConnectedCheck:
						If clientConnected
							multiplayerMenuExit := true
						Else If WinExist("RetroArch ahk_class RetroArch") {
							Log("Module - RetroArch session started, closing the MultiPlayer menu",4)
					Return
					CloseProcess:
						FadeOutStart()
						WinClose("RetroArch ahk_class RetroArch")
					Return
00:30:01:156 | RL |     INFO  | +1203  | BuildScript - Loaded Multi-Player scripts
00:30:01:156 | RL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
00:30:01:156 | RL |  WARNING  | +0     | BuildScript - "C:\RocketLauncher\Lib\User Functions.ahk" not found
00:30:01:156 | RL |     INFO  | +0     | BuildScript - Finished injecting functions into module
00:30:01:156 | RL |     INFO  | +0     | Main - Module is built
00:30:01:156 | RL |     INFO  | +0     | CheckFile - Checking if C:\RocketLauncher\AutoHotkey.dll exists
00:30:01:171 | RL |   DEBUG1  | +16    | CheckFile - Attributes:
					File Size:			785408 bytes
					Created:			9/13/2015 - 10:42:49
					Modified:			8/17/2015 - 11:04:18
00:30:01:187 | RL |     INFO  | +16    | Main - Running module
00:30:01:203 | RL |     INFO  | +15    | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
00:30:01:390 | MD |     INFO  | +N/A   | Module initialized
00:30:01:390 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
00:30:01:421 | MD |   DEBUG2  | +31    | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
00:30:01:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
00:30:01:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
00:30:01:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
00:30:01:421 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
00:30:01:453 | MD |     INFO  | +31    | StartModule - Started
00:30:01:453 | MD |     INFO  | +0     | StartModule - MEmu: RetroArch
					MEmuV: v05-11-2015 Nightly
					MURL: http://themaister.net/retroarch.html
					MAuthor: djvj,zerojay
					MVersion: 2.3.2
					MCRC: C04B6C16
					iCRC: 42C3B552
					MID:
					MSystem: "Acorn BBC Micro","AAE","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Applied Technology MicroBee","Apple IIGS","Atari 2600","Atari 5200","Atari 7800","Atari 8-bit","Atari Classics","Atari Jaguar","Atari Lynx","Atari ST","Atari XEGS","Bally Astrocade","Bandai Gundam RX-78","Bandai Super Vision 8000","Bandai Wonderswan","Bandai Wonderswan Color","Canon X07","Capcom Classics","Capcom Play System","Capcom Play System 2","Capcom Play System 3","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore MAX Machine","Commodore Amiga","Creatronic Mega Duck","Data East Classics","Dragon Data Dragon","Emerson Arcadia 2001","Entex Adventure Vision","Elektronika BK","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Final Burn Alpha","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Konami Classics","MAME","Magnavox Odyssey 2","Microsoft MSX","Microsoft MSX2","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","Midway Classics","Namco Classics","Namco System 22","NEC PC Engine","NEC PC Engine-CD","NEC PC-FX","NEC TurboGrafx-16","NEC SuperGrafx","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo DS","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Color","Nintendo Game Boy Japan","Nintendo Game Boy Advance","Nintendo Game & Watch","Nintendo Super Game Boy","Nintendo Pokemon Mini","Nintendo Virtual Boy","Nintendo Super Famicom","Nintendo Satellaview","Nintendo SuFami Turbo","Panasonic 3DO","Elektronska Industrija Pecom 64","Philips CD-i","Philips Videopac","RCA Studio II","Sega 32X","Sega Classics","Sega Mega Drive 32X","Sega Mark III","Sega SC-3000","Sega SG-1000","Sega CD","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Pico","Sega Saturn","Sega Saturn Japan","Sega VMU","Sega ST-V","Sharp X1","Sinclair ZX Spectrum","Sony PlayStation","Sony PlayStation Minis","Sony PocketStation","Sony PSP","Sord M5","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo CD","SNK Neo Geo Pocket Color","Spectravideo","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Technos","Texas Instruments TI 99-4A","Thomson MO5","Thomson TO7","Tiger Game.com","Tiki-100","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics"
00:30:01:484 | MD |     INFO  | +31    | StartModule - You have a supported System Name for this module: "Nintendo Entertainment System"
00:30:01:484 | MD |     INFO  | +0     | PluginInit - Started
00:30:01:484 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
00:30:01:515 | MD |     INFO  | +32    | CheckFile - Checking if C:\HyperSpin\Databases\Nintendo Entertainment System\Nintendo Entertainment System.xml exists
00:30:01:515 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			271439 bytes
					Created:			9/13/2015 - 10:42:48
					Modified:			4/14/2014 - 2:19:56
00:30:01:515 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
00:30:01:515 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
00:30:01:546 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Searching database for: Name
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Name" with a value: "3-D WorldRunner (USA)"
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Cloneof
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Could not find: Cloneof
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Manufacturer" with a value: "Acclaim"
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Year
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Year" with a value: "1987"
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Genre
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Action"
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Searching database for: Rating
00:30:01:546 | MD |   DEBUG1  | +0     | BuildDatabaseTable - Found "Rating" with a value: "HSRS - GA (General Audience)"
00:30:01:546 | MD |   DEBUG2  | +0     | PluginInit - GameInfo:
					GameInfo Label: Genre | GameInfo Value:
					GameInfo Label: Manufacturer | GameInfo Value:
					GameInfo Label: Name | GameInfo Value:
					GameInfo Label: Rating | GameInfo Value:
					GameInfo Label: Year | GameInfo Value:
00:30:01:578 | MD |   DEBUG1  | +31    | BuildDatabaseTable - Ended
00:30:01:609 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Logo: C:\HyperSpin\Media\Nintendo Entertainment System\Images\Wheel\3-D WorldRunner (USA).png
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Logo: C:\HyperSpin\Media\Main Menu\Images\Wheel\Nintendo Entertainment System.png
00:30:01:609 | MD |   DEBUG2  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Wheel\3-D WorldRunner (USA).png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  C:\HyperSpin\Media\Main Menu\Images\Wheel\Nintendo Entertainment System.png | Asset Extension1:  png | Asset Type1:  system
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Artwork1: C:\HyperSpin\Media\Nintendo Entertainment System\Images\Artwork1\3-D WorldRunner (USA).png
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Box Art: C:\HyperSpin\Media\Nintendo Entertainment System\Images\Artwork2\3-D WorldRunner (USA).png
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Cartridge: C:\HyperSpin\Media\Nintendo Entertainment System\Images\Artwork3\3-D WorldRunner (USA).png
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Flyers: C:\HyperSpin\Media\Nintendo Entertainment System\Images\Artwork4\3-D WorldRunner (USA).png
00:30:01:609 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Letters: C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters
00:30:01:703 | MD |   DEBUG1  | +94    | BuildAssetsTable - Searching for a Other: C:\HyperSpin\Media\Nintendo Entertainment System\Images\Other
00:30:01:734 | MD |   DEBUG2  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  C:\HyperSpin\Media\Nintendo Entertainment System\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
00:30:01:828 | MD |   DEBUG1  | +94    | BuildAssetsTable - Ended
00:30:01:859 | MD |   DEBUG1  | +31    | BuildAssetsTable - Started - Building Table for: Game Video|System Video
00:30:01:859 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a Game Video: C:\HyperSpin\Media\Nintendo Entertainment System\Video\3-D WorldRunner (USA).*
00:30:01:859 | MD |   DEBUG1  | +0     | BuildAssetsTable - Searching for a System Video: C:\HyperSpin\Media\Main Menu\Video\Nintendo Entertainment System.*
00:30:01:859 | MD |   DEBUG1  | +0     | BuildAssetsTable - Ended
00:30:01:859 | MD |     INFO  | +0     | PluginInit - Ended
00:30:01:859 | MD |   DEBUG1  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: 3-D WorldRunner (USA)
00:30:01:859 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Started
00:30:01:859 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,
00:30:01:859 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 1 check
00:30:01:859 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Post loop 2 check
00:30:01:859 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
00:30:01:859 | MD |   DEBUG2  | +0     | XHotkeyTableCreation - Ended
00:30:01:890 | MD |     INFO  | +32    | StartModule - Ended
00:30:01:890 | MD |   DEBUG1  | +0     | Module - Started building the RetroArch object
00:30:01:890 | MD |   DEBUG1  | +0     | Module - Finished building the RetroArch object
00:30:01:890 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - LibRetro_Core: nestopia_libretro
00:30:01:890 | MD |     INFO  | +0     | Module Setting - [Settings] - Fullscreen: true
00:30:01:890 | MD |     INFO  | +0     | Module Setting - [Settings] - ConfigFolder: C:\Emulators\RetroArch\config
00:30:01:890 | MD |     INFO  | +0     | Module Setting - [Settings] - MESS_BIOS_Roms_Folder:
00:30:01:890 | MD |     INFO  | +0     | Module Setting - [Settings] - HideConsole: true
00:30:01:890 | MD |     INFO  | +0     | Module Setting - [Settings] - Eject_Toggle_Key:
00:30:01:890 | MD |     INFO  | +0     | Module Setting - [Settings] - Next_Disk_Key:
00:30:01:921 | MD |     INFO  | +31    | Module Setting - [Settings] - Previous_Disk_Key:
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - SuperGameBoy: false
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - SuperGameBoy: false
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [Network] - Enable_Network_Play: false
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - Enable_Network_Play: false
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - Overlay:
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - Overlay:
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - VideoShader:
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - VideoShader:
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - AspectRatioIndex:
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - AspectRatioIndex:
00:30:01:921 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - CustomViewportWidth:
00:30:01:953 | MD |     INFO  | +31    | Module Setting - [3-D WorldRunner (USA)] - CustomViewportWidth:
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - CustomViewportHeight:
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - CustomViewportHeight:
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - CustomViewportX:
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - CustomViewportX:
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - CustomViewportY:
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - CustomViewportY:
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - StretchToFillBezel: false
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - StretchToFillBezel: false
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - Rotation: 0
00:30:01:953 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - Rotation: 0
00:30:01:984 | MD |     INFO  | +31    | Module Setting - [Nintendo Entertainment System] - CropOverscan:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - CropOverscan:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - ThreadedVideo:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - ThreadedVideo:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - VSync:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - VSync:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - IntegerScale:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - IntegerScale:
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [Nintendo Entertainment System] - ConfigurationPerCore: false
00:30:01:984 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - ConfigurationPerCore: false
00:30:01:984 | MD |     INFO  | +0     | CheckFile - Checking if C:\Emulators\RetroArch\cores\nestopia_libretro.dll exists
00:30:01:984 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			3519639 bytes
					Created:			9/20/2015 - 12:04:37
					Modified:			9/16/2015 - 11:12:18
00:30:01:015 | MD |   DEBUG1  | +32    | Module - Global cfg should be: C:\Emulators\RetroArch\retroarch.cfg
00:30:02:015 | MD |   DEBUG1  | +0     | Module - System cfg should be: C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg
00:30:02:015 | MD |   DEBUG1  | +0     | Module - Core cfg should be: C:\Emulators\RetroArch\config\nestopia_libretro.dll.cfg
00:30:02:015 | MD |   DEBUG1  | +0     | Module - Found a System cfg!
00:30:02:015 | MD |     INFO  | +0     | Module - RetroArch is using C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg as its config file.
00:30:02:015 | MD |   DEBUG1  | +0     | LoadProperties - Started and loading this cfg into memory: C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg
00:30:02:015 | MD |   DEBUG1  | +0     | LoadProperties - Ended
00:30:02:015 | MD |     INFO  | +0     | CheckFile - Checking if C:\Emulators\RetroArch\config\retroarch-core-options.cfg exists
00:30:02:015 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
					File Size:			2906 bytes
					Created:			9/20/2015 - 12:14:35
					Modified:			9/20/2015 - 12:14:50
00:30:02:046 | MD |   DEBUG1  | +31    | LoadProperties - Started and loading this cfg into memory: C:\Emulators\RetroArch\config\retroarch-core-options.cfg
00:30:02:046 | MD |   DEBUG1  | +0     | LoadProperties - Ended
00:30:02:046 | MD |     INFO  | +0     | Module Setting - [Nestopia] - Nestopia_Blargg_NTSC_Filter: disabled
00:30:02:046 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - Nestopia_Blargg_NTSC_Filter: disabled
00:30:02:046 | MD |     INFO  | +0     | Module Setting - [Nestopia] - Nestopia_Palette: canonical
00:30:02:046 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - Nestopia_Palette: canonical
00:30:02:046 | MD |     INFO  | +0     | Module Setting - [Nestopia] - Nestopia_Remove_Sprites_Limit: disabled
00:30:02:046 | MD |     INFO  | +0     | Module Setting - [3-D WorldRunner (USA)] - Nestopia_Remove_Sprites_Limit: disabled
00:30:02:046 | MD |   DEBUG1  | +0     | WriteProperty - Started
00:30:02:046 | MD |   DEBUG1  | +0     | WriteProperty - Ended
00:30:02:078 | MD |   DEBUG1  | +31    | WriteProperty - Started
00:30:02:078 | MD |   DEBUG1  | +0     | WriteProperty - Ended
00:30:02:078 | MD |   DEBUG1  | +0     | WriteProperty - Started
00:30:02:078 | MD |   DEBUG1  | +0     | SaveProperties - Started and saving this cfg to disk: C:\Emulators\RetroArch\config\retroarch-core-options.cfg
00:30:02:078 | MD |   DEBUG1  | +0     | SaveProperties - Ended
00:30:02:078 | MD |     INFO  | +0     | Module - Retroarch standard mode enabled
00:30:02:078 | MD |   DEBUG1  | +0     | LoadProperties - Started and loading this cfg into memory: C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg
00:30:02:078 | MD |   DEBUG1  | +0     | LoadProperties - Ended
00:30:02:109 | MD |   DEBUG1  | +31    | WriteProperty - Started
00:30:02:109 | MD |   DEBUG1  | +0     | WriteProperty - Ended
00:30:02:109 | MD |     INFO  | +0     | Module - Saving changed settings to: "C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg"
00:30:02:109 | MD |   DEBUG1  | +0     | SaveProperties - Started and saving this cfg to disk: C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg
00:30:02:109 | MD |   DEBUG1  | +0     | SaveProperties - Ended
00:30:02:109 | MD |     INFO  | +0     | Run - Running: C:\Emulators\RetroArch\retroarch.exe  "C:\Roms\NES\3-D WorldRunner (USA).nes" -f -c "C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg" -L "C:\Emulators\RetroArch\cores\nestopia_libretro.dll" -s "C:\Emulators\RetroArch\srm\Nintendo Entertainment System\3-D WorldRunner (USA).srm" -S "C:\Emulators\RetroArch\save\Nintendo Entertainment System\3-D WorldRunner (USA).state"
00:30:02:187 | MD |   DEBUG1  | +79    | Run - "retroarch.exe  "C:\Roms\NES\3-D WorldRunner (USA).nes" -f -c "C:\Emulators\RetroArch\config\Nintendo Entertainment System.cfg" -L "C:\Emulators\RetroArch\cores\nestopia_libretro.dll" -s "C:\Emulators\RetroArch\srm\Nintendo Entertainment System\3-D WorldRunner (USA).srm" -S "C:\Emulators\RetroArch\save\Nintendo Entertainment System\3-D WorldRunner (USA).state"" Process ID: 1732
00:30:02:187 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RocketLauncher v1.0.1.3 Debug Console | Class: ConsoleWindowClass | State: 0 | X: 22 | Y: 29 | Width: 669 | Height: 338 | Window HWND: 0x700d6 | Process ID: 1228 | Process Path: C:\RocketLauncher\RocketLauncher.exe
00:30:02:187 | MD |     INFO  | +0     | WinWait - Waiting for "RetroArch ahk_class RetroArch"
00:30:02:531 | MD |   DEBUG1  | +343   | GetActiveWindowStatus - Title: RetroArch | Class: RetroArch | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x60114 | Process ID: 1732 | Process Path: C:\Emulators\RetroArch\retroarch.exe
00:30:02:531 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RetroArch | Class: RetroArch | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x60114 | Process ID: 1732 | Process Path: C:\Emulators\RetroArch\retroarch.exe
00:30:02:531 | MD |     INFO  | +0     | WinWaitActive - Waiting for "RetroArch ahk_class RetroArch"
00:30:02:640 | MD |   DEBUG1  | +110   | GetActiveWindowStatus - Title: RetroArch | Class: RetroArch | State: 0 | X: 0 | Y: 0 | Width: 1024 | Height: 768 | Window HWND: 0x60114 | Process ID: 1732 | Process Path: C:\Emulators\RetroArch\retroarch.exe
00:30:02:640 | MD |     INFO  | +0     | Process - WaitClose retroarch.exe
00:30:09:531 | MD |     INFO  | +6890  | ExitModule - Started
00:30:09:531 | MD |     INFO  | +0     | Starting Updating Statistics:
00:30:09:531 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
00:30:09:531 | MD |   DEBUG2  | +0     | gameSectionStartTime:1449453
00:30:09:531 | MD |   DEBUG2  | +0     | ElapsedTime:7
00:30:09:531 | MD |   DEBUG2  | +0     | Statistics cleared game name: 3-D WorldRunner
00:30:09:656 | MD |   DEBUG2  | +125   | Loaded game statistics from ini files:
					Number_of_Times_Played: 15
					Last_Time_Played: niedziela wrze?nia 20, 2015 12:14:49
					Average_Time_Played: 21
					Total_Time_Played: 311
					System_Total_Played_Time: 2751
					Total_Global_Played_Time: 21869
00:30:09:656 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 16
					Last_Time_Played: niedziela wrze?nia 20, 2015 12:30:01
					Average_Time_Played: 20
					Total_Time_Played: 318
					System_Total_Played_Time: 2758
					Total_Global_Played_Time: 21876
00:30:09:781 | MD |     INFO  | +125   | Game section statistics updated.
00:30:09:781 | MD |     INFO  | +0     | ExitModule - Ended
00:30:09:781 | MD |     INFO  | +0     | End of Module Logs
00:30:09:843 | RL |     INFO  | +8641  | Main - Module ended, exiting RocketLauncher normally
00:30:09:843 | RL |     INFO  | +0     | ExitScript - Started
00:30:09:843 | RL |     INFO  | +0     | SystemCursor - Restoring mouse cursor
00:30:09:859 | RL |     INFO  | +15    | ExitScript - Ended
[/code]
