snes and Retrolaunch
voyagerxp
Hi i've not been on here for a long time and a lot has changed. I've never used Retrolaunch before and i've been trying to set in Rocketlauncher but i can't get it working. I've been following Simply Austins video's but i get this error when launching in RocketLauncher.
Easiest way to fix this would be to download what it's looking for.
If you load up RetroArch on its own (from RetroArch Directory),   *I'm using version 1.2.2*, you should see what's below.
If not, you could be using a different RA build and should update it.
Select that, hit enter.    (Actually says SNES, not *ES.  It's scrolling text)
Let it install.
Quit RetroArch
Re-try the game.
(You are able to use different Cores, but you'll need to change some settings around)
Right i've solved that problem but now i'm having problems with Atari Jaguar and Atari 5200 with RetroArch. Don't want to start another thread so can i get help on here.
On the Atari Jaguar when i try to launch a game i get RetroArch has stopped working.
On the Atari 5200 i get the following error. Please set the RetroArch module setting "Mess_Folder" to the folder that contains your MESS BIOS roms to use MESS with RetroArch.
also in retroarch folder config where it says retroarch-core-options.cfg edit it and inside enable cli and disable the rest i might be wrong but it works for me
Cheers guys, thcdgaf your way worked for me.
Any ideas why Atari Jaguar has stopped working error when launched with RetroArch. It launches and i get a black screen the the error.
