HS not loading wheel from main menu
trailervert
Hey Guys,
Just did the update to the new HS followed SimlyAustin's guide. Everything worked fine during that.
I just noticed that when trying to click the rom path location in HyperHQ it will crash HyperHQ and cause it to close. I am using window 10 and did give HyperHQ admin status. Also noticed that a couple of my wheels will not open from HS main wheel.
Atari 2600 when you select it to go into games it does not load the wheel it just returns back to main menu.
any thoughts as to what I may have done?
Thanks
Paul
Thank you JHell86!
That solved it. I had roms only checked somehow, but no rom path because of the Win10 issue. changed ini and all is sorted.
THANK YOU!
  • 1 month later...
Not to rehash an old thread but this is exactly the issue I am looking to resolve. You mentioned editing the ini files. Is this needed for every emu wheel rom path? And where would the files for each be located?
