SNK Neo Geo CD
spudgunjake
I have look everywhere for a solution, but cant find a simple answer, so I am ask you guys,
I am using RL to launch SNK Neo Geo CD but I am getting the "IPL.txt cant be found error", I can see it in the ISO and the extraction path ..\temp\SNK Neo Geo CD\game...\IPL.txt with wand other files.
I have read the module notes but still cant figure out why I am getting this error.
Using Neorain32 1.4.3 as the Emu..
Thanks John.
Emulador runs properly?
If you have .CUE files probably these have wrong content.
With a bad CUE the emulator gives the error:
can't find iso file
Could not determine sector size from the cue file
Could not open IPL.TXT!
Error: Error while processing IPL.TXT.
Hi thanks for input,
Everything is right, but your reply give me a idea, what might be causing it,
daemon tools should be creating the virtual image from the iso, which it does, but the emulator doesn't look for the virtual drive K in this case with RL, well it doesn't for me yet, will look at the module notes again,
just tested it by loading the ISO with daemon tools and setting the path in the emulator to my drive letter. and it works.
Will update this post.
