Games not launch in hyperspin/hyperlaunch
quile
Hi,
I have setup a clean install of hyperspin 1.4 and rocketlaucher.
The games are starting inside rockerlauncher, but they are not starting inside hyperspin or hyperlaunch.
Below the log of hyperlaunch:
09:40:54 |  HyperLaunch v2.25c
09:40:54 |  System Specs:
		HyperSpin Dir: D:\HyperSpin
		OS: WIN_7
		OS Language: 0413
		OS Admin Status: No
		Monitor #1 (\\.\DISPLAY3): 1366x768 (1366x768 work)
		HyperSpin Res: 1025x556
		AHK Version: 1.1.07.03
09:40:54 |  HyperLaunch launched directly
09:40:56 |  HyperLaunch received "MAME" and "1on1gov"
09:40:56 |  INI Keys read
09:40:56 |  Possible duplicate launch.  is already running, closing HyperLaunch
It is mentioning " possible duplicate launch"  but this is not the case, not other process of hyperlauch is running. Also rebooted pc and give same error/log.
I could not find any solution on the forum or on the net.
So perhaps any idea what could be wrong/I need to change?
Thanks.
Hi Agent47
Thanks for the reply and the link to the post
I did follow austins video for the setup, but seems rocketlaucher 1.0.1.4 has an extra path not in austins video: " Default Frontend Path"  as mentioning in your link.
Second thing I did wrong:
In the hyperspin setting.ini I added:
Hyperlaunch_Path=..\RocketLauncher\RocketLauncher.exe (thought if ever wanted to change drives, I dont need to change drive letter)
But does not seems to work and automaticly it will use HyperLaunch.exe instead: "Can't find HyperLaunch, defaulting to root HyperLaunch.exe"
Adding the correct drive letter have fix the problem:
Hyperlaunch_Path=D:\RocketLauncher\RocketLauncher.exe
So it is working now :-)
Thanks for the help.
