Missing MAME wheel Default Graphic
domdom
Hello everyone,
I just got Hyperspin up and running, and I was attempting to change the wheel setting for Mame, somehow I have removed the Default Mame png from the wheel, now it just has text that says mame...  Under RockerLauncher it does not show the graphic at the bottom left when you click on a system like it does for all the rest.  How can I restore that?
Any suggestions?
The name of the wheel image needs to exactly match the entry on your Main Menu xml in the database folder, same for all other media. Did you rename anything?
Can you point me to where I should be looking?  I tried to change the Mame theme to the Arcade Classics, all it says in my main menu for Mame is
<game name="MAME" />
Where else could I be looking?  Thank you for the reply
So you either need to rename your theme, wheel, and video to "MAME" or you change the name in the XML to whatever you're trying to use.
