MAME Crashes when exiting roms
ward614
While I am able to successfully run MAME games through Hyperspin, every once and a while the windows error "A problem has caused MAME to stop working" appears when I attempt to exit the rom and return to the Hyperspin menu.
If I close out of it, Hyperspin continues normally but I can't do that using my arcade controls and need to break out the mouse. Does anyone have any idea what might be causing this issue or what I can do to get the windows error to be ignored if nothing else?
Before delving deeper, you can try making sure you've got "Run as Administrator" checked off in the mame compatibility options in Windows. If that doesn't work, what version of Windows and of MAME are you running?
Well, that was a lot simpler than I thought. Activating run as administrator stopped the problem entirely! Thank you for your help!
