Kwestone Posted March 10, 2016 Posted March 10, 2016 I am not sure whats wrong with this build. Hyperspin wont launch anything, but launches fine in RLUI. The hyperHQ controls are working fine but when I try to launch the game, nothing. Its like the rocketlauncher isnt receiving the commands from hyperspin to launch.\ Any ideas? The default frontend is set as hyperspin The default hyperspin path is correct The default plugin setting is correct Any other ideas? Any help is greatly appreciated, pulling out my hair atm.
Avar Posted March 10, 2016 Posted March 10, 2016 You mentioned it's set as the default frontend but is HS also set as the active frontend? Also, is the HyperLaunch path in your HS settings.ini set to the exact location of RocketLauncher.exe? Note: all paths are case sensitive.
