can not select a game after i run a game
jrose1184
so i final got retro arch to work in rlauncher runs a game perfect. but when i run it in hyperspin i get a blank screen the once i exit the game hyprer spin can nolonger load a new game. in the task manger hyper launch is still running if i close it i can select another game. is there a fix to both of these? many thanks for reading
This is a known problem with RL - there are posts about it on the RL forums and it's being looked into.
It would be great if you could post on the relevant threads over at RL so more information can be gathered.
04:06:34 PM |  HyperSpin Started
04:06:34 PM |  Going windowed mode
04:06:34 PM |  Checking for updates
04:06:34 PM |  Update Check Complete
04:06:34 PM |  Startup program unavailable
04:06:34 PM |  Playing intro video
04:06:48 PM |  Error intializing joysticks
04:06:48 PM |  Menu Mode is multi
04:06:48 PM |  Loading Main Menu.xml
04:06:48 PM |  Main Menu.xml successfully loaded
04:06:48 PM |  Main Menu wheel loaded successfully
04:06:50 PM |  Loading Nintendo Entertainment System.xml
04:06:50 PM |  Main Menu.xml successfully loaded
04:06:50 PM |  Nintendo Entertainment System wheel loaded successfully
04:06:55 PM |  Launching Game
04:06:55 PM |  Using HyperLaunch
04:06:55 PM |  Getting Launcher path
04:06:55 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
04:06:55 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
04:06:55 PM |  Running Launcher
04:06:55 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "10-Yard Fight (USA, Europe)"
04:07:08 PM |  Launching Game
04:07:08 PM |  Using HyperLaunch
04:07:08 PM |  Getting Launcher path
04:07:08 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
04:07:08 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
04:07:08 PM |  Running Launcher
04:07:08 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "1942 (Japan, USA)"
04:07:11 PM |  Launching Game
04:07:11 PM |  Using HyperLaunch
04:07:11 PM |  Getting Launcher path
04:07:11 PM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
04:07:11 PM |  Launcher located at C:\HyperSpin\HyperLaunch.exe
04:07:11 PM |  Running Launcher
04:07:11 PM |  Launcher Command Line is: C:\HyperSpin\HyperLaunch.exe "Nintendo Entertainment System" "1942 (Japan, USA)"
i can see by looking at the log file that your right its using a deafual but i dont know why?
C:\RocketLauncher\RocketLauncher\RocketLauncher.exe  that is the link to my file i know theres 2 rocketlaunch files just because i named the file before i droped it in.
[Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=Nintendo Entertainment System
Hyperlaunch_PathC:\RocketLauncher\RocketLauncher\RocketLauncher.exe
ok thank you now when i run a mame game i get "can not find C:\RocketLauncher\RocketLauncher\RocketLauncherUI\Databases\MAME\MAME.xml"
the only data base i have in there is system
do i need to move my hyperspin data base to there?
