laburraloca123 Posted April 6, 2016 Posted April 6, 2016 every time I attempt to run a rom I keep getting this error message. Can anyone help??? --------------------------- AutoHotkey.dll --------------------------- Error: "・" is not a valid key name. Line# 12281: Hotkey,KeyGroupWithSpaces,%LabelForSingleKey%,%Options% 12282: } 12282: Else 12282: { 12283: Log("XHotkeyTableCreation - " . (If options = "OFF" ? "Disabling extended Hotkey method for key(s): """ . KeyGroup . """" : "Using extended Hotkey method for key(s): """ . KeyGroup . """ to call a group label"),5) 12284: Loop,Parse,KeyGroup,&,%a_space% 12285: { ---> 12286: Hotkey,XHotKeyTable[currentGroup,A_Index,2],HotKeyModeProcess,%Options% 12287: XHotKeyTable[currentGroup,1,12] := true 12288: } 12289: } 12290: TableKeyGroups .= KeyGroup . "," 12291: Log("XHotkeyTableCreation - Ended",5) 12292: Return,XHotKeyTable 12293: } The current thread will exit. ---------------------------
laburraloca123 Posted April 7, 2016 Author Posted April 7, 2016 Yes i am using RocketLauncher, I've updated RocketLauncher I tried running it as admin and made an exception on my antivirus and no change. i tried installing HyperSpin And RocketLauncher again and no change.
dje37 Posted April 26, 2016 Posted April 26, 2016 Hi i have almost same issue while trying to install and setup HS and RL according to the official tutorial of AV Archivist I'm on Win 10 and Avast is my antivirus When I arrive to the point I need to try a game on RL, an AHK window pop up saying : Error: "・" is not a valid key name. Line# 13966: Hotkey,KeyGroupWithSpaces,%LabelForSingleKey%,%Options% 13967: } 13967: Else 13967: { 13968: Log("XHotkeyTableCreation - " . (If options = "OFF" ? "Disabling extended Hotkey method for key(s): """" : "Using extended Hotkey method for key(s): """ . KeyGroup . """ to call a group label"),5) 13969: Loop,Parse,KeyGroup,&,%a_space% 13970: { ---> 13971: Hotkey,XHotKeyTable[currentGroup,A_Index,2],HotKeyModeProcess,%Options% 13972: XHotKeyTable[currentGroup,1,12] := true 13973: } 13974: } 13975: TableKeyGroups .= KeyGroup . "," 13976: Log("XHotkeyTableCreation - Ended",5) 13977: Return,XHotkeyTable 13978: } The current thread will exit Thks for your help
