cathaldub Posted December 14, 2008 Posted December 14, 2008 Is it possible to hide/Group clones/different sets? Or is there a way to create a mame.xml without clones in it http://emulation.4shared.com
cathaldub Posted December 15, 2008 Author Posted December 15, 2008 Anyone? http://emulation.4shared.com
rschuerken Posted December 18, 2008 Posted December 18, 2008 I have the same question - but looks like there is no answer? I like Hyperspin but it is so useless with mame because the list is too big. And i dont want to play 10 Clones of 1942 so if there is a way to get rid of them and only show one version if it - that would be extremely GREAT !
Mario.NET Posted December 18, 2008 Posted December 18, 2008 Is it possible to hide/Group clones/different sets?Or is there a way to create a mame.xml without clones in it With MAMEFilter you could load the mame.xml file stripping all clones, then save it. There's a sample template to load anly original games from a mame listxml file, apply the same filter to the hyperspin template and you are set! bye
rschuerken Posted December 18, 2008 Posted December 18, 2008 Hi! Thanks for the hint, i tried that but failed, i think im just to dumb. What is the exact way to get a hyperspin compatible xml file? I did: 1. mame -listxml >mame.xml 2. opened mamefilter 3. selected mame:originals (MAME:6) as a load filter and the mame.xml i generated 4. clicked Load data -> result is 3910 Rows (7304 parsed) Now I need the appropiate output template but the only two I have are "mame to mamewah" and "to move_roms batch file". The only way to get a hyperspin is I select hs8:all (HS:5) as a load filter! Any help would be greatly appreciated
rschuerken Posted December 18, 2008 Posted December 18, 2008 Update - as mentioned - just too dumb... Using HyperHQ old version I can generate a hypersin compatible list with the intended filter. Hope it works - will try in a few minutes *gg*
cathaldub Posted December 18, 2008 Author Posted December 18, 2008 Let me know how you get on, I'm going to give this a go later on or in the morning. It would be great if there was a more friendly way of creating xml files with filters in Hyper HQ http://emulation.4shared.com
crusade Posted December 18, 2008 Posted December 18, 2008 If you manage to create a xml file with no clones, could you post it here? I tried to make one this evening, but somehow I couldnt figure it out.:-/
EVEGames Posted December 18, 2008 Posted December 18, 2008 Gentlemen, there's more than 1 way to skin a cat. How about using Clrmamepro to merge your rom sets. Then you create the XML file, and there will be no set 1 / set 2, because Clrmamepro will have merged those sets into their parent sets.
cathaldub Posted December 18, 2008 Author Posted December 18, 2008 Gentlemen, there's more than 1 way to skin a cat. How about using Clrmamepro to merge your rom sets. Then you create the XML file, and there will be no set 1 / set 2, because Clrmamepro will have merged those sets into their parent sets. Sounds like someone wants to do a tutorial http://emulation.4shared.com
jasonorme666 Posted December 7, 2009 Posted December 7, 2009 I'm using Maximus Arcade since it supports this feature. This is the one thing thats stopping me using Hyperspin.
BadBoyBill Posted December 7, 2009 Posted December 7, 2009 Alright I went ahead and added this feature for the next release. It works fine.
GayGoblin Posted December 7, 2009 Posted December 7, 2009 Cant you go into HyperHQ and click the Use parent clones button under mame settings. I think it will fix your problem. It will only pull 1 version of each game. Another thing you can do is just display games with themes. So if 1 version of your game has a theme and the others dont it will pull that version in HS I'm currently having a issue with the list loading. I think something in my theme/rom folders are not matching. Worth a try though
jasonorme666 Posted December 7, 2009 Posted December 7, 2009 Alright I went ahead and added this feature for the next release. It works fine.
maxcade Posted April 25, 2014 Posted April 25, 2014 how bout opening hyperHQ,opening mame,opening navigation/themes tab and ticking parents only ,hope this sorts it for you,regards maxcade
