infinity2134 Posted March 29, 2009 Posted March 29, 2009 I think I have everything set right but when i try to start the rom it goes to a black screen and then eventually returns to the menu. Any idea what is going on? Thanks in advance, Josh
SophT Posted March 29, 2009 Posted March 29, 2009 sorry, you'll need to be more specific. what system are you using? and can you please post the contents of log.txt to make it easier to analyze. thanks! Things I Break ----- System Requirements? How do I remove rom warnings? How do I shut-down my computer? How do I shell HyperSpin?
infinity2134 Posted March 30, 2009 Author Posted March 30, 2009 I messed around with a bit and finally got it to work.
Leavitte13 Posted November 19, 2014 Posted November 19, 2014 How did you get it to work. I've got the same issue. Roms I know will play when loading outside hyperspin with the emulator but not in hyperspin wheel. It goes to a black screen. I'm using zsnes emulator. Other games work just not all of them. Any thoughts?
derekablackburn Posted November 21, 2014 Posted November 21, 2014 How did you get it to work. I've got the same issue. Roms I know will play when loading outside hyperspin with the emulator but not in hyperspin wheel. It goes to a black screen. I'm using zsnes emulator. Other games work just not all of them. Any thoughts? If you are using hyperlaunch make sure that you have your path set correctly in the settings.ini, I had to change mine from a relative path to get zsnes to load correctly.
