nulldc crash when opening from HS - plz help
Mungeste
I'm having problems too, when starting null dc from hyperspin i get a black screen with the windows cursor then have to task manager crash hyperlaunch.. here are my settings if anyone could find a fault or give me any suggestions it would be greatly appreciated. My cab just isn't right without mvc2
nulldc.cfg
;; nullDC config file;;
[nullDC]
Dynarec.Enabled=1
Dynarec.DoConstantPropagation=1
Dynarec.UnderclockFpu=0
Dreamcast.Cable=3
Dreamcast.RTC=1543276888
Emulator.AutoStart=1
Emulator.NoConsole=1
[nullDC_plugins]
GUI=nullDC_GUI_Win32.dll
Current_PVR=nullPVR_Win32.dll
Current_GDR=nullGDR_Win32.dll
Current_AICA=nullAICA_Win32.dll
Current_ExtDevice=nullExtDev_Win32.dll
Current_maple0_5=drkMapleDevices_Win32.dll:0
Current_maple1_5=NULL
Current_maple2_5=NULL
Current_maple3_5=NULL
Current_maple0_0=NULL
Current_maple0_1=NULL
Current_maple0_2=NULL
Current_maple0_3=NULL
Current_maple0_4=NULL
Current_maple1_0=NULL
Current_maple1_1=NULL
Current_maple1_2=NULL
Current_maple1_3=NULL
Current_maple1_4=NULL
[drkpvr]
Emulation.AlphaSortMode=1
Emulation.PaletteMode=1
Emulation.ModVolMode=1
Emulation.ZBufferMode=3
OSD.ShowFPS=0
OSD.ShowStats=0
Fullscreen.Enabled=1
Fullscreen.Res_X=1024
Fullscreen.Res_Y=768
Fullscreen.Refresh_Rate=60
Enhancements.MultiSampleCount=0
Enhancements.MultiSampleQuality=0
Enhancements.AspectRatioMode=1
[imageReader]
PatchRegion=0
LoadDefaultImage=1
DefaultImage=defualt.gdi
LastImage=c:\game.gdi
[nullAica]
BufferSize=1024
LimitFPS=1
HW_mixing=0
SoundRenderer=1
GlobalFocus=1
BufferCount=1
CDDAMute=0
GlobalMute=0
DSPEnabled=0
[nullExtDev]
mode=0
adapter=0
sega dreamcast.ini
[exe info]
path = C:\HyperSpin\Emulators\Sega Dreamcast\
rompath = C:\HyperSpin\Emulators\Sega Dreamcast\roms\
userompath = true
exe = nullDC_1.0.3_nommu.exe
romextension = cdi
parameters =
searchsubfolders = false
pcgame = false
winstate = HIDDEN
hyperlaunch = true
hyperlaunch.ahk
else if (systemName = "Sega Dreamcast" && executable = "nullDC_1.0.3_nommu.exe")
hideDesktop()
Hotkey, %exitEmulatorKey%, CloseProcess
LShift::v
LCTRL::l
LAlt::b
Run, %Executable% -config ImageReaderefaultImage="%romPath%%romName%%romEx tension%", %EmuPath%,Hide UseErrorLevel
WinWait, nullDC
Sleep,1000
WinShow, ahk_class ndc_main_window
Process, WaitClose, nullDC_1.0.3_nommu.exe
Try changing these, as this is what I use with no probs. Also, run nullDC outside of Hyperspin and choose a default image just in case. Add gdi to your romextensions if you're using a set that has them and not just cdi images. If your images are in seperate folders, change search sub folders.
Dreamcast.Cable=0
Emulator.NoConsole=0
PatchRegion=1
Also, change the line in your ahk from this:
to this:
Run, %Executable% -config ImageReader:DefaultImage="%romPath%%romName%%romExtension%", %EmuPath%,Hide UseErrorLevel
^it keeps showing a smiley, but it should be ImageReader : DefaultImage without the spaces.^
Hope this helps out.
Hey,
I cracked this last night, played round with the nulldc.cfg and it started working. However i'm not getting video crashes after a few minutes of play time (which is annoying to say the least). I know this isnt a HS problem but if anyone had any ideas it would be great. (crashing saying there is a driver problem)
Thanks for the support j5350.
  • 4 years later...
j5350:
use the
[code ] tag in BB to avoid smilies: (no spaces)
Run, %Executable% -config ImageReader:DefaultImage="%romPath%%romName%%romEx tension%", %EmuPath%,Hide UseErrorLevel
I was having the same crash issue and this was the right answer, Thanks a lot and sorry for the bad english.
