jchavis444 Posted April 23, 2016 Posted April 23, 2016 any help on how to setup these two..... i cant find a direct guide anywhere...i wouldnt say im a noob, but nowhere near and expert lol and thanks guys cause its truely brain racking
pinsanity Posted April 24, 2016 Posted April 24, 2016 Use the PC Launcher module. Set up each and EVERY game individually and separately beforehand so that it fully launches. Then create launch shortcuts for EVERY exe and put them into a separate folder. Open Rocketlauncher modules folder and find PC launcher module. Open it with notepad and add Big Fish Games and Pop Cap to the list of systems. Save and close. Open Rocketlauncher UI. Go to Big Fish Games system. Go to the modules tab. Click once on the PC launcher module and then select from the icons above "edit global module settings" A second window will open. Enlarge it to fill screen. Select rom settings tab. Open your shortcuts folder you made earlier and select every file. Drag them onto the bullseye red target icon on the open Rocketlauncher window. Done all games are now set up in Big Fish Games. Do the same as above for Pop Cap. Lastly create xml databases for both systems using Dons Hyperspin tools based on the shortcuts folders you made for each and use that in Hyperspin.
