Odd issue with Dolphin
Jaydeekay
I started out setting up dolphin triforce for the arcade Mario Karts using Dolphin 3.0.697. I had it all working in Rocketlauncher & hyperspin perfectly...
Then I set up the Gamecube version of dolphin(Last stable version 4.0.2). I created a portable.txt file in each emulators folder so they're both using their own set of config files. But now when I try to launch the arcade Mario Karts it crashes & I see it's the Gamecube Dolphin emulator (4.0.2) running instead of the other one specified in all the dolphin triforce settings. When I hit "launch Emulator" on the emulator tab in rocketlauncher it starts Dolphin Triforce 3.0.697 just fine. I can start the games from the emulators menu & they work. When I go to the games tab, audit & try to launch, it tries to open the regular Dolphin 4.0.2 & crashes. It worked fine before I set up the regular Dolphin emulator. What did I screw up here? lol
Ended up fixing it by simply wiping all the emulators off hyperspin & the hard drive & setting it all up fresh again. Making sure both had portable.txt files in their folders on the 1st boot so settings don't get mixed. (Pretty sure this was the problem) they're both working properly now.
