Sega genesis roms not seen in Hyperspin
robin1234
i have set up super nintendo no problem
but now i'm setting up sega genesis all roms are named correct and are seen in rocketlauncher and can be played
when i set the roms in hyperspin they wont show up ( only 3 ninja kick back)  did it in hyperHQ and set the roms path correct even did it in the settings check and set the path there correct
still no luck all setting are correct
the fille extencion is bin also set correct
even reinstalled hyperspin and did the upgrade to 1.4 all over no luck
In HyperHQ check to see if you have any wheel filters set for Genesis. The 3 Ninjas wheel is provided by default so if you haven't added any other wheel images and have the Wheels Only filter on it will only show that game.
On a related note, if you're using RocketLauncher you only have to set the rompath and extensions in HyperHQ if you have the Roms Only filter on.
i have set the rompath and extensions in HyperHQ and the Roms Only filter on.
and using Rocketlauncher
than i stil have to change the Wheels only filter
or is that only when you use hyperspin with out Rocketlauncher
If the Wheels Only filter is on it will only display games that have wheel images. So if you haven't added any images for Genesis yet and that filter is on, it will only show 3 Ninjas.
That fix the probleem THX
