I can't enter a game from the MAME wheel, but I could 10 seconds ago
Abqshark
Hyperspin was working fine, then I think I tried to start a bios file or something like that on my wheel and whammo, I can't enter any game now. This is for MAME. I can enter and exit a wheel with the keys I set (enter) and (esc), but not a game. Any idea of how I broke hyperspin? I'm not sure what log to post on here for help. I read something about a fade in error, might that have something to do with it? Thanks for any help or advice you can give.
I'm not a pro at HS yet but have you gone back into RL and checked if your games load from there?
I'm lovin my arcade
When I change any settings I just do one change, test it and then either revert back or keep the new settings. A big mistake I made when I first started was changing a bunch of stuff at once, then I was unsure what was throwing the error.....
I'm lovin my arcade
They run fine from RocketLauncher.
I would check what the fade is set at in RL settings.... I'm at work and can't remember which tab it is
I'm lovin my arcade
Here is a run through trying to get ms. pacman to run. HS starts fine, I go into the mame wheel, but nothing happens when I try to start Ms. Pacman, so I exit out of HS.
HyperSpin Started
06:13:25 AM |  Going FullScreen
06:13:25 AM |  Checking for updates
06:13:25 AM |  Update Check Complete
06:13:25 AM |  Startup program unavailable
06:13:25 AM |  Playing intro video
06:13:28 AM |  Menu Mode is multi
06:13:28 AM |  Loading Main Menu.xml
06:13:28 AM |  Main Menu.xml successfully loaded
06:13:28 AM |  Main Menu wheel loaded successfully
06:13:30 AM |  Loading MAME.xml
06:13:30 AM |  Main Menu.xml successfully loaded
06:13:31 AM |  MAME wheel loaded successfully
06:13:33 AM |  Launching Game
06:13:33 AM |  Using HyperLaunch
06:13:33 AM |  Getting Launcher path
06:13:33 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
06:13:33 AM |  Launcher located at F:\Hyperspin\HyperLaunch.exe
06:13:33 AM |  Running Launcher
06:13:33 AM |  Launcher Command Line is: F:\Hyperspin\HyperLaunch.exe "MAME" "mspacman"
06:13:34 AM |  Launching Game
06:13:34 AM |  Using HyperLaunch
06:13:34 AM |  Getting Launcher path
06:13:34 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
06:13:34 AM |  Launcher located at F:\Hyperspin\HyperLaunch.exe
06:13:34 AM |  Running Launcher
06:13:34 AM |  Launcher Command Line is: F:\Hyperspin\HyperLaunch.exe "MAME" "mspacman"
06:13:35 AM |  Launching Game
06:13:35 AM |  Using HyperLaunch
06:13:35 AM |  Getting Launcher path
06:13:35 AM |  Can't find HyperLaunch, defaulting to root HyperLaunch.exe
06:13:35 AM |  Launcher located at F:\Hyperspin\HyperLaunch.exe
06:13:35 AM |  Running Launcher
06:13:35 AM |  Launcher Command Line is: F:\Hyperspin\HyperLaunch.exe "MAME" "mspacman"
06:13:38 AM |  Loading Main Menu.xml
06:13:38 AM |  Main Menu.xml successfully loaded
06:13:38 AM |  Main Menu wheel loaded successfully
06:13:41 AM |  Exit program unavailable
06:13:41 AM |  Quiting Hyperspin
06:13:41 AM |  Bye!
Are you using the latest rocketlauncher?..... It's looking like there's something wrong with HS path to your RL exe
I'm lovin my arcade
Check over your settings in hyperhq for the mame wheel, make sure all your paths are correct
I'm lovin my arcade
Yout log shows that the Hyperlaunch_path in your HyperSpin/Settings/Settings.ini is incorrect, so it reverts to using HyperLaunch. Make sure that the Hyperlaunch_path is pointing to your RocketLauncher.exe and you don't have any typos.
I think my settings.ini file is correct, although I was curious about that hyperlaunch error my self. Here the top part of my settings.ini
Main]
Menu_Mode=multi
Single_Mode_Name=MAME
Enable_Exit_Menu=true
Enable_Exit=true
Exit_Default=yes
Exit_Action=exit
Version=1.0.0.0
Last_System=MAME
Hyperlaunch_Path=F:\RocketLauncher\RocketLauncher.exe\
I figured it out. As I suspected it had something to do with trying to start the bios file as a game. It was remembering the last game I tried to start and was somehow stuck on that. I went into HyperHQ and went to Wheel Settings>MAME Wheel> Navigation/Themes tab> Wheel Entrance Options and unchecked the "Return to last game" box. It was caught in some kind of loop trying to start that Bios file as a game. Thanks for all your suggestions, as going through the things you mentioned helped me narrow down what was wrong.
You shouldn't have that extra backslash at the end. If you do and it's launching games then chances are it's using HyperLaunch and not RocketLauncher.
Okay, I'll change that. Thanks for the tip.
