tscottn Posted July 26, 2016 Posted July 26, 2016 Hey guys, So im running into a issue with both Atari 5200 and 7800 emulators. It seems that both work perfectly when i load a game through RocketlauncherUI, However when I try to run a game through Hyperspin neither will load a game. Basically it tries to load but then brings be back to the HS main menu. Like I said, both systems run perfectly loading a game through RLUI but not through HS, which is really weird. I have all my other emulators working through HS perfect so I dont think its a setup issue. Attached is my log. I hope someone can help. Thanks so much. 09:41:50:011 | RL | INFO | +N/A | Main - RocketLauncher v1.1.1.0 (www.rlauncher.com) 09:41:50:042 | RL | INFO | +31 | Main - System Specs: RocketLauncher Dir: Z:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 8 Pro SKU: Professional Total Memory: 16347.50 MB Free Memory: 14513.28 MB Used Memory: 1834.219 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 8 GPU 1 Name: NVIDIA GeForce GTX 960 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 10.18.13.6881 Sound 1 Device: NVIDIA High Definition Audio Sound 1 Status: Enabled Sound 2 Device: USB Audio Device Sound 2 Status: Enabled Sound 3 Device: Realtek High Definition Audio Sound 3 Status: Enabled Sound 4 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 4 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1680x1050 (1680x1050 work) [32bit] [59hz] [Landscape] (Primary) Current AHK Desktop Width: 1680 Current AHK Desktop Height: 1050 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 09:41:50:042 | RL | INFO | +0 | CheckFile - Checking if Z:\RocketLauncher\RocketLauncher.exe exists 09:41:50:042 | RL | INFO | +0 | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: Z:\Hyperspin\HyperSpin.exe 09:41:50:042 | RL | INFO | +0 | Main - Raw CLI received: "Atari 5200 Mario Bros. (USA)" 09:41:50:042 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 09:41:50:042 | RL | INFO | +0 | Process.Process - "Exist" "HyperSpin.exe" 09:41:50:058 | RL | INFO | +16 | Main - Detected HyperSpin.exe is currently running 09:41:50:058 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x0 y0 w1680 h1050 09:41:50:058 | RL | INFO | +0 | Main - RocketLauncher received "Atari 5200" and "Mario Bros. (USA)" 09:41:50:058 | RL | INFO | +0 | Main - Did not find a "Z:\RocketLauncher\Settings\Atari 5200\Game Options.ini" file, skipping any game-specific options. 09:41:50:058 | RL | INFO | +0 | Main - Mario Bros. (USA) is using the default emulator: Kat - Atari 5200 09:41:50:058 | RL | INFO | +0 | Main - Checking for a [Kat - Atari 5200] section in Z:\RocketLauncher\Settings\Atari 5200\Emulators.ini 09:41:50:058 | RL | INFO | +0 | Main - Found [Kat - Atari 5200] in Z:\RocketLauncher\Settings\Atari 5200\Emulators.ini 09:41:50:058 | RL | INFO | +0 | CheckFile - Checking if Z:\RocketLauncher\Modules\Kat5200\Kat5200.ahk exists 09:41:50:058 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 09:41:50:058 | RL | INFO | +0 | Main - Mario Bros. (USA) will use module: Z:\RocketLauncher\Modules\Kat5200\Kat5200.ahk 09:41:50:058 | RL | WARNING | +0 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "Z:\RocketLauncher\Settings\Global RocketLauncher.ini" 09:41:50:058 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "Z:\RocketLauncher\Settings\Atari 5200\RocketLauncher.ini" 09:41:50:073 | RL | INFO | +15 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 09:41:50:073 | RL | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\Emulators\Atari 5200\kat 5200\kat5200.exe exists 09:41:50:073 | RL | INFO | +0 | Main - INI Keys read 09:41:50:073 | RL | INFO | +0 | CheckFile - Checking if Z:\RocketLauncher\Module Extensions\7z.exe exists 09:41:50:073 | RL | INFO | +0 | CheckFile - Checking if Z:\RocketLauncher\Module Extensions\7z.dll exists 09:41:50:073 | RL | INFO | +0 | Main - "Mario Bros. (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 09:41:50:073 | RL | INFO | +0 | CheckPaths - Started 09:41:50:073 | RL | INFO | +0 | CheckPaths - Looking for rom: Z:\Hyperspin\Emulators\Atari 5200\roms\Mario Bros. (USA).a52 09:41:50:073 | RL | INFO | +0 | CheckPaths - Found rom: Z:\Hyperspin\Emulators\Atari 5200\roms\Mario Bros. (USA).a52 09:41:50:073 | RL | INFO | +0 | CheckPaths - Ended 09:41:50:073 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event 0 = 2 rlPath = Z:\RocketLauncher pluginPath = Z:\RocketLauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.1.1.0 rlAuthor = djvj rlURL = www.rlauncher.com langFile = Z:\RocketLauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 2136 frontendPath = Z:\Hyperspin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = Z exitEmulatorKey = ~Esc restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = Z:\Hyperspin\Emulators\Atari 5200\kat 5200\kat5200.exe emuPath = Z:\Hyperspin\Emulators\Atari 5200\kat 5200 emuName = Kat - Atari 5200 emuExt = exe baseRomPath = romPath = Z:\Hyperspin\Emulators\Atari 5200\roms romPathFromIni = Z:\Hyperspin\Emulators\Atari 5200\roms romExtension = .a52 romExtensionOrig = .a52 romExtensions = a52 executable = kat5200.exe systemDbName = Atari 5200 systemName = Atari 5200 dbPath = dbName = Mario Bros. (USA) dbExt = romName = Mario Bros. (USA) romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = Z:\RocketLauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = setResolution = logFile = logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel = 3 logShowDebugConsole = false logShowCommandWindow = false logCommandWindow = false logIncludeModule = true logIncludeFileProperties = true logIncludeDLLLogs = false errorSounds = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1680 originalHeight = 1050 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdDriveLetterScsi = vdAddDrive = true servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = Z:\RocketLauncher\Profiles\LEDBlinky ledblinkyRLProfile = Z:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher winIPACFullPath = ultraMapEnabled = false ultraMapFullPath = emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = false hideEmu = false hideFE = false suspendFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 0 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeSounds = true fade7zProgressMode = extraction fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = false fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = true fadeProgressDuration = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoDeveloper = text with label fadeRomInfoPublisher = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = Remaining Time fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = true fadeImgPath = Z:\RocketLauncher\Media\Fade RLDataPath = Z:\RocketLauncher\Data RLMediaPath = Z:\RocketLauncher\Media RLErrSoundPath = Z:\RocketLauncher\Media\Sounds\Error modulesPath = Z:\RocketLauncher\Modules moduleFullName = Z:\RocketLauncher\Modules\Kat5200\Kat5200.ahk moduleName = Kat5200 modulePath = Z:\RocketLauncher\Modules\Kat5200 moduleExtension = ahk moduleExtensionsPath = Z:\RocketLauncher\Module Extensions libPath = Z:\RocketLauncher\Lib sevenZEnabled = false sevenZPath = Z:\RocketLauncher\Module Extensions\7z.exe sevenZDllPath = Z:\RocketLauncher\Module Extensions\7z.dll sevenZExtractPath = Z:\Hyperspin\Extract sevenZExtractPathOrig = sevenZAttachSystemName = false sevenZDelTemp = true sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar 7zExtractPath = Z:\Hyperspin\Extract mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side mgOnLaunch = false pauseEnabled = true pauseKey = H:P pauseBackToMenuBarKey = X pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = Z:\RocketLauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = pauseLoadStateKeyCodes = keyboardEncoder = keyboardEncoderEnabled = false keymapperEnabled = true keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = Z:\Hyperspin\Utilities\Xpadder\Xpadder.exe joyToKeyFullPath = Z:\Utilities\JoyToKey\JoyToKey.exe profilePath = Z:\RocketLauncher\Profiles keymapperProfilePath = Z:\RocketLauncher\Profiles\xpadder keymapperFrontEndProfileName = Hyperspin keymapperFrontEndProfile = xpadder keymapperRocketLauncherProfileEnabled = false joyIDsEnabled = false joyIDsPreferredControllersGlobal = joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = Z:\RocketLauncher\Profiles\xpadder\Hyperspin defaultProfile = Z:\RocketLauncher\Profiles\xpadder\_Default systemProfile = Z:\RocketLauncher\Profiles\xpadder\Atari 5200 xPadderSystemProfile = Z:\RocketLauncher\Profiles\xpadder\Atari 5200\_Default emuProfile = Z:\RocketLauncher\Profiles\xpadder\Atari 5200\Kat - Atari 5200 romProfile = Z:\RocketLauncher\Profiles\xpadder\Atari 5200\Mario Bros. (USA) RocketLauncherProfile = Z:\RocketLauncher\Profiles\xpadder\RocketLauncher blankProfile = Z:\RocketLauncher\Profiles\xpadder\_Default\blank ahkFEProfile = Z:\RocketLauncher\Profiles\AHK\Hyperspin ahkDefaultProfile = Z:\RocketLauncher\Profiles\AHK\_Default ahkSystemProfile = Z:\RocketLauncher\Profiles\AHK\Atari 5200 ahkEmuProfile = Z:\RocketLauncher\Profiles\AHK\Atari 5200\Kat - Atari 5200 ahkRomProfile = Z:\RocketLauncher\Profiles\AHK\Atari 5200\Mario Bros. (USA) ahkRocketLauncherProfile = Z:\RocketLauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false shaderName = false shaderColor = shaderTransparency = statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = Z:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = Z:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe qResFullPath = Z:\RocketLauncher\Module Extensions\QRes.exe mon1O = pacDrivedllFile = Z:\RocketLauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = Z:\RocketLauncher\Lib\User Fade Animations.ini testFile = testDuration = initialErrorMode = 0 09:41:50:073 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 09:41:50:073 | RL | INFO | +0 | BuildScript - Loaded Keymapper Init.ahk scripts 09:41:50:073 | RL | INFO | +0 | BuildScript - Loaded Pause Init.ahk scripts 09:41:50:073 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 09:41:50:073 | RL | WARNING | +0 | BuildScript - "Z:\RocketLauncher\Lib\User Functions Init.ahk" not found 09:41:50:073 | RL | INFO | +0 | BuildScript - Validating module 09:41:50:073 | RL | INFO | +0 | BuildScript - Validation complete 09:41:50:073 | RL | INFO | +0 | BuildScript - Module: MEmu = Kat5200 MEmuV = v0.6.2 MURL = http://kat5200.jillybunch.com/ MAuthor = djvj MVersion = 2.0.4 MCRC = BC8C4343 MID = 635038268901251702 MSystem = "Atari 5200" ;---------------------------------------------------------------------------- ; Notes: ; In you emu dir, create a subdir named bios and place the 5200.rom there extracted. ; When you first start kat5200, you will be presented with a Wizard. Set the bios folder you created as your "Atari 8-Bit Image Directory" and leave Scan for BIOS? checked. ; While in the wizard, check the Fullscreen box to enable it and set Video Zoom to 2x. ; CLI is supported but doesn't seem to work. So for now, set your video options from the GUI. ; Settings are stored in the kat5200.db3 file. ; Roms must be extracted, zip is not supported ;---------------------------------------------------------------------------- StartModule() FadeInStart() primaryExe := new Emulator(emuPath . "\" . executable) ; instantiate emulator executable object emuPrimaryWindow := new Window(new WindowTitle("kat5200","SDL_app")) ; instantiate primary emulator window object emuConsoleWindow := new Window(new WindowTitle("","ConsoleWindowClass")) hideEmuObj := Object(emuConsoleWindow,0,emuPrimaryWindow,1) 7z(romPath, romName, romExtension, sevenZExtractPath) If StringUtils.Contains(romExtension,sevenZFormatsRegEx) ScriptError("Kat5200 only supports extracted roms. Please extract your roms or turn on 7z for this system as the emu is being sent this extension: """ . romExtension . """") HideAppStart(hideEmuObj,hideEmu) primaryExe.Run(" """ . romPath . "\" . romName . romExtension . """") emuPrimaryWindow.Wait() emuPrimaryWindow.WaitActive() HideAppEnd(hideEmuObj,hideEmu) FadeInExit() primaryExe.Process("WaitClose") 7zCleanUp() FadeOutExit() ExitModule() CloseProcess: FadeOutStart() emuPrimaryWindow.Close() Return 09:41:50:089 | RL | INFO | +16 | BuildScript - Loaded Pause scripts 09:41:50:089 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 09:41:50:089 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 09:41:50:089 | RL | WARNING | +0 | BuildScript - "Z:\RocketLauncher\Lib\User Functions.ahk" not found 09:41:50:089 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 09:41:50:089 | RL | INFO | +0 | Main - Module is built 09:41:50:089 | RL | INFO | +0 | CheckFile - Checking if Z:\RocketLauncher\AutoHotkey.dll exists 09:41:50:089 | RL | INFO | +0 | Main - Running module 09:41:50:230 | MD | INFO | +N/A | Module initialized 09:41:50:230 | MD | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists 09:41:50:230 | MD | INFO | +0 | Keymapper - Loading xpadder 09:41:50:230 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 09:41:50:230 | MD | INFO | +0 | GetJoystickArray - Started 09:41:50:230 | MD | INFO | +0 | GetJoystickGUID - Started 09:41:50:230 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: C0B352DBB452E6118008444553540000 09:41:50:230 | MD | INFO | +0 | GetJoystickArray - Ended 09:41:50:230 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> Z:\RocketLauncher\Profiles\xpadder\Atari 5200\_Default\p1.xpadderprofile 09:41:50:230 | MD | INFO | +0 | RunXpadder - Started 09:41:50:230 | MD | INFO | +0 | Process - Exist JoyToKey.exe 09:41:50:230 | MD | INFO | +0 | Run - Running: Z:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 09:41:50:261 | MD | INFO | +31 | Process - WaitClose Xpadder.exe 2 09:41:50:370 | MD | INFO | +109 | Run - Running: Z:\Hyperspin\Utilities\Xpadder\Xpadder.exe "Z:\RocketLauncher\Profiles\xpadder\Atari 5200\_Default\p1.xpadderprofile" /M 09:41:50:370 | MD | INFO | +0 | RunXpadder - Ended 09:41:50:370 | MD | INFO | +0 | RunKeymapper - Ended 09:41:50:370 | MD | INFO | +0 | StartModule - Started 09:41:50:370 | MD | INFO | +0 | StartModule - MEmu: Kat5200 MEmuV: v0.6.2 MURL: http://kat5200.jillybunch.com/ MAuthor: djvj MVersion: 2.0.4 MCRC: BC8C4343 iCRC: MID: MSystem: "Atari 5200" 09:41:50:370 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Atari 5200" 09:41:50:370 | MD | INFO | +0 | PluginInit - Started 09:41:50:370 | MD | INFO | +0 | CheckFile - Checking if Z:\Hyperspin\Databases\Atari 5200\Atari 5200.xml exists 09:41:50:370 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 09:41:50:370 | MD | INFO | +0 | BuildAssetsTable - Ended 09:41:50:370 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 09:41:50:370 | MD | INFO | +0 | BuildAssetsTable - Ended 09:41:50:370 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 09:41:50:370 | MD | INFO | +0 | BuildAssetsTable - Ended 09:41:50:370 | MD | INFO | +0 | PluginInit - Ended 09:41:50:370 | MD | INFO | +0 | StartModule - Ended 09:41:50:370 | MD | INFO | +0 | Process.Run - Running: Z:\Hyperspin\Emulators\Atari 5200\kat 5200\kat5200.exe "Z:\Hyperspin\Emulators\Atari 5200\roms\Mario Bros. (USA).a52" 09:41:50:401 | MD | INFO | +32 | Window.Wait - Waiting for window "kat5200 ahk_class SDL_app" 09:41:50:931 | MD | INFO | +515 | Window.WaitActive - Waiting for "kat5200 ahk_class SDL_app" 09:41:51:079 | MD | INFO | +156 | Process.Process - "WaitClose" "kat5200.exe" 09:41:57:887 | MD | INFO | +6813 | CloseProcess - Started, user requested to end launched application 09:41:58:124 | MD | INFO | +234 | CloseProcess - Ended 09:41:58:124 | MD | INFO | +0 | ExitModule - Started 09:41:58:124 | MD | INFO | +0 | Starting Updating Statistics: 09:41:58:155 | MD | INFO | +32 | Game section statistics updated. 09:41:58:155 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 09:41:58:155 | MD | INFO | +0 | GetJoystickArray - Started 09:41:58:155 | MD | INFO | +0 | GetJoystickGUID - Started 09:41:58:155 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: C0B352DBB452E6118008444553540000 09:41:58:155 | MD | INFO | +0 | GetJoystickArray - Ended 09:41:58:155 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> Z:\RocketLauncher\Profiles\xpadder\Hyperspin\p1.xpadderprofile 09:41:58:155 | MD | INFO | +0 | RunXpadder - Started 09:41:58:155 | MD | INFO | +0 | Process - Exist JoyToKey.exe 09:41:58:155 | MD | INFO | +0 | Run - Running: Z:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 09:41:58:187 | MD | INFO | +31 | Process - WaitClose Xpadder.exe 2 09:41:58:296 | MD | INFO | +109 | Run - Running: Z:\Hyperspin\Utilities\Xpadder\Xpadder.exe "Z:\RocketLauncher\Profiles\xpadder\Hyperspin\p1.xpadderprofile" /M 09:41:58:296 | MD | INFO | +0 | RunXpadder - Ended 09:41:58:296 | MD | INFO | +0 | RunKeymapper - Ended 09:41:58:296 | MD | INFO | +0 | ExitModule - Ended End of Module Logs 09:41:58:405 | RL | INFO | +8313 | Main - Module ended, exiting RocketLauncher normally 09:41:58:405 | RL | INFO | +0 | ExitScript - Started 09:41:58:405 | RL | INFO | +0 | ExitScript - Checking what application is currently in focus. 09:41:58:405 | RL | INFO | +0 | ExitScript - HyperSpin is currently active. Proceeding with exit 09:41:58:405 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 09:41:58:405 | RL | INFO | +0 | ExitScript - Restored cursor
