snakey Posted July 28, 2016 Posted July 28, 2016 Hello folks, I've been running into an issue which I cannot figure out what to do to fix. I added my MS-DOS games to RocketLauncher, followed the Module Notes to get it working (or I believe I did?). When I click the Launch button on RocketLauncher I have no problem and the game opens, full screen. However, if I start the game from HyperSpin, my screen will flicker a few times as if it's trying to go full screen and goes crazy basically, ending up with a Windowed version of the game behind the HyperSpin window. I can ALT+TAB and then ALT+ENTER to get it working but, of course, I just want it to work automatically. I set Full Screen to False just to see what would happen and I also noticed that when the DOS Box Window opens, it loses focus, switching back to the HyperSpin window. --- The other quesiton I have is that I run a setup with 2 monitors (1 Monitor, 1 TV) on extended mode. Would you guys know any way to force the DOS Box Window to open on the 2nd monitor (without going into Clone Mode and all that stuff). An actual setting maybe like MAME and RetroArch have? I forgot to mention, if anyone would have a set of instructions to get it working directly through DOSBox (without Dfend) could you point me in the right direction? I read about the eXoDOS setup but I already own my games.. So maybe a guide to "convert" my games into eXoDOS structure? Thanks a lot everyone!
Guest Posted July 28, 2016 Posted July 28, 2016 Hello folks, I've been running into an issue which I cannot figure out what to do to fix. I added my MS-DOS games to RocketLauncher, followed the Module Notes to get it working (or I believe I did?). When I click the Launch button on RocketLauncher I have no problem and the game opens, full screen. However, if I start the game from HyperSpin, my screen will flicker a few times as if it's trying to go full screen and goes crazy basically, ending up with a Windowed version of the game behind the HyperSpin window. I can ALT+TAB and then ALT+ENTER to get it working but, of course, I just want it to work automatically. I set Full Screen to False just to see what would happen and I also noticed that when the DOS Box Window opens, it loses focus, switching back to the HyperSpin window. --- The other quesiton I have is that I run a setup with 2 monitors (1 Monitor, 1 TV) on extended mode. Would you guys know any way to force the DOS Box Window to open on the 2nd monitor (without going into Clone Mode and all that stuff). An actual setting maybe like MAME and RetroArch have? I forgot to mention, if anyone would have a set of instructions to get it working directly through DOSBox (without Dfend) could you point me in the right direction? I read about the eXoDOS setup but I already own my games.. So maybe a guide to "convert" my games into eXoDOS structure? Thanks a lot everyone! Honestly - just use the exodos set, it's much easier to get working nicely with HS/RL
snakey Posted July 28, 2016 Author Posted July 28, 2016 Honestly - just use the exodos set, it's much easier to get working nicely with HS/RL I know.. But just wanted to get things going with the current DOS games I have.. I have been trying to download it from the Archive.org website but it stops downloading all of a sudden. Would you happen to know another place to get it from? Thanks!
