Sega Model 2 emulator will not return to wheel on exit
jgreno72
Hi, I'm new to posting logs so hopefully I do this right. When exiting Sega Model 2 emulator running from Hyperspin, it does not return to Hyperspin wheel. The windows screen comes back up and Hyperspin is running minimized and will not return to full screen. This is my log:
11:01:37:656 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com)
11:01:37:660 | RL |   WARNING  | +0     | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance.
11:01:38:997 | RL |     DEBUG  | +1344  | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
11:01:38:998 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
11:01:38:000 | RL |      INFO  | +0     | Main - System Specs:
RocketLauncher Dir: E:\RocketLauncher
RocketLauncher is: 32-bit
OS: Microsoft Windows 10 Home
SKU: Windows 8
Total Memory: 8099.54 MB
Free Memory: 5336.21 MB
Used Memory: 2763.328 MB
SystemType: 64-bit
Physical Processors: 1
Logical Processors: 4
GPU 1 Name: Intel(R) HD Graphics 5500
GPU 1 RAM: 1024.00 MB
GPU 1 Driver Version: 10.18.15.4240
Sound 1 Device: Intel® Smart Sound Technology (Intel® SST)
Sound 1 Status: Enabled
Sound 2 Device: Intel(R) Display Audio
Sound 2 Status: Enabled
System Locale: en-US
Formats Locale: en-US
Windows UI Language: en-US
Text Encoding: Windows-1252
OS Admin Status: No
RL Compatibility Flags:  HIGHDPIAWARE
Latest .Net Version: v4.0.30319
Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape]  (Primary)
Monitor #2 (\\.\DISPLAY2): 1920x1080 (1920x1020 work) [32bit] [60hz] [Landscape]
Current AHK Desktop Width: 1920
Current AHK Desktop Height: 1080
Monitor #1 DPI: 100
Monitor #2 DPI: 100
ErrorMode: 0
AutoHotkey Path:
AHK Version: 1.1.13.00
Unicode: No
11:01:39:001 | RL |      INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\RocketLauncher.exe exists
11:01:39:074 | RL |     DEBUG  | +78    | CheckFile - Attributes:
FileDescription          RocketLauncher
FileVersion              1.1.1.1
LegalCopyright           ©2016 RocketLauncher
ProductName              djvj's one swell guy!
ProductVersion           1.1.1.1
CompanyName              Your favorite Front End companion! Visit us @ www.rlauncher.com
File Size: 2179584 bytes
Created: 5/21/2016 - 1:35:31 PM
Modified: 7/19/2016 - 4:09:23 PM
11:01:39:076 | RL |      INFO  | +0     | Main - Raw CLI received: "Sega Model 2 doa"
11:01:39:101 | RL |     TRACE  | +16    | File.__New - Creating new file object of: "E:\RocketLauncher\Module Extensions\RocketLauncher.dll"
11:01:39:135 | RL |      INFO  | +31    | File.CheckFile - Checking if "E:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists
11:01:39:136 | RL |     TRACE  | +0     | File.Exist - This file exists: E:\RocketLauncher\Module Extensions\RocketLauncher.dll
11:01:39:140 | RL |     DEBUG  | +16    | File.CheckFile - Attributes:
FileDescription          RocketLauncher Utils
FileVersion              1.0.0.9
InternalName             RocketLauncher.dll
LegalCopyright           Copyright © RocketLauncher 2013-2016
OriginalFilename         RocketLauncher.dll
ProductName              RocketLauncher
ProductVersion           1.0.0.9
File Size: 68608 bytes
Created: 5/21/2016 - 1:35:54 PM
Modified: 7/19/2016 - 4:09:18 PM
11:01:39:272 | RL |      INFO  | +125   | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\Array.ahk
11:01:39:274 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4781 bytes
Created: 5/21/2016 - 1:35:44 PM
Modified: 5/21/2016 - 2:23:37 PM
11:01:39:307 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2
11:01:39:309 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 5077 bytes
Modified: 5/21/2016 - 2:23:46 PM
11:01:39:310 | RL |      INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\Module Extensions\BlockInput.exe exists
11:01:39:374 | RL |     DEBUG  | +63    | CheckFile - Attributes:
FileDescription
FileVersion              1.1.09.04
InternalName
OriginalFilename
ProductName
ProductVersion           1.1.09.04
File Size: 657920 bytes
Created: 5/21/2016 - 1:35:45 PM
Modified: 5/20/2016 - 4:08:08 PM
11:01:39:411 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop
11:01:39:413 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5323 bytes
Created: 5/21/2016 - 1:35:46 PM
Modified: 5/21/2016 - 2:24:02 PM
11:01:39:433 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk
11:01:39:436 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5716 bytes
11:01:39:544 | RL |      INFO  | +110   | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\gdip.ahk
11:01:39:547 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 88789 bytes
Created: 5/21/2016 - 1:35:47 PM
11:01:39:594 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3
11:01:39:600 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5891 bytes
11:01:39:601 | RL |      INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\Module Extensions\gsdll32.dll exists
11:01:39:651 | RL |     DEBUG  | +47    | CheckFile - Attributes:
File Size: 13090816 bytes
Created: 5/21/2016 - 1:35:50 PM
Modified: 5/20/2016 - 4:08:10 PM
11:01:39:653 | RL |      INFO  | +15    | CheckFile - Checking if E:\RocketLauncher\Module Extensions\itextsharp.dll exists
11:01:39:672 | RL |     DEBUG  | +16    | CheckFile - Attributes:
FileDescription          iTextSharp
FileVersion              5.4.2.0
InternalName             itextsharp.dll
LegalCopyright           Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
OriginalFilename         itextsharp.dll
ProductName              iTextSharp
ProductVersion           5.4.2.0
CompanyName              1T3XT BVBA
File Size: 3743744 bytes
Created: 5/21/2016 - 1:35:52 PM
11:01:39:706 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\Java.ahk | v1.0.0
11:01:39:709 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 7841 bytes
11:01:39:804 | RL |      INFO  | +94    | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\JSON.ahk
11:01:39:806 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 9227 bytes
Modified: 5/21/2016 - 2:24:11 PM
11:01:39:840 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2
11:01:39:844 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4904 bytes
Created: 5/21/2016 - 1:35:53 PM
Modified: 5/20/2016 - 4:08:11 PM
11:01:39:870 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\RegRW64.ahk
11:01:39:876 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 6915 bytes
11:01:39:952 | RL |      INFO  | +78    | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\RIni.ahk | v1.7
11:01:39:958 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 67562 bytes
Modified: 7/5/2016 - 6:41:12 PM
11:01:39:959 | RL |      INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
11:01:39:970 | RL |     DEBUG  | +16    | CheckFile - Attributes:
FileDescription          SevenZipSharp
FileVersion              0.64.5717.6837
InternalName             SevenZipSharp.dll
LegalCopyright           Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
OriginalFilename         SevenZipSharp.dll
ProductName              SevenZipSharp
ProductVersion           0.64.5717.6837
CompanyName              Markovtsev Vadim
File Size: 167424 bytes
Created: 5/21/2016 - 1:35:55 PM
11:01:39:022 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3
11:01:40:023 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5504 bytes
Modified: 5/21/2016 - 2:23:32 PM
11:01:40:074 | RL |      INFO  | +62    | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\VA.ahk
11:01:40:079 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 34688 bytes
11:01:40:100 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1
11:01:40:106 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 3833 bytes
11:01:40:112 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\7z.ahk | v1.1.0
11:01:40:115 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 31579 bytes
Created: 5/21/2016 - 1:35:37 PM
Modified: 7/5/2016 - 6:41:13 PM
11:01:40:127 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Bezel.ahk | v1.2.5
11:01:40:161 | RL |     DEBUG  | +31    | CheckFile - Attributes:
File Size: 119247 bytes
Modified: 7/5/2016 - 6:41:11 PM
11:01:40:172 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Fade.ahk | v1.1.9
11:01:40:213 | RL |     DEBUG  | +31    | CheckFile - Attributes:
File Size: 39542 bytes
Modified: 7/5/2016 - 6:41:14 PM
11:01:40:221 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Fade Init.ahk | v1.0.3
11:01:40:228 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1130 bytes
Modified: 5/21/2016 - 2:23:34 PM
11:01:40:240 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Fade Animations.ahk | v1.2.4
11:01:40:245 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 77966 bytes
Modified: 7/19/2016 - 4:09:19 PM
11:01:40:254 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Keymapper.ahk | v1.1.5
11:01:40:256 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 33668 bytes
Modified: 5/21/2016 - 2:23:43 PM
11:01:40:262 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6
11:01:40:264 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3956 bytes
Modified: 5/21/2016 - 2:24:13 PM
11:01:40:270 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\MultiGame.ahk | v1.1.0
11:01:40:272 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 41541 bytes
Modified: 5/21/2016 - 2:24:18 PM
11:01:40:280 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0
11:01:40:312 | RL |     DEBUG  | +31    | CheckFile - Attributes:
File Size: 161 bytes
Modified: 5/20/2016 - 4:07:51 PM
11:01:40:361 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8
11:01:40:368 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 66776 bytes
11:01:40:405 | RL |      INFO  | +47    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Pause.ahk | v1.2.4
11:01:40:407 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 397144 bytes
Modified: 7/5/2016 - 6:41:19 PM
11:01:40:416 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Pause Init.ahk | v1.0.3
11:01:40:456 | RL |     DEBUG  | +47    | CheckFile - Attributes:
File Size: 553 bytes
11:01:40:486 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Password.ahk | v1.0.4
11:01:40:490 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 10121 bytes
11:01:40:507 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7.1
11:01:40:514 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 26345 bytes
Created: 5/21/2016 - 2:23:51 PM
11:01:40:531 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1.0
11:01:40:536 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3098 bytes
Created: 5/21/2016 - 2:23:32 PM
Modified: 7/5/2016 - 6:41:16 PM
11:01:40:542 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1.1
11:01:40:544 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 6725 bytes
Created: 5/21/2016 - 2:23:42 PM
Modified: 7/5/2016 - 6:41:30 PM
11:01:40:548 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0.0
11:01:40:549 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1549 bytes
Created: 5/21/2016 - 2:23:28 PM
11:01:40:552 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5.1
11:01:40:555 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 7797 bytes
Created: 5/21/2016 - 2:23:27 PM
Modified: 7/19/2016 - 4:09:12 PM
11:01:40:559 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0.0
11:01:40:563 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 2963 bytes
Created: 5/21/2016 - 2:24:07 PM
11:01:40:625 | RL |      INFO  | +63    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.6.0
11:01:40:626 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 9146 bytes
Created: 5/21/2016 - 2:24:28 PM
11:01:40:635 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0.0
11:01:40:637 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 648 bytes
Created: 5/21/2016 - 2:24:01 PM
11:01:40:671 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0.0
11:01:40:672 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 4412 bytes
Created: 5/21/2016 - 2:24:26 PM
Modified: 7/5/2016 - 6:41:21 PM
11:01:40:700 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.1.1
11:01:40:702 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3741 bytes
Created: 5/21/2016 - 2:23:39 PM
11:01:40:709 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5.0
11:01:40:737 | RL |     DEBUG  | +31    | CheckFile - Attributes:
File Size: 9584 bytes
Created: 5/21/2016 - 2:24:25 PM
Modified: 7/5/2016 - 6:41:10 PM
11:01:40:741 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1.0
11:01:40:745 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1220 bytes
11:01:40:763 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0.1
11:01:40:768 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 5520 bytes
Created: 5/21/2016 - 2:23:50 PM
11:01:40:775 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2.0
11:01:40:777 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 4561 bytes
Created: 5/21/2016 - 2:24:09 PM
Modified: 7/5/2016 - 6:41:22 PM
11:01:40:783 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2.0
11:01:40:785 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 22846 bytes
Created: 5/21/2016 - 2:23:30 PM
Modified: 7/5/2016 - 6:41:23 PM
11:01:40:789 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0.0
11:01:40:792 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1156 bytes
Created: 5/21/2016 - 2:23:45 PM
Modified: 7/5/2016 - 6:41:15 PM
11:01:40:811 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7
11:01:40:821 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 72261 bytes
11:01:40:827 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Shader.ahk | v1.0.1
11:01:40:828 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 3943 bytes
Created: 5/21/2016 - 2:23:29 PM
Modified: 5/21/2016 - 2:23:29 PM
11:01:40:832 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Shader Init.ahk | v1.0.0
11:01:40:835 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 397 bytes
Created: 5/21/2016 - 2:23:25 PM
Modified: 5/21/2016 - 2:23:25 PM
11:01:40:865 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Shared.ahk | v1.4.7
11:01:40:867 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 175721 bytes
Modified: 7/5/2016 - 6:41:03 PM
11:01:40:873 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Statistics.ahk | v1.0.4
11:01:40:875 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 26810 bytes
11:01:40:881 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1
11:01:40:883 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 33 bytes
11:01:40:915 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5
11:01:40:917 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 19148 bytes
Modified: 5/21/2016 - 2:24:03 PM
11:01:40:936 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\XHotkey.ahk | v1.0.4
11:01:40:941 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 26540 bytes
11:01:40:948 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2
11:01:40:949 | RL |     DEBUG  | +16    | CheckFile - Attributes:
File Size: 1063 bytes
11:01:40:950 | RL |     DEBUG  | +0     | Main - Received this dbName with no path via CLI: "doa"
11:01:40:951 | RL |     DEBUG  | +0     | Main - dbName: doa
11:01:40:951 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "RocketLauncherUI"
11:01:40:952 | RL |     TRACE  | +0     | Process.__New - Creating new process object for: "E:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe"
11:01:40:953 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "E:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe"
11:01:40:956 | RL |      INFO  | +0     | Process.Process - "Exist" "RocketLauncherUI.exe"
11:01:40:957 | RL |     TRACE  | +0     | Process.GetProcessID
11:01:40:995 | RL |      INFO  | +31    | Main - RocketLauncherUI.exe is not currently running
11:01:40:998 | RL |      INFO  | +16    | Main - RocketLauncher received "Sega Model 2" and "doa"
11:01:41:077 | RL |      INFO  | +78    | Main - Did not find a "E:\RocketLauncher\Settings\Sega Model 2\Game Options.ini" file, skipping any game-specific options.
11:01:41:082 | RL |      INFO  | +0     | Main - doa is using the default emulator: Sega Model 2 Emulator
11:01:41:083 | RL |      INFO  | +0     | Main - Checking for a [Sega Model 2 Emulator] section in E:\RocketLauncher\Settings\Sega Model 2\Emulators.ini
11:01:41:085 | RL |      INFO  | +0     | Main - Checking for a [Sega Model 2 Emulator] section in E:\RocketLauncher\Settings\Global Emulators.ini
11:01:41:089 | RL |      INFO  | +0     | Main - Found [Sega Model 2 Emulator] in E:\RocketLauncher\Settings\Global Emulators.ini
11:01:41:103 | RL |      INFO  | +16    | CheckFile - Checking if E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ahk exists
11:01:41:114 | RL |     DEBUG  | +15    | CheckFile - Attributes:
File Size: 12307 bytes
Created: 5/21/2016 - 1:36:10 PM
Modified: 5/20/2016 - 4:08:22 PM
11:01:41:126 | RL |      INFO  | +16    | Main - CRC Check - CRC matches, this is an official unedited module.
11:01:41:127 | RL |      INFO  | +0     | Main - doa will use module: E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ahk
11:01:41:168 | RL |   WARNING  | +31    | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "E:\RocketLauncher\Settings\Global RocketLauncher.ini"
11:01:41:175 | RL |   WARNING  | +16    | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "E:\RocketLauncher\Settings\Sega Model 2\RocketLauncher.ini"
11:01:41:325 | RL |      INFO  | +156   | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
11:01:41:346 | RL |      INFO  | +16    | CheckFile - Checking if E:\HyperSpin\Emulators\MODEL 2 EMULATOR v1.1a\emulator_multicpu.exe exists
11:01:41:354 | RL |     DEBUG  | +0     | CheckFile - Attributes:
File Size: 1924608 bytes
Created: 7/20/2016 - 8:57:41 PM
Modified: 1/2/2014 - 11:43:46 AM
11:01:41:367 | RL |      INFO  | +15    | Main - INI Keys read
11:01:41:379 | RL |      INFO  | +16    | CheckFile - Checking if E:\RocketLauncher\Module Extensions\7z.exe exists
11:01:41:389 | RL |     DEBUG  | +16    | CheckFile - Attributes:
FileDescription          7-Zip Console
FileVersion              15.06 beta
InternalName             7z
LegalCopyright           Copyright (c) 1999-2015 Igor Pavlov
OriginalFilename         7z.exe
ProductName              7-Zip
ProductVersion           15.06 beta
CompanyName              Igor Pavlov
File Size: 262144 bytes
Modified: 5/22/2016 - 1:15:40 PM
11:01:41:397 | RL |      INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\Module Extensions\7z.dll exists
11:01:41:419 | RL |     DEBUG  | +31    | CheckFile - Attributes:
FileDescription          7z Plugin
InternalName             7z
OriginalFilename         7z.dll
ProductName              7-Zip
File Size: 1012224 bytes
11:01:41:483 | RL |      INFO  | +62    | Main - "doa" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
11:01:41:485 | RL |      INFO  | +0     | CheckPaths - Started
11:01:41:485 | RL |      INFO  | +0     | CheckPaths - Looking for rom: E:\HyperSpin\ROMS\Sega Model 2\doa.zip
11:01:41:486 | RL |      INFO  | +0     | CheckPaths - Found rom: E:\HyperSpin\ROMS\Sega Model 2\doa.zip
11:01:41:487 | RL |     DEBUG  | +0     | CheckPaths - Current romName: doa
11:01:41:488 | RL |     DEBUG  | +0     | CheckPaths - Current romPath: E:\HyperSpin\ROMS\Sega Model 2
11:01:41:488 | RL |     DEBUG  | +0     | CheckPaths - Current romExtension: .zip
11:01:41:489 | RL |      INFO  | +0     | CheckPaths - Ended
11:01:41:490 | RL |      INFO  | +0     | BuildScript - User Variables:
; INJECTED VARIABLES
#NoTrayIcon
#InstallKeybdHook
MiscUtils.DetectHiddenWindows("On")
SetTitleMatchMode, 2
SendMode, Event
0 = 2
rlPath = E:\RocketLauncher
pluginPath = E:\RocketLauncher\Plugins
pluginName = RocketLauncherUI
pluginExt = .plugin
contextOnExit =
rlMode =
rlTitle = RocketLauncher
rlVersion = 1.1.1.1
rlAuthor = djvj
rlURL = www.rlauncher.com
langFile = E:\RocketLauncher\Data\Language\Localization.ini
primMonitor = 1
frontendPID = 0
frontendPath = E:\RocketLauncher\RocketLauncherUI
frontendExe = RocketLauncherUI.exe
frontendExt = exe
frontendName = RocketLauncherUI
frontendDrive = E
exitEmulatorKey = 1joy11
restoreFE = Restore and Click
exitScriptKey = ~q & ~s
toggleCursorKey = ~e & ~t
emuFullPath = E:\HyperSpin\Emulators\MODEL 2 EMULATOR v1.1a\emulator_multicpu.exe
emuPath = E:\HyperSpin\Emulators\MODEL 2 EMULATOR v1.1a
emuName = Sega Model 2 Emulator
emuExt = exe
baseRomPath =
romPath = E:\HyperSpin\ROMS\Sega Model 2
romPathFromIni = E:\HyperSpin\ROMS\Sega Model 2
romExtension = .zip
romExtensionOrig = .zip
romExtensions = zip
executable = emulator_multicpu.exe
systemDbName = Sega Model 2
systemName = Sega Model 2
dbPath =
dbName = doa
dbExt =
romName = doa
romMapPath =
romMappingEnabled = false
romMappingHideParent = false
romMappingMenuWidth = 400
romMappingMenuMargin = 65
romMappingTextMargin = 15
romMappingGameNameTextFont = Bebas Neue
romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
romMappingMenuFlagWidth = 55
altArchiveNameOnly =
altRomNameOnly =
altArchiveAndRomName =
altArchiveAndManyRomNames =
altRomNamesOnly =
romMapScenario =
skipchecks = false
romMatchExt = false
blockInputTime = 0
blockInputFile = E:\RocketLauncher\Module Extensions\BlockInput.exe
errorLevelReporting = false
lockLaunch = false
lockLaunchGame =
screenRotationAngle = 0
screenRotationAngleGame =
setResolution =
logFile =
logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]
logLevel = 10
logShowDebugConsole = false
logShowCommandWindow = false
logCommandWindow = false
logIncludeModule = true
logIncludeDLLLogs = false
errorSounds = true
rlDebugConsoleStdout =
sysType = 64-bit
broadcastWindowTitle =
navUpKey = Up
navDownKey = Down
navLeftKey = Left
navRightKey = Right
navSelectKey = Enter
navP2UpKey = Numpad8
navP2DownKey = Numpad2
navP2LeftKey = Numpad4
navP2RightKey = Numpad6
navP2SelectKey = NumpadEnter
originalWidth = 1920
originalHeight = 1080
vdEnabled = false
vdFullPath =
vdUseSCSI = true
vdDriveLetter =
vdDriveLetterScsi =
vdAddDrive = true
demulShooterPath =
servoStikEnabled = false
servoStikExitMode = false
ledblinkyEnabled = false
ledblinkySystemName =
ledblinkyFullPath =
ledblinkyProfilePath = E:\RocketLauncher\Profiles\LEDBlinky
ledblinkyRLProfile = E:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
winIPACFullPath =
ultraMapEnabled = false
ultraMapFullPath =
emuIdleShutdown = 0
hideCursor = true
hideEmu = true
hideFE = false
suspendFE = false
fadeIn = false
fadeInDuration = 500
fadeInDelay = 0
fadeInExitDelay = 0
fadeOutExitDelay = 0
fadeOut = false
fadeOutExtraScreen = false
fadeOutDuration = 500
fadeOutDelay = 0
fadeLyrInterpolation = 7
fadeMuteEmulator = false
fadeUseBackgrounds = false
fadeClickThrough = false
fadeSounds = true
fade7zProgressMode = extraction
fadeWidthBaseRes = 1280
fadeHeightBaseRes = 720
fadeLyr1Color = FF000000
fadeLyr2X = 0
fadeLyr2Y = 0
fadeLyr2W =
fadeLyr2H =
fadeLyr2Adjust = 1
fadeLyr2PicPad = 0
fadeLyr3Pos = Center
fadeLyr3X = 450
fadeLyr3Y = 450
fadeLyr3W =
fadeLyr3H =
fadeLyr3Adjust = 1
fadeLyr3PicPad = 0
fadeLyr3Speed = 750
fadeLyr3Type = image
fadeLyr3Repeat = 1
fadeLyr3StaticX = 0
fadeLyr3StaticY = 870|1575
fadeLyr3StaticW =
fadeLyr3StaticH =
fadeLyr3StaticAdjust = 1
fadeLyr3StaticPicPad = 0
fadeLyr4Adjust = 1
fadeLyr4X = 1792|952
fadeLyr4Y = 891|1596
fadeLyr4W = 128
fadeLyr4H =
fadeLyr4Pos = No Alignment
fadeLyr4FPS = 50
fadeLyr4PicPad = 0
fadeTranspGifColor = FFFFFF
fadeBarWindow = Image
fadeBarWindowX =
fadeBarWindowY =
fadeBarWindowW = 900
fadeBarWindowH =
fadeBarWindowR = 30
fadeBarWindowM = 30
fadeBarWindowHatchStyle = 8
fadeBar = 7zOnly
fadeProgressDuration = 0
fadeBarBack = true
fadeBarBackColor = FF555555
fadeBarH = 30
fadeBarR = 10
fadeBarColor = DD00BFFF
fadeBarHatchStyle = 8
fadeBarPercentageText = true
fadeBarInfoText = true
fadeBarXOffset = 0
fadeBarYOffset = 150
fadeRomInfoSystemName = image
fadeRomInfoDeveloper = text with label
fadeRomInfoPublisher = text with label
fadeRomInfoGenre = disabled
fadeRomInfoRating = image
fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher
fadeRomInfoTextMargin = 7
fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular
fadeStatsInfoTextMargin = 7
fadeText1X = 0
fadeText1Y = 0
fadeText1 = Loading Game
fadeText2X = 0
fadeText2Y = 0
fadeText3 = Loading Game
fadeText4 = Loading Complete
fadeFont = Bebas Neue
fadeExtractionTime = disabled
fadeExtractionTimeTextX = 0
fadeExtractionTimeTextY = 0
fadeInterruptKey = F
detectFadeErrorEnabled = true
fadeImgPath = E:\RocketLauncher\Media\Fade
RLDataPath = E:\RocketLauncher\Data
RLMediaPath = E:\RocketLauncher\Media
RLErrSoundPath = E:\RocketLauncher\Media\Sounds\Error
modulesPath = E:\RocketLauncher\Modules
moduleFullName = E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ahk
moduleName = Sega Model 2 Emulator
modulePath = E:\RocketLauncher\Modules\Sega Model 2 Emulator
moduleExtension = ahk
moduleExtensionsPath = E:\RocketLauncher\Module Extensions
libPath = E:\RocketLauncher\Lib
sevenZEnabled = false
sevenZPath = E:\RocketLauncher\Module Extensions\7z.exe
sevenZDllPath = E:\RocketLauncher\Module Extensions\7z.dll
sevenZExtractPath = C:\TEMP GAME HYPERSPIN
sevenZExtractPathOrig =
sevenZAttachSystemName = false
sevenZDelTemp = true
sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar
sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar
sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar
7zExtractPath = C:\TEMP GAME HYPERSPIN
mgEnabled = false
mgKey = ~NumpadSub
mgBackgroundColor = FF000000
mgSidePadding = 0.2
mgWidthBaseRes = 1280
mgHeightBaseRes = 720
mgYOffset = 500|800
mgFont = Arial
mgText2Offset = 100
mgUseSound = true
mgSoundfreq = 300
mgExitEffect = none
mgSelectedEffect = rotate
mgUseGameArt = false
mgCandidate =
mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
mgOnLaunch = false
pauseEnabled = false
pauseKey = ~NumpadAdd
pauseBackToMenuBarKey = X
pauseZoomInKey = C
pauseZoomOutKey = V
pauseHiToTextPath = E:\RocketLauncher\Module Extensions\HiToText.exe
pauseSaveStateKeyCodes =
pauseLoadStateKeyCodes =
keyboardEncoder =
keyboardEncoderEnabled = false
keymapperEnabled = true
keymapperAHKMethod = false
keymapper = xpadder
xpadderFullPath = E:\HyperSpin\Profiles\Xpadder\Xpadder.exe
joyToKeyFullPath = E:\RocketLauncher\Profiles\JoyToKey\JoyToKey.exe
profilePath = E:\RocketLauncher\Profiles
keymapperProfilePath = E:\RocketLauncher\Profiles\xpadder
keymapperFrontEndProfile = xpadder
keymapperRocketLauncherProfileEnabled = true
joyIDsEnabled = true
joyIDsPreferredControllersGlobal = Mayflash PS3 Game Controller Adapter
joyIDsPreferredControllersSystem = use_global
joyIDsPreferredControllersOnExit = Mayflash PS3 Game Controller Adapter
CustomJoyNamesEnabled = false
CustomJoyNames =
rotateMethod = false
FEProfile = E:\RocketLauncher\Profiles\xpadder\HyperSpin
defaultProfile = E:\RocketLauncher\Profiles\xpadder\_Default
systemProfile = E:\RocketLauncher\Profiles\xpadder\Sega Model 2
xPadderSystemProfile = E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default
emuProfile = E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator
romProfile = E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa
RocketLauncherProfile = E:\RocketLauncher\Profiles\xpadder\RocketLauncher
blankProfile = E:\RocketLauncher\Profiles\xpadder\_Default\blank
ahkFEProfile = E:\RocketLauncher\Profiles\AHK\HyperSpin
ahkDefaultProfile = E:\RocketLauncher\Profiles\AHK\_Default
ahkSystemProfile = E:\RocketLauncher\Profiles\AHK\Sega Model 2
ahkEmuProfile = E:\RocketLauncher\Profiles\AHK\Sega Model 2\Sega Model 2 Emulator
ahkRomProfile = E:\RocketLauncher\Profiles\AHK\Sega Model 2\doa
ahkRocketLauncherProfile = E:\RocketLauncher\Profiles\AHK\RocketLauncher
bezelEnabled = false
bezelICEnabled = false
shaderName = false
shaderColor =
shaderTransparency =
statisticsEnabled = false
pressDuration = -1
emuVolume = 1
dxwndIni = E:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
dxwndFullPath = E:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
qResFullPath = E:\RocketLauncher\Module Extensions\QRes.exe
mon1O =
pacDrivedllFile = E:\RocketLauncher\Module Extensions\PacDrive32.dll
userFadeAnimIniFile = E:\RocketLauncher\Lib\User Fade Animations.ini
testFile =
testDuration =
initialErrorMode = 0
11:01:41:494 | RL |      INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
11:01:41:497 | RL |      INFO  | +16    | BuildScript - Loaded Keymapper Init.ahk scripts
11:01:41:498 | RL |      INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
11:01:41:499 | RL |     DEBUG  | +0     | BuildScript - Module starts on line: 2
11:01:41:531 | RL |      INFO  | +31    | BuildScript - Validating module
11:01:41:537 | RL |      INFO  | +0     | BuildScript - Validation complete
11:01:41:540 | RL |      INFO  | +0     | BuildScript - Module:
MEmu = Sega Model 2 Emulator
MEmuV = v1.0
MURL = http://nebula.emulatronia.com/
MAuthor = djvj,ghutch92
MVersion = 2.0.8
MCRC = CDCF2145
iCRC = C842B2DD
mId = 635175648125374429
MSystem = "Sega Model 2"
; Notes:
; Manually launch the Sega Model 2 Emulator.
; Under Video enable "auto switch to fullscreen".
; model2.zip must exist in your rom path which contains the needed bios files for the system.
; Module settings overwrite what you have set in the emulator itself.
; For Multiplayer Support:
; To enable the linked games support, set Link_Enabled to true in the module settings in RocketLauncherUI
; The module has an internal list of games that it will only enable it for. Not all of the games work in this emu. See below for more info.
; 1.) Multiplayer does not work when the emulator is launched using the same executable in the same path.
; 2.) Multiplayer only works if player 1 is set to be in master mode and players 2-4 are set to be in slave mode. (this info is stored in the emupath\NVDATA folder, press F2 to set in game)
; 3.) Singleplayer only works if player 1 is set to be in single mode. (this info is stored in the emupath\NVDATA folder, press F2 to set in game)
; 4.) Only the active window accepts keyboard input.
; Fixed Issue 1 by having folders in the emupath named Player 2, Player 3, and Player 4  and within each of these folsers there are separate installs of sega model 2 emulator.
; Fixed Issue 2 and 3 for Player 1 by having a folder named "Multi" in the NVDATA folder for multiplayer dat files and a folder name "Single" in the NVDATA folder for single player dat files.
; Fixed Issue 4 by activating the first player window so first player always has the keyboard and players 2-4 have to use a joystick(gamepad).
;Games that have a working link:
; daytona,daytonagtx,daytonam,daytonas,daytonat,indy500,indy500d,manxtt,motoraid,skisuprg,srallyc,srallycb,srallyp,stcc,stcce,von,vonj,waverunr
; overrev and sgt24h both look like they can support link but I couldn't get it working, because I think m2emulator uses a linking hack to get these games to work in stand alone mode.
; Still need to see if waverunr, stcc, stcce, von, and vonj can link, I couldn't get these working, I think my processor is the issue here. Saw video of stcc & waverunr link working though.
; von and vonj can only do a 2 player link
StartModule()
BezelGUI()
linkEnabled := IniReadCheck(settingsFile, "Settings|" . romName, "Link_Enabled", "false",,1)
SplitScreen2PlayersMode := IniReadCheck(settingsFile, "Settings", "SplitScreen_2_Players","Vertical",,1) ;horizontal or vertical
SplitScreen3PlayersMode := IniReadCheck(settingsFile, "Settings", "SplitScreen_3_Players","P1top",,1) ; For Player1 screen to be on left: P1left. For Player1 screen to be on top: P1top. For Player1 screen to be on bottom: P1bottom. For Player1 screen to be on right: P1right.
If romName in daytona,daytonagtx,daytonam,daytonas,daytonat,indy500,indy500d,manxtt,motoraid,skisuprg,srallyc,srallycb,srallyp,stcc,stcce,von,vonj,waverunr
If (linkEnabled = "true") {
Log("Module - Link mode enabled")
linkEnabledGame := 1
If linkEnabledGame
If (romName = "von") or (romName = "vonj")
SelectedNumberofPlayers := NumberOfPlayersSelectionMenu(2)
Else
SelectedNumberofPlayers := NumberOfPlayersSelectionMenu(4)
FadeInStart()
fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1)
fullScreenWidth := IniReadCheck(settingsFile, "Settings", "FullScreenWidth",A_ScreenWidth,,1)
fullScreenHeight := IniReadCheck(settingsFile, "Settings", "FullScreenHeight",A_ScreenHeight,,1)
emupath2 := IniReadCheck(settingsFile, "Settings", "Player2_EmulatorPath",emupath . "\Player 2",,1) ;must be a unique path to same version of the emulator
emupath3 := IniReadCheck(settingsFile, "Settings", "Player3_EmulatorPath",emupath . "\Player 3",,1) ;must be a unique path to same version of the emulator
emupath4 := IniReadCheck(settingsFile, "Settings", "Player4_EmulatorPath",emupath . "\Player 4",,1) ;must be a unique path to same version of the emulator
CheckFile(romPath . "\model2.zip","Could not locate ""model2.zip"" which contains the bios files for this emulator. Please make sure it exists in the same folder as your roms.")
m2Ini := CheckFile(emuPath . "\EMULATOR.INI")
m2RomDir1 := IniReadCheck(m2Ini, "RomDirs", "Dir1",,,1)
If (m2RomDir1 != romPath)
IniWrite, %romPath%, %m2Ini%, RomDirs, Dir1 ; write the correct romPath to the emu's ini so the user does not need to define this
If SelectedNumberofPlayers > 1
BezelStart(SelectedNumberofPlayers)
Else
BezelStart()
hideEmuObj := Object("AHK_class MYWIN",1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
; Write settings to m2's ini file - this needs to change also
IniWrite, % (If fullscreen = "true" ? 1 : 0), %m2Ini%, Renderer, AutoFull
IniWrite, %fullScreenWidth%, %m2Ini%, Renderer, FullScreenWidth
IniWrite, %fullScreenHeight%, %m2Ini%, Renderer, FullScreenHeight
If (SelectedNumberofPlayers = 1 || !linkEnabledGame) {
; Changing Cabinent Settings for player 1 this is because we will need to switch between master controller mode and single mode
; this info is stored in the NVDATA folder
; store single player settings in the NVDATA\Single folder and the Multiplayer Settings in the NVDATA\Multi folder
If (FileExist(emupath . "\NVDATA\Single\" . romName . ".DAT") && linkEnabledGame) {
Log("Overwriting " . emupath . "\NVDATA\" . romName . ".DAT with " . emupath . "\NVDATA\Single\" . romName . ".DAT")
FileCopy,%emupath%\NVDATA\Single\%romName%.DAT,%emupath%\NVDATA,1
HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait
Run(executable . A_Space . romName, emuPath, "Hide") ; Hides the emulator on launch. When bezel is enabled, this helps not show the emu before the rom is loaded
WinWait("ahk_class MYWIN",,,"Model 2 Emulator")
;WinWaitActive("ahk_class MYWIN",,,"Model 2 Emulator") ;this line only works if fade in is enabled
Sleep, 1000 ; Increase if your Front End is getting a quick flash in before the game loads
} Else {
;screen positions
If (SelectedNumberofPlayers = 2)
If SplitScreen2PlayersMode = Vertical
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight , X2 := A_ScreenWidth//2 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight
Else
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth , H1 := A_ScreenHeight//2 , X2 := 0 , Y2 := A_ScreenHeight//2 , W2 := A_ScreenWidth , H2 := A_ScreenHeight//2
Else If (SelectedNumberofPlayers = 3)
If SplitScreen3PlayersMode = P1left
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight , X2 := A_ScreenWidth//2 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := A_ScreenWidth//2 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else If SplitScreen3PlayersMode = P1bottom
X1 := 0 , Y1 := A_ScreenHeight//2 , W1 := A_ScreenWidth , H1 := A_ScreenHeight//2 , X2 := 0 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := A_ScreenWidth//2 , Y3 := 0 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else If SplitScreen3PlayersMode = P1right
X1 := A_ScreenWidth//2 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight , X2 := 0 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := 0 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else ; top
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth , H1 := A_ScreenHeight//2, X2 := 0 , Y2 := A_ScreenHeight//2 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2, X3 := A_ScreenWidth//2 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2
Else
X1 := 0 , Y1 := 0 , W1 := A_ScreenWidth//2 , H1 := A_ScreenHeight//2 , X2 := A_ScreenWidth//2 , Y2 := 0 , W2 := A_ScreenWidth//2 , H2 := A_ScreenHeight//2 , X3 := 0 , Y3 := A_ScreenHeight//2 , W3 := A_ScreenWidth//2 , H3 := A_ScreenHeight//2 , X4 := A_ScreenWidth//2 , Y4 := A_ScreenHeight//2 , W4 := A_ScreenWidth//2 , H4 := A_ScreenHeight//2
;this loop is for error checking since this emulator needs multiple instances of the emulator starting from different locations to run
Loop, %SelectedNumberofPlayers%
LinkedEmuPath := (A_Index = 1) ? (emupath) : (emupath%A_Index%)
CheckFile(LinkedEmuPath . "\" . executable)
CheckFile(LinkedEmuPath . "\EMULATOR.INI")
If FileExist(emupath . "\NVDATA\Multi\" . romName . ".DAT") {
Log("Overwriting " . emupath . "\NVDATA\" . romName . ".DAT with " . emupath . "\NVDATA\Multi\" . romName . ".DAT")
FileCopy,%emupath%\NVDATA\Multi\%romName%.DAT,%emupath%\NVDATA,1
m2ini := LinkedEmuPath . "\EMULATOR.INI" ;no need to checkfile it here since it's already been done
; Removing Fullscreen
IniWrite, 0, %m2Ini%, Renderer, AutoFull
; Creating the link
IniWrite,127.0.0.1,%LinkedEmuPath%\m2network.ini,network,NextIp ;127.0.0.1 is local address
IniWrite,% (1978 + A_Index - 1),%LinkedEmuPath%\m2network.ini,network,RxPort ;Recieving port
;the last player sends information to the first player completing the circle
IniWrite,% (If (A_Index = SelectedNumberofPlayers) ? 1978 : (1978 + A_Index)),%LinkedEmuPath%\m2network.ini,network,NextPort ;Sending Port
Run(executable . A_Space . romName, LinkedEmuPath, "Hide",Screen%A_Index%PID)
WinWait("ahk_pid " . Screen%A_Index%PID)
WinGet, Screen%A_Index%ID, ID, % "ahk_pid " . Screen%A_Index%PID
If Fullscreen = true
{ WinSet, Style, -0xC00000, % "ahk_id " . Screen%A_Index%ID
ToggleMenu(Screen%A_Index%ID)
WinSet, Style, -0xC40000, % "ahk_id " . Screen%A_Index%ID
currentScreen := A_Index
Log("Moving window " . currentScreen . " to " .  X%currentScreen% . "`," . Y%currentScreen% . " with W" . W%currentScreen% . " H" . H%currentScreen%)
WinMove,  % "ahk_id " . Screen%currentScreen%ID, , % X%currentScreen%, % Y%currentScreen%, % W%currentScreen%, % H%currentScreen%
;check If window moved
timeout := A_TickCount
Loop
{ WinGetPos, X, Y, W, H, % "ahk_id " . Screen%currentScreen%ID
If (X=X%currentScreen%) and (Y=Y%currentScreen%) and (W=W%currentScreen%) and (H=H%currentScreen%)
break
If (timeout<A_TickCount-2000)
Break
Sleep, 50
Sleep, 50
BezelDraw()
HideEmuEnd()
WinShow, ahk_class MYWIN ; Show the emulator
} Else {
Loop %SelectedNumberofPlayers%
WinShow, % "ahk_id " . Screen%a_index%ID ; Show the emulator
WinActivate, ahk_id %Screen1ID% ; activate first player window so that first player can use keyboard instead of last player
;I find that the fade in exit looks better after the winshow lines
FadeInExit()
BezelExit()
FadeOutExit()
ExitModule()
CloseProcess:
FadeOutStart()
If (SelectedNumberofPlayers>1) {
{ WinClose("ahk_id " . Screen%A_Index%ID)
WinWaitClose("ahk_id " . Screen%A_Index%ID)
} Else
WinClose("AHK_class MYWIN")
Return
11:01:41:601 | RL |      INFO  | +63    | BuildScript - Loaded Multi-Player scripts
11:01:41:603 | RL |      INFO  | +0     | BuildScript - Loaded User Functions.ahk script
11:01:41:603 | RL |      INFO  | +0     | BuildScript - Finished injecting functions into module
11:01:41:615 | RL |      INFO  | +15    | Main - Module is built
11:01:41:628 | RL |      INFO  | +16    | CheckFile - Checking if E:\RocketLauncher\AutoHotkey.dll exists
11:01:41:666 | RL |     DEBUG  | +31    | CheckFile - Attributes:
FileDescription          AutoHotkey_H ANSI 32-bit
FileVersion              1.1.13.00
InternalName             AutoHotkey_H
LegalCopyright           Copyright (C) 2003-2013
OriginalFilename         AutoHotkey.exe
ProductName              AutoHotkey_H
ProductVersion           1.1.13.00
File Size: 802304 bytes
Created: 5/21/2016 - 1:35:30 PM
Modified: 7/5/2016 - 6:41:33 PM
11:01:41:670 | RL |      INFO  | +16    | Main - Hiding taskbar
11:01:41:671 | RL |     TRACE  | +0     | Window.__New - Created: "ahk_class Shell_TrayWnd"
11:01:41:672 | RL |     TRACE  | +0     | Window.__New - Created: "Start ahk_class Button"
11:01:41:673 | RL |     TRACE  | +0     | Window.Hide - Hiding window "ahk_class Shell_TrayWnd"
11:01:41:697 | RL |     TRACE  | +15    | Window.Hide - Hiding window "Start ahk_class Button"
11:01:41:700 | RL |      INFO  | +16    | Main - Hiding desktop
11:01:41:716 | RL |      INFO  | +16    | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
11:01:41:728 | RL |      INFO  | +0     | Main - Running module
11:01:42:028 | MD |      INFO  | +N/A   | Module initialized
11:01:42:038 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
11:01:42:041 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~1joy11 not in TableKeyGroups
11:01:42:042 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
11:01:42:059 | MD |     TRACE  | +31    | XHotkeyTableCreation - Post loop 2 check
11:01:42:071 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~1joy11" to call label: "CloseProcess"
11:01:42:073 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
11:01:42:207 | MD |     TRACE  | +141   | Keymapper - Checking for the JoyIDs_Preferred_Controllers key  in E:\RocketLauncher\Settings\Sega Model 2\Games JoyIDs.ini under section [doa]
11:01:42:208 | MD |      INFO  | +0     | LoadPreferredControllers - Started
11:01:42:209 | MD |     TRACE  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = 1
11:01:42:211 | MD |     TRACE  | +0     | LoadPreferredControllers - Creating a list of currently connected joysticks
11:01:42:212 | MD |      INFO  | +0     | GetJoystickArray - Started
11:01:42:301 | MD |     TRACE  | +94    | GetJoystickArray - Joysticks Detected: 1111000000000000
11:01:42:306 | MD |      INFO  | +0     | GetJoystickGUID - Started
11:01:42:331 | MD |      INFO  | +31    | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000
11:01:42:338 | MD |     TRACE  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000
11:01:42:365 | MD |      INFO  | +31    | GetJoystickGUID - Started
11:01:42:367 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000
11:01:42:370 | MD |     TRACE  | +0     | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000
11:01:42:398 | MD |      INFO  | +32    | GetJoystickGUID - Started
11:01:42:425 | MD |      INFO  | +31    | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000
11:01:42:427 | MD |     TRACE  | +0     | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000
11:01:42:459 | MD |      INFO  | +31    | GetJoystickGUID - Started
11:01:42:461 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000
11:01:42:462 | MD |     TRACE  | +0     | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000
11:01:42:464 | MD |      INFO  | +0     | GetJoystickArray - Ended
11:01:42:486 | MD |     TRACE  | +31    | LoadPreferredControllers - Preferred Order Sorting List -> 3.01|0079|1801|702FB16B3B2AE6118001444553540000
11:01:42:487 | MD |     TRACE  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 3.02|0079|1801|E040B26B3B2AE6118002444553540000
11:01:42:489 | MD |     TRACE  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 3.03|0079|1801|008FB26B3B2AE6118003444553540000
11:01:42:490 | MD |     TRACE  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 3.04|0079|1801|20DDB26B3B2AE6118004444553540000
11:01:42:492 | MD |      INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
11:01:42:493 | MD |      INFO  | +0     | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
11:01:42:495 | MD |      INFO  | +0     | ChangeJoystickID - Started
11:01:42:525 | MD |     TRACE  | +32    | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_0079&PID_1801&GUID_702FB16B3B2AE6118001444553540000
11:01:42:546 | MD |      INFO  | +31    | ChangeJoystickID - Ended
11:01:42:579 | MD |      INFO  | +31    | ChangeJoystickID - Started
11:01:42:582 | MD |     TRACE  | +0     | ChangeJoystickID - Swapping Joystick ID: 01000000 to the New Joystick ID: 01000000, for the Joystick VID_0079&PID_1801&GUID_E040B26B3B2AE6118002444553540000
11:01:42:583 | MD |      INFO  | +0     | ChangeJoystickID - Ended
11:01:42:585 | MD |      INFO  | +0     | ChangeJoystickID - Started
11:01:42:587 | MD |     TRACE  | +0     | ChangeJoystickID - Swapping Joystick ID: 02000000 to the New Joystick ID: 02000000, for the Joystick VID_0079&PID_1801&GUID_008FB26B3B2AE6118003444553540000
11:01:42:588 | MD |      INFO  | +0     | ChangeJoystickID - Ended
11:01:42:609 | MD |      INFO  | +31    | ChangeJoystickID - Started
11:01:42:614 | MD |     TRACE  | +0     | ChangeJoystickID - Swapping Joystick ID: 03000000 to the New Joystick ID: 03000000, for the Joystick VID_0079&PID_1801&GUID_20DDB26B3B2AE6118004444553540000
11:01:42:616 | MD |      INFO  | +0     | ChangeJoystickID - Ended
11:01:42:617 | MD |      INFO  | +0     | LoadPreferredControllers - Ended
11:01:42:619 | MD |      INFO  | +0     | CheckFile - Checking if E:\HyperSpin\Profiles\Xpadder\Xpadder.exe exists
11:01:42:643 | MD |     DEBUG  | +32    | CheckFile - Attributes:
File Size: 1178624 bytes
Created: 7/6/2016 - 8:36:47 PM
Modified: 5/28/2016 - 2:38:14 PM
11:01:42:645 | MD |      INFO  | +0     | Keymapper - Loading xpadder
11:01:42:647 | MD |      INFO  | +0     | RunKeymapper - Started, using method "load"
11:01:42:648 | MD |      INFO  | +0     | GetJoystickArray - Started
11:01:42:739 | MD |     TRACE  | +93    | GetJoystickArray - Joysticks Detected: 1111000000000000
11:01:42:766 | MD |      INFO  | +32    | GetJoystickGUID - Started
11:01:42:769 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000
11:01:42:770 | MD |     TRACE  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000
11:01:42:797 | MD |      INFO  | +31    | GetJoystickGUID - Started
11:01:42:802 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000
11:01:42:804 | MD |     TRACE  | +0     | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000
11:01:42:831 | MD |      INFO  | +31    | GetJoystickGUID - Started
11:01:42:862 | MD |      INFO  | +31    | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000
11:01:42:867 | MD |     TRACE  | +0     | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000
11:01:42:895 | MD |      INFO  | +32    | GetJoystickGUID - Started
11:01:42:902 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000
11:01:42:927 | MD |     TRACE  | +31    | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000
11:01:42:929 | MD |      INFO  | +0     | GetJoystickArray - Ended
11:01:42:930 | MD |     TRACE  | +0     | RunKeymapper - Found your keymapper application here: "E:\HyperSpin\Profiles\Xpadder\Xpadder.exe"
11:01:42:931 | MD |     TRACE  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
11:01:42:932 | MD |     TRACE  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:01:42:956 | MD |     TRACE  | +31    | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:01:42:958 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile
11:01:42:959 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\p1.xpadderprofile
11:01:42:961 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile
11:01:42:962 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\p1.xpadderprofile
11:01:42:964 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile
11:01:42:986 | MD |     TRACE  | +31    | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\p1.xpadderprofile
11:01:42:990 | MD |      INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\p1.xpadderprofile
11:01:42:991 | MD |     TRACE  | +0     | RunKeymapper - ID: 2 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:01:42:993 | MD |     TRACE  | +0     | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:01:42:994 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile
11:01:42:013 | MD |     TRACE  | +32    | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\p2.xpadderprofile
11:01:43:015 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile
11:01:43:016 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\p2.xpadderprofile
11:01:43:018 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile
11:01:43:019 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\p2.xpadderprofile
11:01:43:021 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile
11:01:43:024 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\p2.xpadderprofile
11:01:43:026 | MD |     TRACE  | +0     | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:01:43:043 | MD |      INFO  | +31    | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:01:43:045 | MD |     TRACE  | +0     | RunKeymapper - ID: 3 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:01:43:047 | MD |     TRACE  | +0     | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:01:43:049 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile
11:01:43:052 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\p3.xpadderprofile
11:01:43:053 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile
11:01:43:055 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\p3.xpadderprofile
11:01:43:057 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile
11:01:43:081 | MD |     TRACE  | +31    | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\p3.xpadderprofile
11:01:43:085 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile
11:01:43:087 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\p3.xpadderprofile
11:01:43:089 | MD |     TRACE  | +0     | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:01:43:112 | MD |      INFO  | +31    | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:01:43:120 | MD |     TRACE  | +0     | RunKeymapper - ID: 4 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:01:43:141 | MD |     TRACE  | +32    | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator|E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:01:43:146 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile
11:01:43:147 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\doa\p4.xpadderprofile
11:01:43:150 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile
11:01:43:151 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\Sega Model 2 Emulator\p4.xpadderprofile
11:01:43:171 | MD |     TRACE  | +31    | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile
11:01:43:172 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\p4.xpadderprofile
11:01:43:175 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile
11:01:43:177 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\p4.xpadderprofile
11:01:43:178 | MD |     TRACE  | +0     | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:01:43:180 | MD |      INFO  | +0     | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:01:43:182 | MD |      INFO  | +0     | RunXpadder - Started
11:01:43:204 | MD |      INFO  | +31    | Process - Exist JoyToKey.exe
11:01:43:235 | MD |     TRACE  | +31    | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
11:01:43:237 | MD |      INFO  | +0     | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe /C
11:01:43:393 | MD |     DEBUG  | +157   | Run - "Xpadder.exe /C" Process ID: 7828
11:01:43:395 | MD |     TRACE  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\HyperSpin\Profiles\Xpadder\xpadder.ini
11:01:43:397 | MD |      INFO  | +0     | Process - WaitClose Xpadder.exe 2
11:01:44:289 | MD |     TRACE  | +890   | RunXpadder - Reading the order in E:\HyperSpin\Profiles\Xpadder\xpadder.ini and arranging profiles found to match that order
11:01:44:313 | MD |     TRACE  | +31    | RunXpadder - No more controllers to be found
11:01:44:315 | MD |      INFO  | +0     | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M
11:01:44:422 | MD |     DEBUG  | +110   | Run - "Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\Sega Model 2\_Default\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 5396
11:01:44:423 | MD |      INFO  | +0     | RunXpadder - Ended
11:01:44:425 | MD |      INFO  | +0     | RunKeymapper - Ended
11:01:44:426 | MD |      INFO  | +0     | StartModule - Started
11:01:44:428 | MD |      INFO  | +0     | StartModule - MEmu: Sega Model 2 Emulator
MEmuV: v1.0
MURL: http://nebula.emulatronia.com/
MAuthor: djvj,ghutch92
MVersion: 2.0.8
MCRC: CDCF2145
iCRC: C842B2DD
MID:
MSystem: "Sega Model 2"
11:01:44:429 | MD |      INFO  | +0     | StartModule - You have a supported System Name for this module: "Sega Model 2"
11:01:44:481 | MD |      INFO  | +62    | PluginInit - Started
11:01:44:483 | MD |     DEBUG  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating
11:01:44:484 | MD |      INFO  | +0     | CheckFile - Checking if E:\RocketLauncher\RocketLauncherUI\Databases\Sega Model 2\Sega Model 2.xml exists
11:01:44:513 | MD |     DEBUG  | +32    | CheckFile - Attributes:
File Size: 17934 bytes
Created: 5/21/2016 - 5:38:05 PM
Modified: 7/20/2016 - 8:59:50 PM
11:01:44:515 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
11:01:44:517 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
11:01:44:518 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Name
11:01:44:520 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Name" with a value: "Dead or Alive (Model 2B)"
11:01:44:523 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Cloneof
11:01:44:525 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Cloneof
11:01:44:526 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Manufacturer
11:01:44:553 | MD |     DEBUG  | +31    | BuildDatabaseTable - Found "Manufacturer" with a value: "Tecmo"
11:01:44:554 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Year
11:01:44:556 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Year" with a value: "1996"
11:01:44:576 | MD |     DEBUG  | +31    | BuildDatabaseTable - Searching database for: Genre
11:01:44:579 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Fighter"
11:01:44:585 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Rating
11:01:44:587 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Rating" with a value: "AAMA - Yellow (Life Like Violence Mild)"
11:01:44:589 | MD |     TRACE  | +0     | PluginInit - GameInfo:
GameInfo Label: Genre | GameInfo Value:
GameInfo Label: Manufacturer | GameInfo Value:
GameInfo Label: Name | GameInfo Value:
GameInfo Label: Rating | GameInfo Value:
GameInfo Label: Year | GameInfo Value:
11:01:44:606 | MD |     DEBUG  | +31    | BuildDatabaseTable - Ended
11:01:44:612 | MD |      INFO  | +0     | PluginInit - Ended
11:01:44:614 | MD |     DEBUG  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: doa
11:01:44:713 | MD |      INFO  | +94    | SystemCursor - Hiding mouse cursor
11:01:44:857 | MD |     TRACE  | +156   | XHotkeyTableCreation - Started
11:01:44:860 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~1joy11,
11:01:44:861 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
11:01:44:863 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
11:01:44:865 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
11:01:44:866 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
11:01:44:868 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "E:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe"
11:01:44:870 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "E:\RocketLauncher\RocketLauncherUI\RocketLauncherUI.exe"
11:01:44:893 | MD |     TRACE  | +32    | File.__New - Creating new file object of: "E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2\doa.ini"
11:01:44:920 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2.ini"
11:01:44:955 | MD |     TRACE  | +31    | File.__New - Creating new file object of: "E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ini"
11:01:44:982 | MD |     TRACE  | +31    | File.Exist - This file exists: E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ini
11:01:44:016 | MD |     DEBUG  | +32    | RIniFile.__New - "Module" at index 1, adding "GlobalModuleIni" from: "E:\RocketLauncher\Modules\Sega Model 2 Emulator\Sega Model 2 Emulator.ini"
11:01:45:044 | MD |      INFO  | +31    | StartModule - Ended
11:01:45:057 | MD |      INFO  | +0     | StartGlobalUserFeatures - Starting
11:01:45:074 | MD |      INFO  | +31    | StartGlobalUserFeatures - Ending
11:01:45:085 | MD |      INFO  | +0     | CheckFile - Checking if E:\HyperSpin\ROMS\Sega Model 2\model2.zip exists
11:01:45:146 | MD |     DEBUG  | +63    | CheckFile - Attributes:
File Size: 93704 bytes
Created: 7/20/2016 - 10:36:28 PM
Modified: 7/20/2016 - 10:36:28 PM
11:01:45:148 | MD |      INFO  | +0     | CheckFile - Checking if E:\HyperSpin\Emulators\MODEL 2 EMULATOR v1.1a\EMULATOR.INI exists
11:01:45:205 | MD |     DEBUG  | +62    | CheckFile - Attributes:
File Size: 2824 bytes
Modified: 8/3/2016 - 10:53:43 AM
11:01:45:213 | MD |      INFO  | +0     | HideEmuStart - Starting HideEmuTimer, scanning for windows defined in hideEmuObj every 2ms
11:01:45:232 | MD |      INFO  | +31    | HideEmuStart - Ended
11:01:45:237 | MD |      INFO  | +0     | Run - Running: E:\HyperSpin\Emulators\MODEL 2 EMULATOR v1.1a\emulator_multicpu.exe doa
11:01:45:728 | MD |     DEBUG  | +485   | Run - "emulator_multicpu.exe doa" Process ID: 5764
11:01:45:858 | MD |     DEBUG  | +140   | HideEmuTimer - Found a new window to hide:
11:01:45:874 | MD |     DEBUG  | +16    | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x9045e | Process ID: 9992 | Process Path: E:\HyperSpin\HyperSpin.exe
11:01:45:875 | MD |      INFO  | +0     | WinWait - Waiting for "ahk_class MYWIN"
11:01:48:685 | MD |     DEBUG  | +2812  | GetActiveWindowStatus - Title: Dead or Alive (Model 2B) | Class: MYWIN | State: 0 | X: 26 | Y: 26 | Width: 512 | Height: 443 | Window HWND: 0x405ce | Process ID: 5764 | Process Path: E:\HyperSpin\Emulators\MODEL 2 EMULATOR v1.1a\emulator_multicpu.exe
11:01:50:906 | MD |     TRACE  | +2219  | CustomFunction.PostLoad - Starting
11:01:50:908 | MD |      INFO  | +0     | PostLoad - Starting
11:01:50:910 | MD |      INFO  | +0     | PostLoad - Ending
11:01:50:913 | MD |     TRACE  | +0     | CustomFunction.PostLoad - Ending
11:01:50:915 | MD |      INFO  | +0     | Process - WaitClose emulator_multicpu.exe
11:02:01:831 | MD |      INFO  | +10922 | CloseProcess - Started, user requested to end launched application
11:02:01:834 | MD |      INFO  | +0     | WinClose - Closing: AHK_class MYWIN
11:02:03:054 | MD |      INFO  | +1219  | CloseProcess - Ended
11:02:04:028 | MD |      INFO  | +984   | StopGlobalUserFeatures - Starting
11:02:04:030 | MD |      INFO  | +0     | StopGlobalUserFeatures - Ending
11:02:04:033 | MD |      INFO  | +0     | ExitModule - Started
11:02:04:107 | MD |      INFO  | +78    | RunKeymapper - Started, using method "unload"
11:02:04:114 | MD |      INFO  | +0     | GetJoystickArray - Started
11:02:04:326 | MD |     TRACE  | +219   | GetJoystickArray - Joysticks Detected: 1111000000000000
11:02:04:360 | MD |      INFO  | +31    | GetJoystickGUID - Started
11:02:04:366 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000
11:02:04:369 | MD |     TRACE  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000
11:02:04:422 | MD |      INFO  | +63    | GetJoystickGUID - Started
11:02:04:428 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000
11:02:04:430 | MD |     TRACE  | +0     | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000
11:02:04:498 | MD |      INFO  | +78    | GetJoystickGUID - Started
11:02:04:501 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000
11:02:04:503 | MD |     TRACE  | +0     | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000
11:02:04:536 | MD |      INFO  | +31    | GetJoystickGUID - Started
11:02:04:538 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000
11:02:04:541 | MD |     TRACE  | +0     | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000
11:02:04:563 | MD |      INFO  | +31    | GetJoystickArray - Ended
11:02:04:567 | MD |     TRACE  | +0     | RunKeymapper - Looping through controllers to find xpadder profiles for each one
11:02:04:570 | MD |     TRACE  | +0     | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:02:04:594 | MD |     TRACE  | +32    | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:02:04:597 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile
11:02:04:599 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile
11:02:04:602 | MD |      INFO  | +0     | GetProfile - Loading Player 1 Profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile
11:02:04:604 | MD |     TRACE  | +0     | RunKeymapper - ID: 2 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:02:04:640 | MD |     TRACE  | +47    | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:02:04:647 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile
11:02:04:649 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p2.xpadderprofile
11:02:04:651 | MD |     TRACE  | +0     | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:02:04:690 | MD |      INFO  | +46    | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:02:04:718 | MD |     TRACE  | +32    | RunKeymapper - ID: 3 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:02:04:721 | MD |     TRACE  | +0     | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:02:04:723 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile
11:02:04:724 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p3.xpadderprofile
11:02:04:726 | MD |     TRACE  | +0     | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:02:04:729 | MD |      INFO  | +0     | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:02:04:750 | MD |     TRACE  | +31    | RunKeymapper - ID: 4 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter"
11:02:04:752 | MD |     TRACE  | +0     | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank
11:02:04:756 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile
11:02:04:757 | MD |     TRACE  | +0     | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p4.xpadderprofile
11:02:04:759 | MD |     TRACE  | +0     | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:02:04:760 | MD |      INFO  | +0     | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile
11:02:04:828 | MD |      INFO  | +78    | RunXpadder - Started
11:02:04:831 | MD |      INFO  | +0     | Process - Exist JoyToKey.exe
11:02:04:876 | MD |     TRACE  | +47    | RunXpadder - Closing xpadder to refresh controllers seen by xpadder
11:02:04:878 | MD |      INFO  | +0     | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe /C
11:02:05:208 | MD |     DEBUG  | +328   | Run - "Xpadder.exe /C" Process ID: 10572
11:02:05:209 | MD |     TRACE  | +0     | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\HyperSpin\Profiles\Xpadder\xpadder.ini
11:02:05:211 | MD |      INFO  | +0     | Process - WaitClose Xpadder.exe 2
11:02:06:543 | MD |     TRACE  | +1344  | RunXpadder - Reading the order in E:\HyperSpin\Profiles\Xpadder\xpadder.ini and arranging profiles found to match that order
11:02:06:599 | MD |     TRACE  | +47    | RunXpadder - No more controllers to be found
11:02:06:600 | MD |      INFO  | +0     | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M
11:02:06:866 | MD |     DEBUG  | +265   | Run - "Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 9836
11:02:06:868 | MD |      INFO  | +0     | RunXpadder - Ended
11:02:06:870 | MD |      INFO  | +0     | RunKeymapper - Ended
11:02:06:900 | MD |      INFO  | +32    | LoadPreferredControllers - Started
11:02:06:901 | MD |     TRACE  | +0     | LoadPreferredControllers - JoyIDsPreferredControllers = Mayflash PS3 Game Controller Adapter
11:02:06:933 | MD |     TRACE  | +31    | LoadPreferredControllers - Creating a list of currently connected joysticks
11:02:06:951 | MD |      INFO  | +31    | GetJoystickArray - Started
11:02:07:100 | MD |     TRACE  | +141   | GetJoystickArray - Joysticks Detected: 1111000000000000
11:02:07:174 | MD |      INFO  | +78    | GetJoystickGUID - Started
11:02:07:178 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000
11:02:07:181 | MD |     TRACE  | +0     | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000
11:02:07:211 | MD |      INFO  | +31    | GetJoystickGUID - Started
11:02:07:232 | MD |      INFO  | +31    | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000
11:02:07:234 | MD |     TRACE  | +0     | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000
11:02:07:270 | MD |      INFO  | +32    | GetJoystickGUID - Started
11:02:07:277 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000
11:02:07:300 | MD |     TRACE  | +31    | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000
11:02:07:346 | MD |      INFO  | +47    | GetJoystickGUID - Started
11:02:07:349 | MD |      INFO  | +0     | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000
11:02:07:350 | MD |     TRACE  | +0     | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000
11:02:07:353 | MD |      INFO  | +0     | GetJoystickArray - Ended
11:02:07:355 | MD |     TRACE  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|0079|1801|702FB16B3B2AE6118001444553540000
11:02:07:379 | MD |     TRACE  | +31    | LoadPreferredControllers - Preferred Order Sorting List -> 1.02|0079|1801|E040B26B3B2AE6118002444553540000
11:02:07:381 | MD |     TRACE  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.03|0079|1801|008FB26B3B2AE6118003444553540000
11:02:07:382 | MD |     TRACE  | +0     | LoadPreferredControllers - Preferred Order Sorting List -> 1.04|0079|1801|20DDB26B3B2AE6118004444553540000
11:02:07:385 | MD |      INFO  | +0     | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List
11:02:07:409 | MD |      INFO  | +31    | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers
11:02:07:414 | MD |      INFO  | +0     | ChangeJoystickID - Started
11:02:07:487 | MD |     TRACE  | +78    | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_0079&PID_1801&GUID_702FB16B3B2AE6118001444553540000
11:02:07:489 | MD |      INFO  | +0     | ChangeJoystickID - Ended
11:02:07:491 | MD |      INFO  | +0     | ChangeJoystickID - Started
11:02:07:494 | MD |     TRACE  | +0     | ChangeJoystickID - Swapping Joystick ID: 01000000 to the New Joystick ID: 01000000, for the Joystick VID_0079&PID_1801&GUID_E040B26B3B2AE6118002444553540000
11:02:07:512 | MD |      INFO  | +32    | ChangeJoystickID - Ended
11:02:07:514 | MD |      INFO  | +0     | ChangeJoystickID - Started
11:02:07:518 | MD |     TRACE  | +0     | ChangeJoystickID - Swapping Joystick ID: 02000000 to the New Joystick ID: 02000000, for the Joystick VID_0079&PID_1801&GUID_008FB26B3B2AE6118003444553540000
11:02:07:519 | MD |      INFO  | +0     | ChangeJoystickID - Ended
11:02:07:545 | MD |      INFO  | +31    | ChangeJoystickID - Started
11:02:07:557 | MD |     TRACE  | +0     | ChangeJoystickID - Swapping Joystick ID: 03000000 to the New Joystick ID: 03000000, for the Joystick VID_0079&PID_1801&GUID_20DDB26B3B2AE6118004444553540000
11:02:07:582 | MD |      INFO  | +31    | ChangeJoystickID - Ended
11:02:07:584 | MD |      INFO  | +0     | LoadPreferredControllers - Ended
11:02:07:587 | MD |     TRACE  | +0     | CustomFunction.PostExit - Starting
11:02:07:607 | MD |      INFO  | +31    | PostExit - Starting
11:02:07:639 | MD |      INFO  | +32    | PostExit - Ending
11:02:07:673 | MD |     TRACE  | +31    | CustomFunction.PostExit - Ending
11:02:07:704 | MD |      INFO  | +31    | ExitModule - Ended
End of Module Logs
11:02:07:748 | RL |      INFO  | +26031 | Main - Module ended, exiting RocketLauncher normally
11:02:07:751 | RL |      INFO  | +0     | ExitScript - Started
11:02:07:772 | RL |     DEBUG  | +16    | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
11:02:07:775 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
11:02:07:778 | RL |     TRACE  | +15    | StringUtils.Contains - "true" contains "true|kill" at position 1
11:02:07:780 | RL |      INFO  | +0     | ExitScript - Restoring taskbar
11:02:07:782 | RL |     TRACE  | +0     | Window.Show - Unhiding window "ahk_class Shell_TrayWnd"
11:02:07:970 | RL |     TRACE  | +188   | Window.Show - Unhiding window "Start ahk_class Button"
11:02:08:250 | RL |      INFO  | +281   | SystemCursor - Restoring mouse cursor
11:02:08:619 | RL |      INFO  | +359   | ExitScript - Restored cursor
Any help would be greatly appreciated!!
