jgreno72 Posted August 4, 2016 Posted August 4, 2016 Hi, Anyone out there have any thoughts on this? Using Project 64 to emulate runs good through RLUI and Hyperspin only if I have logging on Troubleshooting inside Rocket Launcher. When I shut off logging, or set it low on Info, Nintendo 64 can be heard running in background but the screen is frozen to a partial image of Hyperspin. 19:38:39:456 | RL | INFO | +N/A | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com) 19:38:39:497 | RL | WARNING | +47 | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance. 19:38:41:300 | RL | DEBUG | +1797 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 19:38:41:324 | RL | DEBUG | +31 | Registry.Read - Registry Read finished, returning 0 19:38:41:350 | RL | INFO | +16 | Main - System Specs: RocketLauncher Dir: E:\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 8099.54 MB Free Memory: 5323.33 MB Used Memory: 2776.203 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: Intel(R) HD Graphics 5500 GPU 1 RAM: 1024.00 MB GPU 1 Driver Version: 10.18.15.4240 Sound 1 Device: Intel® Smart Sound Technology (Intel® SST) Sound 1 Status: Enabled Sound 2 Device: Intel(R) Display Audio Sound 2 Status: Enabled OS Language: English_United_States System Locale: en-US Formats Locale: en-US Windows UI Language: en-US Text Encoding: Windows-1252 OS Admin Status: No RL Compatibility Flags: HIGHDPIAWARE Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape] (Primary) Monitor #2 (\\.\DISPLAY2): 1920x1080 (1920x1020 work) [32bit] [60hz] [Landscape] Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 100 Monitor #2 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 19:38:41:372 | RL | INFO | +31 | CheckFile - Checking if E:\RocketLauncher\RocketLauncher.exe exists 19:38:41:484 | RL | DEBUG | +110 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.1.1.1 LegalCopyright ©2016 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.1.1.1 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2179584 bytes Created: 5/21/2016 - 1:35:31 PM Modified: 7/19/2016 - 4:09:23 PM 19:38:41:514 | RL | INFO | +31 | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: E:\HyperSpin\HyperSpin.exe 19:38:41:536 | RL | INFO | +16 | Main - Raw CLI received: "Nintendo 64 007 - GoldenEye (USA)" 19:38:41:687 | RL | TRACE | +156 | File.__New - Creating new file object of: "E:\RocketLauncher\Module Extensions\RocketLauncher.dll" 19:38:41:805 | RL | INFO | +125 | File.CheckFile - Checking if "E:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists 19:38:41:830 | RL | TRACE | +15 | File.Exist - This file exists: E:\RocketLauncher\Module Extensions\RocketLauncher.dll 19:38:41:866 | RL | DEBUG | +47 | File.CheckFile - Attributes: FileDescription RocketLauncher Utils FileVersion 1.0.0.9 InternalName RocketLauncher.dll LegalCopyright Copyright © RocketLauncher 2013-2016 OriginalFilename RocketLauncher.dll ProductName RocketLauncher ProductVersion 1.0.0.9 File Size: 68608 bytes Created: 5/21/2016 - 1:35:54 PM Modified: 7/19/2016 - 4:09:18 PM 19:38:42:027 | RL | INFO | +157 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\Array.ahk 19:38:42:061 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 4781 bytes Created: 5/21/2016 - 1:35:44 PM Modified: 5/21/2016 - 2:23:37 PM 19:38:42:237 | RL | INFO | +172 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2 19:38:42:266 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 5077 bytes Created: 5/21/2016 - 1:35:44 PM Modified: 5/21/2016 - 2:23:46 PM 19:38:42:292 | RL | INFO | +31 | CheckFile - Checking if E:\RocketLauncher\Module Extensions\BlockInput.exe exists 19:38:42:789 | RL | DEBUG | +500 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 5/21/2016 - 1:35:45 PM Modified: 5/20/2016 - 4:08:08 PM 19:38:42:913 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop 19:38:42:935 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 5323 bytes Created: 5/21/2016 - 1:35:46 PM Modified: 5/21/2016 - 2:24:02 PM 19:38:43:096 | RL | INFO | +156 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk 19:38:43:096 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 5/21/2016 - 1:35:46 PM Modified: 5/20/2016 - 4:08:08 PM 19:38:43:265 | RL | INFO | +172 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\gdip.ahk 19:38:43:294 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 88789 bytes Created: 5/21/2016 - 1:35:47 PM Modified: 5/20/2016 - 4:08:08 PM 19:38:43:407 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3 19:38:43:433 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 5891 bytes Created: 5/21/2016 - 1:35:47 PM Modified: 5/20/2016 - 4:08:08 PM 19:38:43:453 | RL | INFO | +15 | CheckFile - Checking if E:\RocketLauncher\Module Extensions\gsdll32.dll exists 19:38:43:735 | RL | DEBUG | +282 | CheckFile - Attributes: File Size: 13090816 bytes Created: 5/21/2016 - 1:35:50 PM Modified: 5/20/2016 - 4:08:10 PM 19:38:43:756 | RL | INFO | +15 | CheckFile - Checking if E:\RocketLauncher\Module Extensions\itextsharp.dll exists 19:38:44:068 | RL | DEBUG | +313 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 5/21/2016 - 1:35:52 PM Modified: 5/20/2016 - 4:08:10 PM 19:38:44:166 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\Java.ahk | v1.0.0 19:38:44:212 | RL | DEBUG | +47 | CheckFile - Attributes: File Size: 7841 bytes Created: 5/21/2016 - 1:35:52 PM Modified: 5/20/2016 - 4:08:10 PM 19:38:44:336 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\JSON.ahk 19:38:44:364 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 9227 bytes Created: 5/21/2016 - 1:35:52 PM Modified: 5/21/2016 - 2:24:11 PM 19:38:44:470 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2 19:38:44:486 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 4904 bytes Created: 5/21/2016 - 1:35:53 PM Modified: 5/20/2016 - 4:08:11 PM 19:38:44:586 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\RegRW64.ahk 19:38:44:610 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 6915 bytes Created: 5/21/2016 - 1:35:54 PM Modified: 5/20/2016 - 4:08:11 PM 19:38:44:748 | RL | INFO | +140 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\RIni.ahk | v1.7 19:38:44:776 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 67562 bytes Created: 5/21/2016 - 1:35:54 PM Modified: 7/5/2016 - 6:41:12 PM 19:38:44:786 | RL | INFO | +0 | CheckFile - Checking if E:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 19:38:45:016 | RL | DEBUG | +234 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.5717.6837 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.5717.6837 CompanyName Markovtsev Vadim File Size: 167424 bytes Created: 5/21/2016 - 1:35:55 PM Modified: 5/20/2016 - 4:08:11 PM 19:38:45:147 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3 19:38:45:174 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 5504 bytes Created: 5/21/2016 - 1:35:55 PM Modified: 5/21/2016 - 2:23:32 PM 19:38:45:337 | RL | INFO | +172 | CRC Check - CRC matches, this is an official unedited Extension: E:\RocketLauncher\Module Extensions\VA.ahk 19:38:45:371 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 34688 bytes Created: 5/21/2016 - 1:35:55 PM Modified: 5/20/2016 - 4:08:11 PM 19:38:45:507 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1 19:38:45:534 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 3833 bytes Created: 5/21/2016 - 1:35:55 PM Modified: 5/20/2016 - 4:08:11 PM 19:38:45:656 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\7z.ahk | v1.1.0 19:38:45:680 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 31579 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 7/5/2016 - 6:41:13 PM 19:38:45:818 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Bezel.ahk | v1.2.5 19:38:45:836 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 119247 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 7/5/2016 - 6:41:11 PM 19:38:46:006 | RL | INFO | +156 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Fade.ahk | v1.1.9 19:38:46:026 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 39542 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 7/5/2016 - 6:41:14 PM 19:38:46:174 | RL | INFO | +140 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Fade Init.ahk | v1.0.3 19:38:46:212 | RL | DEBUG | +47 | CheckFile - Attributes: File Size: 1130 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/21/2016 - 2:23:34 PM 19:38:46:324 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Fade Animations.ahk | v1.2.4 19:38:46:356 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 77966 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 7/19/2016 - 4:09:19 PM 19:38:46:476 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Keymapper.ahk | v1.1.5 19:38:46:506 | RL | DEBUG | +15 | CheckFile - Attributes: File Size: 33668 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/21/2016 - 2:23:43 PM 19:38:46:626 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6 19:38:46:670 | RL | DEBUG | +47 | CheckFile - Attributes: File Size: 3956 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/21/2016 - 2:24:13 PM 19:38:46:799 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\MultiGame.ahk | v1.1.0 19:38:46:828 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 41541 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/21/2016 - 2:24:18 PM 19:38:46:937 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0 19:38:46:958 | RL | DEBUG | +15 | CheckFile - Attributes: File Size: 161 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:47:075 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8 19:38:47:100 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 66776 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:47:246 | RL | INFO | +156 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Pause.ahk | v1.2.4 19:38:47:291 | RL | DEBUG | +47 | CheckFile - Attributes: File Size: 397144 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 7/5/2016 - 6:41:19 PM 19:38:47:406 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Pause Init.ahk | v1.0.3 19:38:47:434 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 553 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:47:542 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Password.ahk | v1.0.4 19:38:47:571 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 10121 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/21/2016 - 2:23:34 PM 19:38:47:686 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7.1 19:38:47:736 | RL | DEBUG | +47 | CheckFile - Attributes: File Size: 26345 bytes Created: 5/21/2016 - 2:23:51 PM Modified: 7/19/2016 - 4:09:19 PM 19:38:47:862 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1.0 19:38:47:885 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 3098 bytes Created: 5/21/2016 - 2:23:32 PM Modified: 7/5/2016 - 6:41:16 PM 19:38:47:993 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1.1 19:38:47:996 | RL | DEBUG | +0 | CheckFile - Attributes: File Size: 6725 bytes Created: 5/21/2016 - 2:23:42 PM Modified: 7/5/2016 - 6:41:30 PM 19:38:48:127 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0.0 19:38:48:150 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 1549 bytes Created: 5/21/2016 - 2:23:28 PM Modified: 7/5/2016 - 6:41:13 PM 19:38:48:297 | RL | INFO | +140 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5.1 19:38:48:321 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 7797 bytes Created: 5/21/2016 - 2:23:27 PM Modified: 7/19/2016 - 4:09:12 PM 19:38:48:439 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0.0 19:38:48:467 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 2963 bytes Created: 5/21/2016 - 2:24:07 PM Modified: 7/5/2016 - 6:41:16 PM 19:38:48:583 | RL | INFO | +109 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.6.0 19:38:48:608 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 9146 bytes Created: 5/21/2016 - 2:24:28 PM Modified: 7/5/2016 - 6:41:16 PM 19:38:48:742 | RL | INFO | +140 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0.0 19:38:48:773 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 648 bytes Created: 5/21/2016 - 2:24:01 PM Modified: 7/5/2016 - 6:41:19 PM 19:38:48:877 | RL | INFO | +93 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0.0 19:38:48:905 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 4412 bytes Created: 5/21/2016 - 2:24:26 PM Modified: 7/5/2016 - 6:41:21 PM 19:38:49:025 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.1.1 19:38:49:054 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 3741 bytes Created: 5/21/2016 - 2:23:39 PM Modified: 7/5/2016 - 6:41:14 PM 19:38:49:191 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5.0 19:38:49:216 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 9584 bytes Created: 5/21/2016 - 2:24:25 PM Modified: 7/5/2016 - 6:41:10 PM 19:38:49:346 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1.0 19:38:49:377 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 1220 bytes Created: 5/21/2016 - 2:23:32 PM Modified: 7/5/2016 - 6:41:21 PM 19:38:49:496 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0.1 19:38:49:535 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 5520 bytes Created: 5/21/2016 - 2:23:50 PM Modified: 7/5/2016 - 6:41:21 PM 19:38:49:654 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2.0 19:38:49:682 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 4561 bytes Created: 5/21/2016 - 2:24:09 PM Modified: 7/5/2016 - 6:41:22 PM 19:38:49:817 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2.0 19:38:49:827 | RL | DEBUG | +15 | CheckFile - Attributes: File Size: 22846 bytes Created: 5/21/2016 - 2:23:30 PM Modified: 7/5/2016 - 6:41:23 PM 19:38:49:936 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0.0 19:38:49:953 | RL | DEBUG | +15 | CheckFile - Attributes: File Size: 1156 bytes Created: 5/21/2016 - 2:23:45 PM Modified: 7/5/2016 - 6:41:15 PM 19:38:50:080 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7 19:38:50:109 | RL | DEBUG | +32 | CheckFile - Attributes: File Size: 72261 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:50:257 | RL | INFO | +140 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Shader.ahk | v1.0.1 19:38:50:301 | RL | DEBUG | +47 | CheckFile - Attributes: File Size: 3943 bytes Created: 5/21/2016 - 2:23:29 PM Modified: 5/21/2016 - 2:23:29 PM 19:38:50:416 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Shader Init.ahk | v1.0.0 19:38:50:436 | RL | DEBUG | +16 | CheckFile - Attributes: File Size: 397 bytes Created: 5/21/2016 - 2:23:25 PM Modified: 5/21/2016 - 2:23:25 PM 19:38:50:566 | RL | INFO | +125 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Shared.ahk | v1.4.7 19:38:50:599 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 175721 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 7/5/2016 - 6:41:03 PM 19:38:50:737 | RL | INFO | +141 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Statistics.ahk | v1.0.4 19:38:50:777 | RL | DEBUG | +47 | CheckFile - Attributes: File Size: 26810 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:50:925 | RL | INFO | +140 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1 19:38:50:955 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 33 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:51:061 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5 19:38:51:091 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 19148 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/21/2016 - 2:24:03 PM 19:38:51:181 | RL | INFO | +94 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\XHotkey.ahk | v1.0.4 19:38:51:199 | RL | DEBUG | +15 | CheckFile - Attributes: File Size: 26540 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:51:311 | RL | INFO | +110 | CRC Check - CRC matches, this is an official unedited Library: E:\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2 19:38:51:335 | RL | DEBUG | +31 | CheckFile - Attributes: File Size: 1063 bytes Created: 5/21/2016 - 1:35:37 PM Modified: 5/20/2016 - 4:07:51 PM 19:38:51:356 | RL | DEBUG | +16 | Main - Received this dbName with no path via CLI: "007 - GoldenEye (USA)" 19:38:51:372 | RL | DEBUG | +0 | Main - dbName: 007 - GoldenEye (USA) 19:38:51:396 | RL | INFO | +16 | Main - Loading Front End Plugin: "HyperSpin" 19:38:51:422 | RL | TRACE | +31 | Process.__New - Creating new process object for: "E:\HyperSpin\HyperSpin.exe" 19:38:51:443 | RL | TRACE | +16 | File.__New - Creating new file object of: "E:\HyperSpin\HyperSpin.exe" 19:38:51:544 | RL | INFO | +109 | Process.Process - "Exist" "HyperSpin.exe" 19:38:51:547 | RL | TRACE | +0 | Process.GetProcessID 19:38:51:610 | RL | INFO | +63 | Main - Detected HyperSpin.exe is currently running 19:38:51:633 | RL | TRACE | +31 | Window.__New - Created: "ahk_pid 9208" 19:38:51:655 | RL | TRACE | +16 | Window.Get - ID is "0x450380" from "ahk_pid 9208" 19:38:51:657 | RL | TRACE | +0 | Window.GetPos - Retrieved x:0 y:0 w: 1920 h: 1080 from "ahk_id 0x450380" 19:38:51:687 | RL | INFO | +31 | Main - HyperSpin.exe coordinates are x0 y0 w1920 h1080 19:38:51:721 | RL | INFO | +31 | Main - RocketLauncher received "Nintendo 64" and "007 - GoldenEye (USA)" 19:38:51:736 | RL | INFO | +16 | Main - Did not find a "E:\RocketLauncher\Settings\Nintendo 64\Game Options.ini" file, skipping any game-specific options. 19:38:51:786 | RL | INFO | +47 | Main - 007 - GoldenEye (USA) is using the default emulator: Project62 (v2.2) documents 19:38:51:802 | RL | INFO | +15 | Main - Checking for a [Project62 (v2.2) documents] section in E:\RocketLauncher\Settings\Nintendo 64\Emulators.ini 19:38:51:822 | RL | INFO | +31 | Main - Found [Project62 (v2.2) documents] in E:\RocketLauncher\Settings\Nintendo 64\Emulators.ini 19:38:51:968 | RL | INFO | +141 | CheckFile - Checking if E:\RocketLauncher\Modules\Project64\project64 (v2.x).ahk exists 19:38:52:037 | RL | DEBUG | +63 | CheckFile - Attributes: File Size: 5163 bytes Created: 7/5/2016 - 7:42:21 PM Modified: 7/5/2016 - 6:41:11 PM 19:38:52:076 | RL | INFO | +46 | Main - CRC Check - CRC matches, this is an official unedited module. 19:38:52:093 | RL | INFO | +16 | Main - 007 - GoldenEye (USA) will use module: E:\RocketLauncher\Modules\Project64\project64 (v2.x).ahk 19:38:52:704 | RL | WARNING | +609 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "E:\RocketLauncher\Settings\Global RocketLauncher.ini" 19:38:52:723 | RL | WARNING | +16 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "E:\RocketLauncher\Settings\Nintendo 64\RocketLauncher.ini" 19:38:52:883 | RL | INFO | +172 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 19:38:53:101 | RL | INFO | +219 | CheckFile - Checking if C:\Users\x\Documents\Games\Project64 2.2\Project64.exe exists 19:38:53:176 | RL | DEBUG | +62 | CheckFile - Attributes: FileDescription Project 64 FileVersion 2.2.0.3 InternalName Project64 LegalCopyright Copyright (C) 2013 OriginalFilename Project64.exe ProductName Project64 ProductVersion 2.2.0.3 File Size: 1298944 bytes Created: 7/11/2016 - 9:09:11 PM Modified: 3/30/2015 - 5:11:34 AM 19:38:53:202 | RL | INFO | +31 | Main - INI Keys read 19:38:53:307 | RL | INFO | +110 | CheckFile - Checking if E:\RocketLauncher\Module Extensions\7z.exe exists 19:38:53:379 | RL | DEBUG | +62 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 262144 bytes Created: 5/21/2016 - 1:35:44 PM Modified: 5/22/2016 - 1:15:40 PM 19:38:53:400 | RL | INFO | +32 | CheckFile - Checking if E:\RocketLauncher\Module Extensions\7z.dll exists 19:38:53:477 | RL | DEBUG | +78 | CheckFile - Attributes: FileDescription 7z Plugin FileVersion 15.06 beta InternalName 7z LegalCopyright Copyright (c) 1999-2015 Igor Pavlov OriginalFilename 7z.dll ProductName 7-Zip ProductVersion 15.06 beta CompanyName Igor Pavlov File Size: 1012224 bytes Created: 5/21/2016 - 1:35:44 PM Modified: 5/20/2016 - 4:08:08 PM 19:38:53:499 | RL | INFO | +15 | CreateRomMapTable - Started 19:38:53:524 | RL | DEBUG | +32 | AltNameExistCheck - Looking for rom: E:\HyperSpin\ROMS\Nintendo 64\007 - GoldenEye (USA).z64 19:38:53:556 | RL | INFO | +31 | AltNameExistCheck - Found rom: E:\HyperSpin\ROMS\Nintendo 64\007 - GoldenEye (USA).z64 19:38:53:577 | RL | INFO | +15 | CreateRomMapTable - Ended, No mapping inis found. 19:38:53:624 | RL | INFO | +47 | Main - "007 - GoldenEye (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 19:38:53:647 | RL | INFO | +16 | CheckPaths - Started 19:38:53:668 | RL | INFO | +31 | CheckPaths - Looking for rom: E:\HyperSpin\ROMS\Nintendo 64\007 - GoldenEye (USA).z64 19:38:53:680 | RL | INFO | +16 | CheckPaths - Found rom: E:\HyperSpin\ROMS\Nintendo 64\007 - GoldenEye (USA).z64 19:38:53:702 | RL | DEBUG | +15 | CheckPaths - Current romName: 007 - GoldenEye (USA) 19:38:53:707 | RL | DEBUG | +0 | CheckPaths - Current romPath: E:\HyperSpin\ROMS\Nintendo 64 19:38:53:746 | RL | DEBUG | +47 | CheckPaths - Current romExtension: .z64 19:38:53:776 | RL | INFO | +32 | CheckPaths - Ended 19:38:53:796 | RL | INFO | +15 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook MiscUtils.DetectHiddenWindows("On") SetTitleMatchMode, 2 SendMode, Event 0 = 2 rlPath = E:\RocketLauncher pluginPath = E:\RocketLauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.1.1.1 rlAuthor = djvj rlURL = www.rlauncher.com langFile = E:\RocketLauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 9208 frontendPath = E:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = E exitEmulatorKey = 1&C|Esc|2joy11 restoreFE = Restore exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = C:\Users\x\Documents\Games\Project64 2.2\Project64.exe emuPath = C:\Users\x\Documents\Games\Project64 2.2 emuName = Project62 (v2.2) documents emuExt = exe baseRomPath = romPath = E:\HyperSpin\ROMS\Nintendo 64 romPathFromIni = E:\HyperSpin\ROMS\Nintendo 64 romExtension = .z64 romExtensionOrig = .z64 romExtensions = z64|7z|zip|n64|v64 executable = Project64.exe systemDbName = Nintendo 64 systemName = Nintendo 64 dbPath = dbName = 007 - GoldenEye (USA) dbExt = romName = 007 - GoldenEye (USA) romMapPath = E:\RocketLauncher\Settings\Nintendo 64\Rom Mapping romMappingEnabled = true romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = true romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingHideParent = false romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingGameNameTextFont = Bebas Neue romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = E:\RocketLauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = setResolution = logFile = logLabel := [" INFO"," WARNING"," ERROR"," DEBUG"," TRACE"] logLevel = 10 logShowDebugConsole = false logShowCommandWindow = false logCommandWindow = false logIncludeModule = true logIncludeFileProperties = true logIncludeDLLLogs = false errorSounds = true rlDebugConsoleStdout = sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = Enter navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1920 originalHeight = 1080 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdDriveLetterScsi = vdAddDrive = true demulShooterPath = servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkySystemName = ledblinkyFullPath = ledblinkyProfilePath = E:\RocketLauncher\Profiles\LEDBlinky ledblinkyRLProfile = E:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher winIPACFullPath = ultraMapEnabled = false ultraMapFullPath = emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = true hideEmu = true hideFE = false suspendFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = DefaultAnimateFadeOut fadeOutDelay = 0 fadeLyrInterpolation = 0 fadeMuteEmulator = false fadeUseBackgrounds = false fadeClickThrough = false fadeSounds = true fade7zProgressMode = extraction fadeWidthBaseRes = 1280 fadeHeightBaseRes = 720 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 450 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = image fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = 7zOnly fadeProgressDuration = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoDeveloper = text with label fadeRomInfoPublisher = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Developer|Genre|Rating|Publisher fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = F detectFadeErrorEnabled = true fadeImgPath = E:\RocketLauncher\Media\Fade RLDataPath = E:\RocketLauncher\Data RLMediaPath = E:\RocketLauncher\Media RLErrSoundPath = E:\RocketLauncher\Media\Sounds\Error modulesPath = E:\RocketLauncher\Modules moduleFullName = E:\RocketLauncher\Modules\Project64\project64 (v2.x).ahk moduleName = project64 (v2.x) modulePath = E:\RocketLauncher\Modules\Project64 moduleExtension = ahk moduleExtensionsPath = E:\RocketLauncher\Module Extensions libPath = E:\RocketLauncher\Lib sevenZEnabled = false sevenZPath = E:\RocketLauncher\Module Extensions\7z.exe sevenZDllPath = E:\RocketLauncher\Module Extensions\7z.dll sevenZExtractPath = C:\TEMP GAME HYPERSPIN sevenZExtractPathOrig = sevenZAttachSystemName = false sevenZDelTemp = true sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar 7zExtractPath = C:\TEMP GAME HYPERSPIN mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1280 mgHeightBaseRes = 720 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side mgOnLaunch = false pauseEnabled = false pauseKey = ~NumpadAdd pauseBackToMenuBarKey = X pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = E:\RocketLauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = pauseLoadStateKeyCodes = keyboardEncoder = keyboardEncoderEnabled = false keymapperEnabled = true keymapperAHKMethod = false keymapper = xpadder xpadderFullPath = E:\HyperSpin\Profiles\Xpadder\Xpadder.exe joyToKeyFullPath = E:\RocketLauncher\Profiles\JoyToKey\JoyToKey.exe profilePath = E:\RocketLauncher\Profiles keymapperProfilePath = E:\RocketLauncher\Profiles\xpadder keymapperFrontEndProfileName = HyperSpin keymapperFrontEndProfile = xpadder keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = Mayflash PS3 Game Controller Adapter joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = Mayflash PS3 Game Controller Adapter CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = E:\RocketLauncher\Profiles\xpadder\HyperSpin defaultProfile = E:\RocketLauncher\Profiles\xpadder\_Default systemProfile = E:\RocketLauncher\Profiles\xpadder\Nintendo 64 xPadderSystemProfile = E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default emuProfile = E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents romProfile = E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA) RocketLauncherProfile = E:\RocketLauncher\Profiles\xpadder\RocketLauncher blankProfile = E:\RocketLauncher\Profiles\xpadder\_Default\blank ahkFEProfile = E:\RocketLauncher\Profiles\AHK\HyperSpin ahkDefaultProfile = E:\RocketLauncher\Profiles\AHK\_Default ahkSystemProfile = E:\RocketLauncher\Profiles\AHK\Nintendo 64 ahkEmuProfile = E:\RocketLauncher\Profiles\AHK\Nintendo 64\Project62 (v2.2) documents ahkRomProfile = E:\RocketLauncher\Profiles\AHK\Nintendo 64\007 - GoldenEye (USA) ahkRocketLauncherProfile = E:\RocketLauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false shaderName = false shaderColor = shaderTransparency = statisticsEnabled = false pressDuration = -1 emuVolume = 1 dxwndIni = E:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = E:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe qResFullPath = E:\RocketLauncher\Module Extensions\QRes.exe mon1O = pacDrivedllFile = E:\RocketLauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = E:\RocketLauncher\Lib\User Fade Animations.ini testFile = testDuration = initialErrorMode = 0 19:38:53:824 | RL | INFO | +31 | BuildScript - Loaded XHotkey Init.ahk scripts 19:38:53:841 | RL | INFO | +16 | BuildScript - Loaded Keymapper Init.ahk scripts 19:38:53:863 | RL | INFO | +16 | BuildScript - Loaded User Functions Init.ahk script 19:38:53:866 | RL | DEBUG | +15 | BuildScript - Module starts on line: 2 19:38:53:891 | RL | INFO | +16 | BuildScript - Validating module 19:38:53:907 | RL | INFO | +16 | BuildScript - Validation complete 19:38:53:939 | RL | INFO | +31 | BuildScript - Module: MEmu = Project64 MEmuV = v2.2.x MURL = http://www.pj64-emu.com/ MAuthor = djvj MVersion = 2.0.5 MCRC = 38E6ADCC iCRC = 28E52E46 MID = 635038268918025653 MSystem = "Nintendo 64","Nintendo 64DD" ;---------------------------------------------------------------------------- ; Notes: ; Run the emu manually and hit Ctrl+T to enter Settings. On Options, check "On loading a ROM go to full screen" ; If roms don't start automatically, enabled advanced settings, and go to the Advanced and check "Start Emulation when rom is opened?" ; I like to turn off the Rom Browser by going to Settings->Rom Selection and uncheck "Use Rom Browser" (advanced settings needs to be on to see this tab) ; If you use Esc as your exit key, it could crash the emu because it also takes the emu out of fullscreen, ; You can remove Esc as a key to change fullscreen mode in the Settings->Keyboard Shortcuts, change CPU State to Game Playing (fullscreen) then Options->Full Screen and remove Esc from Current Keys ; Suggested to use Glide64 Final plugin as your graphics plugin (it does not crash on exit): https://code.google.com/p/glidehqplusglitch64/downloads/detail?name=Glide64_Final.zip&can=2&q= ; 64DD support requires Project 64 2.2.0.3 or above. Only 64DD disk to cart conversions work. ; Original 64DD disk images are not currently supported. ; Project64 Plugins store their settings in the Project64.cfg as of 2.2.0.1 ; Known Plugin issues: ; Video - Rice: crashes with annoying msgbox on exiting from fullscreen ; ; Nintendo 64DD support: ; To play N64DD games it's recommended that you use Project64U instead, this version of the emulator can be used with this module. Download it here: ; https://project64u.wordpress.com/ ; ; Disk dumps aren't supported by the emulator so make sure you use the cart conversions. ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() ; Get emulator version from executable, this is needed since ahk_class uses it exeAtrib := FileGetVersionInfo_AW(EmuPath . "\" . executable, "FileVersion|ProductVersion", "|") Loop, Parse, exeAtrib, |%A_Tab%, %A_Space% A_Index & 1 ? ( _ := A_LoopField ) : ( %_% := A_LoopField ) If (ProductVersion) StringRight, FileEmuVersion, ProductVersion, StrLen(ProductVersion) Log("Module - Detected Project64 Product Version from '" . EmuPath . "\" . executable . "' is " . FileEmuVersion) If (!FileEmuVersion) FileEmuVersion := "2.2.0.3" settingsFile := modulePath . "\" . moduleName . ".ini" Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) ; Controls if emu launches fullscreen or windowed EmuVersion := IniReadCheck(settingsFile, "Settings", "EmuVersion",FileEmuVersion,,1) bezelDelay := IniReadCheck(settingsFile, "Settings", "BezelDelay","",,1) ; amount in milliseconds to give Project64 time to draw its window before bezel takes over hideEmuObj := Object("ahk_class Project64 " . EmuVersion,1) ; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later 7z(romPath, romName, romExtension, sevenZExtractPath) BezelStart("FixResMode") emuCfg := CheckFile(emuPath . "\Config\Project64.cfg") ; check for emu's settings file currentFullScreen := IniReadCheck(emuCfg,"default","Auto Full Screen") If (Fullscreen != "true" And currentFullScreen = 1) IniWrite(0,emuCfg,"default","Auto Full Screen") Else If (Fullscreen = "true" And currentFullScreen = 0) IniWrite(1,emuCfg,"default","Auto Full Screen") HideEmuStart() ; This fully ensures windows are completely hidden even faster than winwait Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath) WinWait("ahk_class Project64 " . EmuVersion) WinWaitActive("ahk_class Project64 " . EmuVersion) If (bezelEnabled = "true") Control, Hide,, msctls_statusbar321, ahk_class Project64 %EmuVersion% ; Removes the StatusBar Sleep % bezelDelay BezelDraw() HideEmuEnd() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() HaltEmu: PostMessage, 0x111, 4152,,, ahk_class Project64 %EmuVersion% ; Pause/Resume emulation If (fullscreen = "true") { PostMessage, 0x111, 4172,,, ahk_class Project64 %EmuVersion% ; fullscreen part1 PostMessage, 0x111, 4173,,, ahk_class Project64 %EmuVersion% ; fullscreen part2 } Return RestoreEmu: Winrestore, ahk_class Project64 %EmuVersion% If (fullscreen = "true") { Sleep, 1000 ; couple required sleeps otherwise the emu doesn't always return to Fullscreen state PostMessage, 0x111, 4172,,, ahk_class Project64 %EmuVersion% ; fullscreen part1 Sleep, 500 PostMessage, 0x111, 4173,,, ahk_class Project64 %EmuVersion% ; fullscreen part2 } PostMessage, 0x111, 4152,,, ahk_class Project64 %EmuVersion% ; Pause/Resume emulation Return CloseProcess: FadeOutStart() PostMessage, 0x111, 4003,,, ahk_class Project64 %EmuVersion% ; End emulation Sleep, 500 ; WinClose("ahk_class Project64 2.0") ; Often leaves the process running PostMessage, 0x111, 4006,,, ahk_class Project64 %EmuVersion% ; Exit Emu Return 19:38:53:995 | RL | INFO | +62 | BuildScript - Loaded Multi-Player scripts 19:38:53:016 | RL | INFO | +16 | BuildScript - Loaded User Functions.ahk script 19:38:54:036 | RL | INFO | +16 | BuildScript - Finished injecting functions into module 19:38:54:058 | RL | INFO | +31 | Main - Module is built 19:38:54:079 | RL | INFO | +15 | CheckFile - Checking if E:\RocketLauncher\AutoHotkey.dll exists 19:38:54:148 | RL | DEBUG | +79 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.13.00 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2003-2013 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.13.00 File Size: 802304 bytes Created: 5/21/2016 - 1:35:30 PM Modified: 7/5/2016 - 6:41:33 PM 19:38:54:156 | RL | INFO | +0 | Main - Hiding taskbar 19:38:54:190 | RL | TRACE | +31 | Window.__New - Created: "ahk_class Shell_TrayWnd" 19:38:54:201 | RL | TRACE | +15 | Window.__New - Created: "Start ahk_class Button" 19:38:54:214 | RL | TRACE | +16 | Window.Hide - Hiding window "ahk_class Shell_TrayWnd" 19:38:54:226 | RL | TRACE | +16 | Window.Hide - Hiding window "Start ahk_class Button" 19:38:54:242 | RL | INFO | +15 | Main - Hiding desktop 19:38:54:294 | RL | INFO | +47 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 19:38:54:361 | RL | INFO | +63 | Main - Running module 19:38:54:863 | MD | INFO | +N/A | Module initialized 19:38:54:885 | MD | TRACE | +31 | XHotkeyTableCreation - Started 19:38:54:923 | MD | TRACE | +31 | XHotkeyTableCreation - KeyGroup ~1&~C not in TableKeyGroups 19:38:54:946 | MD | TRACE | +31 | XHotkeyTableCreation - Post loop 1 check 19:38:54:982 | MD | TRACE | +32 | XHotkeyTableCreation - Post loop 2 check 19:38:54:008 | MD | TRACE | +31 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~1 & ~C" to call label: "CloseProcess" 19:38:55:043 | MD | TRACE | +31 | XHotkeyTableCreation - Ended 19:38:55:046 | MD | TRACE | +0 | XHotkeyTableCreation - Started 19:38:55:093 | MD | TRACE | +47 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups ~1&~C, 19:38:55:122 | MD | TRACE | +31 | XHotkeyTableCreation - Post loop 1 check 19:38:55:152 | MD | TRACE | +32 | XHotkeyTableCreation - Post loop 2 check 19:38:55:182 | MD | TRACE | +31 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 19:38:55:223 | MD | TRACE | +31 | XHotkeyTableCreation - Ended 19:38:55:253 | MD | TRACE | +31 | XHotkeyTableCreation - Started 19:38:55:257 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~2joy11 not in TableKeyGroups ~1&~C,~Esc, 19:38:55:293 | MD | TRACE | +47 | XHotkeyTableCreation - Post loop 1 check 19:38:55:320 | MD | TRACE | +31 | XHotkeyTableCreation - Post loop 2 check 19:38:55:327 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~2joy11" to call label: "CloseProcess" 19:38:55:367 | MD | TRACE | +47 | XHotkeyTableCreation - Ended 19:38:55:607 | MD | TRACE | +235 | Keymapper - Checking for the JoyIDs_Preferred_Controllers key in E:\RocketLauncher\Settings\Nintendo 64\Games JoyIDs.ini under section [007 - GoldenEye (USA)] 19:38:55:643 | MD | INFO | +31 | LoadPreferredControllers - Started 19:38:55:672 | MD | TRACE | +31 | LoadPreferredControllers - JoyIDsPreferredControllers = 1 19:38:55:712 | MD | TRACE | +47 | LoadPreferredControllers - Creating a list of currently connected joysticks 19:38:55:725 | MD | INFO | +0 | GetJoystickArray - Started 19:38:55:786 | MD | TRACE | +63 | GetJoystickArray - Joysticks Detected: 1111000000000000 19:38:55:826 | MD | INFO | +46 | GetJoystickGUID - Started 19:38:55:865 | MD | INFO | +32 | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000 19:38:55:902 | MD | TRACE | +47 | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000 19:38:55:967 | MD | INFO | +62 | GetJoystickGUID - Started 19:38:55:993 | MD | INFO | +31 | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000 19:38:55:042 | MD | TRACE | +47 | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000 19:38:56:105 | MD | INFO | +63 | GetJoystickGUID - Started 19:38:56:143 | MD | INFO | +31 | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000 19:38:56:146 | MD | TRACE | +0 | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000 19:38:56:186 | MD | INFO | +47 | GetJoystickGUID - Started 19:38:56:214 | MD | INFO | +31 | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000 19:38:56:242 | MD | TRACE | +31 | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000 19:38:56:246 | MD | INFO | +0 | GetJoystickArray - Ended 19:38:56:293 | MD | TRACE | +47 | LoadPreferredControllers - Preferred Order Sorting List -> 3.01|0079|1801|702FB16B3B2AE6118001444553540000 19:38:56:342 | MD | TRACE | +47 | LoadPreferredControllers - Preferred Order Sorting List -> 3.02|0079|1801|20DDB26B3B2AE6118004444553540000 19:38:56:383 | MD | TRACE | +47 | LoadPreferredControllers - Preferred Order Sorting List -> 3.03|0079|1801|008FB26B3B2AE6118003444553540000 19:38:56:396 | MD | TRACE | +0 | LoadPreferredControllers - Preferred Order Sorting List -> 3.04|0079|1801|E040B26B3B2AE6118002444553540000 19:38:56:443 | MD | INFO | +47 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 19:38:56:466 | MD | INFO | +31 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 19:38:56:492 | MD | INFO | +31 | ChangeJoystickID - Started 19:38:56:506 | MD | TRACE | +0 | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_0079&PID_1801&GUID_702FB16B3B2AE6118001444553540000 19:38:56:543 | MD | INFO | +47 | ChangeJoystickID - Ended 19:38:56:547 | MD | INFO | +0 | ChangeJoystickID - Started 19:38:56:593 | MD | TRACE | +47 | ChangeJoystickID - Swapping Joystick ID: 01000000 to the New Joystick ID: 01000000, for the Joystick VID_0079&PID_1801&GUID_20DDB26B3B2AE6118004444553540000 19:38:56:623 | MD | INFO | +31 | ChangeJoystickID - Ended 19:38:56:627 | MD | INFO | +0 | ChangeJoystickID - Started 19:38:56:684 | MD | TRACE | +63 | ChangeJoystickID - Swapping Joystick ID: 02000000 to the New Joystick ID: 02000000, for the Joystick VID_0079&PID_1801&GUID_008FB26B3B2AE6118003444553540000 19:38:56:687 | MD | INFO | +0 | ChangeJoystickID - Ended 19:38:56:743 | MD | INFO | +62 | ChangeJoystickID - Started 19:38:56:747 | MD | TRACE | +0 | ChangeJoystickID - Swapping Joystick ID: 03000000 to the New Joystick ID: 03000000, for the Joystick VID_0079&PID_1801&GUID_E040B26B3B2AE6118002444553540000 19:38:56:793 | MD | INFO | +47 | ChangeJoystickID - Ended 19:38:56:797 | MD | INFO | +0 | LoadPreferredControllers - Ended 19:38:56:837 | MD | INFO | +47 | CheckFile - Checking if E:\HyperSpin\Profiles\Xpadder\Xpadder.exe exists 19:38:56:874 | MD | DEBUG | +31 | CheckFile - Attributes: File Size: 1178624 bytes Created: 7/6/2016 - 8:36:47 PM Modified: 5/28/2016 - 2:38:14 PM 19:38:56:902 | MD | INFO | +32 | Keymapper - Loading xpadder 19:38:56:942 | MD | INFO | +31 | RunKeymapper - Started, using method "load" 19:38:56:965 | MD | INFO | +31 | GetJoystickArray - Started 19:38:57:046 | MD | TRACE | +78 | GetJoystickArray - Joysticks Detected: 1111000000000000 19:38:57:076 | MD | INFO | +31 | GetJoystickGUID - Started 19:38:57:076 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000 19:38:57:123 | MD | TRACE | +47 | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000 19:38:57:186 | MD | INFO | +63 | GetJoystickGUID - Started 19:38:57:219 | MD | INFO | +31 | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000 19:38:57:242 | MD | TRACE | +31 | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000 19:38:57:287 | MD | INFO | +32 | GetJoystickGUID - Started 19:38:57:323 | MD | INFO | +46 | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000 19:38:57:327 | MD | TRACE | +0 | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000 19:38:57:387 | MD | INFO | +63 | GetJoystickGUID - Started 19:38:57:387 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000 19:38:57:445 | MD | TRACE | +62 | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000 19:38:57:483 | MD | INFO | +32 | GetJoystickArray - Ended 19:38:57:508 | MD | TRACE | +31 | RunKeymapper - Found your keymapper application here: "E:\HyperSpin\Profiles\Xpadder\Xpadder.exe" 19:38:57:542 | MD | TRACE | +31 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 19:38:57:582 | MD | TRACE | +31 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:38:57:603 | MD | TRACE | +32 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:38:57:633 | MD | TRACE | +31 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile 19:38:57:683 | MD | TRACE | +47 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\p1.xpadderprofile 19:38:57:715 | MD | TRACE | +31 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile 19:38:57:753 | MD | TRACE | +31 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\p1.xpadderprofile 19:38:57:783 | MD | TRACE | +32 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile 19:38:57:813 | MD | TRACE | +31 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\p1.xpadderprofile 19:38:57:837 | MD | INFO | +31 | GetProfile - Loading Player 1 Profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\p1.xpadderprofile 19:38:57:872 | MD | TRACE | +31 | RunKeymapper - ID: 2 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:38:57:903 | MD | TRACE | +32 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:38:57:907 | MD | TRACE | +0 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile 19:38:57:953 | MD | TRACE | +46 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\p2.xpadderprofile 19:38:57:983 | MD | TRACE | +32 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile 19:38:57:986 | MD | TRACE | +0 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\p2.xpadderprofile 19:38:57:029 | MD | TRACE | +47 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile 19:38:58:063 | MD | TRACE | +31 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\p2.xpadderprofile 19:38:58:102 | MD | TRACE | +47 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile 19:38:58:115 | MD | TRACE | +0 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\p2.xpadderprofile 19:38:58:132 | MD | TRACE | +31 | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:38:58:146 | MD | INFO | +0 | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:38:58:146 | MD | TRACE | +0 | RunKeymapper - ID: 3 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:38:58:183 | MD | TRACE | +47 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:38:58:213 | MD | TRACE | +31 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile 19:38:58:253 | MD | TRACE | +31 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\p3.xpadderprofile 19:38:58:257 | MD | TRACE | +0 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile 19:38:58:303 | MD | TRACE | +47 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\p3.xpadderprofile 19:38:58:336 | MD | TRACE | +47 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile 19:38:58:366 | MD | TRACE | +31 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\p3.xpadderprofile 19:38:58:403 | MD | TRACE | +32 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile 19:38:58:430 | MD | TRACE | +31 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\p3.xpadderprofile 19:38:58:436 | MD | TRACE | +0 | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:38:58:473 | MD | INFO | +31 | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:38:58:493 | MD | TRACE | +31 | RunKeymapper - ID: 4 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:38:58:529 | MD | TRACE | +32 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents|E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default|E:\RocketLauncher\Profiles\xpadder\_Default|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:38:58:572 | MD | TRACE | +46 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile 19:38:58:603 | MD | TRACE | +32 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\007 - GoldenEye (USA)\p4.xpadderprofile 19:38:58:636 | MD | TRACE | +31 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile 19:38:58:666 | MD | TRACE | +31 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\Project62 (v2.2) documents\p4.xpadderprofile 19:38:58:676 | MD | TRACE | +0 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile 19:38:58:723 | MD | TRACE | +47 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\p4.xpadderprofile 19:38:58:753 | MD | TRACE | +31 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile 19:38:58:756 | MD | TRACE | +0 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\_Default\p4.xpadderprofile 19:38:58:803 | MD | TRACE | +47 | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:38:58:837 | MD | INFO | +47 | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:38:58:872 | MD | INFO | +31 | RunXpadder - Started 19:38:58:902 | MD | INFO | +32 | Process - Exist JoyToKey.exe 19:38:58:930 | MD | TRACE | +31 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 19:38:58:962 | MD | INFO | +31 | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe /C 19:38:59:102 | MD | DEBUG | +141 | Run - "Xpadder.exe /C" Process ID: 4920 19:38:59:134 | MD | TRACE | +31 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\HyperSpin\Profiles\Xpadder\xpadder.ini 19:38:59:137 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 19:39:00:043 | MD | TRACE | +906 | RunXpadder - Reading the order in E:\HyperSpin\Profiles\Xpadder\xpadder.ini and arranging profiles found to match that order 19:39:00:046 | MD | TRACE | +0 | RunXpadder - No more controllers to be found 19:39:00:092 | MD | INFO | +47 | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M 19:39:00:162 | MD | DEBUG | +63 | Run - "Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\Nintendo 64\_Default\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 7860 19:39:00:192 | MD | INFO | +31 | RunXpadder - Ended 19:39:00:216 | MD | INFO | +31 | RunKeymapper - Ended 19:39:00:253 | MD | INFO | +31 | StartModule - Started 19:39:00:282 | MD | INFO | +32 | StartModule - MEmu: Project64 MEmuV: v2.2.x MURL: http://www.pj64-emu.com/ MAuthor: djvj MVersion: 2.0.5 MCRC: 38E6ADCC iCRC: 28E52E46 MID: MSystem: "Nintendo 64","Nintendo 64DD" 19:39:00:320 | MD | INFO | +46 | StartModule - You have a supported System Name for this module: "Nintendo 64" 19:39:00:356 | MD | INFO | +32 | PluginInit - Started 19:39:00:399 | MD | DEBUG | +47 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating 19:39:00:429 | MD | INFO | +31 | CheckFile - Checking if E:\HyperSpin\Databases\Nintendo 64\Nintendo 64.xml exists 19:39:00:480 | MD | DEBUG | +47 | CheckFile - Attributes: File Size: 101822 bytes Created: 5/21/2016 - 1:34:41 PM Modified: 5/20/2016 - 4:27:08 PM 19:39:00:524 | MD | DEBUG | +47 | BuildDatabaseTable - Searching for a "Game Name" in the database 19:39:00:563 | MD | DEBUG | +31 | BuildDatabaseTable - Found "Game Name" in the database! 19:39:00:601 | MD | DEBUG | +47 | BuildDatabaseTable - Searching database for: Name 19:39:00:648 | MD | DEBUG | +47 | BuildDatabaseTable - Found "Name" with a value: "007 - GoldenEye (USA)" 19:39:00:680 | MD | DEBUG | +31 | BuildDatabaseTable - Searching database for: Cloneof 19:39:00:726 | MD | DEBUG | +47 | BuildDatabaseTable - Could not find: Cloneof 19:39:00:775 | MD | DEBUG | +47 | BuildDatabaseTable - Searching database for: Publisher 19:39:00:812 | MD | DEBUG | +31 | BuildDatabaseTable - Found "Publisher" with a value: "Nintendo" 19:39:00:876 | MD | DEBUG | +62 | BuildDatabaseTable - Searching database for: Year 19:39:00:946 | MD | DEBUG | +78 | BuildDatabaseTable - Found "Year" with a value: "1997" 19:39:01:023 | MD | DEBUG | +79 | BuildDatabaseTable - Searching database for: Genre 19:39:01:086 | MD | DEBUG | +62 | BuildDatabaseTable - Found "Genre" with a value: "Shooter" 19:39:01:134 | MD | DEBUG | +47 | BuildDatabaseTable - Searching database for: Rating 19:39:01:180 | MD | DEBUG | +47 | BuildDatabaseTable - Found "Rating" with a value: "ESRB - T (Teen)" 19:39:01:230 | MD | TRACE | +47 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: Shooter GameInfo Label: Name | GameInfo Value: 007 - GoldenEye (USA) GameInfo Label: Publisher | GameInfo Value: Nintendo GameInfo Label: Rating | GameInfo Value: ESRB - T (Teen) GameInfo Label: Year | GameInfo Value: 1997 19:39:01:273 | MD | DEBUG | +47 | BuildDatabaseTable - Ended 19:39:01:324 | MD | INFO | +46 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 19:39:01:371 | MD | DEBUG | +47 | BuildAssetsTable - Searching for a Game Logo: E:\HyperSpin\Media\Nintendo 64\Images\Wheel\007 - GoldenEye (USA).png 19:39:01:400 | MD | DEBUG | +32 | BuildAssetsTable - Searching for a System Logo: E:\HyperSpin\Media\Main Menu\Images\Wheel\Nintendo 64.png 19:39:01:447 | MD | DEBUG | +46 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: E:\HyperSpin\Media\Nintendo 64\Images\Wheel\007 - GoldenEye (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: E:\HyperSpin\Media\Main Menu\Images\Wheel\Nintendo 64.png | Asset Extension1: png | Asset Type1: system 19:39:01:481 | MD | INFO | +32 | BuildAssetsTable - Ended 19:39:01:524 | MD | INFO | +47 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 19:39:01:571 | MD | DEBUG | +46 | BuildAssetsTable - Searching for a Artwork1: E:\HyperSpin\Media\Nintendo 64\Images\Artwork1\007 - GoldenEye (USA).png 19:39:01:634 | MD | DEBUG | +63 | BuildAssetsTable - Searching for a Box Art: E:\HyperSpin\Media\Nintendo 64\Images\Artwork2\007 - GoldenEye (USA).png 19:39:01:664 | MD | DEBUG | +31 | BuildAssetsTable - Searching for a Cartridge: E:\HyperSpin\Media\Nintendo 64\Images\Artwork3\007 - GoldenEye (USA).png 19:39:01:712 | MD | DEBUG | +47 | BuildAssetsTable - Searching for a Flyers: E:\HyperSpin\Media\Nintendo 64\Images\Artwork4\007 - GoldenEye (USA).png 19:39:01:747 | MD | DEBUG | +31 | BuildAssetsTable - Searching for a Letters: E:\HyperSpin\Media\Nintendo 64\Images\Letters 19:39:01:966 | MD | DEBUG | +219 | BuildAssetsTable - Searching for a Other: E:\HyperSpin\Media\Nintendo 64\Images\Other 19:39:01:021 | MD | DEBUG | +47 | BuildAssetsTable - Media assets found: Asset Label: Cartridge | Asset Path1: E:\HyperSpin\Media\Nintendo 64\Images\Artwork3\007 - GoldenEye (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: Flyers | Asset Path1: E:\HyperSpin\Media\Nintendo 64\Images\Artwork4\007 - GoldenEye (USA).png | Asset Extension1: png | Asset Type1: game Asset Label: Letters | Asset Path1: E:\HyperSpin\Media\Nintendo 64\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: E:\HyperSpin\Media\Nintendo 64\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: E:\HyperSpin\Media\Nintendo 64\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: E:\HyperSpin\Media\Nintendo 64\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: E:\HyperSpin\Media\Nintendo 64\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: E:\HyperSpin\Media\Nintendo 64\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: E:\HyperSpin\Media\Nintendo 64\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: E:\HyperSpin\Media\Nintendo 64\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: E:\HyperSpin\Media\Nintendo 64\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: E:\HyperSpin\Media\Nintendo 64\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: E:\HyperSpin\Media\Nintendo 64\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: E:\HyperSpin\Media\Nintendo 64\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: E:\HyperSpin\Media\Nintendo 64\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: E:\HyperSpin\Media\Nintendo 64\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: E:\HyperSpin\Media\Nintendo 64\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: E:\HyperSpin\Media\Nintendo 64\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: E:\HyperSpin\Media\Nintendo 64\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: E:\HyperSpin\Media\Nintendo 64\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: E:\HyperSpin\Media\Nintendo 64\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: E:\HyperSpin\Media\Nintendo 64\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: E:\HyperSpin\Media\Nintendo 64\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: E:\HyperSpin\Media\Nintendo 64\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: E:\HyperSpin\Media\Nintendo 64\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: E:\HyperSpin\Media\Nintendo 64\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: E:\HyperSpin\Media\Nintendo 64\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: E:\HyperSpin\Media\Nintendo 64\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: E:\HyperSpin\Media\Nintendo 64\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: E:\HyperSpin\Media\Nintendo 64\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: E:\HyperSpin\Media\Nintendo 64\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: E:\HyperSpin\Media\Nintendo 64\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: E:\HyperSpin\Media\Nintendo 64\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: E:\HyperSpin\Media\Nintendo 64\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: E:\HyperSpin\Media\Nintendo 64\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: E:\HyperSpin\Media\Nintendo 64\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: E:\HyperSpin\Media\Nintendo 64\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: E:\HyperSpin\Media\Nintendo 64\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: E:\HyperSpin\Media\Nintendo 64\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: E:\HyperSpin\Media\Nintendo 64\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: E:\HyperSpin\Media\Nintendo 64\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: E:\HyperSpin\Media\Nintendo 64\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 19:39:02:070 | MD | INFO | +62 | BuildAssetsTable - Ended 19:39:02:134 | MD | INFO | +63 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 19:39:02:146 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Video: E:\HyperSpin\Media\Nintendo 64\Video\007 - GoldenEye (USA).* 19:39:02:213 | MD | DEBUG | +78 | BuildAssetsTable - Searching for a System Video: E:\HyperSpin\Media\Main Menu\Video\Nintendo 64.* 19:39:02:294 | MD | DEBUG | +78 | BuildAssetsTable - Media assets found: Asset Label: Game Video | Asset Path1: E:\HyperSpin\Media\Nintendo 64\Video\007 - GoldenEye (USA).mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: System Video | Asset Path1: E:\HyperSpin\Media\Main Menu\Video\Nintendo 64.mp4 | Asset Extension1: mp4 | Asset Type1: system 19:39:02:339 | MD | INFO | +47 | BuildAssetsTable - Ended 19:39:02:372 | MD | INFO | +31 | PluginInit - Ended 19:39:02:413 | MD | DEBUG | +47 | StartModule - Setting romName to the dbName sent to RocketLauncher: 007 - GoldenEye (USA) 19:39:02:507 | MD | INFO | +94 | SystemCursor - Hiding mouse cursor 19:39:02:648 | MD | TRACE | +141 | XHotkeyTableCreation - Started 19:39:02:680 | MD | TRACE | +31 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~1&~C,~Esc,~2joy11, 19:39:02:712 | MD | TRACE | +31 | XHotkeyTableCreation - Post loop 1 check 19:39:02:747 | MD | TRACE | +31 | XHotkeyTableCreation - Post loop 2 check 19:39:02:783 | MD | TRACE | +32 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 19:39:02:822 | MD | TRACE | +46 | XHotkeyTableCreation - Ended 19:39:02:856 | MD | TRACE | +32 | Process.__New - Creating new process object for: "E:\HyperSpin\HyperSpin.exe" 19:39:02:900 | MD | TRACE | +47 | File.__New - Creating new file object of: "E:\HyperSpin\HyperSpin.exe" 19:39:03:072 | MD | TRACE | +171 | File.__New - Creating new file object of: "E:\RocketLauncher\Modules\Project64\Nintendo 64\007 - GoldenEye (USA).ini" 19:39:03:230 | MD | TRACE | +157 | File.__New - Creating new file object of: "E:\RocketLauncher\Modules\Project64\Nintendo 64.ini" 19:39:03:373 | MD | TRACE | +140 | File.__New - Creating new file object of: "E:\RocketLauncher\Modules\Project64\project64 (v2.x).ini" 19:39:03:524 | MD | TRACE | +157 | File.Exist - This file exists: E:\RocketLauncher\Modules\Project64\project64 (v2.x).ini 19:39:03:556 | MD | DEBUG | +31 | RIniFile.__New - "Module" at index 1, adding "GlobalModuleIni" from: "E:\RocketLauncher\Modules\Project64\project64 (v2.x).ini" 19:39:03:612 | MD | INFO | +47 | StartModule - Ended 19:39:03:664 | MD | INFO | +62 | StartGlobalUserFeatures - Starting 19:39:03:695 | MD | INFO | +31 | StartGlobalUserFeatures - Ending 19:39:03:732 | MD | INFO | +32 | Module - Detected Project64 Product Version from 'C:\Users\x\Documents\Games\Project64 2.2\Project64.exe' is 2.2.0.3 19:39:03:765 | MD | INFO | +31 | CheckFile - Checking if C:\Users\x\Documents\Games\Project64 2.2\Config\Project64.cfg exists 19:39:03:808 | MD | DEBUG | +47 | CheckFile - Attributes: File Size: 2426 bytes Created: 7/11/2016 - 9:09:11 PM Modified: 8/4/2016 - 7:33:24 PM 19:39:03:843 | MD | INFO | +31 | HideEmuStart - Starting HideEmuTimer, scanning for windows defined in hideEmuObj every 2ms 19:39:03:885 | MD | INFO | +47 | HideEmuStart - Ended 19:39:03:911 | MD | INFO | +16 | Run - Running: C:\Users\x\Documents\Games\Project64 2.2\Project64.exe "E:\HyperSpin\ROMS\Nintendo 64\007 - GoldenEye (USA).z64" 19:39:04:013 | MD | DEBUG | +109 | Run - "Project64.exe "E:\HyperSpin\ROMS\Nintendo 64\007 - GoldenEye (USA).z64"" Process ID: 3712 19:39:04:041 | MD | DEBUG | +31 | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x450380 | Process ID: 9208 | Process Path: E:\HyperSpin\HyperSpin.exe 19:39:04:106 | MD | DEBUG | +63 | HideEmuTimer - Found a new window to hide: 19:39:04:164 | MD | INFO | +62 | WinWait - Waiting for "ahk_class Project64 2.2.0.3" 19:39:04:415 | MD | DEBUG | +250 | GetActiveWindowStatus - Title: Project64 2.2.0.3 | Class: Project64 2.2.0.3 | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 532 | Window HWND: 0x220538 | Process ID: 3712 | Process Path: C:\Users\x\Documents\Games\Project64 2.2\Project64.exe 19:39:04:439 | MD | DEBUG | +16 | GetActiveWindowStatus - Title: Project64 2.2.0.3 | Class: Project64 2.2.0.3 | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 532 | Window HWND: 0x220538 | Process ID: 3712 | Process Path: C:\Users\x\Documents\Games\Project64 2.2\Project64.exe 19:39:04:464 | MD | INFO | +31 | WinWaitActive - Waiting for "ahk_class Project64 2.2.0.3" 19:39:04:588 | MD | DEBUG | +125 | GetActiveWindowStatus - Title: Project64 2.2.0.3 | Class: Project64 2.2.0.3 | State: 0 | X: 0 | Y: 0 | Width: 646 | Height: 532 | Window HWND: 0x220538 | Process ID: 3712 | Process Path: C:\Users\x\Documents\Games\Project64 2.2\Project64.exe 19:39:04:669 | MD | TRACE | +78 | CustomFunction.PostLoad - Starting 19:39:04:697 | MD | INFO | +31 | PostLoad - Starting 19:39:04:751 | MD | INFO | +47 | PostLoad - Ending 19:39:04:776 | MD | TRACE | +32 | CustomFunction.PostLoad - Ending 19:39:04:806 | MD | INFO | +31 | Process - WaitClose Project64.exe 19:39:55:210 | MD | INFO | +50390 | CloseProcess - Started, user requested to end launched application 19:39:56:520 | MD | INFO | +1313 | CloseProcess - Ended 19:39:58:553 | MD | INFO | +2031 | StopGlobalUserFeatures - Starting 19:39:58:625 | MD | INFO | +78 | StopGlobalUserFeatures - Ending 19:39:58:665 | MD | INFO | +47 | ExitModule - Started 19:39:58:714 | MD | INFO | +47 | RunKeymapper - Started, using method "unload" 19:39:58:744 | MD | INFO | +31 | GetJoystickArray - Started 19:39:58:909 | MD | TRACE | +157 | GetJoystickArray - Joysticks Detected: 1111000000000000 19:39:58:971 | MD | INFO | +62 | GetJoystickGUID - Started 19:39:58:008 | MD | INFO | +47 | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000 19:39:59:068 | MD | TRACE | +47 | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000 19:39:59:110 | MD | INFO | +47 | GetJoystickGUID - Started 19:39:59:150 | MD | INFO | +47 | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000 19:39:59:188 | MD | TRACE | +31 | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000 19:39:59:254 | MD | INFO | +62 | GetJoystickGUID - Started 19:39:59:291 | MD | INFO | +47 | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000 19:39:59:341 | MD | TRACE | +47 | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000 19:39:59:395 | MD | INFO | +47 | GetJoystickGUID - Started 19:39:59:449 | MD | INFO | +62 | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000 19:39:59:497 | MD | TRACE | +47 | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000 19:39:59:527 | MD | INFO | +32 | GetJoystickArray - Ended 19:39:59:570 | MD | TRACE | +46 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 19:39:59:602 | MD | TRACE | +32 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:39:59:658 | MD | TRACE | +47 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:39:59:715 | MD | TRACE | +62 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p1.xpadderprofile 19:39:59:758 | MD | TRACE | +47 | GetProfile - Searching for a Player 1 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile 19:39:59:790 | MD | INFO | +31 | GetProfile - Loading Player 1 Profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile 19:39:59:841 | MD | TRACE | +47 | RunKeymapper - ID: 2 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:39:59:885 | MD | TRACE | +47 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:39:59:931 | MD | TRACE | +47 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p2.xpadderprofile 19:39:59:979 | MD | TRACE | +47 | GetProfile - Searching for a Player 2 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p2.xpadderprofile 19:39:59:028 | MD | TRACE | +47 | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:40:00:078 | MD | INFO | +46 | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:40:00:124 | MD | TRACE | +47 | RunKeymapper - ID: 3 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:40:00:181 | MD | TRACE | +63 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:40:00:214 | MD | TRACE | +31 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p3.xpadderprofile 19:40:00:269 | MD | TRACE | +47 | GetProfile - Searching for a Player 3 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p3.xpadderprofile 19:40:00:320 | MD | TRACE | +62 | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:40:00:353 | MD | INFO | +32 | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:40:00:398 | MD | TRACE | +47 | RunKeymapper - ID: 4 Now searching for a matching profile for this controller: "Mayflash PS3 Game Controller Adapter" 19:40:00:458 | MD | TRACE | +46 | GetProfile - Searching for these profiles (| delimited): E:\RocketLauncher\Profiles\xpadder\HyperSpin|E:\RocketLauncher\Profiles\xpadder\_Default\blank 19:40:00:492 | MD | TRACE | +47 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\Mayflash PS3 Game Controller Adapter\p4.xpadderprofile 19:40:00:541 | MD | TRACE | +47 | GetProfile - Searching for a Player 4 profile -> E:\RocketLauncher\Profiles\xpadder\HyperSpin\p4.xpadderprofile 19:40:00:588 | MD | TRACE | +47 | GetProfile - Searching -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:40:00:638 | MD | INFO | +47 | GetProfile - Loading Profile -> E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile 19:40:00:680 | MD | INFO | +47 | RunXpadder - Started 19:40:00:728 | MD | INFO | +47 | Process - Exist JoyToKey.exe 19:40:00:768 | MD | TRACE | +31 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 19:40:00:809 | MD | INFO | +47 | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe /C 19:40:00:931 | MD | DEBUG | +125 | Run - "Xpadder.exe /C" Process ID: 940 19:40:00:988 | MD | TRACE | +47 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\HyperSpin\Profiles\Xpadder\xpadder.ini 19:40:01:060 | MD | INFO | +78 | Process - WaitClose Xpadder.exe 2 19:40:02:053 | MD | TRACE | +984 | RunXpadder - Reading the order in E:\HyperSpin\Profiles\Xpadder\xpadder.ini and arranging profiles found to match that order 19:40:02:082 | MD | TRACE | +31 | RunXpadder - No more controllers to be found 19:40:02:132 | MD | INFO | +63 | Run - Running: E:\HyperSpin\Profiles\Xpadder\Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M 19:40:02:242 | MD | DEBUG | +109 | Run - "Xpadder.exe "E:\RocketLauncher\Profiles\xpadder\HyperSpin\p1.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" "E:\RocketLauncher\Profiles\xpadder\_Default\blank.xpadderprofile" /M" Process ID: 8584 19:40:02:280 | MD | INFO | +32 | RunXpadder - Ended 19:40:02:320 | MD | INFO | +46 | RunKeymapper - Ended 19:40:02:367 | MD | INFO | +47 | LoadPreferredControllers - Started 19:40:02:414 | MD | TRACE | +47 | LoadPreferredControllers - JoyIDsPreferredControllers = Mayflash PS3 Game Controller Adapter 19:40:02:450 | MD | TRACE | +31 | LoadPreferredControllers - Creating a list of currently connected joysticks 19:40:02:509 | MD | INFO | +63 | GetJoystickArray - Started 19:40:02:646 | MD | TRACE | +125 | GetJoystickArray - Joysticks Detected: 1111000000000000 19:40:02:703 | MD | INFO | +62 | GetJoystickGUID - Started 19:40:02:741 | MD | INFO | +32 | GetJoystickGUID - Ended and found GUID: 702FB16B3B2AE6118001444553540000 19:40:02:777 | MD | TRACE | +47 | GetJoystickArray - ID: 1 | Port: 0 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 702FB16B3B2AE6118001444553540000 19:40:02:817 | MD | INFO | +31 | GetJoystickGUID - Started 19:40:02:858 | MD | INFO | +47 | GetJoystickGUID - Ended and found GUID: 20DDB26B3B2AE6118004444553540000 19:40:02:899 | MD | TRACE | +47 | GetJoystickArray - ID: 2 | Port: 1 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 20DDB26B3B2AE6118004444553540000 19:40:02:938 | MD | INFO | +31 | GetJoystickGUID - Started 19:40:02:977 | MD | INFO | +47 | GetJoystickGUID - Ended and found GUID: 008FB26B3B2AE6118003444553540000 19:40:02:009 | MD | TRACE | +31 | GetJoystickArray - ID: 3 | Port: 2 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: 008FB26B3B2AE6118003444553540000 19:40:03:065 | MD | INFO | +47 | GetJoystickGUID - Started 19:40:03:105 | MD | INFO | +47 | GetJoystickGUID - Ended and found GUID: E040B26B3B2AE6118002444553540000 19:40:03:164 | MD | TRACE | +62 | GetJoystickArray - ID: 4 | Port: 3 | Name: Mayflash PS3 Game Controller Adapter | MID: 0079 | PID: 1801 | GUID: E040B26B3B2AE6118002444553540000 19:40:03:195 | MD | INFO | +31 | GetJoystickArray - Ended 19:40:03:242 | MD | TRACE | +47 | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|0079|1801|702FB16B3B2AE6118001444553540000 19:40:03:291 | MD | TRACE | +47 | LoadPreferredControllers - Preferred Order Sorting List -> 1.02|0079|1801|20DDB26B3B2AE6118004444553540000 19:40:03:340 | MD | TRACE | +47 | LoadPreferredControllers - Preferred Order Sorting List -> 1.03|0079|1801|008FB26B3B2AE6118003444553540000 19:40:03:384 | MD | TRACE | +47 | LoadPreferredControllers - Preferred Order Sorting List -> 1.04|0079|1801|E040B26B3B2AE6118002444553540000 19:40:03:414 | MD | INFO | +31 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 19:40:03:462 | MD | INFO | +47 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 19:40:03:510 | MD | INFO | +47 | ChangeJoystickID - Started 19:40:03:542 | MD | TRACE | +31 | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_0079&PID_1801&GUID_702FB16B3B2AE6118001444553540000 19:40:03:592 | MD | INFO | +47 | ChangeJoystickID - Ended 19:40:03:634 | MD | INFO | +47 | ChangeJoystickID - Started 19:40:03:682 | MD | TRACE | +47 | ChangeJoystickID - Swapping Joystick ID: 01000000 to the New Joystick ID: 01000000, for the Joystick VID_0079&PID_1801&GUID_20DDB26B3B2AE6118004444553540000 19:40:03:726 | MD | INFO | +47 | ChangeJoystickID - Ended 19:40:03:758 | MD | INFO | +31 | ChangeJoystickID - Started 19:40:03:810 | MD | TRACE | +47 | ChangeJoystickID - Swapping Joystick ID: 02000000 to the New Joystick ID: 02000000, for the Joystick VID_0079&PID_1801&GUID_008FB26B3B2AE6118003444553540000 19:40:03:853 | MD | INFO | +47 | ChangeJoystickID - Ended 19:40:03:898 | MD | INFO | +47 | ChangeJoystickID - Started 19:40:03:967 | MD | TRACE | +62 | ChangeJoystickID - Swapping Joystick ID: 03000000 to the New Joystick ID: 03000000, for the Joystick VID_0079&PID_1801&GUID_E040B26B3B2AE6118002444553540000 19:40:03:009 | MD | INFO | +47 | ChangeJoystickID - Ended 19:40:04:050 | MD | INFO | +31 | LoadPreferredControllers - Ended 19:40:04:090 | MD | TRACE | +47 | CustomFunction.PostExit - Starting 19:40:04:128 | MD | INFO | +31 | PostExit - Starting 19:40:04:179 | MD | INFO | +63 | PostExit - Ending 19:40:04:268 | MD | TRACE | +78 | CustomFunction.PostExit - Ending 19:40:04:312 | MD | INFO | +47 | ExitModule - Ended End of Module Logs 19:40:04:464 | RL | INFO | +70109 | Main - Module ended, exiting RocketLauncher normally 19:40:04:481 | RL | INFO | +16 | ExitScript - Started 19:40:04:548 | RL | DEBUG | +62 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 19:40:04:582 | RL | DEBUG | +31 | Registry.Read - Registry Read finished, returning 0 19:40:04:605 | RL | INFO | +32 | ExitScript - Restoring HyperSpin.exe to x0 y0 w h1080 19:40:04:642 | RL | TRACE | +31 | Window.Restore - Restoring window "ahk_id 0x450380" 19:40:04:799 | RL | INFO | +156 | ExitScript - Restoring HyperSpin.exe to attempt to put it into focus 19:40:04:812 | RL | TRACE | +16 | Window.Get - Transparent is "0" from "ahk_id 0x450380" 19:40:04:850 | RL | TRACE | +31 | Window.Set - Setting Transparent to Off for window "ahk_id 0x450380" 19:40:04:880 | RL | INFO | +31 | ExitScript - Checking what application is currently in focus. 19:40:04:907 | RL | TRACE | +32 | Window.Active - "ahk_id 0x450380" is the active window 19:40:04:922 | RL | INFO | +15 | ExitScript - HyperSpin is currently active. Proceeding with exit 19:40:04:942 | RL | TRACE | +16 | StringUtils.Contains - "true" contains "true|kill" at position 1 19:40:04:981 | RL | INFO | +47 | ExitScript - Restoring taskbar 19:40:04:005 | RL | TRACE | +15 | Window.Show - Unhiding window "ahk_class Shell_TrayWnd" 19:40:05:195 | RL | TRACE | +203 | Window.Show - Unhiding window "Start ahk_class Button" 19:40:05:312 | RL | INFO | +110 | SystemCursor - Restoring mouse cursor 19:40:05:436 | RL | INFO | +125 | ExitScript - Restored cursor
