MAME Games Won't Launch
krunchmuffin
RL v1.1.1.1
HS 1.4.16
MAME .178
As you can see, I am new to HS, but not MAME.
When I try to launch a MAME game, nothing happens. I have included the logs. They don't say anything tho. If I grab the path from the logs and run it via CMD line, it works. I can also run from MAME itself.
Also, and I don't know if related, if I launch RocketLauncher.exe it asks to pick a game to test, my NES is in there, but not MAME.
Log File
EDIT: I turned on Debug for RocketLauncher. Here is the log file. It looks like it is getting it.
Thanks!
Hi ,
Apparently, your  RocketLauncher is in this path : C:\RocketLauncher\RocketLauncher.exe
1) First, could you confirm that. ?  is this the correct drive letter?  > if not,  this could be probably the problem.
2) In RLHQ, do you setup the MAME emulator correctly? Is there  any error message from hyperspin whith an error sound or nothing hapens?
ghibu
