radiofrog Posted March 13, 2014 Posted March 13, 2014 SOLVED - Turns out all I had to do was add a couple lines into the nullDC .ini file specifically for any rom that uses a different cable setting (the default setting is "0"). e.g. - [soul Calibur (USA)] Cable = 1 I'm having a very specific problem with the nullDC cable setting. When I ran SoulCalibur straight through nullDC it started fine. Then I ran it in Hyperspin, and it gave me the error about having the wrong AV cable. When I started the game in nullDC directly again, it also gave me the cable error. So I changed the cable setting to the second option, hit reset, and it started again. But every time I run it through Hyperspin it resets. I'm thinking I need to change something in the AHK file, but I'm not sure what to change. Anyone else have this problem/know how to fix it? Thanks! Note: I'm a noob at all this. All my previous emulation experience has been just using MAME without a front end on a Mac. 19:22:19:097 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 4 Last_Time_Played: Friday March 14, 2014 07:22:01 PM Average_Time_Played: 23 Total_Time_Played: 90 System_Total_Played_Time: 106 Total_Global_Played_Time: 620 19:22:19:115 | MD | INFO | +32 | Game section statistics updated. 19:22:19:115 | MD | INFO | +0 | ExitModule - Ended 19:22:19:115 | MD | INFO | +0 | End of Module Logs 19:22:19:195 | HL | INFO | +18252 | Main - Module ended, exiting HyperLaunch normally - - - BLAH BLAH BLAH - - - (EDIT - Code deleted from post since it was irrelevant.)
boss32178 Posted September 24, 2014 Posted September 24, 2014 having the same issue have you got it fixed?
omarus Posted October 31, 2014 Posted October 31, 2014 Hello Radiofrog I have the same problem with a specific game (Netto de Tennis). When I change the cable type from the emulator it works but when I use Hyperspin it resets and it doesn't work anymore. Where do I have to add the line [Netto De Tennis (Japan)] Cable = 1 in the ini file of the emulator? thanks in advance for the reply
