ChrisKant Posted November 2, 2016 Posted November 2, 2016 Hey Guys, after several years of trail and error I could manage the keymapper problems with going over to JoyToKey. Most of the time it works flawless, perfect but on some situation it won't. Maybe some of you guys can help me with this. When hyperspin starts, JoyToKey will start automatically with it because I configured it in HyperHQ as a startup tool. when I start a game on any system, Rocketlauncher switched then the profil to the right ones. After exit the game, rl switched to the an Hyperspin Profil (same like the one from start up). some systems only god one button configured (the xbox guide button for exit), in those cases I configured the Joypad completely in the emulator. so far, everything is great. but with mame, rocketlauncher doesn't want to switch to the blank mame profil and it stays in the Hyperspin Profil. I have no idea why, because on any other emulator does it work great. also games with PC Launcher have sometimes the problem. but only when the Game itself will have problems with something (for example Assassins Creed 1 or 2, Assassins Creed Unity and so on). can some one help me with this? And how can I manage to work with hyper pause and Joytokey... nothing happend when I came into the Pause Modus - cannot left or cancel or do anything. I appreciate your help. If you guys need a rocketlauncher Log, here is one for mame: [code] 12:27:32:359 | RL | INFO | +N/A | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com) 12:27:32:359 | RL | WARNING | +0 | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance. 12:27:32:478 | RL | DEBUG | +109 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 12:27:32:479 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 12:27:32:479 | RL | INFO | +0 | Main - System Specs: RocketLauncher Dir: C:\Hyperspin\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 10 Home SKU: Windows 8 Total Memory: 16332.80 MB Free Memory: 13442.01 MB Used Memory: 2890.789 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: NVIDIA GeForce GTX 970 GPU 1 RAM: -1.00 MB GPU 1 Driver Version: 21.21.13.7306 Sound 1 Device: NVIDIA High Definition Audio Sound 1 Status: Enabled Sound 2 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM) Sound 2 Status: Enabled Sound 3 Device: Realtek High Definition Audio Sound 3 Status: Enabled OS Language: German_Standard System Locale: de-DE Formats Locale: de-DE Windows UI Language: de-DE Text Encoding: Windows-1252 OS Admin Status: Yes RL Compatibility Flags: Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1050 work) [32bit] [59hz] [Landscape] (Primary) Current AHK Desktop Width: 1920 Current AHK Desktop Height: 1080 Monitor #1 DPI: 100 ErrorMode: 0 AutoHotkey Path: AHK Version: 1.1.13.00 Unicode: No 12:27:32:480 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\RocketLauncher.exe exists 12:27:32:481 | RL | INFO | +16 | Main - Using HyperSpin normal mode for version 1.4.0.0 found at: C:\Hyperspin\HyperSpin.exe 12:27:32:482 | RL | INFO | +0 | Main - Raw CLI received: "MAME kinst2" 12:27:32:487 | RL | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Module Extensions\RocketLauncher.dll" 12:27:32:493 | RL | INFO | +0 | File.CheckFile - Checking if "C:\Hyperspin\RocketLauncher\Module Extensions\RocketLauncher.dll" exists 12:27:32:493 | RL | TRACE | +0 | File.Exist - This file exists: C:\Hyperspin\RocketLauncher\Module Extensions\RocketLauncher.dll 12:27:32:499 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\Array.ahk 12:27:32:502 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2 12:27:32:504 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe exists 12:27:32:508 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop 12:27:32:510 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk 12:27:32:513 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\gdip.ahk 12:27:32:519 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3 12:27:32:521 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\gsdll32.dll exists 12:27:32:525 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\itextsharp.dll exists 12:27:32:528 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\Java.ahk | v1.0.0 12:27:32:530 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\JSON.ahk 12:27:32:535 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2 12:27:32:538 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\RegRW64.ahk 12:27:32:541 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\RIni.ahk | v1.7 12:27:32:542 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists 12:27:32:545 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3 12:27:32:547 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Extension: C:\Hyperspin\RocketLauncher\Module Extensions\VA.ahk 12:27:32:552 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1 12:27:32:558 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\7z.ahk | v1.1.0 12:27:32:562 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Bezel.ahk | v1.2.5 12:27:32:565 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Fade.ahk | v1.1.9 12:27:32:571 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Fade Init.ahk | v1.0.3 12:27:32:574 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Fade Animations.ahk | v1.2.4 12:27:32:576 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Keymapper.ahk | v1.1.5 12:27:32:578 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6 12:27:32:580 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\MultiGame.ahk | v1.1.0 12:27:32:582 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0 12:27:32:587 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8 12:27:32:599 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Pause.ahk | v1.2.4 12:27:32:611 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Pause Init.ahk | v1.0.3 12:27:32:614 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Password.ahk | v1.0.4 12:27:32:620 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7.1 12:27:32:625 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1.0 12:27:32:630 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1.1 12:27:32:632 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0.0 12:27:32:639 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5.1 12:27:32:641 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0.0 12:27:32:642 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.6.0 12:27:32:644 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0.0 12:27:32:646 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0.0 12:27:32:648 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.1.1 12:27:32:658 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5.0 12:27:32:660 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1.0 12:27:32:662 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0.1 12:27:32:664 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2.0 12:27:32:666 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2.0 12:27:32:674 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0.0 12:27:32:677 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7 12:27:32:680 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Shader.ahk | v1.0.1 12:27:32:682 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Shader Init.ahk | v1.0.0 12:27:32:689 | RL | INFO | +15 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Shared.ahk | v1.4.7 12:27:32:693 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Statistics.ahk | v1.0.4 12:27:32:697 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1 12:27:32:703 | RL | INFO | +16 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5 12:27:32:707 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\XHotkey.ahk | v1.0.4 12:27:32:710 | RL | INFO | +0 | CRC Check - CRC matches, this is an official unedited Library: C:\Hyperspin\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2 12:27:32:711 | RL | DEBUG | +0 | Main - Received this dbName with no path via CLI: "kinst2" 12:27:32:711 | RL | DEBUG | +0 | Main - dbName: kinst2 12:27:32:711 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 12:27:32:712 | RL | TRACE | +0 | Process.__New - Creating new process object for: "C:\Hyperspin\HyperSpin.exe" 12:27:32:712 | RL | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\HyperSpin.exe" 12:27:32:714 | RL | INFO | +0 | Process.Process - "Exist" "HyperSpin.exe" 12:27:32:714 | RL | TRACE | +0 | Process.GetProcessID 12:27:32:722 | RL | INFO | +15 | Main - Detected HyperSpin.exe is currently running 12:27:32:723 | RL | TRACE | +0 | Window.__New - Created: "ahk_pid 9748" 12:27:32:723 | RL | TRACE | +0 | Window.Get - ID is "0x140718" from "ahk_pid 9748" 12:27:32:724 | RL | TRACE | +0 | Window.GetPos - Retrieved x:320 y:180 w: 1280 h: 720 from "ahk_id 0x140718" 12:27:32:724 | RL | INFO | +0 | Main - HyperSpin.exe coordinates are x320 y180 w1280 h720 12:27:32:724 | RL | INFO | +0 | Main - RocketLauncher received "MAME" and "kinst2" 12:27:32:732 | RL | INFO | +16 | Main - Did not find a "C:\Hyperspin\RocketLauncher\Settings\MAME\Game Options.ini" file, skipping any game-specific options. 12:27:32:735 | RL | INFO | +0 | Main - kinst2 is using the default emulator: Mame-Master 12:27:32:736 | RL | INFO | +0 | Main - Checking for a [Mame-Master] section in C:\Hyperspin\RocketLauncher\Settings\MAME\Emulators.ini 12:27:32:736 | RL | INFO | +0 | Main - Found [Mame-Master] in C:\Hyperspin\RocketLauncher\Settings\MAME\Emulators.ini 12:27:32:739 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ahk exists 12:27:32:743 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 12:27:32:744 | RL | INFO | +0 | Main - kinst2 will use module: C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ahk 12:27:32:774 | RL | WARNING | +31 | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "C:\Hyperspin\RocketLauncher\Settings\Global RocketLauncher.ini" 12:27:32:774 | RL | WARNING | +0 | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "C:\Hyperspin\RocketLauncher\Settings\MAME\RocketLauncher.ini" 12:27:32:810 | RL | INFO | +47 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 12:27:32:819 | RL | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Emulators\Mame-Master\mame64.exe exists 12:27:32:823 | RL | INFO | +0 | Main - INI Keys read 12:27:32:831 | RL | INFO | +16 | CheckFile - Checking if C:\Program Files\7-Zip\7z.exe exists 12:27:32:833 | RL | INFO | +0 | CheckFile - Checking if C:\Program Files\7-Zip\7z.dll exists 12:27:32:842 | RL | INFO | +15 | Main - "kinst2" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side 12:27:32:842 | RL | INFO | +0 | CheckPaths - Started 12:27:32:842 | RL | INFO | +0 | CheckPaths - Looking for rom: D:\HyperSpin\MAME\kinst2.zip 12:27:32:958 | RL | INFO | +110 | CheckPaths - Found rom: D:\HyperSpin\MAME\kinst2.zip 12:27:32:960 | RL | DEBUG | +0 | CheckPaths - Current romName: kinst2 12:27:32:960 | RL | DEBUG | +0 | CheckPaths - Current romPath: D:\HyperSpin\MAME 12:27:32:960 | RL | DEBUG | +0 | CheckPaths - Current romExtension: .zip 12:27:32:961 | RL | INFO | +0 | CheckPaths - Ended 12:27:32:961 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 12:27:32:964 | RL | INFO | +0 | BuildScript - Loaded Fade Init.ahk scripts 12:27:32:964 | RL | INFO | +15 | BuildScript - Loaded Pause Init.ahk scripts 12:27:32:966 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 12:27:32:967 | RL | WARNING | +0 | BuildScript - "C:\Hyperspin\RocketLauncher\Lib\User Functions Init.ahk" not found 12:27:32:968 | RL | DEBUG | +0 | BuildScript - Module starts on line: 2 12:27:32:968 | RL | INFO | +0 | BuildScript - Validating module 12:27:32:977 | RL | INFO | +0 | BuildScript - Validation complete 12:27:32:993 | RL | INFO | +16 | BuildScript - Loaded Pause scripts 12:27:32:996 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 12:27:32:006 | RL | INFO | +16 | BuildScript - Loaded Statistics.ahk script 12:27:33:007 | RL | WARNING | +0 | BuildScript - "C:\Hyperspin\RocketLauncher\Lib\User Functions.ahk" not found 12:27:33:009 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 12:27:33:011 | RL | INFO | +0 | Main - Module is built 12:27:33:012 | RL | INFO | +15 | CheckFile - Checking if C:\Hyperspin\RocketLauncher\AutoHotkey.dll exists 12:27:33:013 | RL | INFO | +0 | Main - Hiding taskbar 12:27:33:014 | RL | TRACE | +0 | Window.__New - Created: "ahk_class Shell_TrayWnd" 12:27:33:014 | RL | TRACE | +0 | Window.__New - Created: "Start ahk_class Button" 12:27:33:014 | RL | TRACE | +0 | Window.Hide - Hiding window "ahk_class Shell_TrayWnd" 12:27:33:122 | RL | TRACE | +110 | Window.Hide - Hiding window "Start ahk_class Button" 12:27:33:123 | RL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 12:27:33:123 | RL | INFO | +0 | Main - Running module 12:27:33:406 | MD | INFO | +N/A | Module initialized 12:27:33:407 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:33:407 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 12:27:33:407 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 12:27:33:408 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 12:27:33:408 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 12:27:33:408 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:33:409 | MD | DEBUG | +0 | fadeInTransitionAnimation: DefaultAnimateFadeIn 12:27:33:409 | MD | DEBUG | +0 | fadeOutTransitionAnimation: DefaultAnimateFadeOut 12:27:33:410 | MD | DEBUG | +0 | fadeLyr3Animation: DefaultFadeAnimation 12:27:33:410 | MD | DEBUG | +0 | fadeLyr37zAnimation: DefaultFadeAnimation 12:27:33:410 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:33:411 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~1 not in TableKeyGroups ~Esc, 12:27:33:411 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 12:27:33:411 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 12:27:33:411 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~1" to call label: "TogglePauseMenuStatus" 12:27:33:412 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:33:412 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:33:412 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~1, 12:27:33:412 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 12:27:33:413 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 12:27:33:413 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot" 12:27:33:413 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:33:413 | MD | INFO | +0 | StartModule - Started 12:27:33:414 | MD | INFO | +0 | StartModule - MEmu: MAME MEmuV: v0.166 MURL: http://www.mame.net/ MAuthor: djvj,faahrev,brolly,Tomkun MVersion: 2.3.7 MCRC: 5C737136 iCRC: 25E2CCF MID: MSystem: "AAE","Aamber Pegasus","Acorn Electron","Amstrad CPC","Amstrad GX4000","APF Imagination Machine","Apple II","Apple IIGS","Applied Technology MicroBee","Atari 8-Bit","Atari 2600","Atari 5200","Atari 7800","Atari Classics","Atari Jaguar","Atari Lynx","Bally Astrocade","Bandai Super Vision 8000","Bandai WonderSwan","Bandai WonderSwan Color","Bit Corporation Gamate","Camputers Lynx","Capcom","Capcom Classics","Capcom Play System","Capcom Play System II","Capcom Play System III","Casio PV-1000","Casio PV-2000","Cave","Coleco ADAM","ColecoVision","Commodore 64","Commodore MAX Machine","Creatronic Mega Duck","Data East Classics","EACA EG2000 Colour Genie","Emerson Arcadia 2001","Entex Adventure Vision","Epoch Game Pocket Computer","Epoch Super Cassette Vision","Exidy Sorcerer","Fairchild Channel F","Fujitsu FM-7","Funtech Super Acan","GamePark 32","GCE Vectrex","Hartung Game Master","HBMAME","Interton VC 4000","Irem Classics","JungleTac Sport Vii","Jupiter Ace","Konami Classics","LaserDisc","Magnavox Odyssey 2","MAME","Matra & Hachette Alice","Mattel Aquarius","Mattel Intellivision","MGT Sam Coupe","Midway Classics","Milton Bradley MicroVision","Namco Classics","Namco System 22","NEC PC-8801","NEC PC Engine","NEC PC Engine-CD","NEC SuperGrafx","NEC TurboGrafx-16","NEC TurboGrafx-CD","Nintendo 64","Nintendo 64DD","Nintendo Arcade Systems","Nintendo Classics","Nintendo Entertainment System","Nintendo Famicom","Nintendo Famicom Disk System","Nintendo Game Boy","Nintendo Game Boy Advance","Nintendo Game Boy Color","Nintendo Pokemon Mini","Nintendo Satellaview","Nintendo Super Famicom","Nintendo Super Game Boy","Nintendo Virtual Boy","Othello Multivision","PacMAME","Philips CD-i","Philips VG 5000","Philips Videopac Plus G7400","RCA Studio II","Sega 32X","Sega CD","Sega Classics","Sega Game Gear","Sega Genesis","Sega Master System","Sega Mega Drive","Sega Model 1","Sega Pico","Sega Saturn","Sega SC-3000","Sega SG-1000","Sega ST-V","Sega VMU","Sharp X1","Sinclair ZX81","SNK Classics","SNK Neo Geo","SNK Neo Geo AES","SNK Neo Geo AES","SNK Neo Geo CD","SNK Neo Geo MVS","SNK Neo Geo Pocket","SNK Neo Geo Pocket Color","Sony PlayStation","Sony PocketStation","Sord M5","Soundic Victory MPT-02","Super Nintendo Entertainment System","Taito Classics","Tandy TRS-80 Color Computer","Texas Instruments TI 99-4A","Tiger Game.com","Tomy Tutor","VTech CreatiVision","Watara Supervision","Williams Classics" 12:27:33:414 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "MAME" 12:27:33:439 | MD | INFO | +31 | PluginInit - Started 12:27:33:440 | MD | DEBUG | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating 12:27:33:440 | MD | INFO | +0 | CheckFile - Checking if C:\Hyperspin\Databases\MAME\MAME.xml exists 12:27:33:442 | MD | DEBUG | +0 | BuildDatabaseTable - Searching for a "Game Name" in the database 12:27:33:442 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Game Name" in the database! 12:27:33:443 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Name 12:27:33:444 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Name" with a value: "Killer Instinct 2 (v1.4)" 12:27:33:444 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Cloneof 12:27:33:444 | MD | DEBUG | +0 | BuildDatabaseTable - Could not find: Cloneof 12:27:33:444 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Publisher 12:27:33:445 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Publisher" with a value: "Rare" 12:27:33:445 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Year 12:27:33:445 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Year" with a value: "1995" 12:27:33:445 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Genre 12:27:33:446 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Genre" with a value: "Fighter" 12:27:33:446 | MD | DEBUG | +0 | BuildDatabaseTable - Searching database for: Rating 12:27:33:446 | MD | DEBUG | +0 | BuildDatabaseTable - Found "Rating" with a value: "AAMA - Red (Animated Violence Strong)" 12:27:33:446 | MD | TRACE | +0 | PluginInit - GameInfo: GameInfo Label: Genre | GameInfo Value: Fighter GameInfo Label: Name | GameInfo Value: Killer Instinct 2 (v1.4) GameInfo Label: Publisher | GameInfo Value: Rare GameInfo Label: Rating | GameInfo Value: AAMA - Red (Animated Violence Strong) GameInfo Label: Year | GameInfo Value: 1995 12:27:33:447 | MD | DEBUG | +0 | BuildDatabaseTable - Ended 12:27:33:447 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 12:27:33:448 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Logo: C:\Hyperspin\Media\MAME\Images\Wheel\kinst2.png 12:27:33:448 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Logo: C:\Hyperspin\Media\Main Menu\Images\Wheel\MAME.png 12:27:33:471 | MD | DEBUG | +31 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: C:\Hyperspin\Media\MAME\Images\Wheel\kinst2.png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: C:\Hyperspin\Media\Main Menu\Images\Wheel\MAME.png | Asset Extension1: png | Asset Type1: system 12:27:33:471 | MD | INFO | +0 | BuildAssetsTable - Ended 12:27:33:472 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 12:27:33:472 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Artwork1: C:\Hyperspin\Media\MAME\Images\Artwork1\kinst2.png 12:27:33:473 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Box Art: C:\Hyperspin\Media\MAME\Images\Artwork2\kinst2.png 12:27:33:474 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Cartridge: C:\Hyperspin\Media\MAME\Images\Artwork3\kinst2.png 12:27:33:474 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Flyers: C:\Hyperspin\Media\MAME\Images\Artwork4\kinst2.png 12:27:33:474 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Letters: C:\Hyperspin\Media\MAME\Images\Letters 12:27:33:504 | MD | DEBUG | +32 | BuildAssetsTable - Searching for a Other: C:\Hyperspin\Media\MAME\Images\Other 12:27:33:506 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Letters | Asset Path1: C:\Hyperspin\Media\MAME\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: C:\Hyperspin\Media\MAME\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: C:\Hyperspin\Media\MAME\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: C:\Hyperspin\Media\MAME\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: C:\Hyperspin\Media\MAME\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: C:\Hyperspin\Media\MAME\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: C:\Hyperspin\Media\MAME\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: C:\Hyperspin\Media\MAME\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: C:\Hyperspin\Media\MAME\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: C:\Hyperspin\Media\MAME\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: C:\Hyperspin\Media\MAME\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: C:\Hyperspin\Media\MAME\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: C:\Hyperspin\Media\MAME\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: C:\Hyperspin\Media\MAME\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: C:\Hyperspin\Media\MAME\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: C:\Hyperspin\Media\MAME\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: C:\Hyperspin\Media\MAME\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: C:\Hyperspin\Media\MAME\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: C:\Hyperspin\Media\MAME\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: C:\Hyperspin\Media\MAME\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: C:\Hyperspin\Media\MAME\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: C:\Hyperspin\Media\MAME\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: C:\Hyperspin\Media\MAME\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: C:\Hyperspin\Media\MAME\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: C:\Hyperspin\Media\MAME\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: C:\Hyperspin\Media\MAME\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: C:\Hyperspin\Media\MAME\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: C:\Hyperspin\Media\MAME\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: C:\Hyperspin\Media\MAME\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: C:\Hyperspin\Media\MAME\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: C:\Hyperspin\Media\MAME\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: C:\Hyperspin\Media\MAME\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: C:\Hyperspin\Media\MAME\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: C:\Hyperspin\Media\MAME\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: C:\Hyperspin\Media\MAME\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: C:\Hyperspin\Media\MAME\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: C:\Hyperspin\Media\MAME\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: C:\Hyperspin\Media\MAME\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: C:\Hyperspin\Media\MAME\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: C:\Hyperspin\Media\MAME\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 12:27:33:507 | MD | INFO | +0 | BuildAssetsTable - Ended 12:27:33:507 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 12:27:33:508 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Video: C:\Hyperspin\Media\MAME\Video\kinst2.* 12:27:33:508 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Video: C:\Hyperspin\Media\Main Menu\Video\MAME.* 12:27:33:509 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Video | Asset Path1: C:\Hyperspin\Media\MAME\Video\kinst2.mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: System Video | Asset Path1: C:\Hyperspin\Media\Main Menu\Video\MAME.mp4 | Asset Extension1: mp4 | Asset Type1: system 12:27:33:509 | MD | INFO | +0 | BuildAssetsTable - Ended 12:27:33:509 | MD | INFO | +0 | PluginInit - Ended 12:27:33:509 | MD | DEBUG | +0 | StartModule - Setting romName to the dbName sent to RocketLauncher: kinst2 12:27:33:510 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:33:510 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1,PrintScreen, 12:27:33:510 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 1 check 12:27:33:511 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 2 check 12:27:33:511 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 12:27:33:511 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:33:511 | MD | TRACE | +0 | Process.__New - Creating new process object for: "C:\Hyperspin\HyperSpin.exe" 12:27:33:529 | MD | TRACE | +31 | File.__New - Creating new file object of: "C:\Hyperspin\HyperSpin.exe" 12:27:33:530 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Modules\MAME\MAME\kinst2.ini" 12:27:33:531 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ini" 12:27:33:532 | MD | TRACE | +0 | File.Exist - This file exists: C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ini 12:27:33:534 | MD | DEBUG | +0 | RIniFile.__New - "Module" at index 1, adding "SystemModuleIni" from: "C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ini" 12:27:33:536 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ini" 12:27:33:538 | MD | TRACE | +0 | File.Exist - This file exists: C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ini 12:27:33:538 | MD | DEBUG | +0 | RIniFile.__New - "Module" at index 2, adding "GlobalModuleIni" from: "C:\Hyperspin\RocketLauncher\Modules\MAME\MAME.ini" 12:27:33:540 | MD | INFO | +0 | StartModule - Ended 12:27:33:540 | MD | INFO | +0 | BezelGUI - Started 12:27:33:592 | MD | INFO | +62 | BezelGUI - Ended 12:27:33:592 | MD | INFO | +0 | i18n - Started 12:27:33:593 | MD | DEBUG | +0 | i18n - Section "German_Standard" & key "dialog.open" not found, trying section "German" 12:27:33:594 | MD | DEBUG | +0 | i18n - Section "German" & key "dialog.open" not found, trying section "English_United_States" 12:27:33:594 | MD | DEBUG | +0 | i18n - Section "English_United_States" & key "dialog.open" not found, trying section "English" 12:27:33:594 | MD | INFO | +0 | i18n - Ended, using "Open" for "dialog.open" 12:27:33:595 | MD | TRACE | +0 | Emulator.__New - Creating new emulator object for: "C:\Hyperspin\Emulators\Mame-Master\mame64.exe" 12:27:33:595 | MD | TRACE | +0 | Process.__New - Creating new process object for: "C:\Hyperspin\Emulators\Mame-Master\mame64.exe" 12:27:33:595 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\Emulators\Mame-Master\mame64.exe" 12:27:33:597 | MD | TRACE | +0 | Window.__New - Created: "ahk_class MAME" 12:27:33:597 | MD | TRACE | +0 | Window.__New - Created: "Open ahk_class ConsoleWindowClass" 12:27:33:597 | MD | TRACE | +0 | Window.__New - Created: "ahk_class ConsoleWindowClass" 12:27:33:597 | MD | TRACE | +0 | Window.__New - Created: "ahk_class MAMEDebugWindow" 12:27:33:598 | MD | TRACE | +0 | Window.__New - Created: "ahk_class MAMEOutput" 12:27:33:598 | MD | DEBUG | +0 | Module - Finished building the MAME object 12:27:33:599 | MD | WARNING | +0 | Module - "MAME" is not a known console or computer system. Defaulting to MAME's Arcade mode for the remainder of this MAME module. 12:27:33:599 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - Fullscreen: false 12:27:33:600 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - LegacyMode: Section does not exist 12:27:33:600 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - LegacyMode: Section does not exist 12:27:33:600 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - LegacyMode: Key does not exist 12:27:33:601 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - LegacyMode: Section does not exist 12:27:33:601 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - LegacyMode: Section does not exist 12:27:33:602 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - LegacyMode: Key does not exist 12:27:33:602 | MD | INFO | +0 | RIniFile.Read - Module - LegacyMode: false (DEFAULT) 12:27:33:603 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - MAME_BIOS_Path: ..\Emulators\Mame-Master\Bios 12:27:33:603 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - Videomode: d3d 12:27:33:604 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - PauseMethod: Key does not exist 12:27:33:604 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - PauseMethod: Key does not exist 12:27:33:604 | MD | INFO | +0 | RIniFile.Read - Module - PauseMethod: 1 (DEFAULT) 12:27:33:605 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - BilinearFilter: Section does not exist 12:27:33:625 | MD | INFO | +32 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - BilinearFilter: true 12:27:33:626 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - HLSL: Section does not exist 12:27:33:626 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - HLSL: Section does not exist 12:27:33:627 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - HLSL: Key does not exist 12:27:33:627 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - HLSL: Section does not exist 12:27:33:628 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - HLSL: Section does not exist 12:27:33:628 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - HLSL: Key does not exist 12:27:33:628 | MD | INFO | +0 | RIniFile.Read - Module - HLSL: false (DEFAULT) 12:27:33:629 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - GLSL: Section does not exist 12:27:33:629 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - GLSL: Section does not exist 12:27:33:629 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - GLSL: Key does not exist 12:27:33:630 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - GLSL: Section does not exist 12:27:33:630 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - GLSL: Section does not exist 12:27:33:631 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - GLSL: Key does not exist 12:27:33:631 | MD | INFO | +0 | RIniFile.Read - Module - GLSL: false (DEFAULT) 12:27:33:632 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - BezelMode: Section does not exist 12:27:33:632 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - BezelMode: Section does not exist 12:27:33:632 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - BezelMode: Key does not exist 12:27:33:633 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - BezelMode: Section does not exist 12:27:33:633 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - BezelMode: Section does not exist 12:27:33:633 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - BezelMode: Key does not exist 12:27:33:633 | MD | INFO | +0 | RIniFile.Read - Module - BezelMode: layout (DEFAULT) 12:27:33:634 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - VerticalRotationMode: Section does not exist 12:27:33:634 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - VerticalRotationMode: Section does not exist 12:27:33:634 | MD | INFO | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - VerticalRotationMode: none 12:27:33:635 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - CheatMode: Key does not exist 12:27:33:635 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - CheatMode: Key does not exist 12:27:33:635 | MD | INFO | +0 | RIniFile.Read - Module - CheatMode: false (DEFAULT) 12:27:33:636 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - CheatModeKey: Key does not exist 12:27:33:636 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - CheatModeKey: Key does not exist 12:27:33:636 | MD | INFO | +0 | RIniFile.Read - Module - CheatModeKey: (NO VALUE) 12:27:33:658 | MD | TRACE | +31 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - UseSoftwareList: Section does not exist 12:27:33:659 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - UseSoftwareList: Section does not exist 12:27:33:659 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - UseSoftwareList: Section does not exist 12:27:33:660 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - UseSoftwareList: Section does not exist 12:27:33:660 | MD | INFO | +0 | RIniFile.Read - Module - UseSoftwareList: false (DEFAULT) 12:27:33:661 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - StaticParameters: Section does not exist 12:27:33:662 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - StaticParameters: Section does not exist 12:27:33:662 | MD | INFO | +0 | RIniFile.Read - Module - StaticParameters: (NO VALUE) 12:27:33:662 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Parameters: Section does not exist 12:27:33:663 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Parameters: Section does not exist 12:27:33:663 | MD | INFO | +0 | RIniFile.Read - Module - Parameters: (NO VALUE) 12:27:33:663 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Parameters: Section does not exist 12:27:33:664 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Parameters: Section does not exist 12:27:33:664 | MD | INFO | +0 | RIniFile.Read - Module - Parameters: (NO VALUE) 12:27:33:664 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - MameRomName: Section does not exist 12:27:33:665 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - MameRomName: Section does not exist 12:27:33:665 | MD | INFO | +0 | RIniFile.Read - Module - MameRomName: (NO VALUE) 12:27:33:665 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Autosave: Section does not exist 12:27:33:666 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Autosave: Section does not exist 12:27:33:666 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Autosave: Section does not exist 12:27:33:666 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Autosave: Section does not exist 12:27:33:667 | MD | INFO | +0 | RIniFile.Read - Module - Autosave: false (DEFAULT) 12:27:33:667 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Volume: Section does not exist 12:27:33:667 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Volume: Section does not exist 12:27:33:667 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - Volume: Key does not exist 12:27:33:687 | MD | TRACE | +31 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Volume: Section does not exist 12:27:33:687 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Volume: Section does not exist 12:27:33:688 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - Volume: Key does not exist 12:27:33:688 | MD | INFO | +0 | RIniFile.Read - Module - Volume: (NO VALUE) 12:27:33:688 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Artwork_Crop: Section does not exist 12:27:33:689 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Artwork_Crop: Section does not exist 12:27:33:689 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Artwork_Crop: Section does not exist 12:27:33:690 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Artwork_Crop: Section does not exist 12:27:33:690 | MD | INFO | +0 | RIniFile.Read - Module - Artwork_Crop: true (DEFAULT) 12:27:33:691 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Use_Bezels: Section does not exist 12:27:33:691 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Use_Bezels: Section does not exist 12:27:33:692 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Use_Bezels: Section does not exist 12:27:33:692 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Use_Bezels: Section does not exist 12:27:33:693 | MD | INFO | +0 | RIniFile.Read - Module - Use_Bezels: false (DEFAULT) 12:27:33:693 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Use_Overlays: Section does not exist 12:27:33:693 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Use_Overlays: Section does not exist 12:27:33:694 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Use_Overlays: Section does not exist 12:27:33:694 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Use_Overlays: Section does not exist 12:27:33:694 | MD | INFO | +0 | RIniFile.Read - Module - Use_Overlays: true (DEFAULT) 12:27:33:695 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Use_Backdrops: Section does not exist 12:27:33:695 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Use_Backdrops: Section does not exist 12:27:33:695 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Use_Backdrops: Section does not exist 12:27:33:696 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Use_Backdrops: Section does not exist 12:27:33:696 | MD | INFO | +0 | RIniFile.Read - Module - Use_Backdrops: true (DEFAULT) 12:27:33:696 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Use_Cpanels: Section does not exist 12:27:33:696 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Use_Cpanels: Section does not exist 12:27:33:697 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Use_Cpanels: Section does not exist 12:27:33:697 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Use_Cpanels: Section does not exist 12:27:33:697 | MD | INFO | +0 | RIniFile.Read - Module - Use_Cpanels: false (DEFAULT) 12:27:33:698 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Use_Marquees: Section does not exist 12:27:33:698 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - Use_Marquees: Section does not exist 12:27:33:720 | MD | TRACE | +31 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Use_Marquees: Section does not exist 12:27:33:720 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - Use_Marquees: Section does not exist 12:27:33:721 | MD | INFO | +0 | RIniFile.Read - Module - Use_Marquees: false (DEFAULT) 12:27:33:721 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - IniPath: Section does not exist 12:27:33:722 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - IniPath: Section does not exist 12:27:33:723 | MD | INFO | +0 | RIniFile.Read - Module - IniPath: (NO VALUE) 12:27:33:723 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - HashPath: Section does not exist 12:27:33:723 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - HashPath: Section does not exist 12:27:33:724 | MD | INFO | +0 | RIniFile.Read - Module - HashPath: (NO VALUE) 12:27:33:724 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - UseControllerRemap: Section does not exist 12:27:33:725 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - UseControllerRemap: Key does not exist 12:27:33:725 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - UseControllerRemap: Section does not exist 12:27:33:725 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - UseControllerRemap: Key does not exist 12:27:33:725 | MD | INFO | +0 | RIniFile.Read - Module - UseControllerRemap: true (DEFAULT) 12:27:33:726 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - ControllerRemapPath: Section does not exist 12:27:33:726 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - ControllerRemapPath: Key does not exist 12:27:33:726 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - ControllerRemapPath: Section does not exist 12:27:33:727 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - ControllerRemapPath: Key does not exist 12:27:33:727 | MD | INFO | +0 | RIniFile.Read - Module - ControllerRemapPath: C:\Hyperspin\Emulators\Mame-Master\ControllerRemap\ControllerRemap.exe (DEFAULT) 12:27:33:727 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\Emulators\Mame-Master\ControllerRemap\ControllerRemap.exe" 12:27:33:729 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - ControllerRemapConfigPath: Section does not exist 12:27:33:729 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - ControllerRemapConfigPath: Key does not exist 12:27:33:729 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - ControllerRemapConfigPath: Section does not exist 12:27:33:730 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - ControllerRemapConfigPath: Key does not exist 12:27:33:750 | MD | INFO | +32 | RIniFile.Read - Module - ControllerRemapConfigPath: C:\Hyperspin\Emulators\Mame-Master\ControllerRemap\ctrlr\ (DEFAULT) 12:27:33:751 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [MAME] - MAMECtrlrPath: Section does not exist 12:27:33:752 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Settings] - MAMECtrlrPath: Key does not exist 12:27:33:752 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [MAME] - MAMECtrlrPath: Section does not exist 12:27:33:753 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - MAMECtrlrPath: Key does not exist 12:27:33:754 | MD | INFO | +0 | RIniFile.Read - Module - MAMECtrlrPath: C:\Hyperspin\Emulators\Mame-Master\ctrlr (DEFAULT) 12:27:33:756 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [kinst2] - Enable_Link_Play: Section does not exist 12:27:33:756 | MD | TRACE | +0 | RIniFile.Read - Module {SystemModuleIni} - [Link/Network] - Enable_Link_Play: Section does not exist 12:27:33:756 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [kinst2] - Enable_Link_Play: Section does not exist 12:27:33:757 | MD | TRACE | +0 | RIniFile.Read - Module {GlobalModuleIni} - [Link/Network] - Enable_Link_Play: Section does not exist 12:27:33:757 | MD | INFO | +0 | RIniFile.Read - Module - Enable_Link_Play: false (DEFAULT) 12:27:33:757 | MD | DEBUG | +0 | FadeInStart - Started 12:27:33:758 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:33:758 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~1 is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 12:27:33:758 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 12:27:33:759 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~1" 12:27:33:759 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 12:27:33:759 | MD | TRACE | +0 | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~1" 12:27:33:760 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 12:27:33:760 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:33:760 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:33:760 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 12:27:33:761 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 12:27:33:761 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 12:27:33:784 | MD | TRACE | +31 | XHotkeyTableCreation - Post loop 11 check 12:27:33:784 | MD | TRACE | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 12:27:33:784 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 12:27:33:785 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:33:785 | MD | DEBUG | +0 | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled 12:27:33:785 | MD | TRACE | +0 | FadeInStart - Fade screen scale factor: X=1.000000, Y= 1.000000 12:27:33:786 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\kinst2\Layer 1*.* 12:27:33:786 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Horizontal\Layer 1*.* 12:27:33:787 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1*.* 12:27:33:787 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1*.png 12:27:33:788 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1 - alt.png 12:27:33:788 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1 - Unknown50862.png 12:27:33:788 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1.png 12:27:33:788 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1*.gif 12:27:33:789 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1*.tif 12:27:33:789 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1*.bmp 12:27:33:789 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 1": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1*.jpg 12:27:33:790 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade will use C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 1 - Unknown50862.png 12:27:33:790 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\kinst2\Info Bar*.* 12:27:33:790 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Horizontal\Info Bar*.* 12:27:33:791 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Info Bar*.* 12:27:33:791 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.* 12:27:33:791 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.* 12:27:33:792 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png 12:27:33:792 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png 12:27:33:792 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif 12:27:33:813 | MD | DEBUG | +31 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif 12:27:33:814 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp 12:27:33:814 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg 12:27:33:815 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade will use C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png 12:27:33:929 | MD | INFO | +110 | DefaultAnimateFadeIn - Started, direction is: in 12:27:33:929 | MD | INFO | +0 | DefaultAnimateFadeIn - Drawing First FadeIn Image. 12:27:34:927 | MD | INFO | +1000 | DefaultAnimateFadeIn - Ended 12:27:34:959 | MD | INFO | +31 | DefaultFadeAnimation - Started 12:27:34:960 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\kinst2\Info Bar*.* 12:27:34:961 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Horizontal\Info Bar*.* 12:27:34:961 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Info Bar*.* 12:27:34:962 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.* 12:27:34:963 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.* 12:27:34:963 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.png 12:27:34:985 | MD | DEBUG | +31 | GetFadeDirPicFile - Found Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png 12:27:34:985 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.gif 12:27:34:986 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.tif 12:27:34:986 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp 12:27:34:987 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Info Bar": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg 12:27:34:987 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade will use C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Info Bar.png 12:27:34:992 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\kinst2\Layer 3*.* 12:27:34:992 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Horizontal\Layer 3*.* 12:27:34:993 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3*.* 12:27:34:993 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 3": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3*.png 12:27:34:994 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer 3": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3.png 12:27:34:994 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 3": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3*.gif 12:27:34:995 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 3": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3*.tif 12:27:34:995 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 3": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3*.bmp 12:27:34:995 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer 3": C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3*.jpg 12:27:34:996 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade will use C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer 3.png 12:27:34:025 | MD | INFO | +31 | BuildAssetsTable - Started - Building Table for: Genre Logo|Rating Logo|Developer Logo|Publisher Logo|Year Logo 12:27:35:026 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Genre Logo: C:\Hyperspin\RocketLauncher\Media\Genre\_Default\Fighter.* 12:27:35:026 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Rating Logo: C:\Hyperspin\RocketLauncher\Media\Rating\_Default\AAMA - Red (Animated Violence Strong).* 12:27:35:048 | MD | DEBUG | +32 | BuildAssetsTable - Searching for a Developer Logo: 12:27:35:048 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Publisher Logo: C:\Hyperspin\RocketLauncher\Media\Publisher\_Default\Rare.* 12:27:35:049 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Year Logo: C:\Hyperspin\RocketLauncher\Media\Year\_Default\1995.* 12:27:35:049 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Rating Logo | Asset Path1: C:\Hyperspin\RocketLauncher\Media\Rating\_Default\AAMA - Red (Animated Violence Strong).png | Asset Extension1: png | Asset Type1: rating 12:27:35:050 | MD | INFO | +0 | BuildAssetsTable - Ended 12:27:35:050 | MD | INFO | +0 | BuildAssetsTable - Started - Building Table for: System Logo|Game Logo|Game Logo 12:27:35:050 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a System Logo: C:\Hyperspin\RocketLauncher\Media\Logos\MAME\_Default\ 12:27:35:051 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Logo: C:\Hyperspin\RocketLauncher\Media\Logos\MAME\kinst2\ 12:27:35:052 | MD | DEBUG | +0 | BuildAssetsTable - Searching for a Game Logo: 12:27:35:052 | MD | DEBUG | +0 | BuildAssetsTable - Media assets found: Asset Label: Rating Logo | Asset Path1: C:\Hyperspin\RocketLauncher\Media\Rating\_Default\AAMA - Red (Animated Violence Strong).png | Asset Extension1: png | Asset Type1: rating Asset Label: System Logo | Asset Path1: C:\Hyperspin\RocketLauncher\Media\Logos\MAME\_Default\MAME.png | Asset Extension1: png | Asset Type1: system 12:27:35:053 | MD | INFO | +0 | BuildAssetsTable - Ended 12:27:35:160 | MD | DEBUG | +109 | FadeInDelay - Started 12:27:35:225 | MD | INFO | +62 | DefaultFadeAnimationLoop - percentage 12:27:35:287 | MD | INFO | +63 | DefaultFadeAnimationLoop - percentage6 12:27:35:346 | MD | INFO | +62 | DefaultFadeAnimationLoop - percentage13 12:27:35:412 | MD | INFO | +63 | DefaultFadeAnimationLoop - percentage19 12:27:35:480 | MD | INFO | +62 | DefaultFadeAnimationLoop - percentage25 12:27:35:539 | MD | DEBUG | +63 | FadeInDelay - Ended 12:27:35:540 | MD | INFO | +0 | DefaultFadeAnimation - Ended 12:27:35:540 | MD | DEBUG | +0 | FadeInStart - Ended 12:27:35:540 | MD | INFO | +0 | DxwndUpdateIniPath - DxwndIni set to C:\Hyperspin\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini 12:27:35:541 | MD | DEBUG | +0 | CoverFE - Started 12:27:35:565 | MD | INFO | +31 | DefaultFadeAnimationLoop - percentage34 12:27:35:576 | MD | INFO | +16 | FadeApp - Hiding Frontend by making it transparent 12:27:35:577 | MD | DEBUG | +0 | CoverFE - Ended 12:27:35:577 | MD | TRACE | +0 | Process.__New - Creating new process object for: "C:\WINDOWS\system32\cmd.exe" 12:27:35:578 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\WINDOWS\system32\cmd.exe" 12:27:35:606 | MD | INFO | +31 | DefaultFadeAnimationLoop - percentage41 12:27:35:674 | MD | INFO | +63 | DefaultFadeAnimationLoop - percentage45 12:27:35:734 | MD | INFO | +62 | DefaultFadeAnimationLoop - percentage52 12:27:35:793 | MD | INFO | +63 | DefaultFadeAnimationLoop - percentage58 12:27:35:856 | MD | INFO | +62 | DefaultFadeAnimationLoop - percentage64 12:27:35:873 | MD | DEBUG | +16 | Process.RunDirect - "C:\WINDOWS\system32\cmd.exe /c "C:\Hyperspin\Emulators\Mame-Master\mame64.exe" -listxml kinst2 > tempBezel.txt" Process ID: 7120 and ErrorLevel reported as: 0 12:27:35:873 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\Emulators\Mame-Master\tempBezel.txt" 12:27:35:875 | MD | TRACE | +0 | File.Read - Read file to memory: C:\Hyperspin\Emulators\Mame-Master\tempBezel.txt 12:27:35:876 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "" from Haystack 12:27:35:877 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "" from Haystack 12:27:35:877 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "" from Haystack 12:27:35:878 | MD | TRACE | +0 | StringUtils.TrimLeft - Trimming "" to "" 12:27:35:878 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "<display tag="screen" type="raster" rotate="0"" from Haystack 12:27:35:879 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "0" from Haystack 12:27:35:879 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "<display tag="screen" type="raster" rotate="0" width="320"" from Haystack 12:27:35:880 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "320" from Haystack 12:27:35:880 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "<display tag="screen" type="raster" rotate="0" width="320" height="240"" from Haystack 12:27:35:881 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "240" from Haystack 12:27:35:882 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "<control type="joy" player="1" buttons="6" ways="8"/> <control type="joy" player="2" buttons="6" ways="8"" from Haystack 12:27:35:882 | MD | TRACE | +0 | StringUtils.RegExMatch - Matched "8" from Haystack 12:27:35:883 | MD | INFO | +0 | Module - MAME ListXML values: Parent = Angle = 0 Height = 240 Width = 320 Ways = 8 12:27:35:883 | MD | TRACE | +0 | File.Delete - Deleting: tempBezel.txt 12:27:35:883 | MD | INFO | +0 | BezelStart - Started 12:27:35:884 | MD | INFO | +0 | Bezel - Layout mode selected but no MAME or MESS layout file found. Using RocketLauncher Bezel normal mode instead. 12:27:35:884 | MD | DEBUG | +0 | Bezel - Bezel mode Normal selected. 12:27:35:934 | MD | INFO | +62 | DefaultFadeAnimationLoop - percentage70 12:27:35:954 | MD | TRACE | +16 | Bezel variable values: [Settings] Game_Monitor = [Settings] Bezel_Supported_Image_Files = png|gif|tif|bmp|jpg [Settings] Bezel_Delay = 0 [Bezel Change] Bezel_Transition_Duration = 500 [Bezel Change] Bezel_Save_Selected = false [Bezel Change] Extra_FullScreen_Bezel = false [Background] Background_Change_Timer = 0 [Background] Background_Transition_Animation = fade [Background] Background_Transition_Duration = 500 [Background] Use_Backgrounds = false [Bezel Change Keys] Next_Bezel_Key = [Bezel Change Keys] Previous_Bezel_Key = 12:27:35:954 | MD | INFO | +0 | Bezel - Game will be moved to monitor 1 if RL finds a valid bezel to be show. 12:27:35:955 | MD | DEBUG | +0 | Bezel - Assuming that game has horizontal orientation. 12:27:35:955 | MD | DEBUG | +0 | Bezel - Looking for Bezel in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\kinst2 12:27:35:957 | MD | DEBUG | +0 | Bezel - Looking for Bezel in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Mame-Master\Horizontal 12:27:35:958 | MD | DEBUG | +0 | Bezel - Looking for Bezel in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Mame-Master 12:27:35:958 | MD | DEBUG | +0 | Bezel - Looking for Bezel in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Horizontal 12:27:35:960 | MD | DEBUG | +0 | Bezel - Found Bezel art in folder: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Horizontal 12:27:35:961 | MD | INFO | +0 | Bezel - Loading Bezel image: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Horizontal\Bezel Nosh.png 12:27:35:964 | MD | DEBUG | +0 | Bezel - Looking for Background in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\kinst2 12:27:35:964 | MD | DEBUG | +0 | Bezel - Looking for Background in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Mame-Master\Horizontal 12:27:35:984 | MD | INFO | +31 | DefaultFadeAnimationLoop - percentage78 12:27:35:991 | MD | DEBUG | +0 | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished. 12:27:35:036 | MD | DEBUG | +47 | Bezel - Looking for Background in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Mame-Master 12:27:36:037 | MD | DEBUG | +0 | Bezel - Looking for Background in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default\Horizontal 12:27:36:038 | MD | DEBUG | +0 | Bezel - Looking for Background in: C:\Hyperspin\RocketLauncher\Media\Bezels\MAME\_Default 12:27:36:038 | MD | DEBUG | +0 | Bezel - Looking for Background in: C:\Hyperspin\RocketLauncher\Media\Bezels\_Default\Horizontal 12:27:36:040 | MD | DEBUG | +0 | Bezel - Looking for Background in: C:\Hyperspin\RocketLauncher\Media\Bezels\_Default 12:27:36:040 | MD | DEBUG | +0 | Bezel - Found Background art in folder: C:\Hyperspin\RocketLauncher\Media\Bezels\_Default 12:27:36:041 | MD | INFO | +0 | Bezel - Loading Background image: C:\Hyperspin\RocketLauncher\Media\Bezels\_Default\Background5 Nosh.png 12:27:36:065 | MD | INFO | +31 | DefaultFadeAnimationLoop - percentage83 12:27:36:065 | MD | DEBUG | +0 | DefaultFadeAnimationLoop - AnimationLoop has finished 12:27:36:066 | MD | DEBUG | +0 | DefaultFadeAnimationLoop - Ended 12:27:36:073 | MD | DEBUG | +0 | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished. 12:27:36:076 | MD | TRACE | +16 | Bezel - Bezel ini file found. Defined screen positions: X1=150 Y1=0 X2=1771 Y2=1200 12:27:36:077 | MD | INFO | +0 | BezelStart - Ended 12:27:36:077 | MD | INFO | +0 | Controller Remap: Start 12:27:36:080 | MD | INFO | +0 | Controller Remap: ControllerRemapConfigPath: C:\Hyperspin\Emulators\Mame-Master\ControllerRemap\ctrlr\ 12:27:36:081 | MD | INFO | +0 | Controller Remap: No Controller config file found. 12:27:36:081 | MD | INFO | +0 | Controller Remap: End 12:27:36:082 | MD | TRACE | +0 | StringUtils.StringLength - This string is "5" long 12:27:36:082 | MD | TRACE | +0 | StringUtils.Right - Trimming "0.178" to "178" 12:27:36:083 | MD | INFO | +0 | Module - Detected MAME Product Version from 'C:\Hyperspin\Emulators\Mame-Master\mame64.exe' is 178 12:27:36:083 | MD | TRACE | +0 | StringUtils.Contains - "MAME" does not contain "ti99_4a|aes|apple2gs|electron|mbeeic|odyssey2|astrocde|samcoupe|vic10|cpc664" 12:27:36:083 | MD | TRACE | +0 | StringUtils.Contains - "MAME" does not contain "studio2|mpt02" 12:27:36:084 | MD | TRACE | +0 | StringUtils.Replace - Replacing "|" with ";" 12:27:36:084 | MD | TRACE | +0 | StringUtils.InStr - Could not find "-rompath" in "" starting at position 1 12:27:36:084 | MD | TRACE | +0 | StringUtils.InStr - Could not find "-rompath" in "" starting at position 1 12:27:36:085 | MD | TRACE | +0 | File.__New - Creating new file object of: "C:\Hyperspin\Emulators\Mame-Master\cfg\MAME\kinst2" 12:27:36:086 | MD | TRACE | +0 | Folder.__New - Created new folder object of: "C:\Hyperspin\Emulators\Mame-Master\cfg\MAME\kinst2" 12:27:36:088 | MD | INFO | +0 | HideAppStart - Starting HideAppTimer, scanning for windows defined every 2ms 12:27:36:089 | MD | INFO | +0 | HideAppStart - Ended 12:27:36:089 | MD | INFO | +0 | Module - Running MAME in non-legacy mode 12:27:36:113 | MD | INFO | +31 | Module - SinglePlayer session 12:27:36:114 | MD | TRACE | +0 | CustomFunction.PreLaunch - Starting 12:27:36:114 | MD | TRACE | +0 | CustomFunction.PreLaunch - Ending 12:27:36:114 | MD | INFO | +0 | Process.Run - Running: "C:\Hyperspin\Emulators\Mame-Master\mame64.exe" kinst2 -rompath "D:\HyperSpin\MAME;D:\HyperSpin\MAME CHDs;E:\Roms\MAME;C:\Hyperspin\Emulators\Mame-Master\Bios" -window -nohlsl_enable -nogl_glsl -video d3d -artwork_crop -nouse_bezels -use_overlays -use_backdrops -nouse_cpanels -nouse_marquees -filter -skip_gameinfo 12:27:36:168 | MD | DEBUG | +47 | Process.Run - "mame64.exe kinst2 -rompath "D:\HyperSpin\MAME;D:\HyperSpin\MAME CHDs;E:\Roms\MAME;C:\Hyperspin\Emulators\Mame-Master\Bios" -window -nohlsl_enable -nogl_glsl -video d3d -artwork_crop -nouse_bezels -use_overlays -use_backdrops -nouse_cpanels -nouse_marquees -filter -skip_gameinfo" Process ID: 3724 12:27:36:194 | MD | TRACE | +31 | CustomFunction.PostLaunch - Starting 12:27:36:195 | MD | TRACE | +0 | CustomFunction.PostLaunch - Ending 12:27:36:195 | MD | TRACE | +0 | Window.__New - Created: "ahk_id 460776" 12:27:36:196 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 12:27:36:197 | MD | TRACE | +0 | Window.GetPos - Retrieved x:182 y:182 w: 993 h: 519 from "ahk_id 460776" 12:27:36:198 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 12:27:36:198 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: C:\Hyperspin\Emulators\Mame-Master\mame64.exe | Class: ConsoleWindowClass | State: 0 | X: 182 | Y: 182 | Width: 993 | Height: 519 | Window HWND: 0x707e8 | Process ID: 3724 | Process Path: C:\Hyperspin\Emulators\Mame-Master\mame64.exe 12:27:36:228 | MD | INFO | +31 | Window.Wait - Waiting for window "ahk_class MAME" 12:27:37:025 | MD | DEBUG | +797 | HideAppTimer - Trying to hide window [1]: "ahk_class MAME" 12:27:37:258 | MD | DEBUG | +235 | HideAppTimer - Trying to hide window [2]: "ahk_class MAMEOutput" 12:27:37:267 | MD | TRACE | +15 | Window.__New - Created: "ahk_id 133130" 12:27:37:268 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 12:27:37:268 | MD | TRACE | +0 | Window.GetPos - Retrieved x:278 y:0 w: 1364 h: 1050 from "ahk_id 133130" 12:27:37:269 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 12:27:37:269 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: MAME: Killer Instinct 2 (v1.4) [kinst2] | Class: MAME | State: 0 | X: 278 | Y: 0 | Width: 1364 | Height: 1050 | Window HWND: 0x2080a | Process ID: 3724 | Process Path: C:\Hyperspin\Emulators\Mame-Master\mame64.exe 12:27:37:270 | MD | TRACE | +0 | Window.__New - Created: "ahk_id 133130" 12:27:37:270 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 12:27:37:270 | MD | TRACE | +0 | Window.GetPos - Retrieved x:278 y:0 w: 1364 h: 1050 from "ahk_id 133130" 12:27:37:271 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 12:27:37:271 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: MAME: Killer Instinct 2 (v1.4) [kinst2] | Class: MAME | State: 0 | X: 278 | Y: 0 | Width: 1364 | Height: 1050 | Window HWND: 0x2080a | Process ID: 3724 | Process Path: C:\Hyperspin\Emulators\Mame-Master\mame64.exe 12:27:37:271 | MD | INFO | +0 | Window.WaitActive - Waiting for "ahk_class MAME" 12:27:37:379 | MD | TRACE | +110 | Window.__New - Created: "ahk_id 133130" 12:27:37:380 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "Off" 12:27:37:380 | MD | TRACE | +0 | Window.GetPos - Retrieved x:278 y:0 w: 1364 h: 1050 from "ahk_id 133130" 12:27:37:381 | MD | TRACE | +0 | MiscUtils.DetectHiddenWindows - Mode changed to "On" 12:27:37:381 | MD | DEBUG | +0 | MiscUtils.GetActiveWindowStatus - Title: MAME: Killer Instinct 2 (v1.4) [kinst2] | Class: MAME | State: 0 | X: 278 | Y: 0 | Width: 1364 | Height: 1050 | Window HWND: 0x2080a | Process ID: 3724 | Process Path: C:\Hyperspin\Emulators\Mame-Master\mame64.exe 12:27:37:416 | MD | INFO | +31 | BezelDraw - Started 12:27:37:496 | MD | TRACE | +78 | Bezel - Bezel ini file found. Defined screen positions: X1=150 Y1=0 X2=1771 Y2=1200 12:27:37:601 | MD | TRACE | +109 | Bezel - Background Screen Position: BezelImage left=0 top=0 right=1920 bottom=1080 12:27:37:605 | MD | INFO | +0 | Bezel - Bezel Screen Offset: left= top= right= bottom= 12:27:37:627 | MD | TRACE | +32 | Window.Set - Setting Transparent to 0 for window "ahk_class ConsoleWindowClass" 12:27:37:757 | MD | INFO | +125 | ToggleMenu - Started 12:27:38:338 | MD | WARNING | +578 | ToggleMenu - Timed out trying to restore MenuBar for 0x2080a 12:27:38:339 | MD | INFO | +0 | ToggleMenu - Ended 12:27:38:861 | MD | TRACE | +531 | Bezel - Moving emulator window delay, window moved 12:27:38:979 | MD | TRACE | +109 | Bezel - Bezel Image Screen Position: BezelImage left=96 top=0 right=1824 bottom=1080 12:27:38:980 | MD | TRACE | +0 | Bezel - Game Screen Position: BezelImage left=231 top=0 right=1690 bottom=1080 12:27:38:008 | MD | TRACE | +32 | Bezel Keys Enabled 12:27:39:009 | MD | INFO | +0 | BezelDraw - Ended 12:27:39:009 | MD | INFO | +0 | HideAppEnd - Stopping HideAppTimer and unhiding flagged windows 12:27:39:049 | MD | INFO | +47 | HideAppEnd - Revealed window: "ahk_class MAME" 12:27:39:049 | MD | INFO | +0 | HideAppEnd - Ended 12:27:39:050 | MD | TRACE | +0 | Window.Show - Unhiding window "ahk_class MAME" 12:27:39:160 | MD | DEBUG | +109 | FadeInExit - Started 12:27:39:161 | MD | DEBUG | +0 | FadeInExit - fadeInExitDelay started 12:27:39:699 | MD | DEBUG | +547 | FadeInExit - fadeInExitDelay ended 12:27:39:700 | MD | INFO | +0 | DefaultAnimateFadeIn - Started, direction is: out 12:27:40:718 | MD | INFO | +1015 | DefaultAnimateFadeIn - Ended 12:27:40:779 | MD | TRACE | +63 | XHotkeyTableCreation - Started 12:27:40:780 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~1 is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 12:27:40:781 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 12:27:40:781 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~1" 12:27:40:782 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 12:27:40:782 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~1" to call label: "TogglePauseMenuStatus" 12:27:40:783 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 12:27:40:783 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:40:783 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:40:784 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 12:27:40:784 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 12:27:40:784 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 12:27:40:785 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 12:27:40:785 | MD | TRACE | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 12:27:40:786 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 12:27:40:786 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:40:786 | MD | DEBUG | +0 | FadeInExit - Ended, waiting for user to close launched application 12:27:40:787 | MD | TRACE | +0 | CustomFunction.PostLoad - Starting 12:27:40:787 | MD | TRACE | +0 | CustomFunction.PostLoad - Ending 12:27:40:788 | MD | INFO | +0 | Process.Process - "WaitClose" "mame64.exe" 12:27:40:788 | MD | TRACE | +0 | Process.GetProcessID 12:27:54:364 | MD | INFO | +13578 | CloseProcess - Started, user requested to end launched application 12:27:54:364 | MD | DEBUG | +0 | FadeOutStart - Started 12:27:54:365 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:54:366 | MD | TRACE | +0 | XHotkeyTableCreation - KeyGroup ~1 is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 12:27:54:367 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 12:27:54:368 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~1" 12:27:54:368 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 12:27:54:369 | MD | TRACE | +0 | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~1" 12:27:54:370 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 12:27:54:370 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:54:371 | MD | TRACE | +0 | XHotkeyTableCreation - Started 12:27:54:394 | MD | TRACE | +31 | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~1,PrintScreen,~e&~t, 12:27:54:395 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 10 check 12:27:54:395 | MD | TRACE | +0 | XHotkeyTableCreation - Disabled Hotkey for: "~Esc" 12:27:54:396 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 11 check 12:27:54:397 | MD | TRACE | +0 | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc" 12:27:54:397 | MD | TRACE | +0 | XHotkeyTableCreation - Post loop 12 check 12:27:54:398 | MD | TRACE | +0 | XHotkeyTableCreation - Ended 12:27:54:398 | MD | DEBUG | +0 | FadeOutStart - No keys were set to interrupt fade so ability to interrupt fade is disabled 12:27:54:399 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer -1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\kinst2\Layer -1*.* 12:27:54:400 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer -1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Horizontal\Layer -1*.* 12:27:54:400 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer -1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\MAME\_Default\Layer -1*.* 12:27:54:401 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer -1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Horizontal\Layer -1*.* 12:27:54:401 | MD | DEBUG | +0 | GetFadeDirPicFile - Checking if any Fade "Layer -1" media exists in: C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.* 12:27:54:424 | MD | DEBUG | +32 | GetFadeDirPicFile - Looking for Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.png 12:27:54:424 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 (2).png 12:27:54:425 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 (3).png 12:27:54:425 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 02 (Gigapig).png 12:27:54:426 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 04 (Gigapig).png 12:27:54:427 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 09 (Gigapig).png 12:27:54:427 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1.png 12:27:54:428 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.gif 12:27:54:428 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.tif 12:27:54:429 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.bmp 12:27:54:429 | MD | DEBUG | +0 | GetFadeDirPicFile - Looking for Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1*.jpg 12:27:54:430 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 01 (Gigapig).jpg 12:27:54:430 | MD | DEBUG | +0 | GetFadeDirPicFile - Found Fade "Layer -1": C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 10 (Gigapig).jpg 12:27:54:431 | MD | INFO | +0 | GetFadePicFile - Randomized images and Fade will use C:\Hyperspin\RocketLauncher\Media\Fade\_Default\Layer -1 - 16x9 GameOver 10 (Gigapig).jpg 12:27:54:546 | MD | INFO | +125 | DefaultAnimateFadeOut - Started, direction is: in 12:27:55:548 | MD | INFO | +1000 | DefaultAnimateFadeOut - Ended 12:27:55:549 | MD | DEBUG | +0 | FadeOutStart - Ended 12:27:55:549 | MD | INFO | +0 | HideEmuStart - Starting HideEmuTimer, scanning for windows defined in hideEmuObj every 2ms 12:27:55:550 | MD | INFO | +0 | HideEmuStart - Ended 12:27:55:550 | MD | DEBUG | +0 | ShowFE - Started 12:27:55:552 | MD | INFO | +0 | FadeApp - Showing Frontend and removing transparency 12:27:55:553 | MD | DEBUG | +0 | ShowFE - Ended 12:27:55:553 | MD | TRACE | +0 | Window.Close - Closing: "ahk_class MAME" 12:27:55:779 | MD | INFO | +234 | CloseProcess - Ended 12:27:55:782 | MD | DEBUG | +0 | Process.Process - "mame64.exe" returned 0 and is now closed. Continuing thread. 12:27:55:783 | MD | INFO | +0 | BezelExit - Started 12:27:55:793 | MD | INFO | +16 | Bezel - Removing bezel image components to exit RocketLauncher. 12:27:55:794 | MD | INFO | +0 | BezelExit - Ended 12:27:55:795 | MD | DEBUG | +0 | FadeOutExit - Started 12:27:56:129 | MD | INFO | +328 | DefaultAnimateFadeOut - Started, direction is: out 12:27:57:124 | MD | INFO | +1000 | DefaultAnimateFadeOut - Ended 12:27:57:127 | MD | DEBUG | +0 | FadeOutExit - Ended 12:27:57:128 | MD | INFO | +0 | ExitModule - Started 12:27:57:129 | MD | INFO | +0 | Starting Updating Statistics: 12:27:57:129 | MD | TRACE | +0 | Total Elapsed Time in Pause in seconds: 0 12:27:57:129 | MD | TRACE | +0 | gameSectionStartTime:2200484 12:27:57:130 | MD | TRACE | +0 | ElapsedTime:16 12:27:57:131 | MD | TRACE | +0 | Statistics cleared game name: kinst2 12:27:57:167 | MD | TRACE | +31 | Loaded game statistics from ini files: Number_of_Times_Played: 6 Last_Time_Played: Dienstag November 1, 2016 11:31:34 Average_Time_Played: 42 Total_Time_Played: 253 System_Total_Played_Time: 1964 Total_Global_Played_Time: 68074 12:27:57:186 | MD | TRACE | +31 | Updated Statistics: Number_of_Times_Played: 7 Last_Time_Played: Mittwoch November 2, 2016 12:27:40 Average_Time_Played: 38 Total_Time_Played: 269 System_Total_Played_Time: 1980 Total_Global_Played_Time: 68090 12:27:57:229 | MD | INFO | +31 | Game section statistics updated. 12:27:57:230 | MD | TRACE | +0 | CustomFunction.PostExit - Starting 12:27:57:230 | MD | TRACE | +0 | CustomFunction.PostExit - Ending 12:27:57:251 | MD | INFO | +32 | ExitModule - Ended End of Module Logs 12:27:57:317 | RL | INFO | +24187 | Main - Module ended, exiting RocketLauncher normally 12:27:57:317 | RL | INFO | +0 | ExitScript - Started 12:27:57:322 | RL | DEBUG | +0 | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32 12:27:57:322 | RL | DEBUG | +0 | Registry.Read - Registry Read finished, returning 0 12:27:57:323 | RL | INFO | +0 | ExitScript - Restoring HyperSpin.exe to x320 y180 w h720 12:27:57:323 | RL | TRACE | +0 | Window.Restore - Restoring window "ahk_id 0x140718" 12:27:57:419 | RL | TRACE | +110 | TimerUtils.Sleep - Sleeping for 10 milliseconds 12:27:57:434 | RL | TRACE | +15 | Window.CreateControl - Created new control for "null" 12:27:57:436 | RL | TRACE | +0 | Control.Click - Clicked control "null" on window "ahk_id 0x140718" 12:27:57:438 | RL | INFO | +0 | ExitScript - Restoring and Clicking HyperSpin.exe to attempt to put it into focus 12:27:57:439 | RL | TRACE | +0 | Window.Get - Transparent is "" from "ahk_id 0x140718" 12:27:57:439 | RL | INFO | +0 | ExitScript - Checking what application is currently in focus. 12:27:57:439 | RL | TRACE | +0 | Window.Active - "ahk_id 0x140718" is the active window 12:27:57:440 | RL | INFO | +0 | ExitScript - HyperSpin is currently active. Proceeding with exit 12:27:57:440 | RL | TRACE | +0 | StringUtils.Contains - "true" contains "true|kill" at position 1 12:27:57:440 | RL | INFO | +0 | ExitScript - Restoring taskbar 12:27:57:440 | RL | TRACE | +0 | Window.Show - Unhiding window "ahk_class Shell_TrayWnd" 12:27:57:548 | RL | TRACE | +110 | Window.Show - Unhiding window "Start ahk_class Button" 12:27:57:557 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 12:27:57:566 | RL | INFO | +15 | ExitScript - Restored cursor [/code] Thanks guys
ChrisKant Posted November 13, 2016 Author Posted November 13, 2016 sorry for bumping this up, does anyone have an idea? or how are you guys handle mame and joy2key together?
