random2k4 Posted November 5, 2016 Posted November 5, 2016 Hi, I got a Problem with my controlls for the Hyperspin Main Menu. I am using two Arcade Sticks for my setup. While configuring the emulators, everything works just fine. I also can set the controlls in the in HyperHQ, the two stickt got recognized and I can configure all the buttons there. Now, when I am starting Hyperspin, I can skip the intro by hitting one button on my controlls. But then in the mein menu I can only navigate with the keyboard and not with the arcade sticks. Also the buttons did not work. But when I start a game with the keyboard the controlls work as they should be. I think there must be a problem in the controlls for the main menu, but I can not find a solution here. I also checked the settings.ini and both joysticks are set to "true" so there is no problem here. Any suggestions?
ChrisKant Posted November 5, 2016 Posted November 5, 2016 Hi, and welcome to Hyperspin Mr Random German Guy :-) most people say, that Hyperspin own control options for sticks won't work well / very buggy even with the newest version. you should use a key mapper to map your sticks to the keyboard. sometimes you can also find help at the German part of this board :-)
random2k4 Posted November 5, 2016 Author Posted November 5, 2016 ah ok, the fun part is, It worked for over three month and then just stopped. I will try to use a keymapper then for the main menu. Thanks for the tip.
