Hyperspin error running Mame64.exe
actman
The hyperspin setup I use has an older mame.exe emulator. For some reason it won't work in 640x480 resolution. So I have to select a lower resolution to go in and play my mame games and go out of hyperspin and select higher resolutions for my other emulators I have installed. I can run mame64.exe from another hyperspin setup on a different drive and it works at 640x480. So I have a feeling its the emulator causing the resolution issue.
So I copied the mame64.exe from my other drive that works to my mame directory that has issues. I set the path in HyperHQ and tested. Now when I go to run a game I get this error:  "Mame is invalid system name or mame64.exe is not supported yet" Can anyone tell me what i am doing wrong?
That's weird, I know the Mameuix emulator works great for everything I've been doing.
Only thing I can think of is the game(s) you have aren't supported by the emulator version you have
Quote
I can click on the mame64.exe and select the rom and it plays fine. Also in my other hyperspin configuration it uses the same rom games so that's not it.
