sound out of sync for daphne
wugly
I am having an interesting problem when I try to play any daphne game.  my sound and video get out of sync.  the difference from the proper running version that is working outside of hyperspin  and the one that is out of sync is that the working one uses 2048 memory buffer for sound and hardware acceleration. wondering if I might have some type of setting wrong with computer or hyperspin or daphne?  here are the two daphne logs
out of sync
--DAPHNE version 1.0.0
--Command line is: R:\Arcade\Daphne\daphne.exe cobraab vldp -fullscreen -x 640 -y 480 -nohwaccel -framefile R:\Arcade\Daphne\framefile\cobraab.txt
--CPU : GenuineIntel 3300 MHz || Mem : 2048 megs
--OS : Windows XP/.NET || Video : NVIDIA GeForce 8500 GT
--OpenGL: Compiled In
--RGB2YUV Function: MMX
--Line Blending Function: MMX
--Audio Mixing Function: MMX
Setting screen width to 640
Setting screen height to 480
Set 640x480 at 32 bpp with flags: 80000000
Initializing sound system ...
Joystick #0 was successfully opened
Remapping input ...
Loading compressed ROM image ic-1.bin...16384 bytes read.
Loading compressed ROM image ic-2.bin...8192 bytes read.
Loading compressed ROM image ic-11.bin...2048 bytes read.
Loading compressed ROM image ic-12.bin...2048 bytes read.
Loading compressed ROM image ic-7.bin...8192 bytes read.
Loading compressed ROM image ic-8.bin...8192 bytes read.
Loading compressed ROM image ic-13.bin...512 bytes read.
Loading compressed ROM image pr-5278.bin...256 bytes read.
Loading compressed ROM image pr-5277.bin...256 bytes read.
Loading compressed ROM image pr-5276.bin...32 bytes read.
Loading compressed ROM image pr-5275.bin...32 bytes read.
total used colors 0x2e - compressing palette
Framefile parse succeeded. Video/Audio directory is: R:/Arcade/Daphne/framefile/../vldp/cobra/
YUV overlay is done in software (ie unaccelerated).
Booting ROM ...
8251 Reset!
8251 mode selected as 1.5 stop bits/parity disabled/8 bit characters/64x baud factor
8251: RTS = 1
8251: Internal Reset
8251 Reset!
8251 mode selected as 1 stop bit/parity disabled/8 bit characters/16x baud factor
VIP9500SG: RESET! (ignored)
VIP9500SG: Reject received (ignored)
Play
VIP9500SG: Frame counter off (ignored)
Pause
VIP9500SG: Step Reverse (pause)
Search to 301 received
Play
Pause
Search to 1228 received
Play
Pause
Search to 37853 received
Play
LDP : disc is already playing, play command ignored
Play
Pause
Search to 40663 received
Play
in sync
--Command line is: daphne.exe cobraab vldp -framefile framefile\cobra.txt -blank_searches -min_seek_delay 1000 -seek_frames_per_ms 20 -homedir . -bank 0 00000000 -bank 1 01001000 -sound_buffer 2048 -x 640 -y 480
--CPU : GenuineIntel 3350 MHz || Mem : 2048 megs
Setting alternate home dir:
Setting sound buffer size to 2048
Set 640x480 at 32 bpp with flags: 0
Remapping input ...
Framefile parse succeeded. Video/Audio directory is: framefile/../vldp/cobra/
YUV overlay is hardware accelerated.
Booting ROM ...
8251 Reset!
8251: RTS = 1
8251 Reset!
Play
Pause
Play
Pause
Play
Pause
Search to 4323 received
Play
Play
Freeing memory used to store audio stream...
Shutting down sound system...
Shutting down video display...
Ps I am still using hyperspin 1 and would like to continue using it since it worked before and just one little thing has stopped working and I do not feel like redoing everything for one glitch
I changed to hyperlaunch 1 script by removing no acceleration and adding the sound buffer. then recompiling it.  works great now did not realize that the hyperlaunch was loading and running daphne not the loader so only configs that worked were on the command line of hyperlaunch
