Problems with GameCube, Wii, PS2, PSX and PSP
Daniel2014BR
Hello Guys.
I recently aquired 5TB HD from. I followed all the instructions and installed all the files demanded. I had succes on running SNES.
However, I am facing some issues.
Once I initiate a game I can't go back to the HS menu. I pressed the L3 3 times, which should be enough to return to main menu, but nothing happened.
Also, my Xbox 360 controller works fine on the game, but when I press R3 to save the state, the other buttons just have no action I am not even able To shutdown or save state. The only thing that I can do is press again R3 and return to the game.
Those are the minor problems however.
What is keeping me awake is the fact that none of the Gamecube/Wii games work. I got a messagem saying that the Dolphin.ini could not be found.
The ps2 games do not work as well. The only message I got was that the application could not start correctly (error: 0xc000007b).
On sony ps1 there was an error with a specific file. I got the following message:
error waiting for the window "ahk_class PC SXR Main". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emultaor working outside your frontend frist. Also turno off fade to see if you are hiding your problem.
At last, on PSP I tust received a message saying: PPSSPP has stopped working. A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available. that the emulator stopped working.
No further explanations, however.
Sorry for all those six questions, Guys. I was so happy to test my new games, but I am already facing problems. I hope someone has a clue and can help to fix this.
I believe is not a hardware problem, since I am using an alienware alpha (i3, 4gb ram, 2gb video card).
Thanks in advance for you help!
Those are the pictures I took with the error screens:
Best regards,
Daniel
I understand, Agent47. Unfortunatetly, I was not aware of that. Regardless this, I imagine that those are problems that may occurr with other users. I am not demanding a soluction, of course. Thanks for your time. I just hope someone has experience on those problems and can help.
