make RL mount .cue virtually w/ DT
mrfloppy
After a lengthy layoff from Hyperspin due to moving, I caught the bug and have delved back into working on my setup. I'm updated to HS 1.4 and am using RL.  My roms for ePSXe are 2 types of files: A single .bin that matches the name in the .xml, and a folder that matches the name in the .xml with a .cue file that matches the name in the .xml and 1 or more track.bin files.  If I attempt to launch the .cue as an ISO in ePSXe it fails to load, thus it does the same when attempting to launch through HS. If I manually load the .bin as an iso it will load and play. I'm certain these titles launched prior to my move and subsequent updating. What simple step am I missing?  I know I can convert the .cue and .bin into a single .bin and it launches and plays fine. It would however be a real time saver not to have to do that.
A few additions.  I do have DT Lite installed.  I feel it used to mount the files to my virtual drive and launch them flawlessly.  This no longer seems to be occurring.  I have pointed RL to DT Lite, but it doesn't seem to know to interact with it based on file time.  I gather ePSXe may no longer be a preferred emulator, and I'm willing to switch to another emulator if this makes the process easier and anyone has a recommendation.  My only caveat is that it will work with my Xbox 1 controller wirelessly.  That seems to be an issue with lots of emulators currently.
