supergameco Posted December 9, 2016 Posted December 9, 2016 Hey, I have configured ePSXe to work with two controllers and it works fine when I launch ePSXe manually and run an ISO. However when I launch the ISO via Hyperspin/RocketLauncher the controllers don't work anymore. RocketLauncher is definitely pointing to the same emulator. Could it somehow be using a different config to when I launch it manually? Thanks in advance.
OnionEclipse Posted December 15, 2016 Posted December 15, 2016 On 12/9/2016 at 4:37 PM, supergameco said: Hey, I have configured ePSXe to work with two controllers and it works fine when I launch ePSXe manually and run an ISO. However when I launch the ISO via Hyperspin/RocketLauncher the controllers don't work anymore. RocketLauncher is definitely pointing to the same emulator. Could it somehow be using a different config to when I launch it manually? Thanks in advance. I haven't used epsxe with RL In a year or so but if I remember correctly RL rewrites the config file (or makes its own) every time it's launched (for lots of emulators). If you go in RL emulator settings for epsxe you should be able to change the config to your liking. The nice thing about that setup is you can delete the current epsxe folder then extract a new version without skipping a beat (as long as you save your saves and bios). If I am not mistaken retroarch is one of the few emulators RL won't overwrite.
OnionEclipse Posted December 15, 2016 Posted December 15, 2016 Looks like my phone wanted to double post for some reason.
