Help Super Street Fighter
vitere22
I am having error starting the game emulator Taito Type X2 image of the error below
http://imgur.com/a/wrEnl
LOG
Quote
18:28:25:929 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Taito Type X2"
18:28:25:930 | MD |     INFO  | +0     | PluginInit - Started
18:28:25:930 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HS\Databases\Taito Type X2\Taito Type X2.xml exists
18:28:25:955 | MD |     INFO  | +32    | PluginInit - Ended
18:28:25:956 | MD |     INFO  | +0     | StartModule - Ended
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - SteamID:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - Application: ..\Emulators\Taito Type X2\ROMS\Super Street Fighter IV Arcade Edition.lnk
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - AppWaitExe:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - DiscImage:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - Parameters:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - OriginGame:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - DXWndGame:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - WorkingFolder:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PreLaunch:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PreLaunchParameters:
18:28:25:957 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PreLaunchMode:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PreLaunchSleep:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PostLaunch:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PostLaunchParameters:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PostLaunchSleep:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PostExit:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PostExitParameters:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - PostExitSleep:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - ExitMethod:
18:28:25:958 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - FadeTitle:
18:28:25:959 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - FadeInExitSleep:
18:28:25:959 | MD |     INFO  | +0     | Module Setting - [Super Street Fighter IV Arcade Edition] - BezelEnabled:
18:28:25:959 | MD |     INFO  | +0     | Module Setting - [Settings] - BezelEnabled:
18:28:25:961 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\HS\RocketLauncher\Media\Fade\_Default\Layer 1.png
18:28:26:030 | MD |     INFO  | +78    | DefaultAnimateFadeIn - Started, direction is: in
18:28:26:030 | MD |     INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
18:28:26:635 | MD |     INFO  | +609   | DefaultAnimateFadeIn - Ended
18:28:26:652 | MD |     INFO  | +16    | DefaultFadeAnimation - Started
18:28:26:653 | MD |     INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\HS\RocketLauncher\Media\Fade\_Default\Info Bar.png
18:28:26:668 | MD |     INFO  | +15    | GetFadePicFile - Randomized images and Fade  will use D:\Hyperspin\HS\RocketLauncher\Media\Fade\_Default\Layer 3.png
18:28:26:793 | MD |     INFO  | +125   | DefaultFadeAnimationLoop - Playing 7z fade complete sound: D:\Hyperspin\HS\RocketLauncher\Media\Fade\_Default\7z complete.mp3
18:28:31:698 | MD |     INFO  | +4907  | DefaultFadeAnimation - Ended
18:28:31:718 | MD |     INFO  | +15    | HideFE - Hiding Frontend by making it transparent
18:28:31:718 | MD |     INFO  | +0     | CheckSettings - Started
18:28:31:718 | MD |     INFO  | +0     | PCLauncher - Setting mode to: "standard"
18:28:31:718 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\HS\Emulators\Taito Type X2\ROMS\Super Street Fighter IV Arcade Edition.lnk exists
18:28:31:719 | MD |     INFO  | +0     | CheckSettings - Ended
18:28:31:719 | MD |     INFO  | +0     | PCLauncher - Launching a standard application.
18:28:31:719 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\HS\Emulators\Taito Type X2\ROMS\"Super Street Fighter IV Arcade Edition.lnk"
18:28:31:748 | MD |     INFO  | +32    | PCLauncher - FadeTitle and AppWaitExe not set by user, but an AppPID was found. Waiting for AppPID: 5572
18:28:31:748 | MD |     INFO  | +0     | WinWait - Waiting for "ahk_pid 5572"
18:28:31:889 | MD |     INFO  | +140   | WinWaitActive - Waiting for "ahk_pid 5572"
18:29:12:293 | MD |    ERROR  | +40406 | ScriptError - There was an error waiting for the window "ahk_pid 5572" to become active. Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
18:29:12:293 | MD |     INFO  | +0     | ExitModule - Started
18:29:12:293 | MD |     INFO  | +0     | Starting Updating Statistics:
18:29:12:340 | MD |     INFO  | +47    | Game section statistics updated.
18:29:12:340 | MD |     INFO  | +0     | ExitModule - Ended
18:29:12:340 | MD |     INFO  | +0     | End of Module Logs
18:28:25:749 | RL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
18:29:12:449 | RL |     INFO  | +46703 | Main - Module ended, exiting RocketLauncher normally
18:29:12:449 | RL |     INFO  | +0     | ExitScript - Started
18:29:12:682 | RL |     INFO  | +234   | SystemCursor - Restoring mouse cursor
18:29:12:693 | RL |     INFO  | +0     | ExitScript - Ended
[/code]
The game starts and stays open and the hyperspin hangs in that error .. starting directly by the folder the game works seems to be hyperspin error, any help would be good because I am new to hyper
