Fade in with RetroArch issue.
dexllgamer
I am seeing an issue where the Fade in screen is interrupted by RetroArch starting.
So when I start any game from any system that uses RetroArch, the fade/loading screen starts, then you see a flash of RetroArch boot, then it switches back to the fade and then fades into the game.  It doesn't look smooth at all.
I have all the Fade settings set to the defaults and I tried using Delay and Exit Delay but it still happens.
Does anyone else have this problem?
Thanks
I figured it out, but I will leave this post just in case anyone else has the issue.
Turns out it was because i had my RetroArch set to full screen.  I set all the core configs back to window mode and the issue doesn't happen.  :-)
