Default genre for MAME
Alex1471
I created some genres to keep track on the many arcade games.
Is there a way to set a default genre in hyperspin? It always starts with all games.
Make whichever genre XML you want to start with the default mame.xml file, then have the complete database as a selectable genre.
Thanks for the fast replay.
I renamed MAME.xml to All Games.xml, my favorites to MAME.xml and added All Games in Genre.xml.
Unfortunately this didn’t solve my problem: the Wheel now starts with my favorites (that’s good) but if I choose All Games in the genre-wheel I just get the favorites and not all games. Furthermore it’s a little bit confusion, that if MAME.xml is choose the message “current genre: All Games” is shown, even though only the favorites are shown.
Do you know what’s the use of "start_on_favorites=false/true" in the MAME.ini? Maybe using this is a possible solution?
Yeah HS is setup such that the "All Games" toggle takes you back to your primary xml; in this case mame.xml. You probably have 2x "All Games" on the genre wheel somewhere now. The method's functional but it's a bit of a workaround and requires a few tweaks. If you still want to go that route I can help you out once I'm at hope and able to poke through the files.
Give the MAME.ini option a shot if its your favourites you're after.
