missing rom extension in ini
ratmandom
hello i have tryed a fourm on here about this and i checked and the settings to rocketlauncher is ok but get this messege can you help
thanks ratmandom
d:)
I take it this is when you try to launch a game but for which system and when exactly are you getting this? More information would be helpful. What is the exact error message. Is your emulator and extension defined for the system?
on hyper launch it says missing ROM extension in ini
rocket launcher says cannot find ini
when i load hyper spin and press enter on a game it just go's blank
Is your emulator and extension defined for the system  whats that
thanks im a noobie :)
d:)
You mention both HyperLaunch and RocketLauncher, which are you using and which version? Also, what version of HS are you using?
it says on hyper spin exe property it v1.4.0.0
and i have rocket launcher linked with hyper spin
i think rocket launcher is the lastest version because it updates
d:)
In RocketLauncherUI got to Global -> Emulators, find your emulator in the list, and verify that your rom extensions are there. Whether your emu/system has 7z support you may need to toggle 7z on/off in the system's RLUI settings.
i just went into hyperspin settings and changed the config settings to the path of hyper spin with notepad and i tryed it with hyper launch no luck but i move the orginal file back
d:)
Main - Did not find a "F:\HyperSpin And RocketLauncher\RocketLauncher\Settings\Apple II\Game Options.ini" file, skipping any game-specific options.
No Default_Emulator found in "F:\HyperSpin And RocketLauncher\RocketLauncher\Settings\Apple II\Emulators.ini" Please set one so RocketLauncher knows what module to use
how do i do this
d:)
i set it up about 7 weeks a go but i downloaded a add on pack now im trying the set up from that let you know if it works i have a cupple more questions about hyper spin if you could help me with that
d:)
i got it working now but it comes up with open file security warning when i try running a game then rocket launcher comes up with the loading screen but i cant minimize it to click alow on it i tryed rocket launcher settings on desktop, but i carnt get any where i tryed looking for a way to make a acception to open file security warning but yrh. and the outher thing was how do i add a wheel i downloaded i think i put it in the right folder i was a pc game wheel but it dosent come up with pc games in rocket launcher and how do i add pc games to hyper spin with the wheel i have only been do this for like 4 days i know i said i sorted it out about 7 weeks a go but i was wateing for a download so i have had 4 days on this i sorta know this and that but you can help so im ok thanks Dominic
d:)
i found a fix for the open file security warning open the emulator and tick the box for open file security warning  not to come up again that works
d:)
